[QGIS Commit] r8517 - trunk/qgis/src/app
svn_qgis at osgeo.org
Sun May 25 20:02:29 EDT 2008
Author: wonder
Date: 2008-05-25 20:02:29 -0400 (Sun, 25 May 2008)
New Revision: 8517
Added:
trunk/qgis/src/app/qgspythonutilsimpl.h
trunk/qgis/src/app/CMakeLists.txt
trunk/qgis/src/app/qgisapp.cpp
trunk/qgis/src/app/qgisapp.h
trunk/qgis/src/app/qgspluginmanager.cpp
trunk/qgis/src/app/qgspluginmanager.h
trunk/qgis/src/app/qgspythondialog.cpp
trunk/qgis/src/app/qgspythondialog.h
trunk/qgis/src/app/qgspythonutils.cpp
trunk/qgis/src/app/qgspythonutils.h
Python utilities separated to an interface and implementation.
Modified: trunk/qgis/src/app/CMakeLists.txt
--- trunk/qgis/src/app/CMakeLists.txt 2008-05-25 22:41:57 UTC (rev 8516)
+++ trunk/qgis/src/app/CMakeLists.txt 2008-05-26 00:02:29 UTC (rev 8517)
@@ -55,6 +55,7 @@
qgspluginmetadata.cpp
qgspluginregistry.cpp
+ qgspythondialog.cpp
qgsprojectproperties.cpp
qgsrasterlayerproperties.cpp
qgssearchquerybuilder.cpp
@@ -115,6 +116,7 @@
qgsoptions.h
qgspastetransformations.h
qgspluginmanager.h
+ qgspythondialog.h
qgsprojectproperties.h
qgsrasterlayerproperties.h
qgssearchquerybuilder.h
@@ -153,8 +155,7 @@
# Python support
IF (PYTHON_FOUND)
- SET (QGIS_APP_SRCS ${QGIS_APP_SRCS} qgspythondialog.cpp qgspythonutils.cpp)
- SET (QGIS_APP_MOC_HDRS ${QGIS_APP_MOC_HDRS} qgspythondialog.h)
+ SET (QGIS_APP_SRCS ${QGIS_APP_SRCS} qgspythonutils.cpp)
ENDIF (PYTHON_FOUND)
QT4_WRAP_CPP(QGIS_APP_MOC_SRCS ${QGIS_APP_MOC_HDRS})
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp 2008-05-25 22:41:57 UTC (rev 8516)
+++ trunk/qgis/src/app/qgisapp.cpp 2008-05-26 00:02:29 UTC (rev 8517)
@@ -167,9 +167,10 @@
#include "qgsdbsourceselect.h"
#endif
-#ifdef HAVE_PYTHON
#include "qgspythondialog.h"
#include "qgspythonutils.h"
+#ifdef HAVE_PYTHON
+#include "qgspythonutilsimpl.h"
#endif
#ifndef WIN32
@@ -304,7 +305,8 @@
// constructor starts here
QgisApp::QgisApp(QSplashScreen *splash, QWidget * parent, Qt::WFlags fl)
: QMainWindow(parent,fl),
- mSplash(splash)
+ mSplash(splash),
+ mPythonUtils(NULL), mPythonConsole(NULL)
// setupUi(this);
resize(640, 480);
@@ -361,11 +363,14 @@
#ifdef HAVE_PYTHON
mSplash->showMessage(tr("Starting Python"), Qt::AlignHCenter | Qt::AlignBottom);
qApp->processEvents();
- QgsPythonUtils::instance()->initPython(mQgisInterface);
+ mPythonUtils = QgsPythonUtilsImpl::instance();
+ mPythonUtils->initPython(mQgisInterface);
+#endif
- if (!QgsPythonUtils::instance()->isEnabled())
+ if (!mPythonUtils || !mPythonUtils->isEnabled())
mActionShowPythonDialog->setEnabled(false);
-#endif
// Create the plugin registry and load plugins
// load any plugins that were running in the last session
@@ -439,9 +444,8 @@
delete mMapTools.mAddRing;
delete mMapTools.mAddIsland;
-#ifdef HAVE_PYTHON
delete mPythonConsole;
-#endif
+ delete mPythonUtils;
// delete map layer registry and provider registry
QgsApplication::exitQgis();
@@ -858,20 +862,18 @@
connect ( mActionMapTips, SIGNAL ( triggered() ), this, SLOT ( toggleMapTips() ) );
mActionMapTips->setCheckable(true);
-#ifdef HAVE_PYTHON
mActionShowPythonDialog = new QAction(tr("Python console"), this);
connect(mActionShowPythonDialog, SIGNAL(triggered()), this, SLOT(showPythonDialog()));
- mPythonConsole = NULL;
-#endif
void QgisApp::showPythonDialog()
-#ifdef HAVE_PYTHON
+ return;
if (mPythonConsole == NULL)
- mPythonConsole = new QgsPythonDialog(mQgisInterface);
+ mPythonConsole = new QgsPythonDialog(mQgisInterface, mPythonUtils);
mPythonConsole->show();
-#endif
void QgisApp::createActionGroups()
@@ -992,9 +994,7 @@
// Plugins Menu
mPluginMenu = menuBar()->addMenu(tr("&Plugins"));
mPluginMenu->addAction(mActionShowPluginManager);
-#ifdef HAVE_PYTHON
mPluginMenu->addAction(mActionShowPythonDialog);
-#endif
mPluginMenu->addSeparator();
// Add the plugin manager action to it
@@ -1705,33 +1705,30 @@
delete myLib;
-#ifdef HAVE_PYTHON
QString pluginName, description, version;
- QgsPythonUtils* pythonUtils = QgsPythonUtils::instance();
- if (pythonUtils->isEnabled())
+ if (mPythonUtils && mPythonUtils->isEnabled())
// check for python plugins system-wide
- QStringList pluginList = pythonUtils->pluginList();
+ QStringList pluginList = mPythonUtils->pluginList();
for (int i = 0; i < pluginList.size(); i++)
QString packageName = pluginList[i];
// import plugin's package
- if (!pythonUtils->loadPlugin(packageName))
+ if (!mPythonUtils->loadPlugin(packageName))
continue;
// get information from the plugin
// if there are some problems, don't continue with metadata retreival
- pluginName = pythonUtils->getPluginMetadata(packageName, "name");
+ pluginName = mPythonUtils->getPluginMetadata(packageName, "name");
if (pluginName != "__error__")
- description = pythonUtils->getPluginMetadata(packageName, "description");
+ description = mPythonUtils->getPluginMetadata(packageName, "description");
if (description != "__error__")
- version = pythonUtils->getPluginMetadata(packageName, "version");
+ version = mPythonUtils->getPluginMetadata(packageName, "version");
if (pluginName == "__error__" || description == "__error__" || version == "__error__")
@@ -1746,7 +1743,7 @@
-#endif
QgsDebugMsg("Loading plugins completed");
QgsDebugMsg("*************************************************\n\n");
@@ -3857,7 +3854,7 @@
void QgisApp::showPluginManager()
- QgsPluginManager *pm = new QgsPluginManager(this);
+ QgsPluginManager *pm = new QgsPluginManager(mPythonUtils, this);
pm->resizeColumnsToContents();
if (pm->exec())
@@ -3882,11 +3879,11 @@
void QgisApp::loadPythonPlugin(QString packageName, QString pluginName)
-#ifdef HAVE_PYTHON
- if (!pythonUtils->isEnabled())
+ QgsDebugMsg("Python is not enabled in QGIS.");
return;
QgsDebugMsg("I should load python plugin: " + pluginName + " (package: " + packageName + ")");
@@ -3895,8 +3892,8 @@
// is loaded already?
if (pRegistry->library(pluginName).isEmpty())
- pythonUtils->loadPlugin(packageName);
- pythonUtils->startPlugin(packageName);
+ mPythonUtils->loadPlugin(packageName);
+ mPythonUtils->startPlugin(packageName);
// TODO: test success
@@ -3907,11 +3904,6 @@
QSettings settings;
settings.writeEntry("/PythonPlugins/" + packageName, true);
-#else
- QgsDebugMsg("Python is not enabled in QGIS.");
-#endif
void QgisApp::loadPlugin(QString name, QString description, QString theFullPathName)
Modified: trunk/qgis/src/app/qgisapp.h
--- trunk/qgis/src/app/qgisapp.h 2008-05-25 22:41:57 UTC (rev 8516)
+++ trunk/qgis/src/app/qgisapp.h 2008-05-26 00:02:29 UTC (rev 8517)
@@ -50,6 +50,7 @@
class QgsPoint;
class QgsProviderRegistry;
class QgsPythonDialog;
+class QgsPythonUtils;
class QgsRasterLayer;
class QgsRect;
class QgsVectorLayer;
@@ -524,9 +525,8 @@
QAction *mActionShowAllToolbars;
QAction *mActionHideAllToolbars;
QAction *mActionToggleFullScreen;
-#ifdef HAVE_PYTHON
QAction *mActionShowPythonDialog;
-#endif
//tool groups -------------------------------------
QActionGroup *mMapToolGroup;
@@ -659,9 +659,8 @@
//!flag to indicat wehter we are in fullscreen mode or not
bool mFullScreenMode;
-#ifdef HAVE_PYTHON
QgsPythonDialog* mPythonConsole;
-#endif
+ QgsPythonUtils* mPythonUtils;
#endif
Modified: trunk/qgis/src/app/qgspluginmanager.cpp
--- trunk/qgis/src/app/qgspluginmanager.cpp 2008-05-25 22:41:57 UTC (rev 8516)
+++ trunk/qgis/src/app/qgspluginmanager.cpp 2008-05-26 00:02:29 UTC (rev 8517)
@@ -39,9 +39,7 @@
#include <qgsdetaileditemwidget.h>
#include <qgsdetaileditemdata.h>
-#ifdef HAVE_PYTHON
#include <qgspythonutils.h>
-#endif
#define TESTLIB
#ifdef TESTLIB
@@ -52,10 +50,13 @@
#include <dlfcn.h>
#endif
#endif
-QgsPluginManager::QgsPluginManager(QWidget * parent, Qt::WFlags fl)
+QgsPluginManager::QgsPluginManager(QgsPythonUtils* pythonUtils, QWidget * parent, Qt::WFlags fl)
: QDialog(parent, fl)
setupUi(this);
+ mPythonUtils = pythonUtils;
// set the default lib dir to the qgis install directory/lib (this info is
// available from the provider registry so we use it here)
QgsProviderRegistry *pr = QgsProviderRegistry::instance();
@@ -118,27 +119,24 @@
void QgsPluginManager::getPythonPluginDescriptions()
-#ifdef HAVE_PYTHON
return;
// look for plugins systemwide
// import plugin's package - skip loading it if an error occured
continue;
- QString pluginName = pythonUtils->getPluginMetadata(packageName, "name");
- QString description = pythonUtils->getPluginMetadata(packageName, "description");
- QString version = pythonUtils->getPluginMetadata(packageName, "version");
+ QString pluginName = mPythonUtils->getPluginMetadata(packageName, "name");
+ QString description = mPythonUtils->getPluginMetadata(packageName, "description");
+ QString version = mPythonUtils->getPluginMetadata(packageName, "version");
if (pluginName == "???" || description == "???" || version == "???")
continue;
@@ -184,7 +182,6 @@
myItems << mypDetailItem << mypLibraryNameItem;
mModelPlugins->appendRow(myItems);
-#endif
@@ -383,12 +380,13 @@
QString pluginName = mModelPlugins->data(myIndex,Qt::UserRole).toString();
if (pRegistry->isPythonPlugin(pluginName))
-#ifdef HAVE_PYTHON
- QString packageName = pRegistry->library(pluginName);
- QgsPythonUtils::instance()->unloadPlugin(packageName);
- //disable it to the qsettings file
- settings.setValue("/PythonPlugins/" + packageName, false);
-#endif
+ QString packageName = pRegistry->library(pluginName);
+ mPythonUtils->unloadPlugin(packageName);
+ //disable it to the qsettings file
+ settings.setValue("/PythonPlugins/" + packageName, false);
else // C++ plugin
Modified: trunk/qgis/src/app/qgspluginmanager.h
--- trunk/qgis/src/app/qgspluginmanager.h 2008-05-25 22:41:57 UTC (rev 8516)
+++ trunk/qgis/src/app/qgspluginmanager.h 2008-05-26 00:02:29 UTC (rev 8517)
@@ -28,6 +28,7 @@
#include "qgisgui.h"
class QgsPluginItem;
class QTableView;
@@ -39,7 +40,7 @@
Q_OBJECT
public:
//! Constructor
- QgsPluginManager(QWidget *parent = 0, Qt::WFlags fl = QgisGui::ModalDialogFlags);
+ QgsPluginManager(QgsPythonUtils* pythonUtils, QWidget *parent = 0, Qt::WFlags fl = QgisGui::ModalDialogFlags);
//! Destructor
~QgsPluginManager();
//! Get description of plugins (name, etc)
@@ -70,6 +71,8 @@
private:
QStandardItemModel *mModelPlugins;
QSortFilterProxyModel * mModelProxy;
#endif
Modified: trunk/qgis/src/app/qgspythondialog.cpp
--- trunk/qgis/src/app/qgspythondialog.cpp 2008-05-25 22:41:57 UTC (rev 8516)
+++ trunk/qgis/src/app/qgspythondialog.cpp 2008-05-26 00:02:29 UTC (rev 8517)
@@ -20,11 +20,12 @@
#include <QShowEvent>
#include <QCloseEvent>
-QgsPythonDialog::QgsPythonDialog(QgisInterface* pIface, QWidget *parent)
+QgsPythonDialog::QgsPythonDialog(QgisInterface* pIface, QgsPythonUtils* pythonUtils, QWidget *parent)
: QDialog(parent)
setupUi(this);
mIface = pIface;
QgsPythonDialog::~QgsPythonDialog()
@@ -41,14 +42,13 @@
QString command = edtCmdLine->text();
QString output;
// when using Py_single_input the return value will be always null
// we're using custom hooks for output and exceptions to show output in console
- if (pythonUtils->runStringUnsafe(command))
+ if (mPythonUtils->runStringUnsafe(command))
- pythonUtils->evalString("sys.stdout.get_and_clean_data()", output);
- QString result = pythonUtils->getResult();
+ mPythonUtils->evalString("sys.stdout.get_and_clean_data()", output);
+ QString result = mPythonUtils->getResult();
// escape the result so python objects display properly and
// we can still use html output to get nicely formatted display
output = escapeHtml(output) + escapeHtml(result);
@@ -59,7 +59,7 @@
else
QString className, errorText;
- pythonUtils->getError(className, errorText);
+ mPythonUtils->getError(className, errorText);
output = "<font color=\"red\">" + escapeHtml(className) + ": " + escapeHtml(errorText) + "</font><br>";
@@ -78,12 +78,12 @@
QDialog::showEvent(event);
- QgsPythonUtils::instance()->installConsoleHooks();
+ mPythonUtils->installConsoleHooks();
void QgsPythonDialog::closeEvent(QCloseEvent* event)
- QgsPythonUtils::instance()->uninstallConsoleHooks();
+ mPythonUtils->uninstallConsoleHooks();
QDialog::closeEvent(event);
Modified: trunk/qgis/src/app/qgspythondialog.h
--- trunk/qgis/src/app/qgspythondialog.h 2008-05-25 22:41:57 UTC (rev 8516)
+++ trunk/qgis/src/app/qgspythondialog.h 2008-05-26 00:02:29 UTC (rev 8517)
@@ -20,6 +20,7 @@
#include "ui_qgspythondialog.h"
class QgisInterface;
class QCloseEvent;
class QShowEvent;
@@ -28,7 +29,7 @@
Q_OBJECT
public:
- QgsPythonDialog(QgisInterface* pIface, QWidget *parent = 0);
+ QgsPythonDialog(QgisInterface* pIface, QgsPythonUtils* pythonUtils, QWidget *parent = 0);
~QgsPythonDialog();
@@ -46,6 +47,7 @@
private:
QgisInterface* mIface;
#endif
Modified: trunk/qgis/src/app/qgspythonutils.cpp
--- trunk/qgis/src/app/qgspythonutils.cpp 2008-05-25 22:41:57 UTC (rev 8516)
+++ trunk/qgis/src/app/qgspythonutils.cpp 2008-05-26 00:02:29 UTC (rev 8517)
@@ -18,7 +18,7 @@
// otherwise issues some warnings
#include <Python.h>
-#include "qgspythonutils.h"
#include "qgsapplication.h"
#include "qgslogger.h"
@@ -28,28 +28,28 @@
#include <QStringList>
#include <QDir>
-QgsPythonUtils* QgsPythonUtils::mInstance = NULL;
+QgsPythonUtilsImpl* QgsPythonUtilsImpl::mInstance = NULL;
-QgsPythonUtils::QgsPythonUtils()
+QgsPythonUtilsImpl::QgsPythonUtilsImpl()
mMainModule = NULL;
mMainDict = NULL;
mPythonEnabled = false;
-QgsPythonUtils::~QgsPythonUtils()
+QgsPythonUtilsImpl::~QgsPythonUtilsImpl()
-QgsPythonUtils* QgsPythonUtils::instance()
+QgsPythonUtilsImpl* QgsPythonUtilsImpl::instance()
if (mInstance == NULL)
- mInstance = new QgsPythonUtils();
+ mInstance = new QgsPythonUtilsImpl();
return mInstance;
-void QgsPythonUtils::initPython(QgisInterface* interface)
+void QgsPythonUtilsImpl::initPython(QgisInterface* interface)
// initialize python
Py_Initialize();
@@ -137,7 +137,7 @@
-void QgsPythonUtils::exitPython()
+void QgsPythonUtilsImpl::exitPython()
Py_Finalize();
mMainModule = NULL;
@@ -146,17 +146,17 @@
-bool QgsPythonUtils::isEnabled()
+bool QgsPythonUtilsImpl::isEnabled()
return mPythonEnabled;
-void QgsPythonUtils::installErrorHook()
+void QgsPythonUtilsImpl::installErrorHook()
runString("sys.excepthook = qgis_except_hook");
-void QgsPythonUtils::installConsoleHooks()
+void QgsPythonUtilsImpl::installConsoleHooks()
runString("sys.displayhook = console_display_hook\n");
@@ -164,20 +164,20 @@
runString("sys.stdout = QgisOutputCatcher()\n");
-void QgsPythonUtils::uninstallConsoleHooks()
+void QgsPythonUtilsImpl::uninstallConsoleHooks()
runString("sys.displayhook = sys.__displayhook__");
runString("sys.stdout = _old_stdout");
-bool QgsPythonUtils::runStringUnsafe(const QString& command)
+bool QgsPythonUtilsImpl::runStringUnsafe(const QString& command)
PyRun_String(command.toLocal8Bit().data(), Py_single_input, mMainDict, mMainDict);
return (PyErr_Occurred() == 0);
-bool QgsPythonUtils::runString(const QString& command, QString msgOnError)
+bool QgsPythonUtilsImpl::runString(const QString& command, QString msgOnError)
bool res = runStringUnsafe(command);
if (res)
@@ -208,7 +208,7 @@
-QString QgsPythonUtils::getTraceback()
+QString QgsPythonUtilsImpl::getTraceback()
#define TRACEBACK_FETCH_ERROR(what) {errMsg = what; goto done;}
@@ -280,7 +280,7 @@
return result;
-QString QgsPythonUtils::getTypeAsString(PyObject* obj)
+QString QgsPythonUtilsImpl::getTypeAsString(PyObject* obj)
if (obj == NULL)
return NULL;
@@ -307,7 +307,7 @@
-bool QgsPythonUtils::getError(QString& errorClassName, QString& errorText)
+bool QgsPythonUtilsImpl::getError(QString& errorClassName, QString& errorText)
if (!PyErr_Occurred())
return false;
@@ -341,12 +341,12 @@
return true;
-QString QgsPythonUtils::getResult()
+QString QgsPythonUtilsImpl::getResult()
return getVariableFromMain("__result");
-QString QgsPythonUtils::getVariableFromMain(QString name)
+QString QgsPythonUtilsImpl::getVariableFromMain(QString name)
PyObject* obj;
PyObject* obj_str;
@@ -372,7 +372,7 @@
return output;
-bool QgsPythonUtils::evalString(const QString& command, QString& result)
+bool QgsPythonUtilsImpl::evalString(const QString& command, QString& result)
PyObject* res = PyRun_String(command.toLocal8Bit().data(), Py_eval_input, mMainDict, mMainDict);
@@ -387,27 +387,27 @@
-QString QgsPythonUtils::pythonPath()
+QString QgsPythonUtilsImpl::pythonPath()
return QgsApplication::pkgDataPath() + "/python";
-QString QgsPythonUtils::pluginsPath()
+QString QgsPythonUtilsImpl::pluginsPath()
return pythonPath() + "/plugins";
-QString QgsPythonUtils::homePluginsPath()
+QString QgsPythonUtilsImpl::homePluginsPath()
return QgsApplication::qgisSettingsDirPath() + "/python/plugins";
-QStringList QgsPythonUtils::pluginList()
+QStringList QgsPythonUtilsImpl::pluginList()
- QDir pluginDir(QgsPythonUtils::pluginsPath(), "*",
+ QDir pluginDir(QgsPythonUtilsImpl::pluginsPath(), "*",
QDir::Name | QDir::IgnoreCase, QDir::Dirs | QDir::NoDotAndDotDot);
- QDir homePluginDir(QgsPythonUtils::homePluginsPath(), "*",
+ QDir homePluginDir(QgsPythonUtilsImpl::homePluginsPath(), "*",
QStringList pluginList = pluginDir.entryList();
@@ -423,7 +423,7 @@
return pluginList;
-QString QgsPythonUtils::getPluginMetadata(QString pluginName, QString function)
+QString QgsPythonUtilsImpl::getPluginMetadata(QString pluginName, QString function)
QString command = pluginName + "." + function + "()";
QString retval = "???";
@@ -449,7 +449,7 @@
-bool QgsPythonUtils::loadPlugin(QString packageName)
+bool QgsPythonUtilsImpl::loadPlugin(QString packageName)
// load plugin's package and ensure that plugin is reloaded when changed
runString(
@@ -480,7 +480,7 @@
-bool QgsPythonUtils::startPlugin(QString packageName)
+bool QgsPythonUtilsImpl::startPlugin(QString packageName)
QString pluginPythonVar = "plugins['" + packageName + "']";
@@ -499,7 +499,7 @@
-bool QgsPythonUtils::unloadPlugin(QString packageName)
+bool QgsPythonUtilsImpl::unloadPlugin(QString packageName)
// unload and delete plugin!
QString varName = "plugins['" + packageName + "']";
Modified: trunk/qgis/src/app/qgspythonutils.h
--- trunk/qgis/src/app/qgspythonutils.h 2008-05-25 22:41:57 UTC (rev 8516)
+++ trunk/qgis/src/app/qgspythonutils.h 2008-05-26 00:02:29 UTC (rev 8517)
@@ -1,5 +1,5 @@
- qgspythonutils.h - routines for interfacing Python
+ qgspythonutils.h - abstract interface for Python routines
begin : October 2006
copyright : (C) 2006 by Martin Dobias
@@ -14,14 +14,12 @@
/* $Id$ */
+#ifndef QGSPYTHONUTILS_H
+#define QGSPYTHONUTILS_H
#include <QString>
-// forward declaration for PyObject
-#ifndef PyObject_HEAD
-struct _object;
-typedef _object PyObject;
-#endif
@@ -34,103 +32,62 @@
- QgsApplication::pkgDataPath() + "/python/plugins"
public:
- QgsPythonUtils();
+ virtual ~QgsPythonUtils() {}
- ~QgsPythonUtils();
- static QgsPythonUtils* instance();
- /* general purpose functions */
+ //! returns true if python support is ready to use (must be inited first)
+ virtual bool isEnabled() = 0;
//! initialize python and import bindings
- void initPython(QgisInterface* interface);
+ virtual void initPython(QgisInterface* interface) = 0;
//! close python interpreter
- void exitPython();
+ virtual void exitPython() = 0;
- //! returns true if python support is ready to use (must be inited first)
- bool isEnabled();
+ /* console */
- //! returns path where QGIS python stuff is located
- QString pythonPath();
- //! run a statement (wrapper for PyRun_String)
- //! this command is more advanced as enables error checking etc.
- //! when an exception is raised, it shows dialog with exception details
- //! @return true if no error occured
- bool runString(const QString& command, QString msgOnError = QString());
//! run a statement, error reporting is not done
- bool runStringUnsafe(const QString& command);
+ virtual bool runStringUnsafe(const QString& command) = 0;
- bool evalString(const QString& command, QString& result);
+ virtual bool evalString(const QString& command, QString& result) = 0;
- //! @return object's type name as a string
- QString getTypeAsString(PyObject* obj);
- //! get information about error to the supplied arguments
- //! @return false if there was no python error
- bool getError(QString& errorClassName, QString& errorText);
- //! get variable from main dictionary
- QString getVariableFromMain(QString name);
- /* python console related functions */
//! change displayhook and excepthook
//! our hooks will just save the result to special variables
//! and those can be used in the program
- void installConsoleHooks();
+ virtual void installConsoleHooks() = 0;
//! get back to the original settings (i.e. write output to stdout)
- void uninstallConsoleHooks();
+ virtual void uninstallConsoleHooks() = 0;
//! get result from the last statement as a string
- QString getResult();
+ virtual QString getResult() = 0;
- /* plugins related functions */
+ //! get information about error to the supplied arguments
+ //! @return false if there was no python error
+ virtual bool getError(QString& errorClassName, QString& errorText) = 0;
- //! return current path for python plugins
- QString pluginsPath();
- //! return current path for home directory python plugins
- QString homePluginsPath();
+ /* plugins */
//! return list of all available python plugins
- QStringList pluginList();
+ virtual QStringList pluginList() = 0;
//! load python plugin (import)
- bool loadPlugin(QString packageName);
+ virtual bool loadPlugin(QString packageName) = 0;
//! start plugin: add to active plugins and call initGui()
- bool startPlugin(QString packageName);
+ virtual bool startPlugin(QString packageName) = 0;
//! helper function to get some information about plugin
//! @param function one of these strings: name, tpye, version, description
- QString getPluginMetadata(QString pluginName, QString function);
+ virtual QString getPluginMetadata(QString pluginName, QString function) = 0;
//! unload plugin
- bool unloadPlugin(QString packageName);
- protected:
- void installErrorHook();
- QString getTraceback();
- //! reference to module __main__
- PyObject* mMainModule;
- //! dictionary of module __main__
- PyObject* mMainDict;
- //! flag determining that python support is enabled
- bool mPythonEnabled;
- static QgsPythonUtils* mInstance;
+ virtual bool unloadPlugin(QString packageName) = 0;
+#endif
Added: trunk/qgis/src/app/qgspythonutilsimpl.h
--- trunk/qgis/src/app/qgspythonutilsimpl.h (rev 0)
+++ trunk/qgis/src/app/qgspythonutilsimpl.h 2008-05-26 00:02:29 UTC (rev 8517)
@@ -0,0 +1,132 @@
+ qgspythonutilsimpl.h - routines for interfacing Python
+ begin : May 2008
+ copyright : (C) 2008 by Martin Dobias
+ email : wonder.sk at gmail dot com
+ * This program is free software; you can redistribute it and/or modify *
+ * it under the terms of the GNU General Public License as published by *
+ * the Free Software Foundation; either version 2 of the License, or *
+ * (at your option) any later version. *
+/* $Id$ */
+#ifndef QGSPYTHONUTILSIMPL_H
+#define QGSPYTHONUTILSIMPL_H
+#include "qgspythonutils.h"
+// forward declaration for PyObject
+#ifndef PyObject_HEAD
+struct _object;
+typedef _object PyObject;
+#endif
+class QgsPythonUtilsImpl : public QgsPythonUtils
+ public:
+ QgsPythonUtilsImpl();
+ virtual ~QgsPythonUtilsImpl();
+ static QgsPythonUtilsImpl* instance();
+ /* general purpose functions */
+ //! initialize python and import bindings
+ void initPython(QgisInterface* interface);
+ //! close python interpreter
+ void exitPython();
+ bool isEnabled();
+ //! returns path where QGIS python stuff is located
+ QString pythonPath();
+ //! run a statement (wrapper for PyRun_String)
+ //! this command is more advanced as enables error checking etc.
+ //! when an exception is raised, it shows dialog with exception details
+ //! @return true if no error occured
+ bool runString(const QString& command, QString msgOnError = QString());
+ //! run a statement, error reporting is not done
+ bool runStringUnsafe(const QString& command);
+ bool evalString(const QString& command, QString& result);
+ //! @return object's type name as a string
+ QString getTypeAsString(PyObject* obj);
+ bool getError(QString& errorClassName, QString& errorText);
+ //! get variable from main dictionary
+ QString getVariableFromMain(QString name);
+ /* python console related functions */
+ //! change displayhook and excepthook
+ //! our hooks will just save the result to special variables
+ //! and those can be used in the program
+ void installConsoleHooks();
+ //! get back to the original settings (i.e. write output to stdout)
+ void uninstallConsoleHooks();
+ //! get result from the last statement as a string
+ QString getResult();
+ /* plugins related functions */
+ //! return current path for python plugins
+ QString pluginsPath();
+ //! return current path for home directory python plugins
+ QString homePluginsPath();
+ //! return list of all available python plugins
+ QStringList pluginList();
+ //! load python plugin (import)
+ bool loadPlugin(QString packageName);
+ //! start plugin: add to active plugins and call initGui()
+ bool startPlugin(QString packageName);
+ //! helper function to get some information about plugin
+ //! @param function one of these strings: name, tpye, version, description
+ QString getPluginMetadata(QString pluginName, QString function);
+ //! unload plugin
+ bool unloadPlugin(QString packageName);
+ protected:
+ void installErrorHook();
+ QString getTraceback();
+ //! reference to module __main__
+ PyObject* mMainModule;
+ //! dictionary of module __main__
+ PyObject* mMainDict;
+ //! flag determining that python support is enabled
+ bool mPythonEnabled;
+ static QgsPythonUtilsImpl* mInstance;
+#endif
