[QGIS Commit] r9354 - trunk/qgis/src/core
svn_qgis at osgeo.org svn_qgis at osgeo.org
Fri Sep 19 05:05:44 EDT 2008
Author: jef
Date: 2008-09-19 05:05:44 -0400 (Fri, 19 Sep 2008)
New Revision: 9354
   trunk/qgis/src/core/qgsgeometry.cpp
fix compile errors
Modified: trunk/qgis/src/core/qgsgeometry.cpp
--- trunk/qgis/src/core/qgsgeometry.cpp	2008-09-19 07:50:17 UTC (rev 9353)
+++ trunk/qgis/src/core/qgsgeometry.cpp	2008-09-19 09:05:44 UTC (rev 9354)
@@ -3156,14 +3156,14 @@
       return 1;
-    if(topological)
+    if ( topological )
+      //find out candidate points for topological corrections
+      if ( topologicalTestPointsSplit( splitLineGeos, topologyTestPoints ) != 0 )
-	//find out candidate points for topological corrections
-	if(topologicalTestPointsSplit(splitLineGeos, topologyTestPoints) != 0)
-	    return 1;
+        return 1;
     //call split function depending on geometry type
     if ( vectorType() == QGis::Line )
@@ -4713,7 +4713,7 @@
   y = *(( double * )( &( mGeometry[wkbPosition + sizeof( double )] ) ) );
   z = 0.0; // Ignore Z for now.
-  ct.transformInPlace( x, y, z);
+  ct.transformInPlace( x, y, z );
   // new x-coordinate
   memcpy( &( mGeometry[wkbPosition] ), &x, sizeof( double ) );
@@ -4894,61 +4894,61 @@
   return 0;
-int QgsGeometry::topologicalTestPointsSplit( const GEOSGeometry* splitLine, QList<QgsPoint>& testPoints) const
+int QgsGeometry::topologicalTestPointsSplit( const GEOSGeometry* splitLine, QList<QgsPoint>& testPoints ) const
   //Find out the intersection points between splitLineGeos and this geometry.
   //These points need to be tested for topological correctness by the calling function
   //if topological editing is enabled
   testPoints.clear();
-  GEOSGeometry* intersectionGeom = GEOSIntersection(mGeos, splitLine);
-  if(intersectionGeom == NULL)
-      return 1;
+  GEOSGeometry* intersectionGeom = GEOSIntersection( mGeos, splitLine );
+  if ( intersectionGeom == NULL )
+    return 1;
   bool simple = false;
   int nIntersectGeoms = 1;
-  if(GEOSGeomTypeId(intersectionGeom) == (GEOS_LINESTRING) || GEOSGeomTypeId(intersectionGeom) == (GEOS_POINT))
+  if ( GEOSGeomTypeId( intersectionGeom ) == GEOS_LINESTRING || GEOSGeomTypeId( intersectionGeom ) == GEOS_POINT )
+    simple = true;
+  if ( !simple )
+    nIntersectGeoms = GEOSGetNumGeometries( intersectionGeom );
+  for ( int i = 0; i < nIntersectGeoms; ++i )
+    const GEOSGeometry* currentIntersectGeom;
+    if ( simple )
-      simple = true;
+      currentIntersectGeom = intersectionGeom;
-  if(!simple)
+    else
-      nIntersectGeoms = GEOSGetNumGeometries(intersectionGeom);
+      currentIntersectGeom = GEOSGetGeometryN( intersectionGeom, i );
-  for(int i = 0; i < nIntersectGeoms; ++i)
+    const GEOSCoordSequence* lineSequence = GEOSGeom_getCoordSeq( currentIntersectGeom );
+    unsigned int sequenceSize = 0;
+    double x, y;
+    if ( GEOSCoordSeq_getSize( lineSequence, &sequenceSize ) != 0 )
-      GEOSGeometry* currentIntersectGeom;
-      if(simple)
-	  currentIntersectGeom = intersectionGeom;
-      else
-	  currentIntersectGeom = GEOSGetGeometryN(intersectionGeom, i);
-      GEOSCoordSequence* lineSequence = GEOSGeom_getCoordSeq(currentIntersectGeom);
-      unsigned int sequenceSize = 0;
-      double x, y;
-      if(GEOSCoordSeq_getSize(lineSequence, &sequenceSize) != 0)
-	  for(int i = 0; i < sequenceSize; ++i)
-	      if(GEOSCoordSeq_getX(lineSequence, i, &x) != 0)
-		  if(GEOSCoordSeq_getY(lineSequence, i, &y) != 0)
-		      testPoints.push_back(QgsPoint(x, y));
+      for ( unsigned int i = 0; i < sequenceSize; ++i )
+        if ( GEOSCoordSeq_getX( lineSequence, i, &x ) != 0 )
+          if ( GEOSCoordSeq_getY( lineSequence, i, &y ) != 0 )
+            testPoints.push_back( QgsPoint( x, y ) );
-  GEOSGeom_destroy(intersectionGeom);
+  GEOSGeom_destroy( intersectionGeom );
   return 0;
More information about the QGIS-commit mailing list
