[QGIS Commit] r8438 - in trunk/qgis: . src/app
svn_qgis at osgeo.org
Wed May 14 18:14:36 EDT 2008
Author: jef
Date: 2008-05-14 18:14:36 -0400 (Wed, 14 May 2008)
New Revision: 8438
trunk/qgis/CMakeLists.txt
trunk/qgis/src/app/qgsabout.cpp
revert r8437 and fix it different
- use FIND_PACKAGE(Qt4 REQUIRED) before SET(QT_... 1)
as cmake's Modules/FindQt4.cmake suggests
- should also fix #913
Modified: trunk/qgis/CMakeLists.txt
--- trunk/qgis/CMakeLists.txt 2008-05-14 21:02:26 UTC (rev 8437)
+++ trunk/qgis/CMakeLists.txt 2008-05-14 22:14:36 UTC (rev 8438)
@@ -133,6 +133,7 @@
# search for Qt4
+FIND_PACKAGE(Qt4 REQUIRED)
SET( QT_USE_QT3SUPPORT TRUE )
SET( QT_USE_QTXML TRUE )
@@ -144,7 +145,6 @@
ENABLE_TESTING()
ENDIF (ENABLE_TESTS)
-FIND_PACKAGE(Qt4 REQUIRED)
INCLUDE( ${QT_USE_FILE} )
@@ -230,7 +230,7 @@
SET (DEFAULT_INCLUDE_SUBDIR include/qgis)
IF (UNIX AND NOT APPLE)
- ADD_DEFINITIONS(-DPREFIX=\\"${CMAKE_INSTALL_PREFIX}\\")
+ ADD_DEFINITIONS(-DPREFIX=${CMAKE_INSTALL_PREFIX})
ENDIF (UNIX AND NOT APPLE)
ENDIF (WIN32)
Modified: trunk/qgis/src/app/qgsabout.cpp
--- trunk/qgis/src/app/qgsabout.cpp 2008-05-14 21:02:26 UTC (rev 8437)
+++ trunk/qgis/src/app/qgsabout.cpp 2008-05-14 22:14:36 UTC (rev 8438)
@@ -24,7 +24,7 @@
#include <QFile>
#include <QTextStream>
#include <QImageReader>
-#include <QtSql/QSqlDatabase>
+#include <QSqlDatabase>
#include <iostream>
/* Uncomment this block to use preloaded images
