[QGIS Commit] r8403 - trunk/qgis/src/ui
svn_qgis at osgeo.org
Wed May 7 00:13:38 EDT 2008
Author: telwertowski
Date: 2008-05-07 00:13:38 -0400 (Wed, 07 May 2008)
New Revision: 8403
trunk/qgis/src/ui/qgsrasterlayerpropertiesbase.ui
Use Qt 4.2 compatible properties
Modified: trunk/qgis/src/ui/qgsrasterlayerpropertiesbase.ui
--- trunk/qgis/src/ui/qgsrasterlayerpropertiesbase.ui 2008-05-06 20:51:09 UTC (rev 8402)
+++ trunk/qgis/src/ui/qgsrasterlayerpropertiesbase.ui 2008-05-07 04:13:38 UTC (rev 8403)
@@ -22,24 +22,12 @@
<bool>true</bool>
</property>
<layout class="QGridLayout" >
- <property name="leftMargin" >
+ <property name="margin" >
<number>9</number>
</property>
- <property name="topMargin" >
- <number>9</number>
- </property>
- <property name="rightMargin" >
- </property>
- <property name="bottomMargin" >
- </property>
- <property name="horizontalSpacing" >
+ <property name="spacing" >
<number>6</number>
</property>
- <property name="verticalSpacing" >
- <number>6</number>
- </property>
<item row="0" column="0" >
<widget class="QTabWidget" name="tabBar" >
<property name="currentIndex" >
@@ -56,24 +44,12 @@
<string>Render as</string>
</property>
<number>9</number>
</property>
- </property>
- </property>
- </property>
<number>6</number>
</property>
- </property>
<item row="0" column="1" >
<widget class="QRadioButton" name="rbtnSingleBand" >
<property name="text" >
@@ -100,18 +76,9 @@
<number>6</number>
</property>
<number>9</number>
</property>
- </property>
- </property>
- </property>
<item>
<widget class="QComboBox" name="cboxColorMap" >
<property name="sizePolicy" >
@@ -151,22 +118,10 @@
<string>RGB Mode Band Selection</string>
</property>
<number>9</number>
</property>
- </property>
- </property>
- </property>
- </property>
<number>6</number>
</property>
<item row="2" column="0" >
@@ -287,12 +242,9 @@
<string>Grayscale Band Selection</string>
</property>
<number>6</number>
</property>
- </property>
<widget class="QLabel" name="label" >
@@ -331,24 +283,12 @@
<string>RGB Scaling</string>
</property>
<number>9</number>
</property>
- </property>
- </property>
- </property>
<number>6</number>
</property>
- </property>
<item row="3" column="3" >
<widget class="QLabel" name="lblBlueMax" >
@@ -659,24 +599,12 @@
<string>Grayscale Band Scaling</string>
</property>
<number>9</number>
</property>
- </property>
- </property>
- </property>
<number>6</number>
</property>
- </property>
<item row="3" column="0" colspan="5" >
<widget class="QLabel" name="lblMinMaxEstimateWarning" >
@@ -904,12 +832,9 @@
<string>Contrast Enhancement</string>
</property>
<number>-1</number>
</property>
- <number>-1</number>
- </property>
<widget class="QLabel" name="labelContrastEnhancement" >
@@ -1191,18 +1116,9 @@
<number>6</number>
</property>
<number>11</number>
</property>
- <number>11</number>
- </property>
- </property>
- </property>
<item>
<widget class="QToolButton" name="pbnAddValuesManually" >
<property name="toolTip" >
@@ -1322,24 +1238,12 @@
<string>Colormap</string>
</attribute>
<number>11</number>
</property>
- </property>
- </property>
- </property>
<number>6</number>
</property>
- </property>
<item row="0" column="2" >
<spacer>
<property name="orientation" >
@@ -1371,18 +1275,9 @@
<number>6</number>
</property>
<number>11</number>
</property>
- </property>
- </property>
- </property>
<item>
<widget class="QLabel" name="mNumberOfEntriesLabel" >
@@ -1456,18 +1351,9 @@
<number>6</number>
</property>
<number>11</number>
</property>
- </property>
- </property>
- </property>
<item>
<widget class="QLabel" name="mColorInterpolationLabel" >
@@ -1485,18 +1371,9 @@
<number>6</number>
</property>
<number>11</number>
</property>
- </property>
- </property>
- </property>
<item>
<widget class="QLabel" name="mClassificationModeLabel" >
@@ -1516,48 +1393,24 @@
<string>General</string>
</attribute>
<number>11</number>
</property>
- </property>
- </property>
- </property>
<number>6</number>
</property>
- </property>
<item row="4" column="0" colspan="3" >
<widget class="QGroupBox" name="grpSRS" >
<property name="title" >
<string>Spatial Reference System</string>
</property>
<number>11</number>
</property>
- </property>
- </property>
- </property>
<number>6</number>
</property>
- </property>
<widget class="QPushButton" name="pbnChangeSpatialRefSys" >
@@ -1584,24 +1437,12 @@
<bool>true</bool>
</property>
<number>11</number>
</property>
- </property>
- </property>
- </property>
<number>6</number>
</property>
- </property>
<item row="0" column="3" >
<widget class="QSpinBox" name="spinMaximumScale" >
@@ -1663,18 +1504,9 @@
<number>6</number>
</property>
<number>11</number>
</property>
- </property>
- </property>
- </property>
<item>
<widget class="QLabel" name="lblColumns" >
@@ -1733,18 +1565,9 @@
<number>6</number>
</property>
<number>11</number>
</property>
- </property>
- </property>
- </property>
<item>
<widget class="Q3GroupBox" name="groupBox10" >
@@ -1754,24 +1577,12 @@
<enum>Qt::Vertical</enum>
</property>
<number>11</number>
</property>
- </property>
- </property>
- </property>
<number>6</number>
</property>
- </property>
<spacer>
@@ -1816,24 +1627,12 @@
</property>
<number>11</number>
</property>
- </property>
- </property>
- </property>
<number>6</number>
</property>
- </property>
<spacer>
@@ -1878,24 +1677,12 @@
</property>
<number>11</number>
</property>
- </property>
- </property>
- </property>
<number>6</number>
</property>
- </property>
<spacer>
@@ -1940,24 +1727,12 @@
<string>Metadata</string>
</attribute>
<number>11</number>
</property>
- </property>
- </property>
- </property>
<number>6</number>
</property>
- </property>
<widget class="QTextBrowser" name="txtbMetadata" />
</item>
@@ -1968,24 +1743,12 @@
<string>Pyramids</string>
</attribute>
<number>9</number>
</property>
- </property>
- </property>
- </property>
<number>6</number>
</property>
- </property>
<item rowspan="2" row="0" column="0" >
<widget class="QTextEdit" name="tePyramidDescription" >
@@ -2033,18 +1796,9 @@
<number>6</number>
</property>
<number>11</number>
</property>
- </property>
- </property>
- </property>
<item>
<spacer>
@@ -2101,24 +1855,12 @@
<string>Histogram</string>
</attribute>
<number>11</number>
</property>
- </property>
- </property>
- </property>
<number>6</number>
</property>
- </property>
<item row="0" column="0" colspan="2" >
<widget class="QLabel" name="pixHistogram" >
@@ -2156,24 +1898,12 @@
<string>Chart Type</string>
</property>
<number>11</number>
</property>
- </property>
- </property>
- </property>
<number>6</number>
</property>
- </property>
<widget class="QRadioButton" name="radHistTypeLine" >
@@ -2207,24 +1937,12 @@
<string>Options</string>
</property>
<number>11</number>
</property>
- </property>
- </property>
- </property>
<number>6</number>
</property>
- </property>
<widget class="QLabel" name="textLabel1_2" >
