[QGIS Commit] r8524 - trunk/qgis/src/app
svn_qgis at osgeo.org
Mon May 26 11:49:58 EDT 2008
Author: timlinux
Date: 2008-05-26 11:49:58 -0400 (Mon, 26 May 2008)
New Revision: 8524
trunk/qgis/src/app/qgsattributetabledisplay.cpp
Gui cleaunups and use buttonbox
Modified: trunk/qgis/src/app/qgsattributetabledisplay.cpp
--- trunk/qgis/src/app/qgsattributetabledisplay.cpp 2008-05-26 15:42:29 UTC (rev 8523)
+++ trunk/qgis/src/app/qgsattributetabledisplay.cpp 2008-05-26 15:49:58 UTC (rev 8524)
@@ -59,7 +59,9 @@
connect(mSearchButton, SIGNAL(clicked()), this, SLOT(search()));
connect(mSearchShowResults, SIGNAL(activated(int)), this, SLOT(searchShowResultsChanged(int)));
connect(btnAdvancedSearch, SIGNAL(clicked()), this, SLOT(advancedSearch()));
- connect(btnClose, SIGNAL(clicked()), this, SLOT(close()));
+ connect(buttonBox, SIGNAL(helpRequested()), this, SLOT(showHelp()));
+ connect(buttonBox->button(QDialogButtonBox::Close), SIGNAL(clicked()),
+ this, SLOT(close()));
connect(tblAttributes, SIGNAL(featureAttributeChanged(int,int)), this, SLOT(changeFeatureAttribute(int,int)));
//disable those buttons until start editing has been pressed and provider supports it
@@ -175,7 +177,7 @@
btnStartEditing->setEnabled(false);
btnStopEditing->setEnabled(true);
- btnClose->setEnabled(false);
+ buttonBox->button(QDialogButtonBox::Close)->setEnabled(false);
//make the dialog modal when in editable
//otherwise map editing and table editing
//may disturb each other
@@ -213,7 +215,7 @@
btnStartEditing->setEnabled(true);
btnStopEditing->setEnabled(false);
- btnClose->setEnabled(true);
+ buttonBox->button(QDialogButtonBox::Close)->setEnabled(true);
mAddAttributeButton->setEnabled(false);
mDeleteAttributeButton->setEnabled(false);
table()->setReadOnly(true);
@@ -400,10 +402,6 @@
settings.setValue("/Windows/AttributeTable/geometry", saveGeometry());
-void QgsAttributeTableDisplay::on_btnHelp_clicked()
- showHelp();
void QgsAttributeTableDisplay::showHelp()
QgsContextHelp::run(context_id);
