[QGIS Commit] r8506 - in trunk/qgis/src: app ui
svn_qgis at osgeo.org
Fri May 23 13:03:48 EDT 2008
Author: timlinux
Date: 2008-05-23 13:03:48 -0400 (Fri, 23 May 2008)
New Revision: 8506
trunk/qgis/src/app/qgscustomprojectiondialog.cpp
trunk/qgis/src/ui/qgscustomprojectiondialogbase.ui
added missing icons for rec naviagation to the custom projection dialog
Modified: trunk/qgis/src/app/qgscustomprojectiondialog.cpp
--- trunk/qgis/src/app/qgscustomprojectiondialog.cpp 2008-05-23 17:02:47 UTC (rev 8505)
+++ trunk/qgis/src/app/qgscustomprojectiondialog.cpp 2008-05-23 17:03:48 UTC (rev 8506)
@@ -44,6 +44,16 @@
setupUi(this);
+ QString myThemePath = QgsApplication::themePath();
+ pbnFirst->setPixmap(QPixmap(myThemePath+"mIconFirst.png"));
+ QString myString = "Setting first button to : " + myThemePath+"mIconFirst.png";
+ qDebug(myString.toLocal8Bit());
+ pbnPrevious->setPixmap(QPixmap(myThemePath+"mIconPrevious.png"));
+ pbnNext->setPixmap(QPixmap(myThemePath+"mIconNext.png"));
+ pbnLast->setPixmap(QPixmap(myThemePath+"mIconLast.png"));
+ pbnNew->setPixmap(QPixmap(myThemePath+"mIconNew.png"));
+ pbnSave->setPixmap(QPixmap(myThemePath+"mActionFileSave.png"));
+ pbnDelete->setPixmap(QPixmap(myThemePath+"mIconDelete.png"));
// user database is created at QGIS startup in QgisApp::createDB
// we just check whether there is our database [MD]
QFileInfo myFileInfo;
@@ -414,18 +424,18 @@
// XXX Need to free memory from the error msg if one is set
if(myResult == SQLITE_OK)
- if (sqlite3_step(myPreparedStatement) == SQLITE_ROW)
- mCurrentRecordId = QString::fromUtf8((char *)sqlite3_column_text(myPreparedStatement,0));
- leName->setText(QString::fromUtf8((char *)sqlite3_column_text(myPreparedStatement,1)));
- //QString myProjectionFamilyId = QString::fromUtf8((char *)sqlite3_column_text(myPreparedStatement,2));
- //cboProjectionFamily->setCurrentText(getProjectionFamilyName(myProjectionFamilyId));
- //QString myEllipsoidId = QString::fromUtf8((char *)sqlite3_column_text(myPreparedStatement,3));
- //cboEllipsoid->setCurrentText(getEllipsoidName(myEllipsoidId));
- leParameters->setText(QString::fromUtf8((char *)sqlite3_column_text(myPreparedStatement,4)));
- mCurrentRecordLong=1;
- lblRecordNo->setText(QString::number(mCurrentRecordLong) + " of " + QString::number(mRecordCountLong));
+ if (sqlite3_step(myPreparedStatement) == SQLITE_ROW)
+ mCurrentRecordId = QString::fromUtf8((char *)sqlite3_column_text(myPreparedStatement,0));
+ leName->setText(QString::fromUtf8((char *)sqlite3_column_text(myPreparedStatement,1)));
+ //QString myProjectionFamilyId = QString::fromUtf8((char *)sqlite3_column_text(myPreparedStatement,2));
+ //cboProjectionFamily->setCurrentText(getProjectionFamilyName(myProjectionFamilyId));
+ //QString myEllipsoidId = QString::fromUtf8((char *)sqlite3_column_text(myPreparedStatement,3));
+ //cboEllipsoid->setCurrentText(getEllipsoidName(myEllipsoidId));
+ leParameters->setText(QString::fromUtf8((char *)sqlite3_column_text(myPreparedStatement,4)));
+ mCurrentRecordLong=1;
+ lblRecordNo->setText(QString::number(mCurrentRecordLong) + " of " + QString::number(mRecordCountLong));
else
@@ -450,13 +460,13 @@
pbnNext->setEnabled(false);
pbnLast->setEnabled(false);
- pbnDelete->setEnabled(false);
+ pbnDelete->setEnabled(true);
else
pbnNext->setEnabled(true);
pbnLast->setEnabled(true);
@@ -688,23 +698,16 @@
void QgsCustomProjectionDialog::on_pbnNew_clicked()
-#ifdef QGISDEBUG
if (pbnNew->text()==tr("Abort"))
- std::cout << "QgsCustomProjectionDialog::on_pbnNew_clicked() - abort requested" << std::endl;
- else
- std::cout << "QgsCustomProjectionDialog::on_pbnNew_clicked() - new requested" << std::endl;
-#endif
- if (pbnNew->text()==tr("Abort"))
//if we get here, user has aborted add record
+ //next line needed for new/abort logic
pbnNew->setText(tr("New"));
//get back to the last used record before insert was pressed
- if (mCurrentRecordId.isEmpty())
+ if (mCurrentRecordId.isEmpty())
on_pbnFirst_clicked();
else
@@ -721,6 +724,9 @@
pbnNew->setText(tr("Abort"));
//clear the controls
leName->setText("");
Modified: trunk/qgis/src/ui/qgscustomprojectiondialogbase.ui
--- trunk/qgis/src/ui/qgscustomprojectiondialogbase.ui 2008-05-23 17:02:47 UTC (rev 8505)
+++ trunk/qgis/src/ui/qgscustomprojectiondialogbase.ui 2008-05-23 17:03:48 UTC (rev 8506)
@@ -65,6 +65,9 @@
<property name="text" >
<string>|<</string>
</property>
+ <property name="icon" >
+ <iconset>../../images/themes/default/mIconFirst.png</iconset>
+ </property>
</widget>
</item>
<item>
@@ -72,6 +75,9 @@
<string><</string>
</property>
+ <iconset>../../images/themes/default/mIconPrevious.png</iconset>
+ </property>
</widget>
</item>
<item>
@@ -89,6 +95,9 @@
<string>></string>
</property>
+ <iconset>../../images/themes/default/mIconNext.png</iconset>
+ </property>
</widget>
</item>
<item>
@@ -96,6 +105,9 @@
<string>>|</string>
</property>
+ <iconset>../../images/themes/default/mIconLast.png</iconset>
+ </property>
</widget>
</item>
<item>
@@ -103,6 +115,9 @@
<string>*</string>
</property>
+ <iconset>../../images/themes/default/mIconNew.png</iconset>
+ </property>
</widget>
</item>
<item>
@@ -110,6 +125,9 @@
<string>S</string>
</property>
+ <iconset>../../images/themes/default/mActionFileSave.png</iconset>
+ </property>
</widget>
</item>
<item>
@@ -117,6 +135,9 @@
<string>X</string>
</property>
+ <iconset>../../images/themes/default/mIconDelete.png</iconset>
+ </property>
</widget>
</item>
</layout>
