[QGIS Commit] r9660 - trunk/qgis/src/providers/grass
svn_qgis at osgeo.org
Mon Nov 17 15:20:39 EST 2008
Author: timlinux
Date: 2008-11-17 15:20:38 -0500 (Mon, 17 Nov 2008)
New Revision: 9660
trunk/qgis/src/providers/grass/qgsgrassprovider.cpp
Fixes for GRASS vector to work with current GRASS in trunk (from Markus Neteler)
Modified: trunk/qgis/src/providers/grass/qgsgrassprovider.cpp
--- trunk/qgis/src/providers/grass/qgsgrassprovider.cpp 2008-11-17 20:11:06 UTC (rev 9659)
+++ trunk/qgis/src/providers/grass/qgsgrassprovider.cpp 2008-11-17 20:20:38 UTC (rev 9660)
@@ -1524,11 +1524,12 @@
// TODO: Is it necessary for build/close ?
G__setenv(( char * ) "MAPSET", map->mapset.toAscii().data() );
- Vect_build_partial( map->map, GV_BUILD_NONE, NULL );
#if defined(GRASS_VERSION_MAJOR) && defined(GRASS_VERSION_MINOR) && \
( ( GRASS_VERSION_MAJOR == 6 && GRASS_VERSION_MINOR >= 4 ) || GRASS_VERSION_MAJOR > 6 )
+ Vect_build_partial( map->map, GV_BUILD_NONE );
Vect_build( map.map );
#else
+ Vect_build_partial( map->map, GV_BUILD_NONE, NULL );
Vect_build( map->map, stderr );
#endif
