[QGIS Commit] r9339 - in docs/trunk/english_us/user_guide: .
appendices
svn_qgis at osgeo.org
Tue Sep 16 13:46:03 EDT 2008
Author: dassau
Date: 2008-09-16 13:46:02 -0400 (Tue, 16 Sep 2008)
New Revision: 9339
Added:
docs/trunk/english_us/user_guide/appendices/grass_toolbox_modules.tex
docs/trunk/english_us/user_guide/grass_integration.tex
docs/trunk/english_us/user_guide/user_guide.tex
started to add all GRASS Toolbox modules in appendix
Added: docs/trunk/english_us/user_guide/appendices/grass_toolbox_modules.tex
--- docs/trunk/english_us/user_guide/appendices/grass_toolbox_modules.tex (rev 0)
+++ docs/trunk/english_us/user_guide/appendices/grass_toolbox_modules.tex 2008-09-16 17:46:02 UTC (rev 9339)
@@ -0,0 +1,634 @@
+\section{GRASS Toolbox modules}\label{appdx_grass_toolbox_modules}
+% when the revision of a section has been finalized,
+% comment out the following line:
+\updatedisclaimer
+\subsubsection{Data import and export modules}\index{GRASS!toolbox!modules}
+In the GRASS Toolbox you find many modules to import and export data into
+the binary GRASS raster and vector format.
+\begin{table}[ht]
+\centering
+\caption{GRASS Toolbox data import modules}\medskip
+ \begin{tabular}{|l|p{5.3in}|}
+ \hline \multicolumn{2}{|c|}{\textbf{Data import modules in the GRASS
+ Toolbox}} \\
+ \hline \textbf{Module name} & \textbf{Purpose} \\
+ \hline r.in.arc & Convert an ESRI ARC/INFO ascii raster file (GRID) into a
+ (binary) raster map layer\\
+ \hline r.in.ascii & Convert an ASCII raster text file into a (binary)
+ raster map layer \\
+ \hline r.in.aster & Georeferencing, rectification, and import of
+ Terra-ASTER imagery and relative DEM's using gdalwarp \\
+ \hline r.in.gdal & Import GDAL supported raster file into a GRASS binary
+ \hline r.in.gdal.loc & Import GDAL supported raster file into a GRASS
+ binary raster map layer and create a fitted location \\
+ \hline r.in.gridatb & Imports GRIDATB.FOR map file (TOPMODEL) into GRASS
+ raster map \\
+ \hline r.in.mat & Import a binary MAT-File(v4) to a GRASS raster \\
+ \hline r.in.poly & Create raster maps from ascii polygon/line data files
+ in the current directory \\
+ \hline r.in.srtm & Import SRTM HGT files into GRASS \\
+ \hline v.in.db & Import vector points from a database table containing
+ coordinates \\
+ \hline v.in.dxf.multiple & Import only same layers of a DXF vector \\
+ \hline v.in.dxf & Import DXF vector layer \\
+ \hline v.in.e00 & Import ESRI E00 file in a vector map \\
+ \hline v.in.garmin & Import vector from gps using gpstrans \\
+ \hline v.in.gpsbabel & Import vector from gps using gpsbabel \\
+ \hline v.in.mapgen & Import MapGen or MatLab vectors in GRASS \\
+ \hline v.in.ogr.all.loc & Import all the OGR/PostGIS vector layers in a
+ given data source and create a fitted location \\
+ \hline v.in.ogr.all & Import all the OGR/PostGIS vector layers in a given
+ data source \\
+ \hline v.in.ogr.loc & Import OGR/PostGIS vector layers and create a fitted
+ location\\
+ \hline v.in.ogr & Import OGR/PostGIS vector layers \\
+ \hline v.in.region & Create new vector area map with current region extent \\
+\hline
+\end{tabular}
+\end{table}
+\begin{table}[ht]
+\centering
+\caption{GRASS Toolbox data export modules}\medskip
+ \hline \multicolumn{2}{|c|}{\textbf{Data export modules in the GRASS
+ Toolbox}} \\
+ \hline r.out.gdal.gtiff & Export raster layer to Geo TIFF \\
+ \hline r.out.arc & Converts a raster map layer into an ESRI ARCGRID file \\
+ \hline r.gridatb & Exports GRASS raster map to GRIDATB.FOR map file
+ (TOPMODEL) \\
+ \hline r.out.mat & Exports a GRASS raster to a binary MAT-File \\
+ \hline r.out.bin & Exports a GRASS raster to a binary array \\
+ \hline r.out.png & Export GRASS raster as non-georeferenced PNG image
+ format \\
+ \hline r.out.ppm & Converts a GRASS raster map to a PPM image file at the
+ pixel resolution of the CURRENTLY DEFINED REGION \\
+ \hline r.out.ppm3 & Converts 3 GRASS raster layers (R,G,B) to a PPM image
+ file at the pixel resolution of the CURRENTLY DEFINED REGION \\
+ \hline r.out.pov & Converts a raster map layer into a height-field file for
+ POVRAY\\
+ \hline r.out.tiff & Exports a GRASS raster map to a 8/24bit TIFF image file
+ at the pixel resolution of the currently defined region\\
+ \hline r.out.vrml & Export a raster map to the Virtual Reality Modeling
+ Language (VRML)\\
+ \hline r.out.xyz & Export a raster map to a text file as x,y,z values based
+ on cell centers\\
+ \hline v.out.ogr & Export vector layer to various formats (OGR library) \\
+ \hline v.out.ogr.shape & Export vector layer to Shape \\
+ \hline v.out.ogr.gml & Export vector layer to GML \\
+ \hline v.out.ogr.postgis & Export vector layer to various formats (OGR
+ library) \\
+ \hline v.out.ogr.mapinfo & Mapinfo export of vector layer \\
+ \hline v.out.ascii & Convert a GRASS binary vector map to a GRASS ASCII
+ vector map \\
+ \hline v.out.dxf & converts a GRASS vector map to DXF \\
+\hline
+\end{tabular}
+\end{table}
+\subsubsection{Data type conversion modules}
+\begin{table}[ht]
+\centering
+\caption{GRASS Toolbox data type conversion modules}\medskip
+ \hline \multicolumn{2}{|c|}{\textbf{Data type conversion modules in the GRASS
+ Toolbox}} \\
+ \hline r.to.vect.point & Convert a raster to vector points \\
+ \hline r.to.vect.line & Convert a raster to vector lines \\
+ \hline r.to.vect.area & Convert a raster to vector areas \\
+ \hline r.to.null & Transform cells with value in null cells \\
+ \hline v.to.rast.constant & Convert a vector to raster using constant \\
+ \hline v.to.rast.attr & Convert a vector to raster using attribute values \\
+ \hline v.to.points & Create points along input lines \\
+\hline
+\end{tabular}
+\end{table}
+\subsubsection{Region and projection configuration modules}
+GRASS GIS region and projection configuration modules.
+\begin{table}[ht]
+\centering
+\caption{GRASS Toolbox region and projection configuration modules}\medskip
+ \hline \multicolumn{2}{|c|}{\textbf{Region and projection configuration modules in the GRASS
+ Toolbox}} \\
+ \hline g.region.multiple.raster & Set the region to match multiple raster
+ maps \\
+ \hline g.region.multiple.vector & Set the region to match multiple vector
+ maps \\
+ \hline g.region.save & Save the current region as a named region \\
+ \hline g.region.zoom & Shrink the current region until it meets non-NULL
+ data from a given raster map \\
+ \hline g.proj.print & Print projection information of the current location\\
+ \hline g.proj.geo & Print projection information from a georeferenced file
+ (raster, vector or image)\\
+ \hline g.proj.proj & Print projection information from a PROJ.4 projection
+ description file\\
+ \hline g.proj.ascii.new & Print projection information from a georeferenced
+ ASCII file containing a WKT projection description and create a new
+ location based on it\\
+ \hline g.proj.geo.new & Print projection information from a georeferenced
+ file (raster, vector or image) and create a new location based on it\\
+ \hline g.proj.proj.new & Print projection information from a PROJ.4
+ projection description file and create a new location based on it \\
+ \hline m.cogo & A simple utility for converting bearing and distance
+ measurements to coordinates and vice versa. It assumes a cartesian
+ coordinate system \\
+\hline
+\end{tabular}
+\end{table}
+\subsubsection{Raster data modules}
+Raster data analysis in GRASS GIS
+\begin{table}[ht]
+\centering
+\caption{GRASS Toolbox develop raster map modules}\medskip
+ \hline \multicolumn{2}{|c|}{\textbf{Develop raster map modules in the GRASS
+ Toolbox}} \\
+ \hline r.compress & Compresses and decompresses raster maps \\
+ \hline r.region.region & Sets the boundary definitions to current or
+ default region \\
+ \hline r.region.raster & Sets the boundary definitions from existent raster
+ map\\
+ \hline r.region.vector & Sets the boundary definitions from existent vector map \\
+ \hline r.region.edge & Sets the boundary definitions by edge (n-s-e-w) \\
+ \hline r.region.alignTo & Sets region to align to a raster map\\
+ \hline r.null.null & Transform cells with value in null cells\\
+ \hline r.null.to & Transform null cells in value cells\\
+ \hline r.quant & This routine produces the quantization file for a
+ floating-point map \\
+ \hline r.resamp.stats & Resamples raster map layers using aggregation \\
+ \hline r.resamp.interp & Resamples raster map layers using interpolation \\
+ \hline r.resample & GRASS raster map layer data resampling capability.
+ Before you must set new resolution\\
+ \hline r.resamp.rst & Reinterpolates and computes topographic analysis
+ using regularized spline with tension and smoothing \\
+ \hline r.support & Allows creation and/or modification of raster map layer
+ support files\\
+ \hline r.support.stats & Update raster map statistics \\
+ \hline r.proj & Re-project a raster map from one location to the current
+ location \\
+\hline
+\end{tabular}
+\end{table}
+\begin{table}[ht]
+\centering
+\caption{GRASS Toolbox raster color management modules}\medskip
+ \hline \multicolumn{2}{|c|}{\textbf{Raster color management modules in the GRASS
+ Toolbox}} \\
+ \hline r.colors.table & Set raster color table from setted tables \\
+ \hline r.colors.rules & Set raster color table from setted rules \\
+ \hline r.blend & Blend color components for two raster maps by given ratio \\
+ \hline r.composite & Blend red, green, raster layers to obtain one color
+ raster \\
+ \hline r.his & Generates red, green and blue raster map layers combining
+ hue, intensity, and saturation (his) values from user-specified input
+ raster map layers \\
+\hline
+\end{tabular}
+\end{table}
+\begin{table}[ht]
+\centering
+\caption{GRASS Toolbox spatial raster analysis modules}\medskip
+ \hline \multicolumn{2}{|c|}{\textbf{Spatial raster analysis modules in the GRASS
+ Toolbox}} \\
+ \hline r.buffer & Raster buffer \\
+ \hline r.mask & Create a MASK for limiting raster operation \\
+ \hline r.mapcalc & Raster map calculator \\
+ \hline r.mapcalculator & Simple map algebra \\
+ \hline r.neighbors & Raster neighbors analyses \\
+ \hline v.neighbors & Count of neighbouring points \\
+ \hline r.statistics & Category or object oriented statistics \\
+ \hline r.cost & Outputs a raster map layer showing the cumulative cost of
+ moving between different geographic locations on an input raster map layer
+ whose cell category values represent cost\\
+ \hline r.drain & Traces a flow through an elevation model on a raster map
+ layer \\
+ \hline r.shaded.relief & Create shaded map \\
+ \hline r.slope.aspect.slope & Generate slope map from DEM (digital
+ elevation model) \\
+ \hline r.slope.aspect.aspect & Generate aspect map from DEM (digital
+ \hline r.param.scale & Extracts terrain parameters from a DEM \\
+ \hline r.texture & Generate images with textural features from a raster map
+ (first serie of indices)\\
+ \hline r.texture.bis & Generate images with textural features from a raster
+ map (second serie of indices)\\
+ \hline r.los & Line-of-sigth raster analysis \\
+ \hline r.clump & Recategorizes into unique categories contiguous cells \\
+ \hline r.grow & Generates a raster map layer with contiguous areas grown by
+ one cell\\
+ \hline r.thin & Thin no-zero cells that denote line features \\
+\hline
+\end{tabular}
+\end{table}
+\begin{table}[ht]
+\centering
+\caption{GRASS Toolbox hydrologic modelling modules}\medskip
+ \hline \multicolumn{2}{|c|}{\textbf{Hydrologic modelling modules in the GRASS
+ Toolbox}} \\
+ \hline r.carve & Takes vector stream data, transforms it to raster, and
+ subtracts depth from the output DEM \\
+ \hline r.fill.dir & Filters and generates a depressionless elevation map
+ and a flow direction map from a given elevation layer \\
+ \hline r.lake.xy & Fills lake from seed point at given level \\
+ \hline r.lake.seed & Fills lake from seed at given level \\
+ \hline r.topidx & Creates a 3D volume map based on 2D elevation and value
+ raster maps \\
+ \hline r.basins.fill & Generates a raster map layer showing watershed
+ subbasins \\
+ \hline r.water.outlet & Watershed basin creation program \\
+\hline
+\end{tabular}
+\end{table}
+\begin{table}[ht]
+\centering
+\caption{GRASS Toolbox change raster category values and labels modules}\medskip
+ \hline \multicolumn{2}{|c|}{\textbf{Raster category and label modules in the GRASS Toolbox}} \\
+ \hline r.reclass.area.greater & Reclasses a raster map greater than user
+ specified area size (in hectares) \\
+ \hline r.reclass.area.lesser & Reclasses a raster map less than user
+ \hline r.reclass & Reclass a raster using a reclassification rules file \\
+ \hline r.recode & Recode raster maps\\
+ \hline r.rescale & Rescales the range of category values in a raster map
+ layer \\
+\hline
+\end{tabular}
+\end{table}
+\begin{table}[ht]
+\centering
+\caption{GRASS Toolbox surface management modules}\medskip
+ \hline \multicolumn{2}{|c|}{\textbf{Surface management modules in the GRASS
+ Toolbox}} \\
+ \hline r.random & Creates a random vector point map contained in a raster \\
+ \hline r.random.cells & Generates random cell values with spatial
+ dependence \\
+ \hline v.kernel & Gaussian kernel density \\
+ \hline r.contour & Produces a contours vector map with specified step from
+ a raster map\\
+ \hline r.contour2 & Produces a contours vector map of specified contours
+ from a raster map \\
+ \hline r.surf.fractal & Creates a fractal surface of a given fractal
+ dimension\\
+ \hline r.surf.gauss & GRASS module to produce a raster map layer of
+ gaussian deviates whose mean and standard deviation can be expressed by the
+ user \\
+ \hline r.surf.random & Produces a raster map layer of uniform random
+ deviates whose range can be expressed by the user \\
+ \hline r.bilinear & Bilinear interpolation utility for raster map layers \\
+ \hline v.surf.bispline & Bicubic or bilinear spline interpolation with
+ Tykhonov regularization\\
+ \hline r.surf.idw & Surface interpolation utility for raster map layers\\
+ \hline r.surf.idw2 & Surface generation program\\
+ \hline r.surf.contour & Surface generation program from rasterized contours \\
+ \hline v.surf.idw & Interpolate attribute values (IDW) \\
+ \hline v.surf.rst & Interpolate attribute values (RST) \\
+ \hline r.fillnulls & Fills no-data areas in raster maps using v.surf.rst
+ splines interpolation \\
+\hline
+\end{tabular}
+\end{table}
+\begin{table}[ht]
+\centering
+\caption{GRASS Toolbox statistic analysis modules}\medskip
+ \hline \multicolumn{2}{|c|}{\textbf{Statistic analysis modules in the GRASS
+ Toolbox}} \\
+ \hline r.category & Prints category values and labels associated with
+ user-specified raster map layers \\
+ \hline r.sum & Sums up the raster cell values \\
+ \hline r.report & Reports statistics for raster map layers \\
+ \hline r.average & Finds the average of values in a cover map within areas
+ assigned the same category value in a user-specified base map \\
+ \hline r.median & Finds the median of values in a cover map within areas
+ \hline r.mode & Finds the mode of values in a cover map within areas
+ assigned the same category value in a user-specified base map.reproject
+ raster image \\
+ \hline r.volume & Calculates the volume of data clumps, and produces a
+ GRASS vector points map containing the calculated centroids of these clumps \\
+ \hline r.surf.area & Surface area estimation for rasters \\
+ \hline r.covar & Outputs a covariance/correlation matrix for user-specified
+ raster map layer(s)\\
+ \hline r.regression.line & Calculates linear regression from two raster
+ maps: y = a + b * x \\
+ \hline r.coin & Tabulates the mutual occurrence (coincidence) of categories
+ for two raster map layers\\
+\hline
+\end{tabular}
+\end{table}
+\subsubsection{GRASS Toolbox vector data modules}
+GRASS vector data analysis ...
+\begin{table}[ht]
+\centering
+\caption{GRASS Toolbox develop vector map modules}\medskip
+ \hline \multicolumn{2}{|c|}{\textbf{Develop vector map modules in the GRASS
+ Toolbox}} \\
+ \hline v.build.all & Rebuild topology of all vectors in the mapset \\
+ \hline v.clean.break & Break lines at each intersection of vector map \\
+ \hline v.clean.snap & Cleaning topology: snap lines to vertex in threshold \\
+ \hline v.clean.rmdangles & Cleaning topology: remove dangles \\
+ \hline v.clean.chdangles & Cleaning topology: change the type of boundary
+ dangle to line \\
+ \hline v.clean.rmbridge & Remove bridges connecting area and island or 2
+ islands \\
+ \hline v.clean.rmdupl & Remove duplicate lines (pay attention to
+ categories!) \\
+ \hline v.clean.rmdac & Remove duplicate area centroids \\
+ \hline v.clean.bpol & Break (topologically clean) polygons (imported from
+ non topological format, like ShapeFile). Boundaries are broken on each
+ point shared between 2 and more polygons where angles of segments are
+ different \\
+ \hline v.clean.prune & Remove vertices in threshold from lines and
+ boundaries, boundary is pruned only if topology is not damaged (new
+ intersection, changed attachement of centroid), first and last segment of
+ the boundary is never changed \\
+ \hline v.clean.rmarea & Remove small areas, the longest boundary with
+ adjacent area is removed \\
+ \hline v.clean.rmline & Remove all lines or boundaries of zero length \\
+ \hline v.clean.rmsa & Remove small angles between lines at nodes \\
+ \hline v.type.lb & Convert lines to boundaries \\
+ \hline v.type.bl & Convert boundaries to lines \\
+ \hline v.type.pc & Convert points to centroids \\
+ \hline v.type.cp & Convert centroids to points \\
+ \hline v.centroids & Add missing centroids to closed boundaries \\
+ \hline v.build.polylines & Build polylines from lines \\
+ \hline v.segment & Creates points/segments from input vector lines and
+ positions \\
+ \hline v.parallel & Create parallel line to input lines \\
+ \hline v.dissolve & Dissolves boundaries between adjacent areas sharing a
+ common category number or attribute \\
+ \hline v.drape & Convert 2D vector to 3D vector by sampling of elevation
+ raster. Default sampling by nearest neighbor \\
+ \hline v.transform & Performs an affine transformation (shift, scale and
+ rotate, or GPCs) on vector map \\
+ \hline v.proj & Allows projection conversion of vector files \\
+\hline
+\end{tabular}
+\end{table}
+\begin{table}[ht]
+\centering
+\caption{GRASS Toolbox database connection modules}\medskip
+ \hline \multicolumn{2}{|c|}{\textbf{Database connection modules in the GRASS
+ Toolbox}} \\
+ \hline v.db.connect & Connect a vector to database \\
+ \hline v.db.sconnect & Disconnect a vector from database \\
+ \hline v.db.what.connect & Set/Show database connection for a vector \\
+\hline
+\end{tabular}
+\end{table}
+\begin{table}[ht]
+\centering
+\caption{GRASS Toolbox spatial and network analysis modules}\medskip
+ \hline \multicolumn{2}{|c|}{\textbf{Spatial and network analysis modules in the GRASS
+ Toolbox}} \\
+ \hline v.extract.where & Select features by attributes \\
+ \hline v.extract.list & Extract selected features \\
+ \hline v.select.overlap & Select features overlapped by features in another
+ map\\
+ \hline v.buffer & Vector buffer \\
+ \hline v.distance & Find the nearest element in vector 'to' for elements in
+ vector 'from'. Various information about this relation may be uploaded to
+ the attribute table of input vector 'from'\\
+ \hline v.net.nodes & Create nodes on network \\
+ \hline v.net.alloc & Allocate network\\
+ \hline v.net.iso & Cut network by cost isolines \\
+ \hline v.net.salesman & Connect nodes by shortest route (traveling
+ salesman) \\
+ \hline v.net.steiner & Connect selected nodes by shortest tree (Steiner
+ tree) \\
+ \hline v.overlay.or & Vector union \\
+ \hline v.overlay.and & Vector intersection \\
+ \hline v.overlay.not & Vector subtraction \\
+ \hline v.overlay.xor & Vector non-intersection \\
+\hline
+\end{tabular}
+\end{table}
+\begin{table}[ht]
+\centering
+\caption{GRASS Toolbox change field modules}\medskip
+ \hline \multicolumn{2}{|c|}{\textbf{Change vector field modules in the GRASS
+ Toolbox}} \\
+ \hline v.category.change & Change layer number \\
+ \hline v.category.add & Add elements to layer (ALL elements of the selected
+ layer type!)\\
+ \hline v.category.del & Delete category values \\
+ \hline v.category.sum & Add a value to the current category values \\
+ \hline v.reclass.file & Reclass category values using a rules file \\
+ \hline v.reclass.attr & Reclass category values using a column attribute
+ (integer positive) \\
+\hline
+\end{tabular}
+\end{table}
+\begin{table}[ht]
+\centering
+\caption{GRASS Toolbox working with vector points modules}\medskip
+ \hline \multicolumn{2}{|c|}{\textbf{Working with vector points modules in the GRASS Toolbox}} \\
+ \hline v.mkgrid.region & Create grid in current region \\
+ coordinates \\
+ \hline v.hull & Create a convex hull \\
+ \hline v.delaunay.line & Delaunay triangulation (lines) \\
+ \hline v.delaunay.area & Delaunay triangulation (areas) \\
+ \hline v.voronoi.line & Voronoi diagram (lines) \\
+ \hline v.voronoi.area & Voronoi diagram (areas) \\
+\hline
+\end{tabular}
+\end{table}
+\begin{table}[ht]
+\centering
+\caption{GRASS Toolbox vector update by other maps modules}\medskip
+ \hline \multicolumn{2}{|c|}{\textbf{Vector update by other maps modules in the GRASS
+ Toolbox}} \\
+ \hline v.rast.stats & Calculates univariate statistics from a GRASS raster
+ map based on vector objects\\
+ \hline v.what.vect & Uploads map for which to edit attribute table \\
+ \hline v.what.rast & Uploads raster values at positions of vector points to
+ the table \\
+ \hline v.sample & Sample a raster file at site locations \\
+\hline
+\end{tabular}
+\end{table}
+\begin{table}[ht]
+\centering
+\caption{GRASS Toolbox report and statistic modules}\medskip
+ \hline \multicolumn{2}{|c|}{\textbf{Vector report and statistic modules in the GRASS
+ Toolbox}} \\
+ \hline v.to.db & Put geometry variables in database \\
+ \hline v.report & Reports geometry statistics for vectors \\
+ \hline v.univar & Calculates univariate statistics on selected table column
+ for a GRASS vector map \\
+ \hline v.normal & Tests for normality for points\\
+\hline
+\end{tabular}
+\end{table}
+\subsubsection{GRASS Toolbox imagery data modules}
+Imagery Modules in GRASS GIS
+\begin{table}[ht]
+\centering
+\caption{GRASS Toolbox imagery analysis modules}\medskip
+ \hline \multicolumn{2}{|c|}{\textbf{Imagery analysis modules in the GRASS
+ Toolbox}} \\
+ \hline i.image.mosaik & Mosaic up to 4 images \\
+ \hline i.rgb.his & Red Green Blue (RGB) to Hue Intensity Saturation (HIS)
+ raster map color transformation function \\
+ \hline i.his.rgb & Hue Intensity Saturation (HIS) to Red Green Blue (RGB)
+ raster map color transform function \\
+ \hline i.landsat.rgb & Auto-balancing of colors for LANDSAT images \\
+ \hline i.fusion.brovey & Brovey transform to merge multispectral and
+ high-res pancromatic channels \\
+ \hline i.zc & Zero-crossing edge detection raster function for image
+ processing \\
+ \hline i.mfilter & \\
+ \hline i.tasscap4 & Tasseled Cap (Kauth Thomas) transformation for
+ LANDSAT-TM 4 data \\
+ \hline i.tasscap5 & Tasseled Cap (Kauth Thomas) transformation for
+ LANDSAT-TM 5 data \\
+ \hline i.tasscap7 & Tasseled Cap (Kauth Thomas) transformation for
+ LANDSAT-TM 7 data \\
+ \hline i.fft & Fast fourier transform for image processing \\
+ \hline i.ifft & Inverse fast fourier transform for image processing \\
+ \hline r.describe & Prints terse list of category values found in a raster
+ map layer \\
+ \hline r.bitpattern & Compares bit patterns with a raster map \\
+ \hline r.kappa & Calculate error matrix and kappa parameter for accuracy
+ assessment of classification result \\
+ \hline i.oif & Calculates optimal index factor table for landsat tm bands \\
+\hline
+\end{tabular}
+\end{table}
+\subsubsection{GRASS Toolbox database modules}
+Database Modules
+\begin{table}[ht]
+\centering
+\caption{GRASS Toolbox database modules}\medskip
+ \hline \multicolumn{2}{|c|}{\textbf{Database management and analysis modules in the GRASS
+ Toolbox}} \\
+ \hline db.connect & Sets general DB connection mapset \\
+ \hline db.connect.schema & Sets general DB connection mapset with a schema \\
+ \hline db.login & Set user/password for driver/database \\
+ \hline db.in.ogr & Imports attribute tables in various formats \\
+ \hline v.db.addtable & Create and add a new table to a vector \\
+ \hline v.db.addcol & Adds one or more columns to the attribute table
+ connected to a given vector map \\
+ \hline v.db.dropcol & Drops a column from the attribute table connected to
+ a given vector map\\
+ \hline v.db.renamecol & Renames a column in a attribute table connected to
+ \hline v.db.update\_const & Allows to assign a new constant value to a
+ column \\
+ \hline v.db.update\_query & Allows to assign a new constant value to a
+ column only if the result of a query is TRUE \\
+ \hline v.db.update\_op & Allows to assign a new value, result of operation
+ on column(s), to a column in the attribute table connected to a given map\\
+ \hline v.db.update\_op\_query & Allows to assign a new value to a column,
+ result of operation on column(s), only if the result of a query is TRUE \\
+ \hline db.execute & Execute any SQL statement \\
+ \hline v.db.join & Allows to join a table to a vector map table \\
+ \hline v.db.univar & Calculates univariate statistics on selected table
+ column for a GRASS vector map \\
+\hline
+\end{tabular}
+\end{table}
+\subsubsection{GRASS Toolbox 3D modules}
+3D Visualization and analysis
+\begin{table}[ht]
+\centering
+\caption{GRASS Toolbox 3D Visualization}\medskip
+ \hline \multicolumn{2}{|c|}{\textbf{3D visualization and analysis modules in the GRASS
+ Toolbox}} \\
+ \hline nviz & 3D visualization tool\\
+\hline
+\end{tabular}
+\end{table}
+\subsubsection{GRASS Toolbox help modules}
+GRASS GIS Help
+\begin{table}[ht]
+\centering
+\caption{GRASS Toolbox Reference Manual}\medskip
+ \hline \multicolumn{2}{|c|}{\textbf{Reference Manual modules in the GRASS
+ Toolbox}} \\
+ \hline g.manual & Open local reference manual for all GRASS modules \\
+\hline
+\end{tabular}
+\end{table}
+\clearpage
Modified: docs/trunk/english_us/user_guide/grass_integration.tex
--- docs/trunk/english_us/user_guide/grass_integration.tex 2008-09-16 07:41:18 UTC (rev 9338)
+++ docs/trunk/english_us/user_guide/grass_integration.tex 2008-09-16 17:46:02 UTC (rev 9339)
@@ -390,52 +390,15 @@
\subsection{GRASS Toolbox}\index{GRASS!toolbox}
The \toolbtntwo{grass_tools}{Open GRASS Tools} box provides analytic
-functions from GRASS within QGIS. To
-use the GRASS toolbox you need to have opened a mapset where you have
-write-permission. This is needed because QGIS will most probably create
-new datasets which need to be written to a valid mapset.
+functions from GRASS within QGIS. To use the GRASS toolbox you need to have
+opened a mapset where you have write-permission. This is needed because QGIS
+will most probably create new datasets which need to be written to a valid mapset.
-Therefore you need to start QGIS from within a GRASS session. Then your
-current mapset will be opened for writing.
+All GRASS Toolbox modules are grouped in thematic blocks. It is pretty simple
+to customize the GRASS Toolbox content as described in Section \ref{sec:toolbox-customizing}.
-Another option for opening a mapset for writing is provided through the
-GRASS plugin entry. Use Plugins->GRASS->Open mapset.
-If you have a greyed out GRASS toolbox button, make sure you open a valid
-mapset for writing, since the GRASS plugin needs a mapset to store its
-results.
-The toolbox also provides a very useful data browser for browsing through your
-current location and the mapsets it contains.
-\subsubsection{Modules inside the toolbox} \index{GRASS!toolbox!modules}
-The GRASS toolbox provides a collection of GRASS modules which can be used
-from within QGIS. They are grouped in thematic blocks which can be defined
-by the user (see Section \ref{sec:toolbox-customizing}).
-%% FIXME Include a list of available GRASS Modules as started below and
-%% as structured in QGIS Version 1.0. I would propose not to import module
-%% images, but the module names and their description
-%% Below is just an example
-\begin{table}[h]
-\centering
-\caption{List of available GRASS Toolbox Modules}\label{tab:grass_modules}\medskip
- \begin{tabular}{|l|p{5.3in}|}
- \hline \multicolumn{2}{|c|}{\textbf{Data import modules}} \\
- \hline \textbf{Module name} & \textbf{Purpose} \\
- \hline r.in.gdal & Import GDAL supported raster file into a GRASS binary raster map layer \\
- \hline r.in.gdal.loc & Import GDAL supported raster file into a GRASS
- binary raster map layer and create a fitted location \\
- \hline r.in.ascii & Converts an ASCII raster file to a GRASS binary raster map layer \\
- \hline ... & ... \\
-\hline
-\end{tabular}
-\end{table}
When clicking on a module a new tab will be added to your toolbox which
provides three new sub-tabs:
\begin{enumerate}
Modified: docs/trunk/english_us/user_guide/user_guide.tex
--- docs/trunk/english_us/user_guide/user_guide.tex 2008-09-16 07:41:18 UTC (rev 9338)
+++ docs/trunk/english_us/user_guide/user_guide.tex 2008-09-16 17:46:02 UTC (rev 9339)
@@ -38,6 +38,7 @@
\appendix
\include{appendices/supported_data_formats}
+\include{appendices/grass_toolbox_modules}
%install guide is a special case because we are extracting it
%out of the INSTALL.t2t document of in the QGIS sources
%when we tag a new document release
