[QGIS Commit] r9577 - trunk/qgis/src/plugins/grass/modules
svn_qgis at osgeo.org
Fri Nov 7 14:27:19 EST 2008
Author: pcav
Date: 2008-11-07 14:27:18 -0500 (Fri, 07 Nov 2008)
New Revision: 9577
trunk/qgis/src/plugins/grass/modules/db.connect.qgm
trunk/qgis/src/plugins/grass/modules/db.connect.schema.qgm
trunk/qgis/src/plugins/grass/modules/db.select.qgm
trunk/qgis/src/plugins/grass/modules/i.in.spotvgt.qgm
trunk/qgis/src/plugins/grass/modules/r.average.qgm
trunk/qgis/src/plugins/grass/modules/r.basins.fill.qgm
trunk/qgis/src/plugins/grass/modules/r.bilinear.qgm
trunk/qgis/src/plugins/grass/modules/r.category.qgm
trunk/qgis/src/plugins/grass/modules/r.coin.qgm
trunk/qgis/src/plugins/grass/modules/r.contour.qgm
trunk/qgis/src/plugins/grass/modules/r.contour2.qgm
trunk/qgis/src/plugins/grass/modules/r.covar.qgm
trunk/qgis/src/plugins/grass/modules/r.cross.qgm
trunk/qgis/src/plugins/grass/modules/r.describe.qgm
trunk/qgis/src/plugins/grass/modules/r.grow.qgm
trunk/qgis/src/plugins/grass/modules/r.his.qgm
trunk/qgis/src/plugins/grass/modules/r.in.aster.qgm
trunk/qgis/src/plugins/grass/modules/r.in.gdal.loc.qgm
trunk/qgis/src/plugins/grass/modules/r.in.gdal.qgm
trunk/qgis/src/plugins/grass/modules/r.median.qgm
trunk/qgis/src/plugins/grass/modules/r.mode.qgm
trunk/qgis/src/plugins/grass/modules/r.out.pov.qgm
trunk/qgis/src/plugins/grass/modules/r.reclass.area.greater.qgm
trunk/qgis/src/plugins/grass/modules/r.reclass.area.lesser.qgm
trunk/qgis/src/plugins/grass/modules/r.reclass.area.qgm
trunk/qgis/src/plugins/grass/modules/r.report.qgm
trunk/qgis/src/plugins/grass/modules/r.resamp.interp.qgm
trunk/qgis/src/plugins/grass/modules/r.resamp.stats.qgm
trunk/qgis/src/plugins/grass/modules/r.resample.qgm
trunk/qgis/src/plugins/grass/modules/r.rescale.qgm
trunk/qgis/src/plugins/grass/modules/r.series.qgm
trunk/qgis/src/plugins/grass/modules/r.support.qgm
trunk/qgis/src/plugins/grass/modules/r.surf.gauss.qgm
trunk/qgis/src/plugins/grass/modules/r.surf.idw.qgm
trunk/qgis/src/plugins/grass/modules/r.surf.random.qgm
trunk/qgis/src/plugins/grass/modules/r.transect.qgm
trunk/qgis/src/plugins/grass/modules/r.what.qgm
trunk/qgis/src/plugins/grass/modules/v.db.join.qgm
trunk/qgis/src/plugins/grass/modules/v.db.update_const.qgm
trunk/qgis/src/plugins/grass/modules/v.db.update_op.qgm
trunk/qgis/src/plugins/grass/modules/v.db.update_op_query.qgm
trunk/qgis/src/plugins/grass/modules/v.db.update_query.qgm
trunk/qgis/src/plugins/grass/modules/v.proj.qgm
More cleaning up of GRASS modules descriptions
Modified: trunk/qgis/src/plugins/grass/modules/db.connect.qgm
--- trunk/qgis/src/plugins/grass/modules/db.connect.qgm 2008-11-07 18:41:36 UTC (rev 9576)
+++ trunk/qgis/src/plugins/grass/modules/db.connect.qgm 2008-11-07 19:27:18 UTC (rev 9577)
@@ -1,7 +1,7 @@
<!DOCTYPE qgisgrassmodule SYSTEM "http://mrcc.com/qgisgrassmodule.dtd">
-<qgisgrassmodule label="Sets general DB connection mapset" module="db.connect">
+<qgisgrassmodule label="Set general DB connection" module="db.connect">
<option key="driver" answer="dbf" hidden="no"/>
<option key="database" answer="$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/" hidden="no"/>
</qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/db.connect.schema.qgm
--- trunk/qgis/src/plugins/grass/modules/db.connect.schema.qgm 2008-11-07 18:41:36 UTC (rev 9576)
+++ trunk/qgis/src/plugins/grass/modules/db.connect.schema.qgm 2008-11-07 19:27:18 UTC (rev 9577)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Sets general DB connection mapset with a schema" module="db.connect">
+<qgisgrassmodule label="Set general DB connection with a schema" module="db.connect">
<option key="schema" answer=" " hidden="no"/>
Modified: trunk/qgis/src/plugins/grass/modules/db.select.qgm
--- trunk/qgis/src/plugins/grass/modules/db.select.qgm 2008-11-07 18:41:36 UTC (rev 9576)
+++ trunk/qgis/src/plugins/grass/modules/db.select.qgm 2008-11-07 19:27:18 UTC (rev 9577)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Prints result of selection from database based on SQL" module="db.select">
+<qgisgrassmodule label="Print result of SQL selection from database" module="db.select">
<option key="table" />
<option key="database" answer="$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/" />
<option key="driver" />
Modified: trunk/qgis/src/plugins/grass/modules/i.in.spotvgt.qgm
--- trunk/qgis/src/plugins/grass/modules/i.in.spotvgt.qgm 2008-11-07 18:41:36 UTC (rev 9576)
+++ trunk/qgis/src/plugins/grass/modules/i.in.spotvgt.qgm 2008-11-07 19:27:18 UTC (rev 9577)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Import of SPOT VGT NDVI file into a raster map" module="i.in.spotvgt">
+<qgisgrassmodule label="Import SPOT VGT NDVI into raster" module="i.in.spotvgt">
<file key="file" type="new" />
<flag key="a" />
<option key="rast" />
Modified: trunk/qgis/src/plugins/grass/modules/r.average.qgm
--- trunk/qgis/src/plugins/grass/modules/r.average.qgm 2008-11-07 18:41:36 UTC (rev 9576)
+++ trunk/qgis/src/plugins/grass/modules/r.average.qgm 2008-11-07 19:27:18 UTC (rev 9577)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Finds the average of values in a cover map within areas assigned the same category value in a user-specified base map" module="r.average">
+<qgisgrassmodule label="Find average values in a cover map within areas with the same category in a user-defined base map" module="r.average">
<option key="base" />
<option key="cover" />
<flag key="c" />
Modified: trunk/qgis/src/plugins/grass/modules/r.basins.fill.qgm
--- trunk/qgis/src/plugins/grass/modules/r.basins.fill.qgm 2008-11-07 18:41:36 UTC (rev 9576)
+++ trunk/qgis/src/plugins/grass/modules/r.basins.fill.qgm 2008-11-07 19:27:18 UTC (rev 9577)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Generates a raster map layer showing watershed subbasins" module="r.basins.fill">
+<qgisgrassmodule label="Generate raster showing watershed subbasins" module="r.basins.fill">
<option key="number" />
<option key="c_map" />
<option key="t_map" />
Modified: trunk/qgis/src/plugins/grass/modules/r.bilinear.qgm
--- trunk/qgis/src/plugins/grass/modules/r.bilinear.qgm 2008-11-07 18:41:36 UTC (rev 9576)
+++ trunk/qgis/src/plugins/grass/modules/r.bilinear.qgm 2008-11-07 19:27:18 UTC (rev 9577)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Bilinear interpolation utility for raster map layers" module="r.bilinear">
+<qgisgrassmodule label="Bilinear interpolation utility for rasters" module="r.bilinear">
<option key="input" />
<option key="output" />
</qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/r.category.qgm
--- trunk/qgis/src/plugins/grass/modules/r.category.qgm 2008-11-07 18:41:36 UTC (rev 9576)
+++ trunk/qgis/src/plugins/grass/modules/r.category.qgm 2008-11-07 19:27:18 UTC (rev 9577)
@@ -1,6 +1,6 @@
-<qgisgrassmodule label="Prints category values and labels associated with user-specified raster map layers" module="r.category">
+<qgisgrassmodule label="Print category values and labels associated with user-defined rasters" module="r.category">
<option key="map" />
</qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/r.coin.qgm
--- trunk/qgis/src/plugins/grass/modules/r.coin.qgm 2008-11-07 18:41:36 UTC (rev 9576)
+++ trunk/qgis/src/plugins/grass/modules/r.coin.qgm 2008-11-07 19:27:18 UTC (rev 9577)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Tabulates the mutual occurrence (coincidence) of categories for two raster map layers" module="r.coin">
+<qgisgrassmodule label="Tabulates the mutual occurrence (coincidence) of categories for two rasters" module="r.coin">
<option key="map1" />
<option key="map2" />
<option key="units" />
Modified: trunk/qgis/src/plugins/grass/modules/r.contour.qgm
--- trunk/qgis/src/plugins/grass/modules/r.contour.qgm 2008-11-07 18:41:36 UTC (rev 9576)
+++ trunk/qgis/src/plugins/grass/modules/r.contour.qgm 2008-11-07 19:27:18 UTC (rev 9577)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Produces a contours vector map with specified step from a raster map" module="r.contour">
+<qgisgrassmodule label="Produce contour vector at specified step from raster" module="r.contour">
<option key="step"/>
<option key="minlevel" answer="0" hidden="no"/>
Modified: trunk/qgis/src/plugins/grass/modules/r.contour2.qgm
--- trunk/qgis/src/plugins/grass/modules/r.contour2.qgm 2008-11-07 18:41:36 UTC (rev 9576)
+++ trunk/qgis/src/plugins/grass/modules/r.contour2.qgm 2008-11-07 19:27:18 UTC (rev 9577)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Produces a contours vector map of specified contours from a raster map" module="r.contour">
+<qgisgrassmodule label="Produce contour vector at specified levels from raster" module="r.contour">
<option key="levels" />
Modified: trunk/qgis/src/plugins/grass/modules/r.covar.qgm
--- trunk/qgis/src/plugins/grass/modules/r.covar.qgm 2008-11-07 18:41:36 UTC (rev 9576)
+++ trunk/qgis/src/plugins/grass/modules/r.covar.qgm 2008-11-07 19:27:18 UTC (rev 9577)
@@ -1,6 +1,6 @@
-<qgisgrassmodule label="Outputs a covariance/correlation matrix for user-specified raster map layer(s)" module="r.covar">
+<qgisgrassmodule label="Output covariance/correlation matrix for user-defined raster(s)" module="r.covar">
</qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/r.cross.qgm
--- trunk/qgis/src/plugins/grass/modules/r.cross.qgm 2008-11-07 18:41:36 UTC (rev 9576)
+++ trunk/qgis/src/plugins/grass/modules/r.cross.qgm 2008-11-07 19:27:18 UTC (rev 9577)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Create a cross product of the category value from multiple raster map layers" module="r.cross">
+<qgisgrassmodule label="Create cross product of category values from multiple rasters" module="r.cross">
<flag key="z" answer="off" hidden="no" />
<file key="input" label="Type in map names separated by a comma" />
Modified: trunk/qgis/src/plugins/grass/modules/r.describe.qgm
--- trunk/qgis/src/plugins/grass/modules/r.describe.qgm 2008-11-07 18:41:36 UTC (rev 9576)
+++ trunk/qgis/src/plugins/grass/modules/r.describe.qgm 2008-11-07 19:27:18 UTC (rev 9577)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Prints terse list of category values found in a raster map layer" module="r.describe">
+<qgisgrassmodule label="Print list of category values found in raster" module="r.describe">
<flag key="1" />
<flag key="r" />
<flag key="d" />
Modified: trunk/qgis/src/plugins/grass/modules/r.grow.qgm
--- trunk/qgis/src/plugins/grass/modules/r.grow.qgm 2008-11-07 18:41:36 UTC (rev 9576)
+++ trunk/qgis/src/plugins/grass/modules/r.grow.qgm 2008-11-07 19:27:18 UTC (rev 9577)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Generates a raster map layer with contiguous areas grown by one cell" module="r.grow">
+<qgisgrassmodule label="Generate raster with contiguous areas grown by one cell" module="r.grow">
<option key="input"/>
<option key="new"/>
<option key="metric"/>
Modified: trunk/qgis/src/plugins/grass/modules/r.his.qgm
--- trunk/qgis/src/plugins/grass/modules/r.his.qgm 2008-11-07 18:41:36 UTC (rev 9576)
+++ trunk/qgis/src/plugins/grass/modules/r.his.qgm 2008-11-07 19:27:18 UTC (rev 9577)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Generates red, green and blue raster map layers combining hue, intensity, and saturation (his) values from user-specified input raster map layers" module="r.his">
+<qgisgrassmodule label="Generate red, green and blue raster map layers combining hue, intensity, and saturation (his) values from user-defined input rasters" module="r.his">
<option key="h_map"/>
<option key="i_map"/>
<option key="s_map"/>
Modified: trunk/qgis/src/plugins/grass/modules/r.in.aster.qgm
--- trunk/qgis/src/plugins/grass/modules/r.in.aster.qgm 2008-11-07 18:41:36 UTC (rev 9576)
+++ trunk/qgis/src/plugins/grass/modules/r.in.aster.qgm 2008-11-07 19:27:18 UTC (rev 9577)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Georeferencing, rectification, and import of Terra-ASTER imagery and relative DEM's using gdalwarp" module="r.in.aster">
+<qgisgrassmodule label="Georeferencing, rectification, and import Terra-ASTER imagery and DEM using gdalwarp" module="r.in.aster">
<file key="input" type="old" />
<option key="proctype" />
<option key="band" />
Modified: trunk/qgis/src/plugins/grass/modules/r.in.gdal.loc.qgm
--- trunk/qgis/src/plugins/grass/modules/r.in.gdal.loc.qgm 2008-11-07 18:41:36 UTC (rev 9576)
+++ trunk/qgis/src/plugins/grass/modules/r.in.gdal.loc.qgm 2008-11-07 19:27:18 UTC (rev 9577)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Import GDAL supported raster file into a binary raster map layer and create a fitted location" module="r.in.gdal">
+<qgisgrassmodule label="Import GDAL supported raster into GRASS raster and create fitted location" module="r.in.gdal">
<flag key="o" answer="off" hidden="yes" />
<flag key="e" answer="on" hidden="yes" />
<file key="input" />
Modified: trunk/qgis/src/plugins/grass/modules/r.in.gdal.qgm
--- trunk/qgis/src/plugins/grass/modules/r.in.gdal.qgm 2008-11-07 18:41:36 UTC (rev 9576)
+++ trunk/qgis/src/plugins/grass/modules/r.in.gdal.qgm 2008-11-07 19:27:18 UTC (rev 9577)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Import GDAL supported raster file into a binary raster map layer" module="r.in.gdal">
+<qgisgrassmodule label="Import GDAL supported raster file into GRASS raster" module="r.in.gdal">
<flag key="o" answer="on" hidden="yes" />
<flag key="e" answer="off" hidden="yes" />
Modified: trunk/qgis/src/plugins/grass/modules/r.median.qgm
--- trunk/qgis/src/plugins/grass/modules/r.median.qgm 2008-11-07 18:41:36 UTC (rev 9576)
+++ trunk/qgis/src/plugins/grass/modules/r.median.qgm 2008-11-07 19:27:18 UTC (rev 9577)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Finds the median of values in a cover map within areas assigned the same category value in a user-specified base map" module="r.median">
+<qgisgrassmodule label="Find median of values in a cover map within areas with the same category in a user-defined base map" module="r.median">
Modified: trunk/qgis/src/plugins/grass/modules/r.mode.qgm
--- trunk/qgis/src/plugins/grass/modules/r.mode.qgm 2008-11-07 18:41:36 UTC (rev 9576)
+++ trunk/qgis/src/plugins/grass/modules/r.mode.qgm 2008-11-07 19:27:18 UTC (rev 9577)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Finds the mode of values in a cover map within areas assigned the same category value in a user-specified base map.reproject raster image" module="r.mode">
+<qgisgrassmodule label="Find the mode of values in a cover map within areas with the same category in a user-defined base map" module="r.mode">
Modified: trunk/qgis/src/plugins/grass/modules/r.out.pov.qgm
--- trunk/qgis/src/plugins/grass/modules/r.out.pov.qgm 2008-11-07 18:41:36 UTC (rev 9576)
+++ trunk/qgis/src/plugins/grass/modules/r.out.pov.qgm 2008-11-07 19:27:18 UTC (rev 9577)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Converts a raster map layer into a height-field file for POVRAY" module="r.out.pov">
+<qgisgrassmodule label="Convert GRASS raster into POVRAY height-field file" module="r.out.pov">
<option key="hftype" />
<option key="bias" />
Modified: trunk/qgis/src/plugins/grass/modules/r.reclass.area.greater.qgm
--- trunk/qgis/src/plugins/grass/modules/r.reclass.area.greater.qgm 2008-11-07 18:41:36 UTC (rev 9576)
+++ trunk/qgis/src/plugins/grass/modules/r.reclass.area.greater.qgm 2008-11-07 19:27:18 UTC (rev 9577)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Reclasses a raster map greater than user specified area size (in hectares)" module="r.reclass.area">
+<qgisgrassmodule label="Reclassify raster map with patches larger than user-defined area size (in hectares)" module="r.reclass.area">
<option key="greater" />
Modified: trunk/qgis/src/plugins/grass/modules/r.reclass.area.lesser.qgm
--- trunk/qgis/src/plugins/grass/modules/r.reclass.area.lesser.qgm 2008-11-07 18:41:36 UTC (rev 9576)
+++ trunk/qgis/src/plugins/grass/modules/r.reclass.area.lesser.qgm 2008-11-07 19:27:18 UTC (rev 9577)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Reclasses a raster map less than user specified area size (in hectares)" module="r.reclass.area">
+<qgisgrassmodule label="Reclassify raster map with patches smaller than user-defined area size (in hectares)" module="r.reclass.area">
<option key="lesser" />
Modified: trunk/qgis/src/plugins/grass/modules/r.reclass.area.qgm
--- trunk/qgis/src/plugins/grass/modules/r.reclass.area.qgm 2008-11-07 18:41:36 UTC (rev 9576)
+++ trunk/qgis/src/plugins/grass/modules/r.reclass.area.qgm 2008-11-07 19:27:18 UTC (rev 9577)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Reclasses a raster map greater or less than user specified area size (in hectares)" module="r.reclass.area">
+<qgisgrassmodule label="Reclassify raster greater or less than user-defined area size (in hectares)" module="r.reclass.area">
Modified: trunk/qgis/src/plugins/grass/modules/r.report.qgm
--- trunk/qgis/src/plugins/grass/modules/r.report.qgm 2008-11-07 18:41:36 UTC (rev 9576)
+++ trunk/qgis/src/plugins/grass/modules/r.report.qgm 2008-11-07 19:27:18 UTC (rev 9577)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Reports statistics for raster map layers" module="r.report">
+<qgisgrassmodule label="Reports statistics for raster" module="r.report">
<option key="units"/>
</qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/r.resamp.interp.qgm
--- trunk/qgis/src/plugins/grass/modules/r.resamp.interp.qgm 2008-11-07 18:41:36 UTC (rev 9576)
+++ trunk/qgis/src/plugins/grass/modules/r.resamp.interp.qgm 2008-11-07 19:27:18 UTC (rev 9577)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Resamples raster map layers using interpolation" module="r.resamp.interp">
+<qgisgrassmodule label="Resample raster using interpolation" module="r.resamp.interp">
<option key="method" />
Modified: trunk/qgis/src/plugins/grass/modules/r.resamp.stats.qgm
--- trunk/qgis/src/plugins/grass/modules/r.resamp.stats.qgm 2008-11-07 18:41:36 UTC (rev 9576)
+++ trunk/qgis/src/plugins/grass/modules/r.resamp.stats.qgm 2008-11-07 19:27:18 UTC (rev 9577)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Resamples raster map layers using aggregation" module="r.resamp.stats">
+<qgisgrassmodule label="Resamples raster using aggregation" module="r.resamp.stats">
Modified: trunk/qgis/src/plugins/grass/modules/r.resample.qgm
--- trunk/qgis/src/plugins/grass/modules/r.resample.qgm 2008-11-07 18:41:36 UTC (rev 9576)
+++ trunk/qgis/src/plugins/grass/modules/r.resample.qgm 2008-11-07 19:27:18 UTC (rev 9577)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="GRASS raster map layer data resampling capability. Before you must set new resolution" module="r.resample">
+<qgisgrassmodule label="Raster data resampling. Set new resolution first" module="r.resample">
<option key="output"/>
</qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/r.rescale.qgm
--- trunk/qgis/src/plugins/grass/modules/r.rescale.qgm 2008-11-07 18:41:36 UTC (rev 9576)
+++ trunk/qgis/src/plugins/grass/modules/r.rescale.qgm 2008-11-07 19:27:18 UTC (rev 9577)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Rescales the range of category values in a raster map layer" module="r.rescale">
+<qgisgrassmodule label="Rescale the range of category values in a raster" module="r.rescale">
<option key="from" />
<option key="to" />
Modified: trunk/qgis/src/plugins/grass/modules/r.series.qgm
--- trunk/qgis/src/plugins/grass/modules/r.series.qgm 2008-11-07 18:41:36 UTC (rev 9576)
+++ trunk/qgis/src/plugins/grass/modules/r.series.qgm 2008-11-07 19:27:18 UTC (rev 9577)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Makes each output cell a function of the values assigned to the corresponding cells in the input raster map layers" module="r.series">
+<qgisgrassmodule label="Make each output cell function of the values assigned to the corresponding cells in the input rasters" module="r.series">
<flag key="n" answer="off" hidden="no" />
Modified: trunk/qgis/src/plugins/grass/modules/r.support.qgm
--- trunk/qgis/src/plugins/grass/modules/r.support.qgm 2008-11-07 18:41:36 UTC (rev 9576)
+++ trunk/qgis/src/plugins/grass/modules/r.support.qgm 2008-11-07 19:27:18 UTC (rev 9577)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Allows creation and/or modification of raster map layer support files" module="r.support">
+<qgisgrassmodule label="Create and/or modify raster support files" module="r.support">
<option key="title" />
<option key="history" />
Modified: trunk/qgis/src/plugins/grass/modules/r.surf.gauss.qgm
--- trunk/qgis/src/plugins/grass/modules/r.surf.gauss.qgm 2008-11-07 18:41:36 UTC (rev 9576)
+++ trunk/qgis/src/plugins/grass/modules/r.surf.gauss.qgm 2008-11-07 19:27:18 UTC (rev 9577)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="GRASS module to produce a raster map layer of gaussian deviates whose mean and standard deviation can be expressed by the user" module="r.surf.gauss">
+<qgisgrassmodule label="Produce raster of gaussian deviates with user-defined mean and standard deviation" module="r.surf.gauss">
<option key="mean" />
<option key="sigma" />
Modified: trunk/qgis/src/plugins/grass/modules/r.surf.idw.qgm
--- trunk/qgis/src/plugins/grass/modules/r.surf.idw.qgm 2008-11-07 18:41:36 UTC (rev 9576)
+++ trunk/qgis/src/plugins/grass/modules/r.surf.idw.qgm 2008-11-07 19:27:18 UTC (rev 9577)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Surface interpolation utility for raster map layers" module="r.surf.idw">
+<qgisgrassmodule label="Surface interpolation utility for raster" module="r.surf.idw">
<option key="npoints" />
Modified: trunk/qgis/src/plugins/grass/modules/r.surf.random.qgm
--- trunk/qgis/src/plugins/grass/modules/r.surf.random.qgm 2008-11-07 18:41:36 UTC (rev 9576)
+++ trunk/qgis/src/plugins/grass/modules/r.surf.random.qgm 2008-11-07 19:27:18 UTC (rev 9577)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Produces a raster map layer of uniform random deviates whose range can be expressed by the user" module="r.surf.random">
+<qgisgrassmodule label="Produce raster of uniform random deviates with user-defined range" module="r.surf.random">
<option key="min" />
<option key="max" />
Modified: trunk/qgis/src/plugins/grass/modules/r.transect.qgm
--- trunk/qgis/src/plugins/grass/modules/r.transect.qgm 2008-11-07 18:41:36 UTC (rev 9576)
+++ trunk/qgis/src/plugins/grass/modules/r.transect.qgm 2008-11-07 19:27:18 UTC (rev 9577)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Outputs raster map layer values lying along user defined transect line(s)" module="r.transect">
+<qgisgrassmodule label="Output raster values along user-defined transect line(s)" module="r.transect">
<flag key="g" />
<option key="line" />
Modified: trunk/qgis/src/plugins/grass/modules/r.what.qgm
--- trunk/qgis/src/plugins/grass/modules/r.what.qgm 2008-11-07 18:41:36 UTC (rev 9576)
+++ trunk/qgis/src/plugins/grass/modules/r.what.qgm 2008-11-07 19:27:18 UTC (rev 9577)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Queries raster map layers on their category values and category labels" module="r.what">
+<qgisgrassmodule label="Query rasters on their category values and labels" module="r.what">
<flag key="f" />
<flag key="c" />
<flag key="i" />
Modified: trunk/qgis/src/plugins/grass/modules/v.db.join.qgm
--- trunk/qgis/src/plugins/grass/modules/v.db.join.qgm 2008-11-07 18:41:36 UTC (rev 9576)
+++ trunk/qgis/src/plugins/grass/modules/v.db.join.qgm 2008-11-07 19:27:18 UTC (rev 9577)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Allows to join a table to a vector map table" module="v.db.join">
+<qgisgrassmodule label="Join table to vector table" module="v.db.join">
<option key="map" layeroption="layer" />
<field key="column" layer="map" type="integer,string" label="Attribute field" />
<option key="otable"/>
Modified: trunk/qgis/src/plugins/grass/modules/v.db.update_const.qgm
--- trunk/qgis/src/plugins/grass/modules/v.db.update_const.qgm 2008-11-07 18:41:36 UTC (rev 9576)
+++ trunk/qgis/src/plugins/grass/modules/v.db.update_const.qgm 2008-11-07 19:27:18 UTC (rev 9577)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Allows to assign a new constant value to a column" module="v.db.update">
+<qgisgrassmodule label="Assign a constant value to a column" module="v.db.update">
<field key="column" layer="map" type="integer,double,varchar,string" label="Attribute field" />
<option key="value"/>
Modified: trunk/qgis/src/plugins/grass/modules/v.db.update_op.qgm
--- trunk/qgis/src/plugins/grass/modules/v.db.update_op.qgm 2008-11-07 18:41:36 UTC (rev 9576)
+++ trunk/qgis/src/plugins/grass/modules/v.db.update_op.qgm 2008-11-07 19:27:18 UTC (rev 9577)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Allows to assign a new value, result of operation on column/s, to a column in the attribute table connected to a given map" module="v.db.update">
+<qgisgrassmodule label="Assign a new value, result of operation on column/s, to a column in the attribute table" module="v.db.update">
<option key="qcolumn" />
Modified: trunk/qgis/src/plugins/grass/modules/v.db.update_op_query.qgm
--- trunk/qgis/src/plugins/grass/modules/v.db.update_op_query.qgm 2008-11-07 18:41:36 UTC (rev 9576)
+++ trunk/qgis/src/plugins/grass/modules/v.db.update_op_query.qgm 2008-11-07 19:27:18 UTC (rev 9577)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Allows to assign a new value to a column, result of operation on column/s, only if the result of a query is TRUE" module="v.db.update">
+<qgisgrassmodule label="Assign a new value to a column, result of operation on column/s, only if the result of a query is TRUE" module="v.db.update">
Modified: trunk/qgis/src/plugins/grass/modules/v.db.update_query.qgm
--- trunk/qgis/src/plugins/grass/modules/v.db.update_query.qgm 2008-11-07 18:41:36 UTC (rev 9576)
+++ trunk/qgis/src/plugins/grass/modules/v.db.update_query.qgm 2008-11-07 19:27:18 UTC (rev 9577)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Allows to assign a new constant value to a column only if the result of a query is TRUE" module="v.db.update">
+<qgisgrassmodule label="Assign a new constant value to a column only if the result of a query is TRUE" module="v.db.update">
Modified: trunk/qgis/src/plugins/grass/modules/v.proj.qgm
--- trunk/qgis/src/plugins/grass/modules/v.proj.qgm 2008-11-07 18:41:36 UTC (rev 9576)
+++ trunk/qgis/src/plugins/grass/modules/v.proj.qgm 2008-11-07 19:27:18 UTC (rev 9577)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Allows projection conversion of vector files" module="v.proj">
+<qgisgrassmodule label="Projection conversion of vector" module="v.proj">
<option key="dbase" />
<option key="location" />
