[QGIS Commit] r10555 - in trunk/qgis: python/core src/app src/core
src/gui
svn_qgis at osgeo.org
Mon Apr 13 06:55:56 EDT 2009
Author: wonder
Date: 2009-04-13 06:55:56 -0400 (Mon, 13 Apr 2009)
New Revision: 10555
trunk/qgis/python/core/qgstolerance.sip
trunk/qgis/src/app/qgsmaptoolmovefeature.cpp
trunk/qgis/src/core/qgssnapper.cpp
trunk/qgis/src/core/qgstolerance.cpp
trunk/qgis/src/core/qgstolerance.h
trunk/qgis/src/gui/qgsmapcanvassnapper.cpp
Fixed handling of tolerance for projected layers (#1634).
Patch contributed by Richard Kostecky.
Modified: trunk/qgis/python/core/qgstolerance.sip
--- trunk/qgis/python/core/qgstolerance.sip 2009-04-13 09:54:34 UTC (rev 10554)
+++ trunk/qgis/python/core/qgstolerance.sip 2009-04-13 10:55:56 UTC (rev 10555)
@@ -16,27 +16,26 @@
- * Static function to get vertex tolerance value from settings
- * @param mapUnitsPerPixel number of map units per pixel
+ * Static function to get vertex tolerance value for a layer.
+ * The value is read from settings and transformed if necessary.
* @return value of vertex tolerance in map units
- static double vertexSearchRadius( double mapUnitsPerPixel );
+ static double vertexSearchRadius( QgsMapLayer* layer, QgsMapRenderer* renderer );
- * Static function to get default tolerance value from settings
+ * Static function to get default tolerance value for a layer.
* @return value of default tolerance in map units
- static double defaultTolerance( double mapUnitsPerPixel );
+ static double defaultTolerance( QgsMapLayer* layer, QgsMapRenderer* renderer );
* Static function to translate tolerance value into current map unit value
* @param tolerace tolerance value to be translated
* @param units type of units to be translated
* @return value of tolerance in map units
- static double toleranceInMapUnits(double tolerance, double mapUnitsPerPixel, UnitType units = MapUnits);
+ static double toleranceInMapUnits( double tolerance, QgsMapLayer* layer, QgsMapRenderer* renderer, UnitType units = MapUnits );
Modified: trunk/qgis/src/app/qgsmaptoolmovefeature.cpp
--- trunk/qgis/src/app/qgsmaptoolmovefeature.cpp 2009-04-13 09:54:34 UTC (rev 10554)
+++ trunk/qgis/src/app/qgsmaptoolmovefeature.cpp 2009-04-13 10:55:56 UTC (rev 10555)
@@ -72,7 +72,7 @@
//find first geometry under mouse cursor and store iterator to it
QgsPoint layerCoords = toLayerCoordinates(( QgsMapLayer* )vlayer, e->pos() );
QSettings settings;
- double searchRadius = QgsTolerance::vertexSearchRadius( mCanvas->mapUnitsPerPixel() );
+ double searchRadius = QgsTolerance::vertexSearchRadius( mCanvas->currentLayer(), mCanvas->mapRenderer() );
QgsRectangle selectRect( layerCoords.x() - searchRadius, layerCoords.y() - searchRadius,
layerCoords.x() + searchRadius, layerCoords.y() + searchRadius );
Modified: trunk/qgis/src/core/qgssnapper.cpp
--- trunk/qgis/src/core/qgssnapper.cpp 2009-04-13 09:54:34 UTC (rev 10554)
+++ trunk/qgis/src/core/qgssnapper.cpp 2009-04-13 10:55:56 UTC (rev 10555)
@@ -57,7 +57,7 @@
//transform point from map coordinates to layer coordinates
layerCoordPoint = mMapRenderer->mapToLayerCoordinates( snapLayerIt->mLayer, mapCoordPoint );
- double tolerance = QgsTolerance::toleranceInMapUnits( snapLayerIt->mTolerance, mMapRenderer->mapUnitsPerPixel(), snapLayerIt->mUnitType );
+ double tolerance = QgsTolerance::toleranceInMapUnits( snapLayerIt->mTolerance, snapLayerIt->mLayer, mMapRenderer, snapLayerIt->mUnitType );
if ( snapLayerIt->mLayer->snapWithContext( layerCoordPoint, tolerance,
currentResultList, snapLayerIt->mSnapTo ) != 0 )
Modified: trunk/qgis/src/core/qgstolerance.cpp
--- trunk/qgis/src/core/qgstolerance.cpp 2009-04-13 09:54:34 UTC (rev 10554)
+++ trunk/qgis/src/core/qgstolerance.cpp 2009-04-13 10:55:56 UTC (rev 10555)
@@ -15,29 +15,70 @@
#include "qgstolerance.h"
#include <QSettings>
+#include <QPoint>
+#include <math.h>
-double QgsTolerance::toleranceInMapUnits( double tolerance, double mapUnitsPerPixel, UnitType units )
+double QgsTolerance::toleranceInMapUnits( double tolerance, QgsMapLayer* layer, QgsMapRenderer* renderer, UnitType units )
if ( units == MapUnits )
return tolerance;
+ double mapUnitsPerPixel = computeMapUnitPerPixel( layer, renderer );
return tolerance * mapUnitsPerPixel;
-double QgsTolerance::vertexSearchRadius( double mapUnitsPerPixel )
+double QgsTolerance::vertexSearchRadius( QgsMapLayer* layer, QgsMapRenderer* renderer )
QSettings settings;
double tolerance = settings.value( "/qgis/digitizing/search_radius_vertex_edit", 10 ).toDouble();
UnitType units = ( QgsTolerance::UnitType ) settings.value( "/qgis/digitizing/search_radius_vertex_edit_unit", 0 ).toInt();
- return toleranceInMapUnits( tolerance, mapUnitsPerPixel, units );
+ return toleranceInMapUnits( tolerance, layer, renderer, units );
-double QgsTolerance::defaultTolerance( double mapUnitsPerPixel )
+double QgsTolerance::defaultTolerance( QgsMapLayer* layer, QgsMapRenderer* renderer )
QSettings settings;
double tolerance = settings.value( "/qgis/digitizing/default_snapping_tolerance", 0 ).toDouble();
UnitType units = ( QgsTolerance::UnitType ) settings.value( "/qgis/digitizing/default_snapping_tolerance_unit", 0 ).toInt();
+double QgsTolerance::computeMapUnitPerPixel( QgsMapLayer* layer, QgsMapRenderer* renderer )
+ if ( ! renderer->hasCrsTransformEnabled() )
+ // if the on-the-fly projections are not enabled, layer units pre pixel are the same as map units per pixel
+ return renderer->mapUnitsPerPixel();
+ // the layer is projected. Find out how many pixels are in one map unit - either horizontal and vertical direction
+ // this check might not work correctly in some cases
+ // (on a large area the pixels projected around "0,0" can have different properties from the actual point)
+ QgsPoint p1 = toLayerCoordinates(layer, renderer, QPoint(0,1));
+ QgsPoint p2 = toLayerCoordinates(layer, renderer, QPoint(0,2));
+ QgsPoint p3 = toLayerCoordinates(layer, renderer, QPoint(1,0));
+ QgsPoint p4 = toLayerCoordinates(layer, renderer, QPoint(2,0));
+ double x = p1.sqrDist(p2);
+ double y = p3.sqrDist(p4);
+ if (x > y)
+ return sqrt(x);
+ else
+ return sqrt(y);
+QgsPoint QgsTolerance::toLayerCoordinates( QgsMapLayer* layer, QgsMapRenderer* renderer, const QPoint& point )
+ QgsPoint pt = renderer->coordinateTransform()->toMapCoordinates( point );
+ return renderer->mapToLayerCoordinates( layer, pt );
Modified: trunk/qgis/src/core/qgstolerance.h
--- trunk/qgis/src/core/qgstolerance.h 2009-04-13 09:54:34 UTC (rev 10554)
+++ trunk/qgis/src/core/qgstolerance.h 2009-04-13 10:55:56 UTC (rev 10555)
@@ -15,8 +15,11 @@
#ifndef QGSTOLERANCE_H
#define QGSTOLERANCE_H
+#include "qgsmaptopixel.h"
+#include "qgsmaprenderer.h"
+#include "qgsmaplayer.h"
+#include "qgspoint.h"
/** \ingroup core
* This is the class is providing tolerance value in map unit values.
@@ -36,28 +39,31 @@
- static double toleranceInMapUnits( double tolerance, double mapUnitsPerPixel, UnitType units = MapUnits );
+ private:
+ static double computeMapUnitPerPixel( QgsMapLayer* layer, QgsMapRenderer* renderer );
+ static QgsPoint toLayerCoordinates( QgsMapLayer* layer, QgsMapRenderer* renderer, const QPoint& point );
#endif
Modified: trunk/qgis/src/gui/qgsmapcanvassnapper.cpp
--- trunk/qgis/src/gui/qgsmapcanvassnapper.cpp 2009-04-13 09:54:34 UTC (rev 10554)
+++ trunk/qgis/src/gui/qgsmapcanvassnapper.cpp 2009-04-13 10:55:56 UTC (rev 10555)
@@ -101,7 +101,7 @@
if ( snappingTol < 0 )
//use search tolerance for vertex editing
- snapLayer.mTolerance = QgsTolerance::vertexSearchRadius( mMapCanvas->mapUnitsPerPixel() );
+ snapLayer.mTolerance = QgsTolerance::vertexSearchRadius( vlayer, mMapCanvas->mapRenderer() );
else
@@ -248,7 +248,7 @@
//default snapping tolerance (returned in map units)
- snapLayer.mTolerance = QgsTolerance::defaultTolerance( mMapCanvas->mapUnitsPerPixel() );
+ snapLayer.mTolerance = QgsTolerance::defaultTolerance( currentVectorLayer, mMapCanvas->mapRenderer() );
snapLayer.mUnitType = QgsTolerance::MapUnits;
snapLayers.append( snapLayer );
