[QGIS Commit] r9584 - trunk/qgis/src/plugins/grass/modules
svn_qgis at osgeo.org
Sat Nov 8 03:28:43 EST 2008
Author: pcav
Date: 2008-11-08 03:28:42 -0500 (Sat, 08 Nov 2008)
New Revision: 9584
trunk/qgis/src/plugins/grass/modules/i.fusion.brovey.qgm
trunk/qgis/src/plugins/grass/modules/i.rgb.his.qgm
trunk/qgis/src/plugins/grass/modules/m.cogo.qgm
trunk/qgis/src/plugins/grass/modules/r.colors.rules.qgm
trunk/qgis/src/plugins/grass/modules/r.his.qgm
trunk/qgis/src/plugins/grass/modules/r.in.arc.qgm
trunk/qgis/src/plugins/grass/modules/r.in.ascii.qgm
trunk/qgis/src/plugins/grass/modules/r.in.gridatb.qgm
trunk/qgis/src/plugins/grass/modules/r.lake.qgm
trunk/qgis/src/plugins/grass/modules/r.lake.xy.qgm
trunk/qgis/src/plugins/grass/modules/r.neighbors.qgm
trunk/qgis/src/plugins/grass/modules/r.out.arc.qgm
trunk/qgis/src/plugins/grass/modules/r.out.bin.qgm
trunk/qgis/src/plugins/grass/modules/r.out.gdal.gtiff.qgm
trunk/qgis/src/plugins/grass/modules/r.out.gridatb.qgm
trunk/qgis/src/plugins/grass/modules/r.out.mat.qgm
trunk/qgis/src/plugins/grass/modules/r.out.png.qgm
trunk/qgis/src/plugins/grass/modules/r.out.pov.qgm
trunk/qgis/src/plugins/grass/modules/r.out.ppm.qgm
trunk/qgis/src/plugins/grass/modules/r.out.ppm3.qgm
trunk/qgis/src/plugins/grass/modules/r.out.tiff.qgm
trunk/qgis/src/plugins/grass/modules/r.out.vrml.qgm
trunk/qgis/src/plugins/grass/modules/r.out.xyz.qgm
trunk/qgis/src/plugins/grass/modules/r.reclass.file.qgm
trunk/qgis/src/plugins/grass/modules/r.reclass.qgm
trunk/qgis/src/plugins/grass/modules/r.resamp.rst.qgm
trunk/qgis/src/plugins/grass/modules/r.slope.aspect.slope.qgm
trunk/qgis/src/plugins/grass/modules/r.to.vect.area.qgm
trunk/qgis/src/plugins/grass/modules/r.volume.qgm
trunk/qgis/src/plugins/grass/modules/v.clean.break.qgm
trunk/qgis/src/plugins/grass/modules/v.db.univar.qgm
trunk/qgis/src/plugins/grass/modules/v.in.e00.qgm
trunk/qgis/src/plugins/grass/modules/v.out.dxf.qgm
trunk/qgis/src/plugins/grass/modules/v.random.qgm
trunk/qgis/src/plugins/grass/modules/v.rast.stats.qgm
trunk/qgis/src/plugins/grass/modules/v.reclass.file.qgm
trunk/qgis/src/plugins/grass/modules/v.to.rast.attr.qgm
trunk/qgis/src/plugins/grass/modules/v.to.rast.constant.qgm
trunk/qgis/src/plugins/grass/modules/v.univar.qgm
trunk/qgis/src/plugins/grass/modules/v.what.rast.qgm
Further cleanup of GRASS modules, according to http://wiki.qgis.org/qgiswiki/Adding_New_Tools_to_the_GRASS_Toolbox
Fixes https://trac.osgeo.org/qgis/ticket/1363
Modified: trunk/qgis/src/plugins/grass/modules/i.fusion.brovey.qgm
--- trunk/qgis/src/plugins/grass/modules/i.fusion.brovey.qgm 2008-11-08 00:57:53 UTC (rev 9583)
+++ trunk/qgis/src/plugins/grass/modules/i.fusion.brovey.qgm 2008-11-08 08:28:42 UTC (rev 9584)
@@ -1,7 +1,7 @@
<!DOCTYPE qgisgrassmodule SYSTEM "http://mrcc.com/qgisgrassmodule.dtd">
-<qgisgrassmodule label="Brovey transform to merge multispectral and high-res pancromatic channels" module="i.fusion.brovey">
+<qgisgrassmodule label="Brovey transform to merge multispectral and high-res panchromatic channels" module="i.fusion.brovey">
<flag key="l" />
<flag key="q" />
<flag key="s" />
Modified: trunk/qgis/src/plugins/grass/modules/i.rgb.his.qgm
--- trunk/qgis/src/plugins/grass/modules/i.rgb.his.qgm 2008-11-08 00:57:53 UTC (rev 9583)
+++ trunk/qgis/src/plugins/grass/modules/i.rgb.his.qgm 2008-11-08 08:28:42 UTC (rev 9584)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Red Green Blue (RGB) to Hue Intensity Saturation (HIS) raster map color transformation function" module="i.rgb.his">
+<qgisgrassmodule label="Red Green Blue (RGB) to Hue Intensity Saturation (HIS) raster color transformation function" module="i.rgb.his">
<option key="red_input" />
<option key="green_input" />
<option key="blue_input" />
Modified: trunk/qgis/src/plugins/grass/modules/m.cogo.qgm
--- trunk/qgis/src/plugins/grass/modules/m.cogo.qgm 2008-11-08 00:57:53 UTC (rev 9583)
+++ trunk/qgis/src/plugins/grass/modules/m.cogo.qgm 2008-11-08 08:28:42 UTC (rev 9584)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="A simple utility for converting bearing and distance measurements to coordinates and vice versa. It assumes a cartesian coordinate system" module="m.cogo">
+<qgisgrassmodule label="Converting bearing and distance measurements to coordinates and vice versa" module="m.cogo">
<file key="input" type="old" />
<option key="coord" />
<flag key="r" />
Modified: trunk/qgis/src/plugins/grass/modules/r.colors.rules.qgm
--- trunk/qgis/src/plugins/grass/modules/r.colors.rules.qgm 2008-11-08 00:57:53 UTC (rev 9583)
+++ trunk/qgis/src/plugins/grass/modules/r.colors.rules.qgm 2008-11-08 08:28:42 UTC (rev 9584)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Set raster color table from setted rules" module="r.colors">
+<qgisgrassmodule label="Set raster color table from user-defined rules" module="r.colors">
<option key="map" update="yes" />
<file key="rules" type="old" />
</qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/r.his.qgm
--- trunk/qgis/src/plugins/grass/modules/r.his.qgm 2008-11-08 00:57:53 UTC (rev 9583)
+++ trunk/qgis/src/plugins/grass/modules/r.his.qgm 2008-11-08 08:28:42 UTC (rev 9584)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Generate red, green and blue raster map layers combining hue, intensity, and saturation (his) values from user-defined input rasters" module="r.his">
+<qgisgrassmodule label="Generate red, green and blue rasters combining hue, intensity, and saturation (his) values from user-defined input rasters" module="r.his">
<option key="h_map"/>
<option key="i_map"/>
<option key="s_map"/>
Modified: trunk/qgis/src/plugins/grass/modules/r.in.arc.qgm
--- trunk/qgis/src/plugins/grass/modules/r.in.arc.qgm 2008-11-08 00:57:53 UTC (rev 9583)
+++ trunk/qgis/src/plugins/grass/modules/r.in.arc.qgm 2008-11-08 08:28:42 UTC (rev 9584)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Convert ESRI ARC/INFO ascii raster (GRID) into a GRASS raster" module="r.in.arc">
+<qgisgrassmodule label="Import ESRI ARC/INFO ASCII raster (GRID) into GRASS raster" module="r.in.arc">
<option key="type" />
<option key="mult" />
Modified: trunk/qgis/src/plugins/grass/modules/r.in.ascii.qgm
--- trunk/qgis/src/plugins/grass/modules/r.in.ascii.qgm 2008-11-08 00:57:53 UTC (rev 9583)
+++ trunk/qgis/src/plugins/grass/modules/r.in.ascii.qgm 2008-11-08 08:28:42 UTC (rev 9584)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Convert ASCII raster into GRASS raster" module="r.in.ascii">
+<qgisgrassmodule label="Import ASCII raster into GRASS raster" module="r.in.ascii">
<option key="nv" />
Modified: trunk/qgis/src/plugins/grass/modules/r.in.gridatb.qgm
--- trunk/qgis/src/plugins/grass/modules/r.in.gridatb.qgm 2008-11-08 00:57:53 UTC (rev 9583)
+++ trunk/qgis/src/plugins/grass/modules/r.in.gridatb.qgm 2008-11-08 08:28:42 UTC (rev 9584)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Imports GRIDATB.FOR map file (TOPMODEL) into GRASS raster map" module="r.in.gridatb">
+<qgisgrassmodule label="Import GRIDATB.FOR map file (TOPMODEL) into GRASS raster" module="r.in.gridatb">
<option key="output" />
</qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/r.lake.qgm
--- trunk/qgis/src/plugins/grass/modules/r.lake.qgm 2008-11-08 00:57:53 UTC (rev 9583)
+++ trunk/qgis/src/plugins/grass/modules/r.lake.qgm 2008-11-08 08:28:42 UTC (rev 9584)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Fills lake from seed at given level" module="r.lake">
+<qgisgrassmodule label="Fill lake from seed at given level" module="r.lake">
<option key="dem" />
<option key="wl" />
<option key="xy" />
Modified: trunk/qgis/src/plugins/grass/modules/r.lake.xy.qgm
--- trunk/qgis/src/plugins/grass/modules/r.lake.xy.qgm 2008-11-08 00:57:53 UTC (rev 9583)
+++ trunk/qgis/src/plugins/grass/modules/r.lake.xy.qgm 2008-11-08 08:28:42 UTC (rev 9584)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Fills lake from seed point at given level" module="r.lake">
+<qgisgrassmodule label="Fill lake from seed point at given level" module="r.lake">
<option key="xy" />
<option key="wl" />
Modified: trunk/qgis/src/plugins/grass/modules/r.neighbors.qgm
--- trunk/qgis/src/plugins/grass/modules/r.neighbors.qgm 2008-11-08 00:57:53 UTC (rev 9583)
+++ trunk/qgis/src/plugins/grass/modules/r.neighbors.qgm 2008-11-08 08:28:42 UTC (rev 9584)
@@ -2,7 +2,7 @@
<!-- TODO: this is bad -->
-<qgisgrassmodule label="Raster neighbors analyses" module="r.neighbors">
+<qgisgrassmodule label="Raster neighbors analysis" module="r.neighbors">
<option key="input"/>
<option key="method"/>
<option key="size"/>
Modified: trunk/qgis/src/plugins/grass/modules/r.out.arc.qgm
--- trunk/qgis/src/plugins/grass/modules/r.out.arc.qgm 2008-11-08 00:57:53 UTC (rev 9583)
+++ trunk/qgis/src/plugins/grass/modules/r.out.arc.qgm 2008-11-08 08:28:42 UTC (rev 9584)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Convert GRASS raster into ESRI ARCGRID" module="r.out.arc">
+<qgisgrassmodule label="Export raster into ESRI ARCGRID" module="r.out.arc">
<option key="input" />
<option key="dp" answer="2"/>
<flag key="h" />
Modified: trunk/qgis/src/plugins/grass/modules/r.out.bin.qgm
--- trunk/qgis/src/plugins/grass/modules/r.out.bin.qgm 2008-11-08 00:57:53 UTC (rev 9583)
+++ trunk/qgis/src/plugins/grass/modules/r.out.bin.qgm 2008-11-08 08:28:42 UTC (rev 9584)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Export GRASS raster to binary array" module="r.out.bin">
+<qgisgrassmodule label="Export raster to binary array" module="r.out.bin">
<option key="null" />
<flag key="h" />
Modified: trunk/qgis/src/plugins/grass/modules/r.out.gdal.gtiff.qgm
--- trunk/qgis/src/plugins/grass/modules/r.out.gdal.gtiff.qgm 2008-11-08 00:57:53 UTC (rev 9583)
+++ trunk/qgis/src/plugins/grass/modules/r.out.gdal.gtiff.qgm 2008-11-08 08:28:42 UTC (rev 9584)
@@ -4,6 +4,6 @@
<qgisgrassmodule label="Export raster to Geo TIFF" module="r.out.gdal">
<option key="input" region="no"/>
<option key="format" answer="GTiff" hidden="yes" />
- <option key="type" />
+ <option key="type" label="Choose appropriate format"/>
<file key="output" type="new" filters="Geo TIFF (*.tif *.tiff)" />
</qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/r.out.gridatb.qgm
--- trunk/qgis/src/plugins/grass/modules/r.out.gridatb.qgm 2008-11-08 00:57:53 UTC (rev 9583)
+++ trunk/qgis/src/plugins/grass/modules/r.out.gridatb.qgm 2008-11-08 08:28:42 UTC (rev 9584)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Export GRASS raster to GRIDATB.FOR map file (TOPMODEL)" module="r.out.gridatb">
+<qgisgrassmodule label="Export raster to GRIDATB.FOR map file (TOPMODEL)" module="r.out.gridatb">
<file key="output" type="new" />
</qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/r.out.mat.qgm
--- trunk/qgis/src/plugins/grass/modules/r.out.mat.qgm 2008-11-08 00:57:53 UTC (rev 9583)
+++ trunk/qgis/src/plugins/grass/modules/r.out.mat.qgm 2008-11-08 08:28:42 UTC (rev 9584)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Export GRASS raster to binary MAT-File" module="r.out.mat">
+<qgisgrassmodule label="Export raster to binary MAT-File" module="r.out.mat">
</qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/r.out.png.qgm
--- trunk/qgis/src/plugins/grass/modules/r.out.png.qgm 2008-11-08 00:57:53 UTC (rev 9583)
+++ trunk/qgis/src/plugins/grass/modules/r.out.png.qgm 2008-11-08 08:28:42 UTC (rev 9584)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Export GRASS raster as non-georeferenced PNG image format" module="r.out.png">
+<qgisgrassmodule label="Export raster as non-georeferenced PNG image format" module="r.out.png">
</qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/r.out.pov.qgm
--- trunk/qgis/src/plugins/grass/modules/r.out.pov.qgm 2008-11-08 00:57:53 UTC (rev 9583)
+++ trunk/qgis/src/plugins/grass/modules/r.out.pov.qgm 2008-11-08 08:28:42 UTC (rev 9584)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Convert GRASS raster into POVRAY height-field file" module="r.out.pov">
+<qgisgrassmodule label="Export raster into POVRAY height-field file" module="r.out.pov">
<option key="map" />
<option key="hftype" />
<option key="bias" />
Modified: trunk/qgis/src/plugins/grass/modules/r.out.ppm.qgm
--- trunk/qgis/src/plugins/grass/modules/r.out.ppm.qgm 2008-11-08 00:57:53 UTC (rev 9583)
+++ trunk/qgis/src/plugins/grass/modules/r.out.ppm.qgm 2008-11-08 08:28:42 UTC (rev 9584)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Convert GRASS raster to PPM image at the resolution of the current region" module="r.out.ppm">
+<qgisgrassmodule label="Export raster to PPM image at the resolution of the current region" module="r.out.ppm">
<flag key="G" />
Modified: trunk/qgis/src/plugins/grass/modules/r.out.ppm3.qgm
--- trunk/qgis/src/plugins/grass/modules/r.out.ppm3.qgm 2008-11-08 00:57:53 UTC (rev 9583)
+++ trunk/qgis/src/plugins/grass/modules/r.out.ppm3.qgm 2008-11-08 08:28:42 UTC (rev 9584)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Convert 3 GRASS rasters (R,G,B) to PPM image at the resolution of the current region" module="r.out.ppm3">
+<qgisgrassmodule label="Export 3 GRASS rasters (R,G,B) to PPM image at the resolution of the current region" module="r.out.ppm3">
<flag key="c" hidden="yes" />
<option key="red" />
<option key="green" />
Modified: trunk/qgis/src/plugins/grass/modules/r.out.tiff.qgm
--- trunk/qgis/src/plugins/grass/modules/r.out.tiff.qgm 2008-11-08 00:57:53 UTC (rev 9583)
+++ trunk/qgis/src/plugins/grass/modules/r.out.tiff.qgm 2008-11-08 08:28:42 UTC (rev 9584)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Export GRASS raster to 8/24bit TIFF image at the resolution of the current region" module="r.out.tiff">
+<qgisgrassmodule label="Export raster to 8/24bit TIFF image at the resolution of the current region" module="r.out.tiff">
<option key="compression" />
<flag key="p" />
Modified: trunk/qgis/src/plugins/grass/modules/r.out.vrml.qgm
--- trunk/qgis/src/plugins/grass/modules/r.out.vrml.qgm 2008-11-08 00:57:53 UTC (rev 9583)
+++ trunk/qgis/src/plugins/grass/modules/r.out.vrml.qgm 2008-11-08 08:28:42 UTC (rev 9584)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Export a raster map to the Virtual Reality Modeling Language (VRML)" module="r.out.vrml">
+<qgisgrassmodule label="Export raster to Virtual Reality Modeling Language (VRML)" module="r.out.vrml">
<option key="elev" />
<option key="color" />
<option key="exag" />
Modified: trunk/qgis/src/plugins/grass/modules/r.out.xyz.qgm
--- trunk/qgis/src/plugins/grass/modules/r.out.xyz.qgm 2008-11-08 00:57:53 UTC (rev 9583)
+++ trunk/qgis/src/plugins/grass/modules/r.out.xyz.qgm 2008-11-08 08:28:42 UTC (rev 9584)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Export a raster map to a text file as x,y,z values based on cell centers" module="r.out.xyz">
+<qgisgrassmodule label="Export raster to text file as x,y,z values based on cell centers" module="r.out.xyz">
<option key="fs" />
Modified: trunk/qgis/src/plugins/grass/modules/r.reclass.file.qgm
--- trunk/qgis/src/plugins/grass/modules/r.reclass.file.qgm 2008-11-08 00:57:53 UTC (rev 9583)
+++ trunk/qgis/src/plugins/grass/modules/r.reclass.file.qgm 2008-11-08 08:28:42 UTC (rev 9584)
@@ -3,6 +3,6 @@
<qgisgrassmodule label="Create new layer with category values based upon user's reclassification of categories in existing raster" module="r.reclass.file">
- <file key="rules_file" type="new" fileoption="olayer" label="Text file" filters="Txt (*.txt), Csv (*.csv)" />
+ <file key="rules_file" type="new" fileoption="olayer" label="Text file" />
</qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/r.reclass.qgm
--- trunk/qgis/src/plugins/grass/modules/r.reclass.qgm 2008-11-08 00:57:53 UTC (rev 9583)
+++ trunk/qgis/src/plugins/grass/modules/r.reclass.qgm 2008-11-08 08:28:42 UTC (rev 9584)
@@ -3,6 +3,6 @@
<qgisgrassmodule label="Reclass a raster using a reclassification rules file" module="r.reclass">
- <file key="rules" type="old" filters="Txt (*.txt), Csv (*.csv)" />
+ <file key="rules" type="old" />
</qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/r.resamp.rst.qgm
--- trunk/qgis/src/plugins/grass/modules/r.resamp.rst.qgm 2008-11-08 00:57:53 UTC (rev 9583)
+++ trunk/qgis/src/plugins/grass/modules/r.resamp.rst.qgm 2008-11-08 08:28:42 UTC (rev 9584)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Reinterpolates and computes topographic analysis using regularized spline with tension and smoothing" module="r.resamp.rst">
+<qgisgrassmodule label="Reinterpolate and compute topographic analysis using regularized spline with tension and smoothing" module="r.resamp.rst">
<option key="ew_res" />
<option key="ns_res" />
Modified: trunk/qgis/src/plugins/grass/modules/r.slope.aspect.slope.qgm
--- trunk/qgis/src/plugins/grass/modules/r.slope.aspect.slope.qgm 2008-11-08 00:57:53 UTC (rev 9583)
+++ trunk/qgis/src/plugins/grass/modules/r.slope.aspect.slope.qgm 2008-11-08 08:28:42 UTC (rev 9584)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Generate slope map from DEM (digital elevation model)" module="r.slope.aspect">
+<qgisgrassmodule label="Generate slope raster from DEM (digital elevation model)" module="r.slope.aspect">
<option key="elevation" />
<option key="slope" />
</qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/r.to.vect.area.qgm
--- trunk/qgis/src/plugins/grass/modules/r.to.vect.area.qgm 2008-11-08 00:57:53 UTC (rev 9583)
+++ trunk/qgis/src/plugins/grass/modules/r.to.vect.area.qgm 2008-11-08 08:28:42 UTC (rev 9584)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Convert a raster to vector areas" module="r.to.vect">
+<qgisgrassmodule label="Convert raster to vector areas" module="r.to.vect">
<option key="feature" answer="area" hidden="yes" />
Modified: trunk/qgis/src/plugins/grass/modules/r.volume.qgm
--- trunk/qgis/src/plugins/grass/modules/r.volume.qgm 2008-11-08 00:57:53 UTC (rev 9583)
+++ trunk/qgis/src/plugins/grass/modules/r.volume.qgm 2008-11-08 08:28:42 UTC (rev 9584)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Calculates the volume of data clumps, and produces a GRASS vector points map containing the calculated centroids of these clumps" module="r.volume">
+<qgisgrassmodule label="Calculate volume of data clumps, and produces a vector with centroids of clumps" module="r.volume">
<flag key="f" />
<option key="data" />
<option key="clump" />
Modified: trunk/qgis/src/plugins/grass/modules/v.clean.break.qgm
--- trunk/qgis/src/plugins/grass/modules/v.clean.break.qgm 2008-11-08 00:57:53 UTC (rev 9583)
+++ trunk/qgis/src/plugins/grass/modules/v.clean.break.qgm 2008-11-08 08:28:42 UTC (rev 9584)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Break lines at each intersection of vector map" module="v.clean">
+<qgisgrassmodule label="Break lines at each intersection of vector" module="v.clean">
<option key="input" typeoption="type"/>
<option key="tool" answer="break" hidden="yes"/>
<option key="output"/>
Modified: trunk/qgis/src/plugins/grass/modules/v.db.univar.qgm
--- trunk/qgis/src/plugins/grass/modules/v.db.univar.qgm 2008-11-08 00:57:53 UTC (rev 9583)
+++ trunk/qgis/src/plugins/grass/modules/v.db.univar.qgm 2008-11-08 08:28:42 UTC (rev 9584)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Calculates univariate statistics on selected table column for a GRASS vector map" module="v.db.univar">
+<qgisgrassmodule label="Calculates univariate statistics on selected table column for a vector" module="v.db.univar">
<option key="table" />
<field key="column" layer="table" type="integer,double" label="Attribute field" />
<flag key="e" answer="no"/>
Modified: trunk/qgis/src/plugins/grass/modules/v.in.e00.qgm
--- trunk/qgis/src/plugins/grass/modules/v.in.e00.qgm 2008-11-08 00:57:53 UTC (rev 9583)
+++ trunk/qgis/src/plugins/grass/modules/v.in.e00.qgm 2008-11-08 08:28:42 UTC (rev 9584)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Import ESRI E00 file in a vector map" module="v.in.e00">
+<qgisgrassmodule label="Import ESRI E00 file into vector" module="v.in.e00">
<file key="file" type="old" label="E00 vector layer" />
<option key="vect" />
Modified: trunk/qgis/src/plugins/grass/modules/v.out.dxf.qgm
--- trunk/qgis/src/plugins/grass/modules/v.out.dxf.qgm 2008-11-08 00:57:53 UTC (rev 9583)
+++ trunk/qgis/src/plugins/grass/modules/v.out.dxf.qgm 2008-11-08 08:28:42 UTC (rev 9584)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Convert GRASS vector to DXF" module="v.out.dxf">
+<qgisgrassmodule label="Export vector to DXF" module="v.out.dxf">
<file key="output" type="new" filters="DXF (*.dxf)"/>
</qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/v.random.qgm
--- trunk/qgis/src/plugins/grass/modules/v.random.qgm 2008-11-08 00:57:53 UTC (rev 9583)
+++ trunk/qgis/src/plugins/grass/modules/v.random.qgm 2008-11-08 08:28:42 UTC (rev 9584)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Randomly generate 2D/3D GRASS vector points" module="v.random">
+<qgisgrassmodule label="Randomly generate 2D/3D vector points" module="v.random">
<option key="n" answer="1" hidden="no"/>
<option key="zmin" answer="0.0" hidden="no"/>
<option key="zmax" answer="0.0" hidden="no"/>
Modified: trunk/qgis/src/plugins/grass/modules/v.rast.stats.qgm
--- trunk/qgis/src/plugins/grass/modules/v.rast.stats.qgm 2008-11-08 00:57:53 UTC (rev 9583)
+++ trunk/qgis/src/plugins/grass/modules/v.rast.stats.qgm 2008-11-08 08:28:42 UTC (rev 9584)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Calculates univariate statistics from a GRASS raster map based on vector objects" module="v.rast.stats">
+<qgisgrassmodule label="Calculates univariate statistics from a raster map based on vector objects" module="v.rast.stats">
<option key="raster"/>
<option key="vector" typemask="area"/>
<option key="colprefix"/>
Modified: trunk/qgis/src/plugins/grass/modules/v.reclass.file.qgm
--- trunk/qgis/src/plugins/grass/modules/v.reclass.file.qgm 2008-11-08 00:57:53 UTC (rev 9583)
+++ trunk/qgis/src/plugins/grass/modules/v.reclass.file.qgm 2008-11-08 08:28:42 UTC (rev 9584)
@@ -4,7 +4,7 @@
<qgisgrassmodule label="Reclass category values using a rules file" module="v.reclass">
<option key="input" typeoption="type" layeroption="layer"/>
- <file key="rules" type="new" fileoption="olayer" label="Text file" filters="Txt (*.txt), Csv (*.csv)" />
+ <file key="rules" type="new" fileoption="olayer" label="Text file" />
</qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/v.to.rast.attr.qgm
--- trunk/qgis/src/plugins/grass/modules/v.to.rast.attr.qgm 2008-11-08 00:57:53 UTC (rev 9583)
+++ trunk/qgis/src/plugins/grass/modules/v.to.rast.attr.qgm 2008-11-08 08:28:42 UTC (rev 9584)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Convert a vector to raster using attribute values" module="v.to.rast">
+<qgisgrassmodule label="Convert vector to raster using attribute values" module="v.to.rast">
<option key="input" layeroption="layer"/>
<field key="column" layer="input" type="integer,double" label="Attribute field" />
Modified: trunk/qgis/src/plugins/grass/modules/v.to.rast.constant.qgm
--- trunk/qgis/src/plugins/grass/modules/v.to.rast.constant.qgm 2008-11-08 00:57:53 UTC (rev 9583)
+++ trunk/qgis/src/plugins/grass/modules/v.to.rast.constant.qgm 2008-11-08 08:28:42 UTC (rev 9584)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Convert a vector to raster using constant" module="v.to.rast">
+<qgisgrassmodule label="Convert vector to raster using constant" module="v.to.rast">
<option key="value" />
Modified: trunk/qgis/src/plugins/grass/modules/v.univar.qgm
--- trunk/qgis/src/plugins/grass/modules/v.univar.qgm 2008-11-08 00:57:53 UTC (rev 9583)
+++ trunk/qgis/src/plugins/grass/modules/v.univar.qgm 2008-11-08 08:28:42 UTC (rev 9584)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Calculates univariate statistics on selected table column for a GRASS vector map" module="v.univar">
+<qgisgrassmodule label="Calculates univariate statistics on selected table column for a vector" module="v.univar">
<option key="map" typeoption="type"/>
</qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/v.what.rast.qgm
--- trunk/qgis/src/plugins/grass/modules/v.what.rast.qgm 2008-11-08 00:57:53 UTC (rev 9583)
+++ trunk/qgis/src/plugins/grass/modules/v.what.rast.qgm 2008-11-08 08:28:42 UTC (rev 9584)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Uploads raster values at positions of vector points to the table" module="v.what.rast">
+<qgisgrassmodule label="Upload raster values at positions of vector points to the table" module="v.what.rast">
<option key="vector" layeroption="layer" typemask="point"/>
<field key="column" layer="vector" type="integer,double"/>
