[QGIS Commit] r9670 - in trunk/qgis: . doc
svn_qgis at osgeo.org svn_qgis at osgeo.org
Wed Nov 19 03:51:59 EST 2008
Author: jef
Date: 2008-11-19 03:51:59 -0500 (Wed, 19 Nov 2008)
New Revision: 9670
   trunk/qgis/INSTALL
   trunk/qgis/doc/INSTALL.t2t
update required GDAL version in INSTALL
Modified: trunk/qgis/INSTALL
--- trunk/qgis/INSTALL	2008-11-19 08:13:42 UTC (rev 9669)
+++ trunk/qgis/INSTALL	2008-11-19 08:51:59 UTC (rev 9670)
@@ -171,7 +171,7 @@
  * Proj >= ? (known to work with 4.4.x)
  * GEOS >= 2.2 (3.0 is supported, maybe 2.1.x works too)
  * Sqlite3 >= ? (probably 3.0.0)
- * GDAL/OGR >= 1.4.x (1.2.x should work)
+ * GDAL/OGR >= 1.4.x
 '''Optional dependencies:'''
  * for GRASS plugin - GRASS >= 6.0.0
Modified: trunk/qgis/doc/INSTALL.t2t
--- trunk/qgis/doc/INSTALL.t2t	2008-11-19 08:13:42 UTC (rev 9669)
+++ trunk/qgis/doc/INSTALL.t2t	2008-11-19 08:51:59 UTC (rev 9670)
@@ -20,7 +20,7 @@
 %apply vim formatting to the whol document as it screws up some formatting
 %rather apply it selectively to paragraphs where needed.
-% To generate teh text version of this document:
+% To generate the text version of this document:
 % txt2tags -t txt -o INSTALL INSTALL.t2t
 % To generate the moinmoin version of this document
 % txt2tags -t moin INSTALL.moin  INSTALL.t2t
@@ -94,7 +94,7 @@
More information about the QGIS-commit mailing list
