[QGIS Commit] r8522 - trunk/qgis/src/core
svn_qgis at osgeo.org
Mon May 26 10:47:34 EDT 2008
Author: timlinux
Date: 2008-05-26 10:47:34 -0400 (Mon, 26 May 2008)
New Revision: 8522
trunk/qgis/src/core/qgsmaprender.cpp
Just fixed some code indentation
Modified: trunk/qgis/src/core/qgsmaprender.cpp
--- trunk/qgis/src/core/qgsmaprender.cpp 2008-05-26 14:25:56 UTC (rev 8521)
+++ trunk/qgis/src/core/qgsmaprender.cpp 2008-05-26 14:47:34 UTC (rev 8522)
@@ -215,12 +215,12 @@
QPaintDevice* thePaintDevice = painter->device();
if(!thePaintDevice)
- return;
+ return;
mDrawing = true;
QgsCoordinateTransform* ct;
#ifdef QGISDEBUG
@@ -250,13 +250,13 @@
li.toBack();
QgsRect r1, r2;
while (li.hasPrevious())
if(mRenderContext.renderingStopped())
- break;
+ break;
QString layerId = li.previous();
@@ -278,8 +278,8 @@
QgsLogger::warning("Layer not found in registry!");
continue;
- QgsDebugMsg("Rendering layer " + ml->name());
+ QgsDebugMsg("Rendering layer " + ml->name());
QgsDebugMsg(" Layer minscale " + QString("%1").arg(ml->minScale()) );
QgsDebugMsg(" Layer maxscale " + QString("%1").arg(ml->maxScale()) );
QgsDebugMsg(" Scale dep. visibility enabled? " + QString("%1").arg(ml->scaleBasedVisibility()) );
@@ -289,20 +289,20 @@
|| (!ml->scaleBasedVisibility()))
connect(ml, SIGNAL(drawingProgress(int,int)), this, SLOT(onDrawingProgress(int,int)));
- // Now do the call to the layer that actually does
- // the rendering work!
+ // Now do the call to the layer that actually does
+ // the rendering work!
bool split = false;
if (projectionsEnabled())
- r1 = mExtent;
- split = splitLayersExtent(ml, r1, r2);
+ r1 = mExtent;
+ split = splitLayersExtent(ml, r1, r2);
ct = new QgsCoordinateTransform(ml->srs(), *mDestSRS);
- mRenderContext.setExtent(r1);
+ mRenderContext.setExtent(r1);
else
@@ -318,54 +318,54 @@
QgsMapToPixel bk_mapToPixel;
double debug = fabs(rasterScaleFactor - 1.0);
if(ml->type() == QgsMapLayer::RASTER && fabs(rasterScaleFactor - 1.0) > 0.000001)
- scaleRaster = true;
+ scaleRaster = true;
if(scaleRaster)
- bk_mapToPixel = mRenderContext.mapToPixel();
- rasterMapToPixel = mRenderContext.mapToPixel();
- rasterMapToPixel.setMapUnitsPerPixel(mRenderContext.mapToPixel().mapUnitsPerPixel() / rasterScaleFactor);
- rasterMapToPixel.setYmax(mSize.height() * rasterScaleFactor);
- mRenderContext.setMapToPixel(rasterMapToPixel);
- mRenderContext.painter()->save();
- mRenderContext.painter()->scale(1.0/rasterScaleFactor, 1.0/rasterScaleFactor);
+ bk_mapToPixel = mRenderContext.mapToPixel();
+ rasterMapToPixel = mRenderContext.mapToPixel();
+ rasterMapToPixel.setMapUnitsPerPixel(mRenderContext.mapToPixel().mapUnitsPerPixel() / rasterScaleFactor);
+ rasterMapToPixel.setYmax(mSize.height() * rasterScaleFactor);
+ mRenderContext.setMapToPixel(rasterMapToPixel);
+ mRenderContext.painter()->save();
+ mRenderContext.painter()->scale(1.0/rasterScaleFactor, 1.0/rasterScaleFactor);
if (!ml->draw(mRenderContext))
- emit drawError(ml);
+ emit drawError(ml);
if (split)
- mRenderContext.setExtent(r2);
+ mRenderContext.setExtent(r2);
if(scaleRaster)
- mRenderContext.setMapToPixel(bk_mapToPixel);
- mRenderContext.painter()->restore();
+ mRenderContext.setMapToPixel(bk_mapToPixel);
+ mRenderContext.painter()->restore();
disconnect(ml, SIGNAL(drawingProgress(int,int)), this, SLOT(onDrawingProgress(int,int)));
else
QgsDebugMsg("Layer not rendered because it is not within the defined "
- "visibility scale range");
+ "visibility scale range");
} // while (li.hasPrevious())
- QgsDebugMsg("Done rendering map layers");
+ QgsDebugMsg("Done rendering map layers");
if (!mOverview)
// render all labels for vector layers in the stack, starting at the base
@@ -373,15 +373,15 @@
- break;
+ break;
// TODO: emit drawingProgress((myRenderCounter++),zOrder.size());
QgsMapLayer *ml = QgsMapLayerRegistry::instance()->mapLayer(layerId);
if (ml && (ml->type() != QgsMapLayer::RASTER))
// only make labels if the layer is visible
@@ -393,24 +393,24 @@
- QgsRect r1 = mExtent;
+ QgsRect r1 = mExtent;
else
ct = NULL;
- mRenderContext.setCoordTransform(ct);
- ml->drawLabels(mRenderContext);
+ mRenderContext.setCoordTransform(ct);
+ ml->drawLabels(mRenderContext);
if (split)
@@ -418,7 +418,7 @@
// make sure progress bar arrives at 100%!
emit drawingProgress(1,1);
#ifdef QGISDEBUG
QgsDebugMsg("Rendering done in (seconds): " + QString("%1").arg(renderTime.elapsed() / 1000.0) );
#endif
