[QGIS Commit] r9575 - trunk/qgis/src/gui
svn_qgis at osgeo.org
Fri Nov 7 12:24:36 EST 2008
Author: timlinux
Date: 2008-11-07 12:24:36 -0500 (Fri, 07 Nov 2008)
New Revision: 9575
trunk/qgis/src/gui/qgisinterface.h
Tidy up to header and fix some typos
Modified: trunk/qgis/src/gui/qgisinterface.h
--- trunk/qgis/src/gui/qgisinterface.h 2008-11-07 17:23:33 UTC (rev 9574)
+++ trunk/qgis/src/gui/qgisinterface.h 2008-11-07 17:24:36 UTC (rev 9575)
@@ -63,15 +63,19 @@
//! Zoom to full extent of map layers
virtual void zoomFull() = 0;
- //! Zoom to previous view extent
+ //! Zoom to previous view extent
virtual void zoomToPrevious() = 0;
- //! Zoome to extent of the active layer
+ //! Zoom to extent of the active layer
virtual void zoomToActiveLayer() = 0;
//! Add a vector layer
virtual QgsVectorLayer* addVectorLayer( QString vectorLayerPath, QString baseName, QString providerKey ) = 0;
//! Add a raster layer given a raster layer file name
virtual QgsRasterLayer* addRasterLayer( QString rasterLayerPath, QString baseName = QString() ) = 0;
//! Add a WMS layer
virtual QgsRasterLayer* addRasterLayer( const QString& url, const QString& layerName, const QString& providerKey, const QStringList& layers,
const QStringList& styles, const QString& format, const QString& crs ) = 0;
@@ -86,20 +90,13 @@
//! Add an icon to the plugins toolbar
virtual int addToolBarIcon( QAction *qAction ) = 0;
//! Remove an action (icon) from the plugin toolbar
virtual void removeToolBarIcon( QAction *qAction ) = 0;
//! Add toolbar with specified name
virtual QToolBar * addToolBar( QString name ) = 0;
- // TODO: is this deprecated in favour of QgsContextHelp?
- /** Open a url in the users browser. By default the QGIS doc directory is used
- * as the base for the URL. To open a URL that is not relative to the installed
- * QGIS documentation, set useQgisDocDirectory to false.
- * @param url URL to open
- * @param useQgisDocDirectory If true, the URL will be formed by concatenating
- * url to the QGIS documentation directory path (<prefix>/share/doc)
- virtual void openURL( QString url, bool useQgisDocDirectory = true ) = 0;
/** Return a pointer to the map canvas */
virtual QgsMapCanvas * mapCanvas() = 0;
@@ -120,10 +117,22 @@
/** Add window to Window menu. The action title is the window title
* and the action should raise, unminimize and activate the window. */
virtual void addWindow( QAction *action ) = 0;
/** Remove window from Window menu. Calling this is necessary only for
* windows which are hidden rather than deleted when closed. */
virtual void removeWindow( QAction *action ) = 0;
+ // TODO: is this deprecated in favour of QgsContextHelp?
+ /** Open a url in the users browser. By default the QGIS doc directory is used
+ * as the base for the URL. To open a URL that is not relative to the installed
+ * QGIS documentation, set useQgisDocDirectory to false.
+ * @param url URL to open
+ * @param useQgisDocDirectory If true, the URL will be formed by concatenating
+ * url to the QGIS documentation directory path (<prefix>/share/doc)
+ virtual void openURL( QString url, bool useQgisDocDirectory = true ) = 0;
/** Accessors for inserting items into menus and toolbars.
* An item can be inserted before any existing action.
@@ -257,7 +266,7 @@
#ifdef WIN32
# define QGISEXTERN extern "C" __declspec( dllexport )
# ifdef _MSC_VER
-// do not warn about C bindings returing QString
+// do not warn about C bindings returning QString
# pragma warning(disable:4190)
# endif
#else
