[QGIS Commit] r10472 - in trunk/qgis/src: app providers/spatialite
svn_qgis at osgeo.org
Sun Apr 5 06:43:36 EDT 2009
Author: jef
Date: 2009-04-05 06:43:36 -0400 (Sun, 05 Apr 2009)
New Revision: 10472
trunk/qgis/src/app/qgsspatialitesourceselect.cpp
trunk/qgis/src/providers/spatialite/qgsspatialiteprovider.cpp
make spatialite provider work on windows
Modified: trunk/qgis/src/app/qgsspatialitesourceselect.cpp
--- trunk/qgis/src/app/qgsspatialitesourceselect.cpp 2009-04-05 10:39:51 UTC (rev 10471)
+++ trunk/qgis/src/app/qgsspatialitesourceselect.cpp 2009-04-05 10:43:36 UTC (rev 10472)
@@ -31,8 +31,9 @@
#include <QHeaderView>
#include <QStringList>
-#include <cassert>
-#include <iostream>
+#ifdef _MSC_VER
+#define strcasecmp(a,b) stricmp(a,b)
+#endif
QgsSpatiaLiteSourceSelect::QgsSpatiaLiteSourceSelect( QgisApp * app, Qt::WFlags fl ):
QDialog( app, fl ), qgisApp( app )
@@ -491,7 +492,7 @@
else
qDebug( "Unable to get list of spatially enabled tables from the database" );
- qDebug( sqlite3_errmsg( handle ) );
+ qDebug( "%s", sqlite3_errmsg( handle ) );
closeSpatiaLiteDb( handle );
@@ -572,6 +573,7 @@
QMessageBox::critical( this, tr( "SpatiaLite getTableInfo Error" ),
tr( "Failure exploring tables from: %1\n\n%2" ).arg( mSqlitePath ).arg( errCause ) );
+ return false;
void QgsSpatiaLiteSourceSelect::showHelp()
Modified: trunk/qgis/src/providers/spatialite/qgsspatialiteprovider.cpp
--- trunk/qgis/src/providers/spatialite/qgsspatialiteprovider.cpp 2009-04-05 10:39:51 UTC (rev 10471)
+++ trunk/qgis/src/providers/spatialite/qgsspatialiteprovider.cpp 2009-04-05 10:43:36 UTC (rev 10472)
@@ -32,6 +32,10 @@
#include "qgslogger.h"
+#ifdef _MSC_VER
+#endif
const QString SPATIALITE_KEY = "spatialite";
const QString SPATIALITE_DESCRIPTION = "SpatiaLite data provider";
@@ -213,13 +217,13 @@
sql += ", ";
sql += fieldname;
- if ( fetchGeometry == true )
+ if ( fetchGeometry )
sql += QString( ", AsBinary(%1)" ).arg( geometryColumn );
sql += QString( " FROM %1 WHERE ROWID = %2" ).arg( quotedValue( mTableName ) ).arg( featureId );
- const char *xSql = sql.toUtf8();
+ QByteArray xSql = sql.toUtf8();
if ( sqlite3_prepare_v2( sqliteHandle, xSql, strlen( xSql ), &stmt, NULL ) != SQLITE_OK )
// some error occurred
@@ -239,7 +243,7 @@
if ( ret == SQLITE_ROW )
// one valid row has been fetched from the result set
- if ( mFetchGeom == false )
+ if ( !mFetchGeom )
// no geometry was required
feature.setGeometryAndOwnership( 0, 0 );
@@ -300,7 +304,7 @@
if ( mFetchGeom )
QString geoCol = QString( "AsBinary(%1)" ).arg( geometryColumn );
- const char *geomName = geoCol.toUtf8();
+ QByteArray geomName = geoCol.toUtf8();
if ( strcasecmp( geomName, sqlite3_column_name( stmt, ic ) ) == 0 )
if ( sqlite3_column_type( stmt, ic ) == SQLITE_BLOB )
@@ -362,7 +366,7 @@
@@ -423,7 +427,7 @@
if ( mFetchGeom )
if ( strcasecmp( geomName, sqlite3_column_name( sqliteStatement, ic ) ) == 0 )
if ( sqlite3_column_type( sqliteStatement, ic ) == SQLITE_BLOB )
@@ -484,7 +488,7 @@
sql += ", ";
sql += fieldname;
@@ -492,10 +496,10 @@
QString whereClause;
- if ( rect.isEmpty() == false )
+ if ( !rect.isEmpty() )
// some kind of MBR spatial filtering is required
- whereClause = "WHERE ";
+ whereClause = " WHERE ";
if ( useIntersect )
// we are requested to evaluate a true INTERSECT relationship
@@ -505,7 +509,7 @@
arg( QString::number( rect.xMaximum(), 'f', 6 ) ).arg( QString::number( rect.yMaximum(), 'f', 6 ) );
whereClause += QString( "Intersects(%1, BuildMbr(%2)) AND " ).arg( geometryColumn ).arg( mbr );
- if ( spatialIndexRTree == true )
+ if ( spatialIndexRTree )
// using the RTree spatial index
QString mbrFilter = QString( "xmin <= %1 AND " ).arg( QString::number( rect.xMaximum(), 'f', 6 ) );
@@ -515,7 +519,7 @@
QString idxName = QString( "idx_%1_%2" ).arg( mTableName ).arg( geometryColumn );
whereClause += QString( "ROWID IN (SELECT pkid FROM %1 WHERE %2)" ).arg( idxName ).arg( mbrFilter );
- else if ( spatialIndexMbrCache == true )
+ else if ( spatialIndexMbrCache )
// using the MbrCache spatial index
QString mbr = QString( "%1, %2, %3, %4" ).
@@ -536,12 +540,12 @@
- if ( whereClause.isEmpty() == false )
+ if ( !whereClause.isEmpty() )
sql += whereClause;
mFetchGeom = fetchGeometry;
mAttributesToFetch = fetchAttributes;
if ( sqlite3_prepare_v2( sqliteHandle, xSql, strlen( xSql ), &sqliteStatement, NULL ) != SQLITE_OK )
@@ -753,7 +757,7 @@
sql = QString( "SELECT DISTINCT %1 FROM %2 ORDER BY %1" ).arg( fld.name() ).arg( quotedValue( mTableName ) );
// SQLite prepared statement
@@ -829,7 +833,7 @@
QString sql;
QString values;
int ia;
- const char *xSql;
+ QByteArray xSql;
if ( flist.size() == 0 )
return true;
@@ -844,7 +848,7 @@
toCommit = true;
- if ( primaryKey.isEmpty() == false )
+ if ( !primaryKey.isEmpty() )
sql = QString( "INSERT INTO %1 (%2, %3" ).
arg( quotedValue( mTableName ) ).arg( quotedValue( primaryKey ) ).arg( quotedValue( geometryColumn ) );
@@ -934,7 +938,7 @@
// binding a TEXT value
QString txt = it->toString();
int len = txt.length();
- const char *vl = txt.toUtf8();
+ QByteArray vl = txt.toUtf8();
sqlite3_bind_text( stmt, ++ia, vl, len, SQLITE_TRANSIENT );
else
@@ -997,7 +1001,7 @@
char *errMsg = NULL;
bool toCommit = false;
QString sql;
- const char *xSql;
+ QByteArray xSql;
sql = "BEGIN";
int ret = sqlite3_exec( sqliteHandle, sql.toUtf8(), NULL, NULL, &errMsg );
@@ -1221,7 +1225,7 @@
QString sql;
- const char *xSql;
+ QByteArray xSql;
sql = "BEGIN";
