[QGIS Commit] r8427 - trunk/qgis/mac
svn_qgis at osgeo.org svn_qgis at osgeo.org
Wed May 14 08:49:10 EDT 2008
Author: timlinux
Date: 2008-05-14 08:49:10 -0400 (Wed, 14 May 2008)
New Revision: 8427
Added:
   trunk/qgis/mac/1-release-extra.sh
   trunk/qgis/mac/2-release-extra-qt.sh
Alternative post build scripts for mac if using Tim's qgis universal deps bundle for OS X
Added: trunk/qgis/mac/1-release-extra.sh
--- trunk/qgis/mac/1-release-extra.sh	                        (rev 0)
+++ trunk/qgis/mac/1-release-extra.sh	2008-05-14 12:49:10 UTC (rev 8427)
@@ -0,0 +1,108 @@
+#!/bin/sh
+# Copy supportibng libraries (except Qt) to openModeller bundle
+# and make search paths for them relative to bundle
+APP_PREFIX=/Applications/qgis0.11.0.app
+BUNDLE_DIR=${APP_PREFIX}/Contents/MacOS
+LIB_DIR=/usr/local/qgis_universal_deps/lib
+#set -x
+cp -r ${LIB_DIR}/libexpat.dylib  ${BUNDLE_DIR}/lib
+cp -r ${LIB_DIR}/libgdal.1.dylib  ${BUNDLE_DIR}/lib
+cp -r ${LIB_DIR}/libgeos.dylib  ${BUNDLE_DIR}/lib
+cp -r ${LIB_DIR}/libproj.dylib  ${BUNDLE_DIR}/lib
+cp -r ${LIB_DIR}/libgsl.dylib  ${BUNDLE_DIR}/lib
+cp -r ${LIB_DIR}/libgslcblas.dylib  ${BUNDLE_DIR}/lib
+#cp -r ${LIB_DIR}/libsqlite3.0.dylib  ${BUNDLE_DIR}
+pushd .
+cd ${BUNDLE_DIR}/lib
+ln -s libgdal.1.dylib libgdal.dylib
+ln -s libexpat.dylib libexpat.1.dylib
+ln -s libgsl.dylib libgsl.0.dylib
+ln -s libgslcblas.dylib libgslcblas.0.dylib
+#ln -s libsqlite3.0.dylib libsqlite3.dylib
+popd
+install_name_tool -change ${LIB_DIR}/libgdal.1.dylib \
+                   @executable_path/lib/libgdal.1.dylib \
+                   ${BUNDLE_DIR}/qgis
+install_name_tool -change ${LIB_DIR}/libproj.dylib \
+                   @executable_path/lib/libproj.dylib \
+LIBS="lib/libqgis_core.dylib \
+      lib/libqgis_gui.dylib \
+      lib/libexpat.1.dylib \
+      lib/libgsl.0.dylib \
+      lib/libgslcblas.0.dylib \
+      lib/libexpat.dylib \
+      lib/libgdal.dylib \
+      lib/libgeos.dylib \
+      lib/libproj.dylib"
+# Next we work through all the libs except Qt libs
+# and update the library ids and paths for these libs
+for LIB in $LIBS
+do
+  install_name_tool -id @executable_path/$LIB ${BUNDLE_DIR}/${LIB}
+  #echo "install_name_tool -id @executable_path/$LIB ${BUNDLE_DIR}/${LIB}"
+  # for debugging only
+  for LIBPATH in `otool -L ${BUNDLE_DIR}/${LIB} \
+                  | sed 's/(\([a-zA-Z0-9\., ]*\))//g' \
+                  | grep  $LIB_DIR \
+                  | grep -v framework` #frameworks (in particular qt frameworks)
+                                       #get dealt with in another script
+  do
+    #echo $LIBPATH
+    BASELIB=`basename "$LIBPATH"`
+    #echo $BASELIB
+    install_name_tool -change ${LIBPATH} \
+                      @executable_path/lib/${BASELIB} \
+                      ${BUNDLE_DIR}/${LIB}
+  done
+  #otool -L ${BUNDLE_DIR}/${LIB}
+  echo ${LIB}
+done
+# Next sort out the qgis plugins....
+LIBS="libcopyrightlabelplugin.so
+      libgpxprovider.so
+      libscalebarplugin.so
+      libdelimitedtextplugin.so
+      libgridmakerplugin.so
+      libwfsplugin.so
+      libdelimitedtextprovider.so
+      libnortharrowplugin.so
+      libwfsprovider.so
+      libgeorefplugin.so
+      libogrprovider.so
+      libwmsprovider.so
+      libgpsimporterplugin.so
+      libquickprintplugin.so
+      libevis.so"
+for LIB in $LIBS
+do
+  install_name_tool -id @executable_path/lib/qgis/${LIB} ${BUNDLE_DIR}/lib/qgis/${LIB}
+  for LIBPATH in `otool -L ${BUNDLE_DIR}/lib/qgis/${LIB} \
+                  | grep  $LIB_DIR \
+                  | grep -v framework` #frameworks (in particular qt frameworks) get
+                                       #dealt with in another script
+  do
+    #echo "------------"
+    #echo $LIBPATH
+    #echo $BASELIB
+    install_name_tool -change ${LIBPATH} @executable_path/lib/${BASELIB} ${BUNDLE_DIR}/lib/qgis/${LIB}
+  done
+  echo $LIB
+  #otool -L ${BUNDLE_DIR}/lib/qgis/${LIB}
+  #echo "----------------------------------"
+done
Property changes on: trunk/qgis/mac/1-release-extra.sh
___________________________________________________________________
Added: trunk/qgis/mac/2-release-extra-qt.sh
--- trunk/qgis/mac/2-release-extra-qt.sh	                        (rev 0)
+++ trunk/qgis/mac/2-release-extra-qt.sh	2008-05-14 12:49:10 UTC (rev 8427)
@@ -0,0 +1,143 @@
+#!/bin/sh
+# Copy Qt frameworks to atlas bundle
+MACOS_PREFIX=${APP_PREFIX}/Contents/MacOS
+FRAMEWORKPREFIX=${APP_PREFIX}/Contents/Frameworks
+mkdir -p $MACOS_PREFIX
+mkdir -p $FRAMEWORKPREFIX
+pushd $PWD
+cd $FRAMEWORKPREFIX
+# Edit version when any library is upgraded
+UNIVERSAL_LIBS_PREFIX=/usr/local/qgis_universal_deps
+QTPREFIX=${UNIVERSAL_LIBS_PREFIX}/lib
+QTFRAMEWORKS="QtCore QtGui QtNetwork QtSql QtSvg QtXml"
+# Copy supporting frameworks to application bundle
+for FRAMEWORK in $QTFRAMEWORKS
+do
+	LIBFRAMEWORK=$FRAMEWORK.framework/Versions/4/$FRAMEWORK
+	if test ! -f $LIBFRAMEWORK; then
+		mkdir -p $FRAMEWORK.framework/Versions/4
+		cp $QTPREFIX/$LIBFRAMEWORK $LIBFRAMEWORK
+		install_name_tool -id @executable_path/../Frameworks/$LIBFRAMEWORK $LIBFRAMEWORK
+	fi
+done
+# Update path to supporting frameworks
+for FRAMEWORK in QtGui QtNetwork QtSql QtSvg QtXml
+do
+	install_name_tool -change ${QTPREFIX}/QtCore.framework/Versions/4/QtCore \
+		@executable_path/../Frameworks/QtCore.framework/Versions/4/QtCore \
+		$FRAMEWORK.framework/Versions/4/$FRAMEWORK
+done
+for FRAMEWORK in QtSvg
+do
+	install_name_tool -change ${QTPREFIX}/QtGui.framework/Versions/4/QtGui \
+		@executable_path/../Frameworks/QtGui.framework/Versions/4/QtGui \
+	install_name_tool -change ${QTPREFIX}/QtXml.framework/Versions/4/QtXml \
+		@executable_path/../Frameworks/QtXml.framework/Versions/4/QtXml \
+done
+# Update qgis related libs and binaries
+cd $MACOS_PREFIX
+FILES="qgis
+  lib/libqgis_core.dylib
+  lib/libomg_widgets.dylib
+  lib/qgis/libcopyrightlabelplugin.so
+  lib/qgis/libgpxprovider.so
+  lib/qgis/libscalebarplugin.so
+  lib/qgis/libdelimitedtextplugin.so
+  lib/qgis/libgridmakerplugin.so
+  lib/qgis/libwfsplugin.so
+  lib/qgis/libdelimitedtextprovider.so
+  lib/qgis/libnortharrowplugin.so
+  lib/qgis/libwfsprovider.so
+  lib/qgis/libgeorefplugin.so
+  lib/qgis/libogrprovider.so
+  lib/qgis/libwmsprovider.so
+  lib/qgis/libgpsimporterplugin.so
+  lib/qgis/libevis.so
+  lib/qgis/libquickprintplugin.so"
+for FILE in ${FILES}
+do
+ for FRAMEWORK in QtCore QtGui QtNetwork QtSql QtSvg QtXml
+	do
+    set -x
+		install_name_tool -change ${QTPREFIX}/${FRAMEWORK}.framework/Versions/4/$FRAMEWORK \
+			@executable_path/../Frameworks/$FRAMEWORK.framework/Versions/4/$FRAMEWORK \
+			$MACOS_PREFIX/$FILE
+	done
+done
+# Update qt imageformat plugin paths
+cd ${MACOS_PREFIX}/../
+mkdir -p plugins/imageformats
+cd plugins/imageformats
+LIBJPEG=libjpeg.dylib
+LIBQJPEG=${UNIVERSAL_LIBS_PREFIX}/plugins/imageformats/libqjpeg.dylib
+if test ! -f $LIBJPEG; then
+	cp $LIBQJPEG $LIBJPEG
+	# Update path to supporting libraries
+		$LIBJPEG
+		$LIBJPEG
+	install_name_tool -change $LIBQJPEG @executable_path/../plugins/imageformats/$LIBJPEG
+fi
+LIBGIF=libgif.dylib
+LIBQGIF=${UNIVERSAL_LIBS_PREFIX}/plugins/imageformats/libqgif.dylib
+if test ! -f $LIBGIF; then
+	cp $LIBQGIF $LIBGIF
+		$LIBGIF
+		$LIBGIF
+	install_name_tool -change $LIBQGIF @executable_path/../plugins/imageformats/$LIBGIF
+fi
+# QT Sql Drivers
+mkdir -p plugins/sqldrivers
+cd plugins/sqldrivers
+LIBSQLITE=libqsqlite.dylib
+LIBQSQLITE=${UNIVERSAL_LIBS_PREFIX}/plugins/sqldrivers/libqsqlite.dylib
+if test ! -f $LIBSQLITE; then
+	cp $LIBQSQLITE $LIBSQLITE
+		$LIBSQLITE
+	install_name_tool -change ${QTPREFIX}/QtSql.framework/Versions/4/QtSql \
+		@executable_path/../Frameworks/QtSql.framework/Versions/4/QtSql \
+		$LIBSQLITE
+	install_name_tool -change $LIBSQLITE @executable_path/../plugins/sqldrivers/$LIBSQLITE
+fi
+popd
Property changes on: trunk/qgis/mac/2-release-extra-qt.sh
More information about the QGIS-commit mailing list
