[QGIS Commit] r9254 - trunk/qgis/src/core/raster
svn_qgis at osgeo.org
Wed Sep 3 18:09:13 EDT 2008
Author: ersts
Date: 2008-09-03 18:09:13 -0400 (Wed, 03 Sep 2008)
New Revision: 9254
trunk/qgis/src/core/raster/qgscolorrampshader.cpp
trunk/qgis/src/core/raster/qgscolorrampshader.h
-More intelligent search through color ramp item list
-Fix bug that prevented color cache from working
-Results in significant improvement in rendering speeds for paletted images
Modified: trunk/qgis/src/core/raster/qgscolorrampshader.cpp
--- trunk/qgis/src/core/raster/qgscolorrampshader.cpp 2008-09-03 10:31:46 UTC (rev 9253)
+++ trunk/qgis/src/core/raster/qgscolorrampshader.cpp 2008-09-03 22:09:13 UTC (rev 9254)
@@ -25,14 +25,16 @@
QgsColorRampShader::QgsColorRampShader( double theMinimumValue, double theMaximumValue ) : QgsRasterShaderFunction( theMinimumValue, theMaximumValue )
QgsDebugMsg( "called." );
- mMaximumColorCacheSize = 256; //good starting value
+ mMaximumColorCacheSize = 1024; //good starting value
+ mCurrentColorRampItemIndex = 0;
bool QgsColorRampShader::generateShadedValue( double theValue, int* theReturnRedValue, int* theReturnGreenValue, int* theReturnBlueValue )
- //Get the shaded from the cache if it exists already
+ //Get the shaded value from the cache if it exists already
QColor myColor = mColorCache.value(theValue);
- if(myColor.isValid())
+ if ( myColor.isValid() )
*theReturnRedValue = myColor.red();
*theReturnGreenValue = myColor.green();
@@ -40,17 +42,28 @@
return true;
- //Else we have to generate the shaded value
- if ( QgsColorRampShader::INTERPOLATED == mColorRampType )
+ //pixel value not in cache so generate new value
+ //Check to be sure mCurrentColorRampItemIndex is within the valid range.
+ if ( mCurrentColorRampItemIndex < 0 )
- return getInterpolatedColor( theValue, theReturnRedValue, theReturnGreenValue, theReturnBlueValue );
- else if ( QgsColorRampShader::DISCRETE == mColorRampType )
+ else if ( mCurrentColorRampItemIndex >= mColorRampItemList.size() )
- return getDiscreteColor( theValue, theReturnRedValue, theReturnGreenValue, theReturnBlueValue );
+ mCurrentColorRampItemIndex = mColorRampItemList.size() - 1;
- return getExactColor( theValue, theReturnRedValue, theReturnGreenValue, theReturnBlueValue );
+ if ( QgsColorRampShader::EXACT == mColorRampType )
+ return getExactColor( theValue, theReturnRedValue, theReturnGreenValue, theReturnBlueValue );
+ else if ( QgsColorRampShader::INTERPOLATED == mColorRampType )
+ return getInterpolatedColor( theValue, theReturnRedValue, theReturnGreenValue, theReturnBlueValue );
+ return getDiscreteColor( theValue, theReturnRedValue, theReturnGreenValue, theReturnBlueValue );
bool QgsColorRampShader::generateShadedValue( double theRedValue, double theGreenValue, double theBlueValue, int* theReturnRedValue, int* theReturnGreenValue, int* theReturnBlueValue )
@@ -81,54 +94,84 @@
bool QgsColorRampShader::getDiscreteColor( double theValue, int* theReturnRedValue, int* theReturnGreenValue, int* theReturnBlueValue )
- if ( mColorRampItemList.count() <= 0 )
+ int myColorRampItemCount = mColorRampItemList.count();
+ if ( myColorRampItemCount <= 0 )
return false;
- QList<QgsColorRampShader::ColorRampItem>::const_iterator it;
- QList<QgsColorRampShader::ColorRampItem>::const_iterator last_it = mColorRampItemList.begin();
- double myCurrentRampValue;
- for ( it = mColorRampItemList.begin(); it != mColorRampItemList.end(); ++it )
+ QgsColorRampShader::ColorRampItem myColorRampItem;
+ while ( mCurrentColorRampItemIndex >= 0 && mCurrentColorRampItemIndex < myColorRampItemCount )
- myCurrentRampValue = it->value;
- if ( theValue <= myCurrentRampValue )
+ //Start searching from the last index - assumtion is that neighboring pixels tend to be similar values
+ myColorRampItem = mColorRampItemList.value( mCurrentColorRampItemIndex );
+ //If the previous entry is less, then search closer to the top of the list (assumes mColorRampItemList is sorted)
+ if ( mCurrentColorRampItemIndex != 0 && theValue <= mColorRampItemList.at( mCurrentColorRampItemIndex - 1 ).value )
- *theReturnRedValue = it->color.red();
- *theReturnGreenValue = it->color.green();
- *theReturnBlueValue = it->color.blue();
+ mCurrentColorRampItemIndex--;
+ else if ( theValue <= myColorRampItem.value )
+ *theReturnRedValue = myColorRampItem.color.red();
+ *theReturnGreenValue = myColorRampItem.color.green();
+ *theReturnBlueValue = myColorRampItem.color.blue();
//Cache the shaded value
- if(mMaximumColorCacheSize <= mColorCache.size())
+ if ( mMaximumColorCacheSize >= mColorCache.size() )
- mColorCache.insert(theValue, it->color);
+ mColorCache.insert( theValue, myColorRampItem.color );
return true;
+ //Search deeper into the color ramp list
+ else
+ mCurrentColorRampItemIndex++;
return false; // value not found
bool QgsColorRampShader::getExactColor( double theValue, int* theReturnRedValue, int* theReturnGreenValue, int* theReturnBlueValue )
return false;
- if ( theValue == it->value )
+ if ( theValue == myColorRampItem.value )
return true;
+ //pixel value sits between ramp entries so bail
+ else if ( mCurrentColorRampItemIndex != myColorRampItemCount - 1 && theValue > myColorRampItem.value && theValue < mColorRampItemList.at( mCurrentColorRampItemIndex + 1 ).value )
+ return false;
+ else if ( theValue > myColorRampItem.value )
+ //Search back toward the begining of the list
+ else
@@ -136,47 +179,82 @@
bool QgsColorRampShader::getInterpolatedColor( double theValue, int* theReturnRedValue, int* theReturnGreenValue, int* theReturnBlueValue )
return false;
- QList<QgsColorRampShader::ColorRampItem>::const_iterator last_it = mColorRampItemList.end();
double myCurrentRampRange; //difference between two consecutive entry values
- double myDiffTheValueLastRampValue; //difference between value and last entry value
- double myDiffCurrentRampValueTheValue; //difference between this entry value and value
+ double myOffsetInRange; //difference between the previous entry value and value
- if ( last_it != mColorRampItemList.end() )
+ else if ( mCurrentColorRampItemIndex != 0 && theValue <= myColorRampItem.value )
+ QgsColorRampShader::ColorRampItem myPreviousColorRampItem = mColorRampItemList.value( mCurrentColorRampItemIndex - 1 );
+ myCurrentRampRange = myColorRampItem.value - myPreviousColorRampItem.value;
+ myOffsetInRange = theValue - myPreviousColorRampItem.value;
+ *theReturnRedValue = ( int )(( double ) myPreviousColorRampItem.color.red() + ((( double ) (myColorRampItem.color.red() - myPreviousColorRampItem.color.red()) / myCurrentRampRange ) * myOffsetInRange ));
+ *theReturnGreenValue = ( int )(( double ) myPreviousColorRampItem.color.green() + ((( double ) (myColorRampItem.color.green() - myPreviousColorRampItem.color.green()) / myCurrentRampRange) * myOffsetInRange ));
+ *theReturnBlueValue = ( int )(( double ) myPreviousColorRampItem.color.blue() + ((( double ) (myColorRampItem.color.blue() - myPreviousColorRampItem.color.blue()) / myCurrentRampRange ) * myOffsetInRange));
- myCurrentRampRange = myCurrentRampValue - last_it->value;
- myDiffTheValueLastRampValue = theValue - last_it->value;
- myDiffCurrentRampValueTheValue = myCurrentRampValue - theValue;
+ QColor myNewColor( *theReturnRedValue, *theReturnGreenValue, *theReturnBlueValue );
+ mColorCache.insert( theValue, myNewColor );
+ return true;
+ else if ( mCurrentColorRampItemIndex == 0 && theValue <= myColorRampItem.value )
- *theReturnRedValue = ( int )(( it->color.red() * myDiffTheValueLastRampValue + last_it->color.red() * myDiffCurrentRampValueTheValue ) / myCurrentRampRange );
- *theReturnGreenValue = ( int )(( it->color.green() * myDiffTheValueLastRampValue + last_it->color.green() * myDiffCurrentRampValueTheValue ) / myCurrentRampRange );
- *theReturnBlueValue = ( int )(( it->color.blue() * myDiffTheValueLastRampValue + last_it->color.blue() * myDiffCurrentRampValueTheValue ) / myCurrentRampRange );
- //Cache the shaded value
- return true;
+ return true;
- last_it = it;
+ else
+ return false;
return false;
+void QgsColorRampShader::setColorRampType( QgsColorRampShader::COLOR_RAMP_TYPE theColorRampType )
+ //When the ramp type changes we need to clear out the cache
+ mColorCache.clear();
+ mColorRampType = theColorRampType;
void QgsColorRampShader::setColorRampType( QString theType )
+ //When the type of the ramp changes we need to clear out the cache
if ( theType == "INTERPOLATED" )
mColorRampType = INTERPOLATED;
Modified: trunk/qgis/src/core/raster/qgscolorrampshader.h
--- trunk/qgis/src/core/raster/qgscolorrampshader.h 2008-09-03 10:31:46 UTC (rev 9253)
+++ trunk/qgis/src/core/raster/qgscolorrampshader.h 2008-09-03 22:09:13 UTC (rev 9254)
@@ -67,10 +67,10 @@
int getMaximumColorCacheSize() { return mMaximumColorCacheSize; }
/**Set custom colormap */
- void setColorRampItemList( const QList<QgsColorRampShader::ColorRampItem>& theList ) { mColorRampItemList = theList; }
+ void setColorRampItemList( const QList<QgsColorRampShader::ColorRampItem>& theList ) { mColorRampItemList = theList; } //TODO: sort on set
/**Set the color ramp type*/
- void setColorRampType( QgsColorRampShader::COLOR_RAMP_TYPE theColorRampType ) {mColorRampType = theColorRampType;}
+ void setColorRampType( QgsColorRampShader::COLOR_RAMP_TYPE theColorRampType );
void setColorRampType( QString );
@@ -93,7 +93,11 @@
QgsColorRampShader::COLOR_RAMP_TYPE mColorRampType;
QMap<double, QColor> mColorCache;
- int mMaximumColorCacheSize; //The color cache could eat a ton of memory if you have 32-bit data
+ /** Maximum size of the color cache. The color cache could eat a ton of memory if you have 32-bit data */
+ int mMaximumColorCacheSize;
+ /** Current index to start searching the color table*/
+ int mCurrentColorRampItemIndex;
#endif
