[QGIS Commit] r10552 - trunk/qgis/src/ui
svn_qgis at osgeo.org
Mon Apr 13 05:41:48 EDT 2009
Author: wonder
Date: 2009-04-13 05:41:48 -0400 (Mon, 13 Apr 2009)
New Revision: 10552
Added:
trunk/qgis/src/ui/qgsattributetabledialog.ui
Removed:
trunk/qgis/src/ui/BeataGui.ui
trunk/qgis/src/ui/qgsattributetablebase.ui
Removed old attribute table ui file, renamed and updated current ui file.
Deleted: trunk/qgis/src/ui/BeataGui.ui
--- trunk/qgis/src/ui/BeataGui.ui 2009-04-13 09:17:47 UTC (rev 10551)
+++ trunk/qgis/src/ui/BeataGui.ui 2009-04-13 09:41:48 UTC (rev 10552)
@@ -1,274 +0,0 @@
-<ui version="4.0" >
- <class>BeataDialogGui</class>
- <widget class="QDialog" name="BeataDialogGui" >
- <property name="geometry" >
- <rect>
- <x>0</x>
- <y>0</y>
- <width>623</width>
- <height>570</height>
- </rect>
- </property>
- <property name="windowTitle" >
- <string>Attribute Table</string>
- </property>
- <layout class="QGridLayout" >
- <property name="leftMargin" >
- <number>0</number>
- </property>
- <property name="topMargin" >
- </property>
- <property name="rightMargin" >
- </property>
- <property name="bottomMargin" >
- </property>
- <property name="horizontalSpacing" >
- <number>2</number>
- </property>
- <property name="verticalSpacing" >
- </property>
- <item row="0" column="0" >
- <widget class="BeataView" name="mView" >
- <property name="alternatingRowColors" >
- <bool>true</bool>
- </property>
- </widget>
- </item>
- <item row="1" column="0" >
- <layout class="QHBoxLayout" >
- <item>
- <widget class="QToolButton" name="mRemoveSelectionButton" >
- <property name="toolTip" >
- <string>Remove selection</string>
- </property>
- <property name="text" >
- <string/>
- </property>
- <property name="icon" >
- <iconset>../../images/themes/default/mActionUnselectAttributes.png</iconset>
- </property>
- <property name="iconSize" >
- <size>
- <width>18</width>
- <height>18</height>
- </size>
- </property>
- <property name="shortcut" >
- <string/>
- </property>
- </widget>
- </item>
- <item>
- <widget class="QToolButton" name="mSelectedToTopButton" >
- <string>Move selected to top</string>
- </property>
- <string/>
- </property>
- <iconset>../../images/themes/default/mActionSelectedToTop.png</iconset>
- </property>
- <size>
- <width>18</width>
- </size>
- </property>
- <string>Ctrl+T</string>
- </property>
- </widget>
- </item>
- <item>
- <widget class="QToolButton" name="mInvertSelectionButton" >
- <string>Invert selection</string>
- </property>
- <string/>
- </property>
- <iconset>../../images/themes/default/mActionInvertSelection.png</iconset>
- </property>
- <size>
- <width>18</width>
- </size>
- </property>
- <string>Ctrl+S</string>
- </property>
- </widget>
- </item>
- <item>
- <widget class="QToolButton" name="mCopySelectedRowsButton" >
- <string>Copy selected rows to clipboard (Ctrl+C)</string>
- </property>
- <property name="whatsThis" >
- <string>Copies the selected rows to the clipboard</string>
- </property>
- <string/>
- </property>
- <iconset>../../images/themes/default/mActionEditCopy.png</iconset>
- </property>
- <size>
- <width>18</width>
- </size>
- </property>
- <string>Ctrl+C</string>
- </property>
- </widget>
- </item>
- <item>
- <widget class="QToolButton" name="mZoomMapToSelectedRowsButton" >
- <string>Zoom map to the selected rows (Ctrl-J)</string>
- </property>
- <string>Zoom map to the selected rows</string>
- </property>
- <string/>
- </property>
- <iconset>../../images/themes/default/mActionZoomToSelected.png</iconset>
- </property>
- <size>
- <width>18</width>
- </size>
- </property>
- <string>Ctrl+J</string>
- </property>
- </widget>
- </item>
- <item>
- <widget class="QToolButton" name="mToggleEditingButton" >
- <string>Toggle editing mode</string>
- </property>
- <string>Click to toggle table editing</string>
- </property>
- <string/>
- </property>
- <iconset>../../images/themes/default/mActionToggleEditing.png</iconset>
- </property>
- <size>
- <width>18</width>
- </size>
- </property>
- <property name="checkable" >
- <bool>true</bool>
- </property>
- </widget>
- </item>
- <item>
- <widget class="QLabel" name="searchFor" >
- <string>Look for</string>
- </property>
- </widget>
- </item>
- <item>
- <widget class="QLineEdit" name="query" />
- </item>
- <item>
- <widget class="QLabel" name="searchIn" >
- <string>in</string>
- </property>
- </widget>
- </item>
- <item>
- <widget class="QComboBox" name="columnBox" />
- </item>
- <item>
- <widget class="QPushButton" name="searchButton" >
- <string>&Search</string>
- </property>
- </widget>
- </item>
- </layout>
- </item>
- <item row="2" column="0" >
- <item>
- <widget class="QCheckBox" name="cbxShowSelectedOnly" >
- <string>Show selected records only</string>
- </property>
- </widget>
- </item>
- <item>
- <spacer>
- <property name="orientation" >
- <enum>Qt::Horizontal</enum>
- </property>
- <property name="sizeHint" >
- <size>
- <width>40</width>
- <height>20</height>
- </size>
- </property>
- </spacer>
- </item>
- <item>
- <widget class="QLabel" name="label" >
- <string>Advanced search</string>
- </property>
- </widget>
- </item>
- <item>
- <widget class="QToolButton" name="mAdvancedSearchButton" >
- <string>...</string>
- </property>
- <size>
- <width>12</width>
- <height>12</height>
- </size>
- </property>
- </widget>
- </item>
- </layout>
- </item>
- </layout>
- </widget>
- <customwidgets>
- <customwidget>
- <class>BeataView</class>
- <extends>QTableView</extends>
- <header>BeataView.h</header>
- </customwidget>
- </customwidgets>
- <tabstops>
- <tabstop>mView</tabstop>
- <tabstop>searchButton</tabstop>
- <tabstop>query</tabstop>
- <tabstop>columnBox</tabstop>
- </tabstops>
- <resources/>
- <connections/>
-</ui>
Deleted: trunk/qgis/src/ui/qgsattributetablebase.ui
--- trunk/qgis/src/ui/qgsattributetablebase.ui 2009-04-13 09:17:47 UTC (rev 10551)
+++ trunk/qgis/src/ui/qgsattributetablebase.ui 2009-04-13 09:41:48 UTC (rev 10552)
@@ -1,262 +0,0 @@
- <class>QgsAttributeTableBase</class>
- <widget class="QDialog" name="QgsAttributeTableBase" >
- <rect>
- <x>0</x>
- <y>0</y>
- <width>687</width>
- <height>583</height>
- </rect>
- </property>
- </property>
- <property name="windowIcon" >
- <iconset>
- <normaloff/>
- </iconset>
- </property>
- <number>6</number>
- </property>
- </property>
- <property name="margin" >
- </property>
- </property>
- <string/>
- </property>
- <iconset>
- <normaloff>../xpm/remove_selection.xpm</normaloff>../xpm/remove_selection.xpm</iconset>
- </property>
- <string/>
- </property>
- </widget>
- </item>
- <item row="0" column="1" >
- </property>
- <string/>
- </property>
- <iconset>
- <normaloff>../xpm/selected_to_top.png</normaloff>../xpm/selected_to_top.png</iconset>
- </property>
- </property>
- </widget>
- </item>
- <item row="0" column="2" >
- </property>
- <string/>
- </property>
- <iconset>
- <normaloff>../xpm/switch_selection.png</normaloff>../xpm/switch_selection.png</iconset>
- </property>
- </property>
- </widget>
- </item>
- <item row="0" column="3" >
- </property>
- </property>
- <string/>
- </property>
- <iconset>
- <normaloff>../xpm/copy_selection.png</normaloff>../xpm/copy_selection.png</iconset>
- </property>
- </property>
- </widget>
- </item>
- <item row="0" column="4" >
- </property>
- </property>
- <string/>
- </property>
- </property>
- </widget>
- </item>
- <item row="0" column="6" >
- <spacer>
- </property>
- <property name="sizeHint" stdset="0" >
- <size>
- <width>421</width>
- </size>
- </property>
- </spacer>
- </item>
- <item row="2" column="0" colspan="7" >
- <item>
- <widget class="QLabel" name="textLabel1" >
- <string>Search for</string>
- </property>
- <property name="buddy" >
- <cstring>mSearchText</cstring>
- </property>
- </widget>
- </item>
- <item>
- <widget class="QLineEdit" name="mSearchText" />
- </item>
- <item>
- <widget class="QLabel" name="textLabel2" >
- </property>
- <cstring>mSearchColumns</cstring>
- </property>
- </widget>
- </item>
- <item>
- <widget class="QComboBox" name="mSearchColumns" >
- <property name="sizePolicy" >
- <sizepolicy vsizetype="Fixed" hsizetype="Expanding" >
- <horstretch>0</horstretch>
- <verstretch>0</verstretch>
- </sizepolicy>
- </property>
- </widget>
- </item>
- <item>
- <widget class="QPushButton" name="mSearchButton" >
- <string>Search</string>
- </property>
- </widget>
- </item>
- <item>
- <widget class="QComboBox" name="mSearchShowResults" />
- </item>
- <item>
- <widget class="QPushButton" name="btnAdvancedSearch" >
- <string>Adva&nced...</string>
- </property>
- <string>Alt+N</string>
- </property>
- </widget>
- </item>
- </layout>
- </item>
- <item row="3" column="0" colspan="7" >
- <widget class="QDialogButtonBox" name="buttonBox" >
- <property name="standardButtons" >
- <set>QDialogButtonBox::Close|QDialogButtonBox::Help</set>
- </property>
- </widget>
- </item>
- <item row="1" column="0" colspan="7" >
- <widget class="QgsAttributeTable" native="1" name="tblAttributes" >
- <sizepolicy vsizetype="Expanding" hsizetype="Expanding" >
- </sizepolicy>
- </property>
- </widget>
- </item>
- <item row="0" column="5" >
- </property>
- </property>
- <string/>
- </property>
- <bool>true</bool>
- </property>
- </widget>
- </item>
- </layout>
- </widget>
- <layoutdefault spacing="6" margin="11" />
- <customwidgets>
- <customwidget>
- <class>QgsAttributeTable</class>
- <extends>QWidget</extends>
- <header>qgsattributetable.h</header>
- </customwidget>
- </customwidgets>
- <tabstops>
- <tabstop>mRemoveSelectionButton</tabstop>
- <tabstop>mSelectedToTopButton</tabstop>
- <tabstop>mInvertSelectionButton</tabstop>
- <tabstop>mCopySelectedRowsButton</tabstop>
- <tabstop>mZoomMapToSelectedRowsButton</tabstop>
- <tabstop>mSearchText</tabstop>
- <tabstop>mSearchColumns</tabstop>
- <tabstop>mSearchButton</tabstop>
- <tabstop>mSearchShowResults</tabstop>
- <tabstop>btnAdvancedSearch</tabstop>
- <tabstop>buttonBox</tabstop>
- </tabstops>
- <resources/>
- <connections>
- <connection>
- <sender>buttonBox</sender>
- <signal>accepted()</signal>
- <receiver>QgsAttributeTableBase</receiver>
- <slot>accept()</slot>
- <hints>
- <hint type="sourcelabel" >
- <x>645</x>
- <y>560</y>
- </hint>
- <hint type="destinationlabel" >
- <x>682</x>
- <y>529</y>
- </hint>
- </hints>
- </connection>
- </connections>
-</ui>
Copied: trunk/qgis/src/ui/qgsattributetabledialog.ui (from rev 10549, trunk/qgis/src/ui/BeataGui.ui)
--- trunk/qgis/src/ui/qgsattributetabledialog.ui (rev 0)
+++ trunk/qgis/src/ui/qgsattributetabledialog.ui 2009-04-13 09:41:48 UTC (rev 10552)
@@ -0,0 +1,274 @@
+<ui version="4.0" >
+ <class>QgsAttributeTableDialog</class>
+ <widget class="QDialog" name="QgsAttributeTableDialog" >
+ <property name="geometry" >
+ <rect>
+ <x>0</x>
+ <y>0</y>
+ <width>623</width>
+ <height>570</height>
+ </rect>
+ </property>
+ <property name="windowTitle" >
+ <string>Attribute Table</string>
+ </property>
+ <layout class="QGridLayout" >
+ <property name="leftMargin" >
+ <number>0</number>
+ </property>
+ <property name="topMargin" >
+ </property>
+ <property name="rightMargin" >
+ </property>
+ <property name="bottomMargin" >
+ </property>
+ <property name="horizontalSpacing" >
+ <number>2</number>
+ </property>
+ <property name="verticalSpacing" >
+ </property>
+ <item row="0" column="0" >
+ <widget class="QgsAttributeTableView" name="mView" >
+ <property name="alternatingRowColors" >
+ <bool>true</bool>
+ </property>
+ </widget>
+ </item>
+ <item row="1" column="0" >
+ <layout class="QHBoxLayout" >
+ <item>
+ <widget class="QToolButton" name="mRemoveSelectionButton" >
+ <property name="toolTip" >
+ <string>Remove selection</string>
+ </property>
+ <property name="text" >
+ <string/>
+ </property>
+ <property name="icon" >
+ <iconset>../../images/themes/default/mActionUnselectAttributes.png</iconset>
+ </property>
+ <property name="iconSize" >
+ <size>
+ <width>18</width>
+ <height>18</height>
+ </size>
+ </property>
+ <property name="shortcut" >
+ <string/>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QToolButton" name="mSelectedToTopButton" >
+ <string>Move selected to top</string>
+ </property>
+ <string/>
+ </property>
+ <iconset>../../images/themes/default/mActionSelectedToTop.png</iconset>
+ </property>
+ <size>
+ <width>18</width>
+ </size>
+ </property>
+ <string>Ctrl+T</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QToolButton" name="mInvertSelectionButton" >
+ <string>Invert selection</string>
+ </property>
+ <string/>
+ </property>
+ <iconset>../../images/themes/default/mActionInvertSelection.png</iconset>
+ </property>
+ <size>
+ <width>18</width>
+ </size>
+ </property>
+ <string>Ctrl+S</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QToolButton" name="mCopySelectedRowsButton" >
+ <string>Copy selected rows to clipboard (Ctrl+C)</string>
+ </property>
+ <property name="whatsThis" >
+ <string>Copies the selected rows to the clipboard</string>
+ </property>
+ <string/>
+ </property>
+ <iconset>../../images/themes/default/mActionEditCopy.png</iconset>
+ </property>
+ <size>
+ <width>18</width>
+ </size>
+ </property>
+ <string>Ctrl+C</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QToolButton" name="mZoomMapToSelectedRowsButton" >
+ <string>Zoom map to the selected rows (Ctrl-J)</string>
+ </property>
+ <string>Zoom map to the selected rows</string>
+ </property>
+ <string/>
+ </property>
+ <iconset>../../images/themes/default/mActionZoomToSelected.png</iconset>
+ </property>
+ <size>
+ <width>18</width>
+ </size>
+ </property>
+ <string>Ctrl+J</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QToolButton" name="mToggleEditingButton" >
+ <string>Toggle editing mode</string>
+ </property>
+ <string>Click to toggle table editing</string>
+ </property>
+ <string/>
+ </property>
+ <iconset>../../images/themes/default/mActionToggleEditing.png</iconset>
+ </property>
+ <size>
+ <width>18</width>
+ </size>
+ </property>
+ <property name="checkable" >
+ <bool>true</bool>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QLabel" name="searchFor" >
+ <string>Look for</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QLineEdit" name="query" />
+ </item>
+ <item>
+ <widget class="QLabel" name="searchIn" >
+ <string>in</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QComboBox" name="columnBox" />
+ </item>
+ <item>
+ <widget class="QPushButton" name="searchButton" >
+ <string>&Search</string>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </item>
+ <item row="2" column="0" >
+ <item>
+ <widget class="QCheckBox" name="cbxShowSelectedOnly" >
+ <string>Show selected records only</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <spacer>
+ <property name="orientation" >
+ <enum>Qt::Horizontal</enum>
+ </property>
+ <property name="sizeHint" >
+ <size>
+ <width>40</width>
+ <height>20</height>
+ </size>
+ </property>
+ </spacer>
+ </item>
+ <item>
+ <widget class="QLabel" name="label" >
+ <string>Advanced search</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QToolButton" name="mAdvancedSearchButton" >
+ <string>...</string>
+ </property>
+ <size>
+ <width>12</width>
+ <height>12</height>
+ </size>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </item>
+ </layout>
+ </widget>
+ <customwidgets>
+ <customwidget>
+ <class>QgsAttributeTableView</class>
+ <extends>QTableView</extends>
+ <header>qgsattributetableview.h</header>
+ </customwidget>
+ </customwidgets>
+ <tabstops>
+ <tabstop>mView</tabstop>
+ <tabstop>searchButton</tabstop>
+ <tabstop>query</tabstop>
+ <tabstop>columnBox</tabstop>
+ </tabstops>
+ <resources/>
+ <connections/>
+</ui>
