[QGIS Commit] r9713 - trunk/qgis/src/core
svn_qgis at osgeo.org
Thu Nov 27 09:15:27 EST 2008
Author: mhugent
Date: 2008-11-27 09:15:27 -0500 (Thu, 27 Nov 2008)
New Revision: 9713
trunk/qgis/src/core/qgsgeometry.cpp
trunk/qgis/src/core/qgsgeometry.h
Function name without get, changed more function calls to use numberOfGeometries()
Modified: trunk/qgis/src/core/qgsgeometry.cpp
--- trunk/qgis/src/core/qgsgeometry.cpp 2008-11-27 14:05:12 UTC (rev 9712)
+++ trunk/qgis/src/core/qgsgeometry.cpp 2008-11-27 14:15:27 UTC (rev 9713)
@@ -4832,7 +4832,7 @@
GEOSGeometry *cutEdges = GEOSPolygonizer_getCutEdges( &nodedGeometry, 1 );
if ( cutEdges )
- if ( GEOSGetNumGeometries( cutEdges ) > 0 )
+ if ( numberOfGeometries( cutEdges ) > 0 )
GEOSGeom_destroy( cutEdges );
GEOSGeom_destroy( nodedGeometry );
@@ -4844,7 +4844,7 @@
#endif
GEOSGeometry *polygons = GEOSPolygonize( &nodedGeometry, 1 );
- if ( !polygons || GEOSGetNumGeometries( polygons ) == 0 )
+ if ( !polygons || numberOfGeometries( polygons ) == 0 )
if ( polygons )
GEOSGeom_destroy( polygons );
@@ -4864,7 +4864,7 @@
//ratio intersect geometry / geometry. This should be close to 1
//if the polygon belongs to the input geometry
- for ( int i = 0; i < getNumberOfGeometries( polygons ); i++ )
+ for ( int i = 0; i < numberOfGeometries( polygons ); i++ )
const GEOSGeometry *polygon = GEOSGetGeometryN( polygons, i );
intersectGeometry = GEOSIntersection( mGeos, polygon );
@@ -4883,7 +4883,7 @@
bool splitDone = true;
- int nGeometriesThis = getNumberOfGeometries( mGeos ); //original number of geometries
+ int nGeometriesThis = numberOfGeometries( mGeos ); //original number of geometries
if ( testedGeometries.size() == nGeometriesThis )
splitDone = false;
@@ -5003,7 +5003,7 @@
return unionGeometry;
-int QgsGeometry::getNumberOfGeometries(GEOSGeometry* g) const
+int QgsGeometry::numberOfGeometries(GEOSGeometry* g) const
if(!g)
Modified: trunk/qgis/src/core/qgsgeometry.h
--- trunk/qgis/src/core/qgsgeometry.h 2008-11-27 14:05:12 UTC (rev 9712)
+++ trunk/qgis/src/core/qgsgeometry.h 2008-11-27 14:15:27 UTC (rev 9713)
@@ -418,7 +418,7 @@
GEOSGeometry* nodeGeometries( const GEOSGeometry *splitLine, GEOSGeometry *poly ) const;
/**Returns number of single geometry in a geos geometry. Is save for geos 2 and 3*/
- int getNumberOfGeometries(GEOSGeometry* g) const;
+ int numberOfGeometries(GEOSGeometry* g) const;
int mergeGeometriesMultiTypeSplit( QVector<GEOSGeometry*>& splitResult );
