[QGIS Commit] r9579 - trunk/qgis/src/plugins/grass/modules
svn_qgis at osgeo.org svn_qgis at osgeo.org
Fri Nov 7 14:35:50 EST 2008
Author: pcav
Date: 2008-11-07 14:35:50 -0500 (Fri, 07 Nov 2008)
New Revision: 9579
   trunk/qgis/src/plugins/grass/modules/r.out.arc.qgm
   trunk/qgis/src/plugins/grass/modules/r.out.ppm.qgm
   trunk/qgis/src/plugins/grass/modules/r.out.ppm3.qgm
   trunk/qgis/src/plugins/grass/modules/v.out.dxf.qgm
More cleaning
Modified: trunk/qgis/src/plugins/grass/modules/r.out.arc.qgm
--- trunk/qgis/src/plugins/grass/modules/r.out.arc.qgm	2008-11-07 19:32:00 UTC (rev 9578)
+++ trunk/qgis/src/plugins/grass/modules/r.out.arc.qgm	2008-11-07 19:35:50 UTC (rev 9579)
@@ -1,7 +1,7 @@
 <!DOCTYPE qgisgrassmodule SYSTEM "http://mrcc.com/qgisgrassmodule.dtd">
-<qgisgrassmodule label="Converts GRASS raster into ESRI ARCGRID" module="r.out.arc">
+<qgisgrassmodule label="Convert GRASS raster into ESRI ARCGRID" module="r.out.arc">
 	<option key="input" />
 	<option key="dp" answer="2"/>
 	<flag key="h" />
Modified: trunk/qgis/src/plugins/grass/modules/r.out.ppm.qgm
--- trunk/qgis/src/plugins/grass/modules/r.out.ppm.qgm	2008-11-07 19:32:00 UTC (rev 9578)
+++ trunk/qgis/src/plugins/grass/modules/r.out.ppm.qgm	2008-11-07 19:35:50 UTC (rev 9579)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Converts a GRASS raster map to a PPM image file at the pixel resolution of the CURRENTLY DEFINED REGION" module="r.out.ppm">
+<qgisgrassmodule label="Convert GRASS raster to PPM image at the resolution of the current region" module="r.out.ppm">
 	<flag key="G" />
 	<file key="output" type="new" />
Modified: trunk/qgis/src/plugins/grass/modules/r.out.ppm3.qgm
--- trunk/qgis/src/plugins/grass/modules/r.out.ppm3.qgm	2008-11-07 19:32:00 UTC (rev 9578)
+++ trunk/qgis/src/plugins/grass/modules/r.out.ppm3.qgm	2008-11-07 19:35:50 UTC (rev 9579)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel resolution of the CURRENTLY DEFINED REGION" module="r.out.ppm3">
+<qgisgrassmodule label="Convert 3 GRASS rasters (R,G,B) to PPM image at the resolution of the current region" module="r.out.ppm3">
 	<flag key="c" hidden="yes" />
 	<option key="red" />
 	<option key="green" />
Modified: trunk/qgis/src/plugins/grass/modules/v.out.dxf.qgm
--- trunk/qgis/src/plugins/grass/modules/v.out.dxf.qgm	2008-11-07 19:32:00 UTC (rev 9578)
+++ trunk/qgis/src/plugins/grass/modules/v.out.dxf.qgm	2008-11-07 19:35:50 UTC (rev 9579)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Converts GRASS vector to DXF" module="v.out.dxf">
+<qgisgrassmodule label="Convert GRASS vector to DXF" module="v.out.dxf">
 	<file key="output" type="new" filters="DXF (*.dxf)"/>
 </qgisgrassmodule>
More information about the QGIS-commit mailing list
