[QGIS Commit] r9630 - trunk/qgis/src/app
    svn_qgis at osgeo.org
    Wed Nov 12 16:38:13 EST 2008
Author: wonder
Date: 2008-11-12 16:38:12 -0500 (Wed, 12 Nov 2008)
New Revision: 9630
   trunk/qgis/src/app/qgisapp.cpp
   trunk/qgis/src/app/qgisapp.h
   trunk/qgis/src/app/qgspluginregistry.cpp
   trunk/qgis/src/app/qgspluginregistry.h
Moved plugin loading from QgisApp to QgsPluginRegistry
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp	2008-11-12 19:54:21 UTC (rev 9629)
+++ trunk/qgis/src/app/qgisapp.cpp	2008-11-12 21:38:12 UTC (rev 9630)
@@ -187,11 +187,6 @@
 class QTreeWidgetItem;
-/* typedefs for plugins */
-typedef QgisPlugin *create_ui( QgisInterface * qI );
-typedef QString name_t();
-typedef QString description_t();
-typedef int type_t();
 // IDs for locating particular menu items
 const int BEFORE_RECENT_PATHS = 123;
@@ -397,7 +392,8 @@
   // load any plugins that were running in the last session
   mSplash->showMessage( tr( "Restoring loaded plugins" ), Qt::AlignHCenter | Qt::AlignBottom );
   qApp->processEvents();
-  restoreSessionPlugins( QgsApplication::pluginPath() );
+  QgsPluginRegistry::instance()->setQgisInterface( mQgisInterface );
+  QgsPluginRegistry::instance()->restoreSessionPlugins( QgsApplication::pluginPath() );
   mSplash->showMessage( tr( "Initializing file filters" ), Qt::AlignHCenter | Qt::AlignBottom );
@@ -1827,111 +1823,9 @@
   abt->activateWindow();
-/** Load up any plugins used in the last session
-void QgisApp::restoreSessionPlugins( QString thePluginDirString )
-  QSettings mySettings;
-#ifdef WIN32
-  QString pluginExt = "*.dll";
-#else
-  QString pluginExt = "*.so*";
-#endif
-  // check all libs in the current plugin directory and get name and descriptions
-  QDir myPluginDir( thePluginDirString, pluginExt, QDir::Name | QDir::IgnoreCase, QDir::Files | QDir::NoSymLinks );
-  for ( uint i = 0; i < myPluginDir.count(); i++ )
-    QString myFullPath = thePluginDirString + "/" + myPluginDir[i];
-    QString baseName = QFileInfo( myFullPath ).baseName();
-    QLibrary *myLib = new QLibrary( myFullPath );
-    bool loaded = myLib->load();
-    if ( loaded )
-      name_t * myName = ( name_t * ) cast_to_fptr( myLib->resolve( "name" ) );
-      description_t *  myDescription = ( description_t * )  cast_to_fptr( myLib->resolve( "description" ) );
-      version_t *  myVersion = ( version_t * ) cast_to_fptr( myLib->resolve( "version" ) );
-      if ( myName && myDescription  && myVersion )
-        //check if the plugin was active on last session
-        // Windows stores a "true" value as a 1 in the registry so we
-        // have to use readBoolEntry in this function
-        if ( mySettings.value( "/Plugins/" + baseName ).toBool() )
-          //QgsDebugMsg("Loading plugin: " + myEntryName);
-          loadPlugin( myFullPath, myName() );
-        else
-          //QgsDebugMsg("Plugin was not active last session, leaving disabled: " + myEntryName);
-      else
-        //QgsDebugMsg("Failed to get name, description, or type for " + myLib->fileName());
-    else
-      //QgsDebugMsg("Failed to load " + myLib->fileName());
-      //QgsDebugMsg("Reason: " + myLib->errorString());
-    delete myLib;
-  QString pluginName, description, version;
-  if ( mPythonUtils && mPythonUtils->isEnabled() )
-    // check for python plugins system-wide
-    QStringList pluginList = mPythonUtils->pluginList();
-    std::cout << "Loading python plugins" << std::endl; // OK
-    for ( int i = 0; i < pluginList.size(); i++ )
-      QString packageName = pluginList[i];
-      // import plugin's package
-      if ( !mPythonUtils->loadPlugin( packageName ) )
-        continue;
-      // get information from the plugin
-      // if there are some problems, don't continue with metadata retreival
-      pluginName = mPythonUtils->getPluginMetadata( packageName, "name" );
-      if ( pluginName != "__error__" )
-        description = mPythonUtils->getPluginMetadata( packageName, "description" );
-        if ( description != "__error__" )
-          version = mPythonUtils->getPluginMetadata( packageName, "version" );
-      if ( pluginName == "__error__" || description == "__error__" || version == "__error__" )
-        QMessageBox::warning( this, tr( "Python error" ), tr( "Error when reading metadata of plugin " ) + packageName );
-        continue;
-      if ( mySettings.value( "/PythonPlugins/" + packageName ).toBool() )
-        loadPythonPlugin( packageName, pluginName );
-  std::cout << "Plugin loading completed" << std::endl;  // OK
   Convenience function for readily creating file filters.
@@ -4131,6 +4025,7 @@
   pm->resizeColumnsToContents();
   if ( pm->exec() )
+    QgsPluginRegistry* pRegistry = QgsPluginRegistry::instance();
     // load selected plugins
     std::vector < QgsPluginItem > pi = pm->getSelectedPlugins();
     std::vector < QgsPluginItem >::iterator it = pi.begin();
@@ -4139,11 +4034,11 @@
       QgsPluginItem plugin = *it;
       if ( plugin.isPython() )
-        loadPythonPlugin( plugin.fullPath(), plugin.name() );
+        pRegistry->loadPythonPlugin( plugin.fullPath() );
       else
-        loadPlugin( plugin.fullPath(), plugin.name() );
+        pRegistry->loadCppPlugin( plugin.fullPath() );
       it++;
@@ -4200,114 +4095,8 @@
-void QgisApp::loadPythonPlugin( QString packageName, QString pluginName )
-  if ( !mPythonUtils || !mPythonUtils->isEnabled() )
-    QgsDebugMsg( "Python is not enabled in QGIS." );
-    return;
-  QgsPluginRegistry *pRegistry = QgsPluginRegistry::instance();
-  // is loaded already?
-  if ( ! pRegistry->isLoaded( packageName ) )
-    mPythonUtils->loadPlugin( packageName );
-    mPythonUtils->startPlugin( packageName );
-    // TODO: test success
-    // add to plugin registry
-    pRegistry->addPlugin( packageName, QgsPluginMetadata( packageName, pluginName, NULL, true ) );
-    // add to settings
-    QSettings settings;
-    settings.setValue( "/PythonPlugins/" + packageName, true );
-    std::cout << "Loaded : " << pluginName.toLocal8Bit().constData() << " (package: "
-              << packageName.toLocal8Bit().constData() << ")" << std::endl; // OK
-void QgisApp::loadPlugin( QString theFullPathName, QString name )
-  // first check to see if its already loaded
-  QString baseName = QFileInfo( theFullPathName ).baseName();
-  if ( pRegistry->isLoaded( baseName ) )
-    // plugin is loaded
-    // QMessageBox::warning(this, "Already Loaded", description + " is already loaded");
-  else
-    QLibrary *myLib = new QLibrary( theFullPathName );
-    QString myError; //we will only show detailed diagnostics if something went wrong
-    myError += "Library name is " + myLib->fileName() + " " + QString( __LINE__ ) + " in " + QString( __FUNCTION__ ) + "\n";
-    if ( loaded )
-      myError += "Attempting to resolve the classFactory function " +  QString( __LINE__ ) + " in " + QString( __FUNCTION__ ) + "\n";
-      type_t *pType = ( type_t * ) cast_to_fptr( myLib->resolve( "type" ) );
-      switch ( pType() )
-        case QgisPlugin::RENDERER:
-        case QgisPlugin::UI:
-          // UI only -- doesn't use mapcanvas
-          create_ui *cf = ( create_ui * ) cast_to_fptr( myLib->resolve( "classFactory" ) );
-          if ( cf )
-            QgisPlugin *pl = cf( mQgisInterface );
-            if ( pl )
-              pl->initGui();
-              // add it to the plugin registry
-              pRegistry->addPlugin( baseName, QgsPluginMetadata( myLib->fileName(), name, pl ) );
-              //add it to the qsettings file [ts]
-              settings.setValue( "/Plugins/" + baseName, true );
-            else
-              // something went wrong
-              QMessageBox::warning( this, tr( "Error Loading Plugin" ), tr( "There was an error loading a plugin."
-                                    "The following diagnostic information may help the QGIS developers resolve the issue:\n%1." ).arg
-                                    ( myError ) );
-              //disable it to the qsettings file [ts]
-              settings.setValue( "/Plugins/" + baseName, false );
-          else
-            QgsDebugMsg( "Unable to find the class factory for " + theFullPathName );
-        break;
-        default:
-          // type is unknown
-          QgsDebugMsg( "Plugin " + theFullPathName + " did not return a valid type and cannot be loaded" );
-          break;
-    else
-      QgsDebugMsg( "Failed to load " + theFullPathName );
-    delete myLib;
 void QgisApp::checkQgisVersion()
   QApplication::setOverrideCursor( Qt::WaitCursor );
Modified: trunk/qgis/src/app/qgisapp.h
--- trunk/qgis/src/app/qgisapp.h	2008-11-12 19:54:21 UTC (rev 9629)
+++ trunk/qgis/src/app/qgisapp.h	2008-11-12 21:38:12 UTC (rev 9630)
@@ -378,16 +378,10 @@
     void zoomToLayerExtent();
     //! zoom to actual size of raster layer
     void zoomActualSize();
-    //! load any plugins used in the last qgis session
-    void restoreSessionPlugins( QString thePluginDirString );
     //! plugin manager
     void showPluginManager();
     //! load python support if possible
     void loadPythonSupport();
-    //! plugin loader
-    void loadPlugin( QString mFullPath, QString name );
-    //! python plugin loader
-    void loadPythonPlugin( QString packageName, QString pluginName );
     //! Find the QMenu with the given name (ie the user visible text on the menu item)
     QMenu* getPluginMenu( QString menuName );
     //! Add the action to the submenu with the given name under the plugin menu
Modified: trunk/qgis/src/app/qgspluginregistry.cpp
--- trunk/qgis/src/app/qgspluginregistry.cpp	2008-11-12 19:54:21 UTC (rev 9629)
+++ trunk/qgis/src/app/qgspluginregistry.cpp	2008-11-12 21:38:12 UTC (rev 9630)
@@ -17,12 +17,28 @@
 /* $Id$ */
+#include <QDir>
+#include <QFileInfo>
+#include <QLibrary>
+#include <QMessageBox>
+#include <QSettings>
+#include "qgis.h"
+#include "qgisinterface.h"
 #include "qgspluginregistry.h"
 #include "qgspluginmetadata.h"
 #include "qgisplugin.h"
 #include "qgspythonutils.h"
 #include "qgslogger.h"
+/* typedefs for plugins */
+typedef QgisPlugin *create_ui( QgisInterface * qI );
+typedef QString name_t();
+typedef QString description_t();
+typedef int type_t();
 QgsPluginRegistry *QgsPluginRegistry::_instance = 0;
 QgsPluginRegistry *QgsPluginRegistry::instance()
@@ -34,11 +50,16 @@
 QgsPluginRegistry::QgsPluginRegistry()
-    : mPythonUtils( NULL )
+    : mPythonUtils( NULL ), mQgisInterface( NULL )
 // constructor does nothing
+void QgsPluginRegistry::setQgisInterface( QgisInterface* iface )
+  mQgisInterface = iface;
 void QgsPluginRegistry::setPythonUtils( QgsPythonUtils* pythonUtils )
   mPythonUtils = pythonUtils;
@@ -129,3 +150,217 @@
+void QgsPluginRegistry::loadPythonPlugin( QString packageName )
+  if ( !mPythonUtils || !mPythonUtils->isEnabled() )
+    QgsDebugMsg( "Python is not enabled in QGIS." );
+    return;
+  // is loaded already?
+  if ( ! isLoaded( packageName ) )
+    mPythonUtils->loadPlugin( packageName );
+    mPythonUtils->startPlugin( packageName );
+    // TODO: test success
+    QString pluginName = mPythonUtils->getPluginMetadata( packageName, "name" );
+    // add to plugin registry
+    addPlugin( packageName, QgsPluginMetadata( packageName, pluginName, NULL, true ) );
+    // add to settings
+    QSettings settings;
+    settings.setValue( "/PythonPlugins/" + packageName, true );
+    std::cout << "Loaded : " << pluginName.toLocal8Bit().constData() << " (package: "
+        << packageName.toLocal8Bit().constData() << ")" << std::endl; // OK
+void QgsPluginRegistry::loadCppPlugin( QString theFullPathName )
+  QString baseName = QFileInfo( theFullPathName ).baseName();
+  // first check to see if its already loaded
+  if ( isLoaded( baseName ) )
+    // plugin is loaded
+    // QMessageBox::warning(this, "Already Loaded", description + " is already loaded");
+    return;
+  QLibrary myLib( theFullPathName );
+  QString myError; //we will only show detailed diagnostics if something went wrong
+  myError += "Library name is " + myLib.fileName() + " " + QString( __LINE__ ) + " in " + QString( __FUNCTION__ ) + "\n";
+  bool loaded = myLib.load();
+  if ( ! loaded )
+    QgsDebugMsg( "Failed to load " + theFullPathName );
+    return;
+  myError += "Attempting to resolve the classFactory function " +  QString( __LINE__ ) + " in " + QString( __FUNCTION__ ) + "\n";
+  type_t *pType = ( type_t * ) cast_to_fptr( myLib.resolve( "type" ) );
+  name_t *pName = ( name_t * ) cast_to_fptr( myLib.resolve( "name" ) );
+  switch ( pType() )
+    case QgisPlugin::RENDERER:
+    case QgisPlugin::UI:
+      // UI only -- doesn't use mapcanvas
+      create_ui *cf = ( create_ui * ) cast_to_fptr( myLib.resolve( "classFactory" ) );
+      if ( cf )
+        QgisPlugin *pl = cf( mQgisInterface );
+        if ( pl )
+          pl->initGui();
+          // add it to the plugin registry
+          addPlugin( baseName, QgsPluginMetadata( myLib.fileName(), pName(), pl ) );
+          //add it to the qsettings file [ts]
+          settings.setValue( "/Plugins/" + baseName, true );
+        else
+          // something went wrong
+          QMessageBox::warning( mQgisInterface->mainWindow(), QObject::tr( "Error Loading Plugin" ),
+                                QObject::tr( "There was an error loading a plugin."
+              "The following diagnostic information may help the QGIS developers resolve the issue:\n%1." ).arg
+                  ( myError ) );
+          //disable it to the qsettings file [ts]
+          settings.setValue( "/Plugins/" + baseName, false );
+      else
+        QgsDebugMsg( "Unable to find the class factory for " + theFullPathName );
+    break;
+    default:
+      // type is unknown
+      QgsDebugMsg( "Plugin " + theFullPathName + " did not return a valid type and cannot be loaded" );
+      break;
+void QgsPluginRegistry::restoreSessionPlugins( QString thePluginDirString )
+  QSettings mySettings;
+#ifdef WIN32
+  QString pluginExt = "*.dll";
+#else
+  QString pluginExt = "*.so*";
+#endif
+  // check all libs in the current plugin directory and get name and descriptions
+  QDir myPluginDir( thePluginDirString, pluginExt, QDir::Name | QDir::IgnoreCase, QDir::Files | QDir::NoSymLinks );
+  for ( uint i = 0; i < myPluginDir.count(); i++ )
+    QString myFullPath = thePluginDirString + "/" + myPluginDir[i];
+    if (checkCppPlugin( myFullPath ) )
+      // check if the plugin was active on last session
+      QString baseName = QFileInfo( myFullPath ).baseName();
+      if ( mySettings.value( "/Plugins/" + baseName ).toBool() )
+        loadCppPlugin( myFullPath );
+  if ( mPythonUtils && mPythonUtils->isEnabled() )
+    // check for python plugins system-wide
+    QStringList pluginList = mPythonUtils->pluginList();
+    QgsDebugMsg("Loading python plugins");
+    for ( int i = 0; i < pluginList.size(); i++ )
+      QString packageName = pluginList[i];
+      if (checkPythonPlugin( packageName ) )
+        if ( mySettings.value( "/PythonPlugins/" + packageName ).toBool() )
+          loadPythonPlugin( packageName );
+  QgsDebugMsg("Plugin loading completed");
+bool QgsPluginRegistry::checkCppPlugin( QString pluginFullPath )
+  QLibrary myLib( pluginFullPath );
+  if ( ! loaded )
+    //QgsDebugMsg("Failed to load " + myLib.fileName());
+    //QgsDebugMsg("Reason: " + myLib.errorString());
+    return false;
+  name_t * myName = ( name_t * ) cast_to_fptr( myLib.resolve( "name" ) );
+  description_t *  myDescription = ( description_t * )  cast_to_fptr( myLib.resolve( "description" ) );
+  version_t *  myVersion = ( version_t * ) cast_to_fptr( myLib.resolve( "version" ) );
+  if ( myName && myDescription  && myVersion )
+    return true;
+  QgsDebugMsg("Failed to get name, description, or type for " + myLib.fileName());
+  return false;
+bool QgsPluginRegistry::checkPythonPlugin( QString packageName )
+  // import plugin's package
+  if ( !mPythonUtils->loadPlugin( packageName ) )
+    return false;
+  QString pluginName, description, version;
+  // get information from the plugin
+  // if there are some problems, don't continue with metadata retreival
+  pluginName = mPythonUtils->getPluginMetadata( packageName, "name" );
+  if ( pluginName != "__error__" )
+    description = mPythonUtils->getPluginMetadata( packageName, "description" );
+    if ( description != "__error__" )
+      version = mPythonUtils->getPluginMetadata( packageName, "version" );
+  if ( pluginName == "__error__" || description == "__error__" || version == "__error__" )
+    QMessageBox::warning( mQgisInterface->mainWindow(), QObject::tr( "Python error" ),
+                          QObject::tr( "Error when reading metadata of plugin " ) + packageName );
+    return false;
+  return true;
Modified: trunk/qgis/src/app/qgspluginregistry.h
--- trunk/qgis/src/app/qgspluginregistry.h	2008-11-12 19:54:21 UTC (rev 9629)
+++ trunk/qgis/src/app/qgspluginregistry.h	2008-11-12 21:38:12 UTC (rev 9630)
@@ -25,6 +25,7 @@
 class QgsPluginMetadata;
 class QgsPythonUtils;
 class QgisPlugin;
+class QgisInterface;
 class QString;
@@ -41,6 +42,9 @@
   public:
     //! Returns the instance pointer, creating the object on the first call
     static QgsPluginRegistry* instance();
+    //! set pointer to qgis interface passed to plugins (used by QgisApp)
+    void setQgisInterface( QgisInterface* iface );
     //! Check whether this module is loaded
     bool isLoaded( QString key );
@@ -69,13 +73,27 @@
     //! Dump list of plugins
     void dump();
+    //! C++ plugin loader
+    void loadCppPlugin( QString mFullPath );
+    //! Python plugin loader
+    void loadPythonPlugin( QString packageName );
+    //! Load any plugins used in the last qgis session
+    void restoreSessionPlugins( QString thePluginDirString );
   protected:
     //! protected constructor
     QgsPluginRegistry();
+    //! Try to load and get metadata from c++ plugin, return true on success
+    bool checkCppPlugin( QString pluginFullPath );
+    //! Try to load and get metadata from Python plugin, return true on success
+    bool checkPythonPlugin( QString packageName );
   private:
     static QgsPluginRegistry* _instance;
     QMap<QString, QgsPluginMetadata> mPlugins;
     QgsPythonUtils* mPythonUtils;
+    QgisInterface* mQgisInterface;
 #endif //QgsPluginRegistry_H
