[QGIS Commit] r8551 - in trunk/qgis/src: app ui
svn_qgis at osgeo.org svn_qgis at osgeo.org
Fri May 30 11:53:14 EDT 2008
Author: timlinux
Date: 2008-05-30 11:53:14 -0400 (Fri, 30 May 2008)
New Revision: 8551
   trunk/qgis/src/app/qgsgeomtypedialog.cpp
   trunk/qgis/src/ui/qgsgeomtypedialogbase.ui
Use button box for cross platform consistency
Modified: trunk/qgis/src/app/qgsgeomtypedialog.cpp
--- trunk/qgis/src/app/qgsgeomtypedialog.cpp	2008-05-30 15:51:24 UTC (rev 8550)
+++ trunk/qgis/src/app/qgsgeomtypedialog.cpp	2008-05-30 15:53:14 UTC (rev 8551)
@@ -17,14 +17,19 @@
 /* $Id$ */
 #include "qgsgeomtypedialog.h"
-#include "qgsaddattrdialog.h"
+#include "qgsapplication.h"
+#include <QPushButton>
 QgsGeomTypeDialog::QgsGeomTypeDialog(QWidget *parent, Qt::WFlags fl)
 : QDialog(parent, fl)
   setupUi(this);
-  connect(buttonBox, SIGNAL(accepted()), this, SLOT(accept()));
-  connect(buttonBox, SIGNAL(rejected()), this, SLOT(reject()));
+  QString myThemePath = QgsApplication::themePath();
+  mAddAttributeButton->setIcon(QIcon(QPixmap(myThemePath + "/mActionNewAttribute.png")));
+  mRemoveAttributeButton->setIcon(QIcon(QPixmap(myThemePath + "/mActionDeleteAttribute.png")));
+  mTypeBox->addItem(tr("Real"),"Real");
+  mTypeBox->addItem(tr("Integer"),"Integer");;
+  mTypeBox->addItem(tr("String"),"String");
   mPointRadioButton->setChecked(true);
   mFileFormatComboBox->insertItem("ESRI Shapefile");
@@ -58,19 +63,15 @@
 void QgsGeomTypeDialog::on_mAddAttributeButton_clicked()
-  std::list<QString> types;
-  types.push_back("Real");
-  types.push_back("Integer");
-  types.push_back("String");
-  QgsAddAttrDialog d(types, this);
-  if(d.exec()==QDialog::Accepted)
-    mAttributeView->addTopLevelItem(new QTreeWidgetItem(QStringList() << d.name() << d.type()));
+  QString myName = mNameEdit->text();
+  //use userrole to avoid translated type string
+  QString myType = mTypeBox->itemData ( mTypeBox->currentIndex(),Qt::UserRole ).toString();
+  mAttributeView->addTopLevelItem(new QTreeWidgetItem( QStringList() << myName << myType ));
   if(mAttributeView->topLevelItemCount()>0)
     mOkButton->setEnabled(true);
+  mNameEdit->clear();
 void QgsGeomTypeDialog::on_mRemoveAttributeButton_clicked()
Modified: trunk/qgis/src/ui/qgsgeomtypedialogbase.ui
--- trunk/qgis/src/ui/qgsgeomtypedialogbase.ui	2008-05-30 15:51:24 UTC (rev 8550)
+++ trunk/qgis/src/ui/qgsgeomtypedialogbase.ui	2008-05-30 15:53:14 UTC (rev 8551)
@@ -5,8 +5,8 @@
    <rect>
     <x>0</x>
     <y>0</y>
-    <width>400</width>
-    <height>427</height>
+    <width>395</width>
+    <height>422</height>
    </rect>
   </property>
   <property name="windowTitle" >
@@ -16,7 +16,7 @@
    <bool>true</bool>
   </property>
   <layout class="QGridLayout" >
-   <item row="1" column="0" colspan="2" >
+   <item row="0" column="0" >
     <widget class="QLabel" name="mFileFormatLabel" >
      <property name="text" >
       <string>File format</string>
@@ -26,50 +26,10 @@
      </property>
     </widget>
    </item>
-   <item row="1" column="2" colspan="2" >
+   <item row="0" column="1" colspan="3" >
     <widget class="QComboBox" name="mFileFormatComboBox" />
    </item>
-   <item row="3" column="1" colspan="2" >
-    <widget class="QPushButton" name="mRemoveAttributeButton" >
-     <property name="text" >
-      <string>Remove</string>
-     </property>
-    </widget>
-   </item>
-   <item row="3" column="3" >
-    <spacer>
-     <property name="orientation" >
-      <enum>Qt::Horizontal</enum>
-     </property>
-     <property name="sizeType" >
-      <enum>QSizePolicy::Expanding</enum>
-     </property>
-     <property name="sizeHint" >
-      <size>
-       <width>91</width>
-       <height>20</height>
-      </size>
-     </property>
-    </spacer>
-   </item>
-   <item row="2" column="0" colspan="3" >
-    <widget class="QLabel" name="mAttributeLabel" >
-      <string>Attributes</string>
-     </property>
-     <property name="buddy" >
-      <cstring>mAddAttributeButton</cstring>
-     </property>
-    </widget>
-   </item>
-   <item row="3" column="0" >
-    <widget class="QPushButton" name="mAddAttributeButton" >
-      <string>Add</string>
-     </property>
-    </widget>
-   </item>
-   <item row="0" column="0" colspan="4" >
+   <item row="1" column="0" colspan="4" >
     <widget class="QGroupBox" name="buttonGroup1" >
      <property name="title" >
       <string>Type</string>
@@ -99,8 +59,89 @@
      </layout>
     </widget>
    </item>
-   <item row="4" column="0" colspan="4" >
+   <item row="2" column="0" colspan="4" >
+    <widget class="QLabel" name="mAttributeLabel" >
+     <property name="text" >
+      <string>Attributes</string>
+     </property>
+    </widget>
+   </item>
+   <item row="3" column="0" >
+    <widget class="QLabel" name="textLabel1" >
+      <string>Name</string>
+     </property>
+     <property name="buddy" >
+      <cstring>mNameEdit</cstring>
+     </property>
+    </widget>
+   </item>
+   <item row="3" column="1" colspan="3" >
+    <widget class="QLineEdit" name="mNameEdit" />
+   </item>
+   <item row="4" column="0" >
+    <widget class="QLabel" name="textLabel2" >
+      <string>Type</string>
+     </property>
+      <cstring>mTypeBox</cstring>
+     </property>
+    </widget>
+   </item>
+   <item row="4" column="1" colspan="3" >
+    <widget class="QComboBox" name="mTypeBox" />
+   </item>
+   <item row="5" column="0" colspan="2" >
+    <spacer>
+     <property name="orientation" >
+      <enum>Qt::Horizontal</enum>
+     </property>
+     <property name="sizeHint" >
+      <size>
+       <width>291</width>
+       <height>20</height>
+      </size>
+     </property>
+    </spacer>
+   </item>
+   <item row="5" column="2" >
+    <widget class="QToolButton" name="mRemoveAttributeButton" >
+     <property name="toolTip" >
+      <string>Remove selected row</string>
+     </property>
+      <string>...</string>
+     </property>
+     <property name="icon" >
+      <iconset>../../images/themes/default/mActionDeleteAttribute.png</iconset>
+     </property>
+    </widget>
+   </item>
+   <item row="5" column="3" >
+    <widget class="QToolButton" name="mAddAttributeButton" >
+      <string>Add values manually</string>
+     </property>
+     </property>
+      <iconset>../../images/themes/default/mActionNewAttribute.png</iconset>
+     </property>
+    </widget>
+   </item>
+   <item row="6" column="0" colspan="4" >
     <widget class="QTreeWidget" name="mAttributeView" >
+     <property name="sizePolicy" >
+      <sizepolicy vsizetype="Expanding" hsizetype="Expanding" >
+       <horstretch>0</horstretch>
+       <verstretch>0</verstretch>
+      </sizepolicy>
+     </property>
+     <property name="alternatingRowColors" >
+      <bool>true</bool>
+     </property>
      <property name="rootIsDecorated" >
       <bool>false</bool>
      </property>
@@ -116,7 +157,7 @@
      </column>
     </widget>
    </item>
-   <item row="5" column="0" colspan="4" >
+   <item row="7" column="0" colspan="4" >
     <widget class="QDialogButtonBox" name="buttonBox" >
@@ -130,13 +171,50 @@
  </widget>
  <layoutdefault spacing="6" margin="11" />
  <tabstops>
+  <tabstop>mFileFormatComboBox</tabstop>
   <tabstop>mPointRadioButton</tabstop>
   <tabstop>mLineRadioButton</tabstop>
   <tabstop>mPolygonRadioButton</tabstop>
-  <tabstop>mFileFormatComboBox</tabstop>
+  <tabstop>mNameEdit</tabstop>
+  <tabstop>mTypeBox</tabstop>
+  <tabstop>mRemoveAttributeButton</tabstop>
   <tabstop>mAddAttributeButton</tabstop>
-  <tabstop>mRemoveAttributeButton</tabstop>
+  <tabstop>mAttributeView</tabstop>
+  <tabstop>buttonBox</tabstop>
  </tabstops>
  <resources/>
- <connections/>
+ <connections>
+  <connection>
+   <sender>buttonBox</sender>
+   <signal>accepted()</signal>
+   <receiver>QgsGeomTypeDialogBase</receiver>
+   <slot>accept()</slot>
+   <hints>
+    <hint type="sourcelabel" >
+     <x>349</x>
+     <y>400</y>
+    </hint>
+    <hint type="destinationlabel" >
+     <x>387</x>
+     <y>304</y>
+    </hint>
+   </hints>
+  </connection>
+  <connection>
+   <signal>rejected()</signal>
+   <slot>reject()</slot>
+   <hints>
+     <x>275</x>
+     <y>400</y>
+    </hint>
+     <x>242</x>
+     <y>308</y>
+    </hint>
+   </hints>
+  </connection>
+ </connections>
 </ui>
More information about the QGIS-commit mailing list
