[QGIS Commit] r8411 - in trunk/qgis: debian scripts
svn_qgis at osgeo.org
Wed May 7 16:13:22 EDT 2008
Author: jef
Date: 2008-05-07 16:13:22 -0400 (Wed, 07 May 2008)
New Revision: 8411
Added:
trunk/qgis/debian/libqgisgrass0.10.install
Removed:
trunk/qgis/debian/libqgis-core0.9.install
trunk/qgis/debian/libqgis-gui0.9.install
trunk/qgis/debian/libqgisgrass0.9.install
trunk/qgis/debian/python-qgis.install
trunk/qgis/debian/changelog
trunk/qgis/debian/control
trunk/qgis/debian/qgis.install
trunk/qgis/scripts/build_debian_package.sh
merged Release-0.10.0 changes r8366:r8391 into the trunk.
Modified: trunk/qgis/debian/changelog
--- trunk/qgis/debian/changelog 2008-05-07 16:33:23 UTC (rev 8410)
+++ trunk/qgis/debian/changelog 2008-05-07 20:13:22 UTC (rev 8411)
@@ -1,9 +1,53 @@
-qgis (0.9.2test2) unstable; urgency=low
+qgis (0.10.0-2) gutsy; urgency=low
+ * fix libgdal1 grass depenency for ubuntu gutsy/hardy (1.4.0 | 1.5.0)
- * fixed various packaging bugs
+ -- Jürgen E. Fischer <jef at norbit.de> Wed, 30 Apr 2008 22:35:42 +0200
- -- Jürgen E. Fischer <jef at norbit.de> Sun, 13 Apr 2008 03:51:14 +0200
+qgis (0.10.0-1) gutsy; urgency=low
+ * updated Maintainer field
+ * updated version for sip build dependency and removed old libgdal<1.5
+ dependencies.
+ * removed explicit shared library dependency for qgis and qgis-grass-plugin.
+ * removed recommends for qt4-designer on libqgis1-dev, because there's also
+ a depends.
+ -- Jürgen E. Fischer <jef at norbit.de> Mon, 28 Apr 2008 22:21:53 +0200
+qgis (0.10.0) gutsy; urgency=low
+ * This release includes over 120 bug fixes and enchancements
+ * over the QGIS 0.9.1 release. In addition we have added
+ * the following new features:
+ * Improvements to digitising capabilities.
+ * Supporting default and defined styles (.qml) files for file based
+ * vector layers. With styles you can save the symbolisation
+ * and other settings associated with a vector layer and they
+ * will be loaded whenever you load that layer.
+ * Improved support for transparency and contrast stretching
+ * in raster layers. Support for color ramps in raster layers.
+ * Support for non-north up rasters. Many other raster
+ * improvements 'under the hood'.
+ * Updated icons for improved visual consistancy.
+ * Support for migration of old projects to work in newer QGIS versions.
+ -- Jürgen E. Fischer <jef at norbit.de> Fri, 18 Apr 2008 00:51:58 +0200
qgis (0.9.2test1) gutsy; urgency=low
* Testing package to see if icons deploy
Modified: trunk/qgis/debian/control
--- trunk/qgis/debian/control 2008-05-07 16:33:23 UTC (rev 8410)
+++ trunk/qgis/debian/control 2008-05-07 20:13:22 UTC (rev 8411)
@@ -1,21 +1,21 @@
Source: qgis
Section: science
Priority: extra
-Maintainer: Debian GIS Project <pkg-grass-devel at lists.alioth.debian.org>
-Uploaders: Francesco Paolo Lovergine <frankie at debian.org>
-Build-Depends: debhelper (>= 5.0.0), libgdal1-dev | libgdal1-1.3.2-dev | libgdal1-1.4.0-dev , libpq-dev,
+Maintainer: Quantum GIS developers <qgis-developer at lists.osgeo.org>
+Build-Depends: debhelper (>= 5.0.0), libgdal1-dev, libpq-dev,
libgeos-dev (>= 2.0.1-1), dpatch, grass-dev, libsqlite3-dev, libgsl0-dev, proj, libexpat1-dev,
- flex, bison, python-dev, cmake (>=2.4.3) , python-sip4, python-sip4-dev, python-qt4-dev,
- sharutils, sip4 (>= 4.4), libqt4-core (>=4.2.0), libqt4-dev (>=4.2.0), libqt4-gui (>=4.2.0),
- libqt4-qt3support (>=4.2.0), libqt4-sql (>=4.2.0), python-qt4 (>=4.0.0), python-qt4-dev (>=4.0.0)
+ flex, bison, python-dev, cmake (>=2.4.3), python-sip4 (>= 4.5.0), python-central (>=0.5), python,
+ sharutils, sip4 (>= 4.5), libqt4-core (>=4.2.0), libqt4-dev (>=4.2.0), libqt4-gui (>=4.2.0),
+ libqt4-qt3support (>=4.2.0), libqt4-sql (>=4.2.0), python-qt4 (>=4.0.0), python-qt4-dev (>=4.0.0),
+ python-sip4-dev (>= 4.5.0)
Standards-Version: 3.7.2
XS-Python-Version: current
Homepage: http://qgis.org/
Package: qgis
Architecture: any
-Depends: ${shlibs:Depends}, ${misc:Depends}, libqgis-core0.9, libqgis-gui0.9
-Suggests: qgis-plugin-grass, python-qgis
+Depends: ${shlibs:Depends}, ${misc:Depends}
+Suggests: qgis-plugin-grass
XB-Python-Version: ${python:Versions}
Description: Geographic Information System (GIS)
A Geographic Information System (GIS) manages,
@@ -29,7 +29,7 @@
Elevation Model (DEM) formats including
GeoTIFF, Arc/Info ASCII Grid, and USGS ASCII DEM.
-Package: libqgis-core0.9
+Package: libqgis-core0.10
Architecture: any
Replaces: qgis (<=0.9.2rc1)
@@ -42,7 +42,7 @@
This package contains the shared core library that
provides an interface for plugins.
-Package: libqgis-gui0.9
+Package: libqgis-gui0.10
Architecture: any
@@ -55,20 +55,6 @@
This package contains the shared gui library that
-Package: python-qgis
-Architecture: any
-Section: python
-Depends: ${shlibs:Depends}, ${misc:Depends}, ${python:Depends}, libqgis-core0.9, libqgis-gui0.9
-Provides: ${python:Provides}
-XB-Python-Version: ${python:Versions}
-Description: QGIS Geographic Information System - Python bindings and plugins
- QGIS is a Geographic Information System (GIS)
- which manages, analyzes and display databases of
- geographic information.
- This package contains the Python bindings and
- plugins.
Package: libqgis1-dev
Architecture: any
Section: libdevel
@@ -76,7 +62,6 @@
Provides: libqgis-dev
Conflicts: libqgis-dev, qgis-dev
Replaces: qgis-dev
-Suggests: qt4-designer
Description: QGIS Geographic Information System - development files
@@ -87,12 +72,12 @@
Package: qgis-plugin-grass
Architecture: any
-Depends: qgis (= ${binary:Version}), ${shlibs:Depends}, ${misc:Depends}, libgdal1-1.4.0-grass | libgdal1-1.3.2-grass, libqgisgrass0.9
+Depends: qgis (= ${binary:Version}), ${shlibs:Depends}, ${misc:Depends}, libgdal1-1.4.0-grass | libgdal1-1.5.0-grass
Description: Plugin for accessing GRASS data from QGIS
This plugin enables a GRASS data access toolbox in the QGIS
geographic data viewer.
-Package: libqgisgrass0.9
+Package: libqgisgrass0.10
Architecture: any
Description: QGIS Geographic Information System - shared grass library
Deleted: trunk/qgis/debian/libqgis-core0.9.install
--- trunk/qgis/debian/libqgis-core0.9.install 2008-05-07 16:33:23 UTC (rev 8410)
+++ trunk/qgis/debian/libqgis-core0.9.install 2008-05-07 20:13:22 UTC (rev 8411)
@@ -1 +0,0 @@
-usr/lib/libqgis_core.so.*
Deleted: trunk/qgis/debian/libqgis-gui0.9.install
--- trunk/qgis/debian/libqgis-gui0.9.install 2008-05-07 16:33:23 UTC (rev 8410)
+++ trunk/qgis/debian/libqgis-gui0.9.install 2008-05-07 20:13:22 UTC (rev 8411)
@@ -1 +0,0 @@
-usr/lib/libqgis_gui.so.*
Copied: trunk/qgis/debian/libqgisgrass0.10.install (from rev 8410, branches/Release-0.10.0/debian/libqgisgrass0.10.install)
--- trunk/qgis/debian/libqgisgrass0.10.install (rev 0)
+++ trunk/qgis/debian/libqgisgrass0.10.install 2008-05-07 20:13:22 UTC (rev 8411)
@@ -0,0 +1,2 @@
+usr/lib/libqgisgrass.so
+usr/lib/libqgisgrass.so.*
Deleted: trunk/qgis/debian/libqgisgrass0.9.install
--- trunk/qgis/debian/libqgisgrass0.9.install 2008-05-07 16:33:23 UTC (rev 8410)
+++ trunk/qgis/debian/libqgisgrass0.9.install 2008-05-07 20:13:22 UTC (rev 8411)
@@ -1 +0,0 @@
-usr/lib/libqgisgrass.so.*
Deleted: trunk/qgis/debian/python-qgis.install
--- trunk/qgis/debian/python-qgis.install 2008-05-07 16:33:23 UTC (rev 8410)
+++ trunk/qgis/debian/python-qgis.install 2008-05-07 20:13:22 UTC (rev 8411)
@@ -1,4 +0,0 @@
-usr/share/qgis/python/*
-usr/lib/python*/site-packages/qgis/__init__.py
-usr/lib/python*/site-packages/qgis/qgisconfig.py
-usr/lib/python*/site-packages/qgis/*.so
Modified: trunk/qgis/debian/qgis.install
--- trunk/qgis/debian/qgis.install 2008-05-07 16:33:23 UTC (rev 8410)
+++ trunk/qgis/debian/qgis.install 2008-05-07 20:13:22 UTC (rev 8411)
@@ -1,6 +1,13 @@
usr/bin/qgis
usr/bin/qgis_help
-usr/share/qgis/doc/AUTHORS usr/share/qgis/doc/SPONSORS usr/share/qgis/doc/CODING usr/share/qgis/doc/favicon.ico usr/share/qgis/doc/index.html usr/share/qgis/doc/qgisdoc.css usr/share/qgis/doc/userguide.pdf usr/share/qgis/doc/images usr/share/doc/qgis
+usr/share/qgis/doc/CODING
+usr/share/qgis/doc/favicon.ico
+usr/share/qgis/doc/index.html
+usr/share/qgis/doc/qgisdoc.css
+usr/share/qgis/doc/AUTHORS
+usr/share/qgis/doc/SPONSORS
+usr/share/qgis/doc/images
+usr/share/qgis/doc/userguide.pdf usr/share/doc/qgis
usr/share/pixmaps/*
usr/share/qgis/i18n/*
usr/share/qgis/images/*
@@ -24,3 +31,7 @@
usr/lib/qgis/libwfsplugin.so
usr/lib/qgis/libwfsprovider.so
usr/lib/qgis/libwmsprovider.so
+usr/share/qgis/python/*
+usr/lib/python*/site-packages/qgis/__init__.py
+usr/lib/python*/site-packages/qgis/qgisconfig.py
+usr/lib/python*/site-packages/qgis/*.so
Modified: trunk/qgis/scripts/build_debian_package.sh
--- trunk/qgis/scripts/build_debian_package.sh 2008-05-07 16:33:23 UTC (rev 8410)
+++ trunk/qgis/scripts/build_debian_package.sh 2008-05-07 20:13:22 UTC (rev 8411)
@@ -22,4 +22,4 @@
export DEBEMAIL=tim at linfiniti.com
#dch -v 0.9.1+svn`date +%Y%m%d`
dch -v 0.9.2rc1
-fakeroot dpkg-buildpackage
+fakeroot dpkg-buildpackage -kAA4D3BA997626237
