[QGIS Commit] r9403 - in trunk/qgis/src: app core
svn_qgis at osgeo.org
Wed Sep 24 10:00:55 EDT 2008
Author: homann
Date: 2008-09-24 10:00:55 -0400 (Wed, 24 Sep 2008)
New Revision: 9403
trunk/qgis/src/app/qgisapp.cpp
trunk/qgis/src/core/qgscoordinatereferencesystem.cpp
trunk/qgis/src/core/qgscoordinatereferencesystem.h
trunk/qgis/src/core/qgsmaplayer.cpp
Removed asking to validate projections of raster file, when reading a project.
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp 2008-09-24 12:03:21 UTC (rev 9402)
+++ trunk/qgis/src/app/qgisapp.cpp 2008-09-24 14:00:55 UTC (rev 9403)
@@ -270,7 +270,7 @@
//it in the ctor of the layer projection selector
QgsGenericProjectionSelector * mySelector = new QgsGenericProjectionSelector();
- mySelector->setMessage(); //shows a generic message
+ mySelector->setMessage( srs->validationHint() ); //shows a generic message, if not speficied
proj4String = QgsProject::instance()->readEntry( "SpatialRefSys", "//ProjectCRSProj4String", GEOPROJ4 );
QgsCoordinateReferenceSystem defaultCRS;
if ( defaultCRS.createFromProj4( proj4String ) )
Modified: trunk/qgis/src/core/qgscoordinatereferencesystem.cpp
--- trunk/qgis/src/core/qgscoordinatereferencesystem.cpp 2008-09-24 12:03:21 UTC (rev 9402)
+++ trunk/qgis/src/core/qgscoordinatereferencesystem.cpp 2008-09-24 14:00:55 UTC (rev 9403)
@@ -45,14 +45,16 @@
QgsCoordinateReferenceSystem::QgsCoordinateReferenceSystem()
: mMapUnits( QGis::UNKNOWN ),
- mIsValidFlag( 0 )
+ mIsValidFlag( 0 ),
+ mValidationHint ( 0 )
mCRS = OSRNewSpatialReference( NULL );
QgsCoordinateReferenceSystem::QgsCoordinateReferenceSystem( QString theWkt )
- mIsValidFlag( 0 )
createFromWkt( theWkt );
@@ -61,7 +63,8 @@
QgsCoordinateReferenceSystem::QgsCoordinateReferenceSystem( const long theId, CRS_TYPE theType )
- mIsValidFlag( 0 )
createFromId( theId, theType );
@@ -138,6 +141,7 @@
mSRID = srs.mSRID;
mEpsg = srs.mEpsg;
mIsValidFlag = srs.mIsValidFlag;
+ mValidationHint = srs.mValidationHint;
if ( mIsValidFlag )
OSRDestroySpatialReference( mCRS );
@@ -1099,6 +1103,11 @@
mCustomSrsValidation = f;
+CUSTOM_CRS_VALIDATION QgsCoordinateReferenceSystem::customSrsValidation()
+ return mCustomSrsValidation;
void QgsCoordinateReferenceSystem::debugPrint()
QgsDebugMsg( "***SpatialRefSystem***" );
@@ -1107,3 +1116,13 @@
QgsDebugMsg( "* Proj4 : " + proj4String() );
QgsDebugMsg( "* Desc. : " + mDescription );
+void QgsCoordinateReferenceSystem::setValidationHint( QString html )
+ mValidationHint = html;
+QString QgsCoordinateReferenceSystem::validationHint()
+ return mValidationHint;
Modified: trunk/qgis/src/core/qgscoordinatereferencesystem.h
--- trunk/qgis/src/core/qgscoordinatereferencesystem.h 2008-09-24 12:03:21 UTC (rev 9402)
+++ trunk/qgis/src/core/qgscoordinatereferencesystem.h 2008-09-24 14:00:55 UTC (rev 9403)
@@ -248,6 +248,10 @@
static void setCustomSrsValidation( CUSTOM_CRS_VALIDATION f );
+ /** Gets custom function
+ static CUSTOM_CRS_VALIDATION customSrsValidation();
// Accessors -----------------------------------
/*! Get the SrsId - if possible
@@ -336,6 +340,14 @@
/*! Print the description if debugging
void debugPrint();
+ /*! Set user hint for validation
+ void setValidationHint( QString html );
+ /*! Get user hint for validation
+ QString validationHint();
private:
// Open SQLite db and show message if ccannot be opened
// returns the same code as sqlite3_open
@@ -367,6 +379,8 @@
bool loadFromDb( QString db, QString field, long id );
+ QString mValidationHint;
static CUSTOM_CRS_VALIDATION mCustomSrsValidation;
Modified: trunk/qgis/src/core/qgsmaplayer.cpp
--- trunk/qgis/src/core/qgsmaplayer.cpp 2008-09-24 12:03:21 UTC (rev 9402)
+++ trunk/qgis/src/core/qgsmaplayer.cpp 2008-09-24 14:00:55 UTC (rev 9403)
@@ -140,6 +140,10 @@
bool QgsMapLayer::readXML( QDomNode & layer_node )
+ QgsCoordinateReferenceSystem savedCRS;
+ CUSTOM_CRS_VALIDATION savedValidation;
+ bool layerError;
QDomElement element = layer_node.toElement();
// XXX not needed? QString type = element.attribute("type");
@@ -149,15 +153,31 @@
QDomElement mne = mnl.toElement();
mDataSource = mne.text();
- // Set the CRS so that we don't ask the user.
+ // Set the CRS from project file, asking the user if necessary.
// Make it the saved CRS to have WMS layer projected correctly.
// We will still overwrite whatever GDAL etc picks up anyway
// further down this function.
QDomNode srsNode = layer_node.namedItem( "srs" );
mCRS->readXML( srsNode );
+ mCRS->validate();
+ savedCRS = *mCRS;
+ // Do not validate any projections in children, they will be overwritten anyway.
+ // No need to ask the user for a projections when it is overwritten, is there?
+ savedValidation = QgsCoordinateReferenceSystem::customSrsValidation();
+ QgsCoordinateReferenceSystem::setCustomSrsValidation( NULL );
// now let the children grab what they need from the Dom node.
- if ( !readXml( layer_node ) )
+ layerError = !readXml( layer_node );
+ // overwrite CRS with what we read from project file before the raster/vector
+ // file readnig functions changed it. They will if projections is specfied in the file.
+ // FIXME: is this necessary?
+ QgsCoordinateReferenceSystem::setCustomSrsValidation( savedValidation );
+ *mCRS = savedCRS;
+ // Abort if any error in layer, such as not found.
+ if ( layerError )
return false;
@@ -195,10 +215,6 @@
setLayerName( mne.text() );
- // overwrite srs
- // FIXME: is this necessary?
- mCRS->readXML( srsNode );
//read transparency level
QDomNode transparencyNode = layer_node.namedItem( "transparencyLevelInt" );
if ( ! transparencyNode.isNull() )
