[QGIS Commit] r8549 - branches/advanced_printing_branch/src/app/composer
svn_qgis at osgeo.org svn_qgis at osgeo.org
Fri May 30 11:48:52 EDT 2008
Author: mhugent
Date: 2008-05-30 11:48:52 -0400 (Fri, 30 May 2008)
New Revision: 8549
   branches/advanced_printing_branch/src/app/composer/qgscomposermap.cpp
   branches/advanced_printing_branch/src/app/composer/qgscomposermap.h
More cleanups in composer map
Modified: branches/advanced_printing_branch/src/app/composer/qgscomposermap.cpp
--- branches/advanced_printing_branch/src/app/composer/qgscomposermap.cpp	2008-05-30 15:46:41 UTC (rev 8548)
+++ branches/advanced_printing_branch/src/app/composer/qgscomposermap.cpp	2008-05-30 15:48:52 UTC (rev 8549)
@@ -227,56 +227,12 @@
   mDrawing = false;
-double QgsComposerMap::scaleFromUserScale ( double us )
-  double s=0;
-  switch ( mComposition->mapCanvas()->mapUnits() ) {
-    case QGis::METERS :
-      s = 1000. * mComposition->scale() / us;
-      break;
-    case QGis::FEET :
-      s = 304.8 * mComposition->scale() / us;
-      break;
-    case QGis::UNKNOWN :
-    case QGis::DEGREES :
-      s = mComposition->scale() / us;
-      break;
-  return s;
-double QgsComposerMap::userScaleFromScale ( double s )
-  double us=0;
-      us = 1000. * mComposition->scale() / s;
-      break;
-    case QGis::FEET :
-      us = 304.8 * mComposition->scale() / s;
-      break;
-      us = mComposition->scale() / s;
-      break;
-  return us;
 void QgsComposerMap::mapCanvasChanged ( void )
     mCacheUpdated = false;
     QGraphicsRectItem::update();
 bool QgsComposerMap::selected( void )
     return mSelected;
@@ -324,14 +280,7 @@
   } else {
       QgsProject::instance()->writeEntry( "Compositions", path+"calculate", QString("extent") );
-  QgsProject::instance()->writeEntry( "Compositions", path+"north", mUserExtent.yMax() );
-  QgsProject::instance()->writeEntry( "Compositions", path+"south", mUserExtent.yMin() );
-  QgsProject::instance()->writeEntry( "Compositions", path+"east", mUserExtent.xMax() );
-  QgsProject::instance()->writeEntry( "Compositions", path+"west", mUserExtent.xMin() );
-  QgsProject::instance()->writeEntry( "Compositions", path+"scale", mUserScale );
   QgsProject::instance()->writeEntry( "Compositions", path+"frame", mFrame );
   QgsProject::instance()->writeEntry( "Compositions", path+"previewmode", mPreviewMode );
@@ -360,14 +309,6 @@
     mCalculate = Scale;
-  mUserExtent.setYmax ( QgsProject::instance()->readDoubleEntry( "Compositions", path+"north", 100, &ok) );
-  mUserExtent.setYmin ( QgsProject::instance()->readDoubleEntry( "Compositions", path+"south", 0, &ok) );
-  mUserExtent.setXmax ( QgsProject::instance()->readDoubleEntry( "Compositions", path+"east", 100, &ok) );
-  mUserExtent.setXmin ( QgsProject::instance()->readDoubleEntry( "Compositions", path+"west", 0, &ok) );
-  mUserScale =  QgsProject::instance()->readDoubleEntry( "Compositions", path+"scale", 1000., &ok);
-  mScale = scaleFromUserScale ( mUserScale );
   mFrame = QgsProject::instance()->readBoolEntry("Compositions", path+"frame", true, &ok);
Modified: branches/advanced_printing_branch/src/app/composer/qgscomposermap.h
--- branches/advanced_printing_branch/src/app/composer/qgscomposermap.h	2008-05-30 15:46:41 UTC (rev 8548)
+++ branches/advanced_printing_branch/src/app/composer/qgscomposermap.h	2008-05-30 15:48:52 UTC (rev 8549)
@@ -141,9 +141,6 @@
     /** \brief Map name, used in legend combobox etc. */
     QString mName;
-    // Map region in map units specified by user
-    QgsRect mUserExtent;
     // Map region in map units realy used for rendering
     // It can be the same as mUserExtent, but it can be bigger in on dimension if mCalculate==Scale,
     // so that full rectangle in paper is used.
@@ -152,10 +149,6 @@
     // Cache extent (it can be bigger for example than mExtent)
     QgsRect mCacheExtent;
-    // Size of of the map rectangle in the composition in paper units
-    //double mWidth;
-    //double mHeight;
     // Number of paper units in map per paper unit on paper, this is the xxx part of 1:xxx
     double mUserScale;
@@ -189,12 +182,6 @@
     /**Store last scale factor to avoid unnecessary repaints in case preview mode is 'Render'*/
     double mLastScaleFactorX;
-    /** \brief calculate mScale from mUserScale */
-    double scaleFromUserScale ( double us );
-    /** \brief calculate mUserScale from mScale */
-    double userScaleFromScale ( double s );
     /**Sets new Extent and changes only width and height*/
     void setNewExtent(const QgsRect& extent);
     /**Sets new scale and changes only mExtent*/
More information about the QGIS-commit mailing list
