[QGIS Commit] r8519 - trunk/qgis
svn_qgis at osgeo.org
Mon May 26 10:16:04 EDT 2008
Author: timlinux
Date: 2008-05-26 10:16:03 -0400 (Mon, 26 May 2008)
New Revision: 8519
trunk/qgis/CMakeLists.txt
remove some duplication of version vars in top level cmakelists.txt
Modified: trunk/qgis/CMakeLists.txt
--- trunk/qgis/CMakeLists.txt 2008-05-26 11:47:36 UTC (rev 8518)
+++ trunk/qgis/CMakeLists.txt 2008-05-26 14:16:03 UTC (rev 8519)
@@ -1,11 +1,9 @@
-PROJECT(qgis0.11.0)
SET(CPACK_PACKAGE_VERSION_MAJOR "0")
SET(CPACK_PACKAGE_VERSION_MINOR "11")
SET(CPACK_PACKAGE_VERSION_PATCH "0")
+SET(COMPLETE_VERSION ${CPACK_PACKAGE_VERSION_MAJOR}.${CPACK_PACKAGE_VERSION_MINOR}.${CPACK_PACKAGE_VERSION_PATCH})^
SET(RELEASE_NAME "Metis")
-SET(PROJECT_VERSION ${CPACK_PACKAGE_VERSION_MAJOR}.${CPACK_PACKAGE_VERSION_MINOR}.${CPACK_PACKAGE_VERSION_PATCH})
+SET(PROJECT_VERSION ${COMPLETE_VERSION})
PROJECT(qgis${PROJECT_VERSION})
@@ -14,7 +12,9 @@
# - nice output when configured
# - rename *.ui files to have the same filename as their implementation
# e.g. instead of blahblahbase.ui use blahblah.ui
-# because it's more common in Qt4
+# because it's more common in Qt4
+# Note on last point above by Tim Sutton - I prefer to have the base suffix
+# as it indicates the ui generated class will be a base class for the widget.
# CMake settings
@@ -360,7 +360,7 @@
SET(CPACK_PACKAGE_VENDOR "Open Source Geospatial Foundation")
SET(CPACK_PACKAGE_DESCRIPTION_FILE "${CMAKE_CURRENT_SOURCE_DIR}/README")
SET(CPACK_RESOURCE_FILE_LICENSE "${CMAKE_CURRENT_SOURCE_DIR}/COPYING")
-SET(CPACK_PACKAGE_INSTALL_DIRECTORY "Quantum GIS ${CPACK_PACKAGE_VERSION_MAJOR}.${CPACK_PACKAGE_VERSION_MINOR}")
+SET(CPACK_PACKAGE_INSTALL_DIRECTORY "Quantum GIS ${COMPLETE_VERSION}")
IF(WIN32 AND NOT UNIX)
# There is a bug in NSI that does not handle full unix paths properly. Make
# sure there is at least one set of four (4) backslashes.
