[QGIS Commit] r9598 - trunk/qgis/src/app
svn_qgis at osgeo.org
Sat Nov 8 14:05:49 EST 2008
Author: jef
Date: 2008-11-08 14:05:49 -0500 (Sat, 08 Nov 2008)
New Revision: 9598
trunk/qgis/src/app/qgsattributetable.cpp
trunk/qgis/src/app/qgsattributetable.h
trunk/qgis/src/app/qgsattributetabledisplay.cpp
partly fix #1377, #1382 and #1306
Modified: trunk/qgis/src/app/qgsattributetable.cpp
--- trunk/qgis/src/app/qgsattributetable.cpp 2008-11-08 18:55:36 UTC (rev 9597)
+++ trunk/qgis/src/app/qgsattributetable.cpp 2008-11-08 19:05:49 UTC (rev 9598)
@@ -171,7 +171,7 @@
QList < int >::iterator it;
for ( it = idsOfSelected.begin(); it != idsOfSelected.end(); ++it )
- selectRowWithId(( *it ) );
+ selectRowWithId( *it );
connect( this, SIGNAL( itemSelectionChanged() ), this, SLOT( handleChangedSelections() ) );
@@ -226,7 +226,7 @@
void QgsAttributeTable::sortColumn( int col, bool ascending )
- int type = horizontalHeaderItem( col )->data( QgsAttributeTable::AttributeType ).toInt();
+ int type = horizontalHeaderItem( col )->data( AttributeType ).toInt();
qsort( 0, rowCount() - 1, col, ascending, type != QVariant::Int && type != QVariant::Double );
@@ -437,6 +437,19 @@
clipboard->setText( toClipboard, QClipboard::Clipboard );
+void QgsAttributeTable::addFeatureToTable( QgsVectorLayer *layer, int id )
+ blockSignals( true );
+ QgsFeature f;
+ if ( layer->featureAtId( id, f, false, true ) == 0 )
+ putFeatureInTable( rowCount(), f );
+ blockSignals( false );
void QgsAttributeTable::fillTable( QgsVectorLayer *layer )
@@ -457,7 +470,7 @@
QTableWidgetItem *twi = new QTableWidgetItem( fldIt->name() );
twi->setData( AttributeIndex, fldIt.key() );
twi->setData( AttributeName, fldIt->name() );
- twi->setData( QgsAttributeTable::AttributeType, (int)(fldIt->type()));
+ twi->setData( AttributeType, ( int ) fldIt->type() );
setHorizontalHeaderItem( h, twi );
mAttrIdxMap.insert( fldIt.key(), h );
@@ -596,28 +609,27 @@
-void QgsAttributeTable::selectRowsWithId( const QgsFeatureIds& ids )
+void QgsAttributeTable::selectRowsWithId( const QgsFeatureIds &ids, QgsVectorLayer *layer )
+#if 0
// if selecting rows takes too much time we can use progress dialog
- QProgressDialog progress( tr("Updating selection..."), tr("Abort"), 0, mSelected.size(), tabledisplay);
- int i=0;
- for(std::set<int>::iterator iter=mSelected.begin();iter!=mSelected.end();++iter)
+ QProgressDialog progress( tr( "Updating selection..." ), tr( "Abort" ), 0, mSelected.size(), tabledisplay );
+ int i = 0;
+ for ( std::set<int>::iterator iter = mSelected.begin();iter != mSelected.end();++iter )
++i;
- progress.setValue(i);
+ progress.setValue( i );
qApp->processEvents();
- if(progress.wasCanceled())
+ if ( progress.wasCanceled() )
//deselect the remaining features if action was canceled
- mSelected.erase(iter,--mSelected.end());
+ mSelected.erase( iter, --mSelected.end() );
break;
- selectRowWithId(*iter);//todo: avoid that the table gets repainted during each selection
+ selectRowWithId( *iter );//todo: avoid that the table gets repainted during each selection
+#endif
// to select more rows at once effectively, we stop sending signals to handleChangedSelections()
// otherwise it will repaint map everytime row is selected
@@ -627,6 +639,12 @@
QgsFeatureIds::const_iterator it;
for ( it = ids.begin(); it != ids.end(); it++ )
+ if ( layer && !rowIdMap.contains( *it ) )
+ // add feature if we do not already have it
+ addFeatureToTable( layer, *it );
@@ -754,7 +772,7 @@
QTableWidgetItem *twi = new QTableWidgetItem( fld.name() );
twi->setData( AttributeIndex, attr );
twi->setData( AttributeName, fld.name() );
- twi->setData( AttributeType, fld.type() );
+ twi->setData( AttributeType, ( int ) fld.type() );
insertColumn( columnCount() );
setHorizontalHeaderItem( columnCount() - 1, twi );
Modified: trunk/qgis/src/app/qgsattributetable.h
--- trunk/qgis/src/app/qgsattributetable.h 2008-11-08 18:55:36 UTC (rev 9597)
+++ trunk/qgis/src/app/qgsattributetable.h 2008-11-08 19:05:49 UTC (rev 9598)
@@ -87,7 +87,7 @@
/**Swaps the selected rows such that the selected ones are on the top of the table*/
void bringSelectedToTop();
/** Selects rows with chosen feature IDs */
- void selectRowsWithId( const QgsFeatureIds& ids );
+ void selectRowsWithId( const QgsFeatureIds& ids, QgsVectorLayer *layer = 0 );
/** Shows only rows with chosen feature IDs, others get hidden */
void showRowsWithId( const QgsFeatureIds& ids );
/** Shows all rows */
@@ -95,6 +95,10 @@
/**Fills the contents of a provider into this table*/
void fillTable( QgsVectorLayer *layer );
+ /** adds a feature to the current table */
+ void addFeatureToTable( QgsVectorLayer *layer, int id );
void addAttribute( int idx, const QgsField &fld );
void deleteAttribute( int idx );
Modified: trunk/qgis/src/app/qgsattributetabledisplay.cpp
--- trunk/qgis/src/app/qgsattributetabledisplay.cpp 2008-11-08 18:55:36 UTC (rev 9597)
+++ trunk/qgis/src/app/qgsattributetabledisplay.cpp 2008-11-08 19:05:49 UTC (rev 9598)
@@ -244,7 +244,7 @@
void QgsAttributeTableDisplay::selectRowsWithId( const QgsFeatureIds &ids )
- tblAttributes->selectRowsWithId( ids );
+ tblAttributes->selectRowsWithId( ids, mLayer );
void QgsAttributeTableDisplay::setTheme()
