[QGIS Commit] r9586 - trunk/qgis/src/plugins/grass/modules
svn_qgis at osgeo.org
Sat Nov 8 04:37:18 EST 2008
Author: pcav
Date: 2008-11-08 04:37:18 -0500 (Sat, 08 Nov 2008)
New Revision: 9586
trunk/qgis/src/plugins/grass/modules/r.to.vect.line.qgm
trunk/qgis/src/plugins/grass/modules/r.to.vect.point.qgm
Cleanup of GRASS modules
Modified: trunk/qgis/src/plugins/grass/modules/r.to.vect.line.qgm
--- trunk/qgis/src/plugins/grass/modules/r.to.vect.line.qgm 2008-11-08 08:35:37 UTC (rev 9585)
+++ trunk/qgis/src/plugins/grass/modules/r.to.vect.line.qgm 2008-11-08 09:37:18 UTC (rev 9586)
@@ -1,7 +1,7 @@
<!DOCTYPE qgisgrassmodule SYSTEM "http://mrcc.com/qgisgrassmodule.dtd">
-<qgisgrassmodule label="Convert a raster to vector lines" module="r.to.vect">
+<qgisgrassmodule label="Convert raster to vector lines" module="r.to.vect">
<option key="input" />
<option key="output" />
<option key="feature" answer="line" hidden="yes" />
Modified: trunk/qgis/src/plugins/grass/modules/r.to.vect.point.qgm
--- trunk/qgis/src/plugins/grass/modules/r.to.vect.point.qgm 2008-11-08 08:35:37 UTC (rev 9585)
+++ trunk/qgis/src/plugins/grass/modules/r.to.vect.point.qgm 2008-11-08 09:37:18 UTC (rev 9586)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Convert a raster to vector points" module="r.to.vect">
+<qgisgrassmodule label="Convert raster to vector points" module="r.to.vect">
<option key="feature" answer="point" hidden="yes" />
