[QGIS Commit] r9638 - trunk/qgis
svn_qgis at osgeo.org
Sat Nov 15 01:10:32 EST 2008
Author: timlinux
Date: 2008-11-15 01:10:32 -0500 (Sat, 15 Nov 2008)
New Revision: 9638
trunk/qgis/BUGS
Added some more notes relating to bug filing
Modified: trunk/qgis/BUGS
--- trunk/qgis/BUGS 2008-11-14 23:42:08 UTC (rev 9637)
+++ trunk/qgis/BUGS 2008-11-15 06:10:32 UTC (rev 9638)
@@ -1,7 +1,30 @@
-$Id$
-See the QGIS ticket/bug database at
+Help I think I found a bug!
+If you find a bug in QGIS, you can report it using the QGIS ticket/bug database at:
http://trac.osgeo.org/qgis/report
-for the list of current bugs.
+Some hints about when you should file a bug:
+ - just because a bug is filed doesnt always mean we can or will fix it.
+ Sometimes people ask for things that will require many man hours to to and
+ offer little reward to work ratio benifit when compared to the other issues
+ in the queue. Also some things are simply not fixable due to whatever
+ technical reason.
+ - sometimes we don't fix a bug because the user's vision of how QGIS should
+ behave doesn't match ours. Hey we are all humans it can happen...
+ - always check that your bug has not already been filed by someone else since
+ dealing with duplicate tickets causes a lot of time wasting.
+ - always provide contact details and make sure you are subscribed to the
+ ticket entry (either by adding yourself to CC field or by logging in before
+ filing the ticket).
+ - dont be offended if we don't see tickets as having the same priority as you
+ do. While we appreciate it's inconvenient if some issue prevents you doing
+ your work, we need to take the big picture view of things and focus on
+ things that affect the largest proportion of our user base.
+$Id$
