[QGIS Commit] r10566 - in trunk/qgis/src/plugins: . oracle_raster
svn_qgis at osgeo.org svn_qgis at osgeo.org
Wed Apr 15 10:18:30 EDT 2009
Author: mhugent
Date: 2009-04-15 10:18:30 -0400 (Wed, 15 Apr 2009)
New Revision: 10566
Added:
   trunk/qgis/src/plugins/oracle_raster/
   trunk/qgis/src/plugins/oracle_raster/CMakeLists.txt
   trunk/qgis/src/plugins/oracle_raster/oracleplugin.png
   trunk/qgis/src/plugins/oracle_raster/oracleplugin.qrc
   trunk/qgis/src/plugins/oracle_raster/qgsoracle_plugin.cpp
   trunk/qgis/src/plugins/oracle_raster/qgsoracle_plugin.h
   trunk/qgis/src/plugins/oracle_raster/qgsoracleconnect_ui.cpp
   trunk/qgis/src/plugins/oracle_raster/qgsoracleconnect_ui.h
   trunk/qgis/src/plugins/oracle_raster/qgsoracleconnectbase.ui
   trunk/qgis/src/plugins/oracle_raster/qgsselectgeoraster_ui.cpp
   trunk/qgis/src/plugins/oracle_raster/qgsselectgeoraster_ui.h
   trunk/qgis/src/plugins/oracle_raster/qgsselectgeorasterbase.ui
   trunk/qgis/src/plugins/CMakeLists.txt
Added oracle spatial raster plugin provided by Ivan Lucena
Modified: trunk/qgis/src/plugins/CMakeLists.txt
--- trunk/qgis/src/plugins/CMakeLists.txt	2009-04-14 17:23:14 UTC (rev 10565)
+++ trunk/qgis/src/plugins/CMakeLists.txt	2009-04-15 14:18:30 UTC (rev 10566)
@@ -3,6 +3,7 @@
   interpolation
   north_arrow
   scale_bar
+  oracle_raster
 IF (POSTGRES_FOUND)
Added: trunk/qgis/src/plugins/oracle_raster/CMakeLists.txt
--- trunk/qgis/src/plugins/oracle_raster/CMakeLists.txt	                        (rev 0)
+++ trunk/qgis/src/plugins/oracle_raster/CMakeLists.txt	2009-04-15 14:18:30 UTC (rev 10566)
@@ -0,0 +1,55 @@
+# Files
+SET (ORACLE_SRCS
+     qgsoracle_plugin.cpp
+     qgsselectgeoraster_ui.cpp
+     qgsoracleconnect_ui.cpp
+SET (ORACLE_UIS
+     qgsselectgeorasterbase.ui
+     qgsoracleconnectbase.ui
+SET (ORACLE_MOC_HDRS
+     qgsoracle_plugin.h
+     qgsselectgeoraster_ui.h
+     qgsoracleconnect_ui.h
+SET (ORACLE_RCCS  oracleplugin.qrc)
+# Build
+QT4_WRAP_UI (ORACLE_UIS_H  ${ORACLE_UIS})
+QT4_WRAP_CPP (ORACLE_MOC_SRCS  ${ORACLE_MOC_HDRS})
+QT4_ADD_RESOURCES(ORACLE_RCC_SRCS ${ORACLE_RCCS})
+ADD_LIBRARY (oracleplugin MODULE ${ORACLE_SRCS} ${ORACLE_MOC_SRCS} ${ORACLE_RCC_SRCS} ${ORACLE_UIS_H})
+INCLUDE_DIRECTORIES(
+     ${CMAKE_CURRENT_BINARY_DIR}
+       ${GDAL_INCLUDE_DIR}
+     ../../core ../../core/raster ../../core/renderer ../../core/symbology
+     ../../gui
+TARGET_LINK_LIBRARIES(oracleplugin
+  qgis_core
+  qgis_gui
+# Install
+INSTALL(TARGETS oracleplugin
+  RUNTIME DESTINATION ${QGIS_PLUGIN_DIR}
+  LIBRARY DESTINATION ${QGIS_PLUGIN_DIR})
Added: trunk/qgis/src/plugins/oracle_raster/oracleplugin.png
(Binary files differ)
Property changes on: trunk/qgis/src/plugins/oracle_raster/oracleplugin.png
___________________________________________________________________
   + application/octet-stream
Added: trunk/qgis/src/plugins/oracle_raster/oracleplugin.qrc
--- trunk/qgis/src/plugins/oracle_raster/oracleplugin.qrc	                        (rev 0)
+++ trunk/qgis/src/plugins/oracle_raster/oracleplugin.qrc	2009-04-15 14:18:30 UTC (rev 10566)
@@ -0,0 +1,5 @@
+<RCC>
+    <qresource prefix="/oracleplugin/" >
+        <file>oracleplugin.png</file>
+    </qresource>
+</RCC>
Added: trunk/qgis/src/plugins/oracle_raster/qgsoracle_plugin.cpp
--- trunk/qgis/src/plugins/oracle_raster/qgsoracle_plugin.cpp	                        (rev 0)
+++ trunk/qgis/src/plugins/oracle_raster/qgsoracle_plugin.cpp	2009-04-15 14:18:30 UTC (rev 10566)
@@ -0,0 +1,153 @@
+    oracleplugin.cpp  Access Oracle Spatial Plugin
+    begin                : Oracle Spatial Plugin
+    copyright            : (C) Ivan Lucena
+    email                : ivan.lucena at pmldnet.com
+ *   This program is free software; you can redistribute it and/or modify  *
+ *   it under the terms of the GNU General Public License as published by  *
+ *   the Free Software Foundation; either version 2 of the License, or     *
+ *   (at your option) any later version.                                   *
+/* $Id$ */
+#include "qgsoracle_plugin.h"
+#include "qgsselectgeoraster_ui.h"
+static const char * const sIdent = "$Id: oracleplugin.cpp  $";
+static const QString sName = QObject::tr("Oracle Spatial GeoRaster");
+static const QString sDescription = QObject::tr("Access Oracle Spatial GeoRaster");
+static const QString sPluginVersion = QObject::tr("Version 0.1");
+static const QgisPlugin::PLUGINTYPE sPluginType = QgisPlugin::UI;
+// THE FOLLOWING METHODS ARE MANDATORY FOR ALL PLUGINS
+ * Constructor for the plugin. The plugin is passed a pointer
+ * an interface object that provides access to exposed functions in QGIS.
+ * @param theQGisInterface - Pointer to the QGIS interface object
+QgsOraclePlugin::QgsOraclePlugin(QgisInterface * theQgisInterface) :
+QgisPlugin(sName, sDescription, sPluginVersion, sPluginType),
+mQGisIface(theQgisInterface)
+QgsOraclePlugin::~QgsOraclePlugin()
+ * Initialize the GUI interface for the plugin - this is only called once when the plugin is
+ * added to the plugin registry in the QGIS application.
+void QgsOraclePlugin::initGui()
+    // Create the action for tool
+    mQActionPointer = new QAction(QIcon(":/oracleplugin/oracleplugin.png"), tr("Select GeoRaster"), this);
+    // Set the what's this text
+    mQActionPointer->setWhatsThis(tr("Open a Oracle Spatial GeoRaster"));
+    // Connect the action to the run
+    connect(mQActionPointer, SIGNAL(triggered()), this, SLOT(run()));
+    // Add the icon to the toolbar
+    mQGisIface->addToolBarIcon(mQActionPointer);
+    mQGisIface->addPluginToMenu(tr("&Oracle Spatial"), mQActionPointer);
+//method defined in interface
+void QgsOraclePlugin::help()
+    //implement me!
+// Slot called when the menu item is triggered
+// If you created more menu items / toolbar buttons in initiGui, you should
+// create a separate handler for each action - this single run() method will
+// not be enough
+void QgsOraclePlugin::run()
+    QgsOracleSelectGeoraster *myPluginGui = new QgsOracleSelectGeoraster(mQGisIface->mainWindow(), mQGisIface, QgisGui::ModalDialogFlags);
+    myPluginGui->setAttribute(Qt::WA_DeleteOnClose);
+    myPluginGui->show();
+// Unload the plugin by cleaning up the GUI
+void QgsOraclePlugin::unload()
+    // remove the GUI
+    mQGisIface->removePluginMenu("&Oracle Spatial", mQActionPointer);
+    mQGisIface->removeToolBarIcon(mQActionPointer);
+    delete mQActionPointer;
+//  THE FOLLOWING CODE IS AUTOGENERATED BY THE PLUGIN BUILDER SCRIPT
+//    YOU WOULD NORMALLY NOT NEED TO MODIFY THIS, AND YOUR PLUGIN
+//      MAY NOT WORK PROPERLY IF YOU MODIFY THIS INCORRECTLY
+ * Required extern functions needed  for every plugin
+ * These functions can be called prior to creating an instance
+ * of the plugin class
+// Class factory to return a new instance of the plugin class
+QGISEXTERN QgisPlugin * classFactory(QgisInterface * theQgisInterfacePointer)
+    return new QgsOraclePlugin(theQgisInterfacePointer);
+// Return the name of the plugin - note that we do not user class members as
+// the class may not yet be insantiated when this method is called.
+QGISEXTERN QString name()
+    return sName;
+// Return the description
+QGISEXTERN QString description()
+    return sDescription;
+// Return the type (either UI or MapLayer plugin)
+QGISEXTERN int type()
+    return sPluginType;
+// Return the version number for the plugin
+QGISEXTERN QString version()
+    return sPluginVersion;
+// Delete ourself
+QGISEXTERN void unload(QgisPlugin * thePluginPointer)
+    delete thePluginPointer;
Added: trunk/qgis/src/plugins/oracle_raster/qgsoracle_plugin.h
--- trunk/qgis/src/plugins/oracle_raster/qgsoracle_plugin.h	                        (rev 0)
+++ trunk/qgis/src/plugins/oracle_raster/qgsoracle_plugin.h	2009-04-15 14:18:30 UTC (rev 10566)
@@ -0,0 +1,65 @@
+    oracleplugin.h
+/* $Id$ */
+#ifndef OraclePlugin_H
+#define OraclePlugin_H
+// Qt Includes
+#include <QObject>
+#include <QAction>
+// QGIS Includes
+#include <qgisplugin.h>
+#include <qgisinterface.h>
+#include <qgisgui.h>
+class QgsOraclePlugin : public QObject, public QgisPlugin
+    Q_OBJECT
+public:
+     * Constructor for a plugin. The QgisInterface pointer is passed by
+     * QGIS when it attempts to instantiate the plugin.
+     * @param theInterface Pointer to the QgisInterface object.
+    QgsOraclePlugin(QgisInterface * theInterface);
+    //! Destructor
+    virtual ~QgsOraclePlugin();
+public slots:
+    //! init the gui
+    virtual void initGui();
+    //! Show the dialog box
+    void run();
+    //! unload the plugin
+    void unload();
+    //! show the help document
+    void help();
+private:
+    int mPluginType;
+    //! Pointer to the QGIS interface object
+    QgisInterface *mQGisIface;
+    //!pointer to the qaction for this plugin
+    QAction * mQActionPointer;
+#endif //OraclePlugin_H
Added: trunk/qgis/src/plugins/oracle_raster/qgsoracleconnect_ui.cpp
--- trunk/qgis/src/plugins/oracle_raster/qgsoracleconnect_ui.cpp	                        (rev 0)
+++ trunk/qgis/src/plugins/oracle_raster/qgsoracleconnect_ui.cpp	2009-04-15 14:18:30 UTC (rev 10566)
@@ -0,0 +1,88 @@
+    oracleconnectgui.cpp
+/* $Id$ */
+#include "qgsoracleconnect_ui.h"
+// Qt Includes
+#include <QSettings>
+#include <QMessageBox>
+QgsOracleConnect::QgsOracleConnect(QWidget* parent,
+        const QString& connName,
+        Qt::WFlags fl) : QDialog(parent, fl)
+    setupUi(this);
+    if ( ! connName.isEmpty() )
+        // populate the dialog with the information stored for the connection
+        // populate the fields with the stored setting parameters
+        QSettings settings;
+        QString key = "/Oracle/connections/" + connName;
+        txtDatabase->setText( settings.value( key + "/database" ).toString() );
+        txtUsername->setText( settings.value( key + "/username" ).toString() );
+        if ( settings.value( key + "/savepass" ).toString() == "true" )
+            txtPassword->setText( settings.value( key + "/password" ).toString() );
+            chkStorePassword->setChecked( true );
+        txtName->setText( connName );
+QgsOracleConnect::~QgsOracleConnect()
+void QgsOracleConnect::on_btnCancel_clicked()
+    helpInfo();
+void QgsOracleConnect::on_btnOk_clicked()
+    saveConnection();
+void QgsOracleConnect::saveConnection()
+    QString baseKey = "/Oracle/connections/";
+    settings.setValue( baseKey + "selected", txtName->text() );
+    baseKey += txtName->text();
+    settings.setValue( baseKey + "/database", txtDatabase->text() );
+    settings.setValue( baseKey + "/username", txtUsername->text() );
+    settings.setValue( baseKey + "/password", txtPassword->text() );
+    settings.setValue( baseKey + "/savepass", chkStorePassword->isChecked() ? "true" : "false" );
+    settings.setValue( baseKey + "/subdtset", "GEOR:" +
+            txtUsername->text() + "/" +
+            txtPassword->text() + "@" +
+            txtDatabase->text() );
+    accept();
+void QgsOracleConnect::helpInfo()
+    //  QgsContextHelp::run( context_id );
Added: trunk/qgis/src/plugins/oracle_raster/qgsoracleconnect_ui.h
--- trunk/qgis/src/plugins/oracle_raster/qgsoracleconnect_ui.h	                        (rev 0)
+++ trunk/qgis/src/plugins/oracle_raster/qgsoracleconnect_ui.h	2009-04-15 14:18:30 UTC (rev 10566)
@@ -0,0 +1,46 @@
+    oracleconnectgui.u
+/* $Id$ */
+#ifndef QgsOracleConnect_H
+#define	QgsOracleConnect_H
+// Qt Designer Includes
+#include "ui_qgsoracleconnectbase.h"
+// QGIS Includes
+class QgsOracleConnect : public QDialog, private Ui::OracleConnectGuiBase
+    Q_OBJECT
+public:
+    QgsOracleConnect(QWidget* parent = 0,
+            const QString& connName = QString::null,
+            Qt::WFlags fl = QgisGui::ModalDialogFlags);
+    ~QgsOracleConnect();
+private:
+    void saveConnection();
+    void helpInfo();
+public slots:
+    void on_btnOk_clicked();
+    void on_btnCancel_clicked();
+    void on_btnHelp_clicked();
+#endif	/* _ORACLECONNECTGUI_H */
Added: trunk/qgis/src/plugins/oracle_raster/qgsoracleconnectbase.ui
--- trunk/qgis/src/plugins/oracle_raster/qgsoracleconnectbase.ui	                        (rev 0)
+++ trunk/qgis/src/plugins/oracle_raster/qgsoracleconnectbase.ui	2009-04-15 14:18:30 UTC (rev 10566)
@@ -0,0 +1,248 @@
+<ui version="4.0" >
+ <class>OracleConnectGuiBase</class>
+ <widget class="QDialog" name="OracleConnectGuiBase" >
+  <property name="geometry" >
+   <rect>
+    <x>0</x>
+    <y>0</y>
+    <width>436</width>
+    <height>207</height>
+   </rect>
+  </property>
+  <property name="windowTitle" >
+   <string>Create Oracle Connection</string>
+  </property>
+  <property name="windowIcon" >
+   <iconset>
+    <normaloff/>
+   </iconset>
+  </property>
+  <widget class="QWidget" name="layoutWidget" >
+    <rect>
+     <x>339</x>
+     <y>11</y>
+     <width>89</width>
+     <height>189</height>
+    </rect>
+   </property>
+   <layout class="QVBoxLayout" name="boxConfirm" >
+    <property name="spacing" >
+     <number>6</number>
+    </property>
+    <property name="margin" >
+     <number>0</number>
+    </property>
+    <item>
+     <widget class="QPushButton" name="btnOk" >
+      <property name="text" >
+       <string>OK</string>
+      </property>
+      <property name="shortcut" >
+       <string/>
+      </property>
+      <property name="autoDefault" >
+       <bool>true</bool>
+      </property>
+      <property name="default" >
+       <bool>true</bool>
+      </property>
+     </widget>
+    </item>
+    <item>
+     <widget class="QPushButton" name="btnCancel" >
+       <string>Cancel</string>
+      </property>
+       <string/>
+      </property>
+       <bool>true</bool>
+      </property>
+     </widget>
+    </item>
+    <item>
+     <spacer>
+      <property name="orientation" >
+       <enum>Qt::Vertical</enum>
+      </property>
+      <property name="sizeType" >
+       <enum>QSizePolicy::Expanding</enum>
+      </property>
+      <property name="sizeHint" stdset="0" >
+       <size>
+        <width>87</width>
+        <height>121</height>
+       </size>
+      </property>
+     </spacer>
+    </item>
+   </layout>
+  </widget>
+  <widget class="QGroupBox" name="GroupBox1" >
+    <rect>
+     <x>10</x>
+     <y>10</y>
+     <width>322</width>
+     <height>191</height>
+    </rect>
+   </property>
+   <property name="title" >
+    <string>Connection Information</string>
+   </property>
+   <layout class="QVBoxLayout" name="_2" >
+    </property>
+    </property>
+    <item>
+     <layout class="QHBoxLayout" name="boxFields" >
+      </property>
+      </property>
+      <item>
+       <layout class="QVBoxLayout" name="boxFieldLabels" >
+        </property>
+        </property>
+        <item>
+         <widget class="QLabel" name="TextLabel1_2" >
+           <string>Name</string>
+          </property>
+          <property name="buddy" >
+           <cstring>txtName</cstring>
+          </property>
+         </widget>
+        </item>
+        <item>
+         <widget class="QLabel" name="TextLabel2" >
+           <string>Database instance</string>
+          </property>
+           <cstring>txtDatabase</cstring>
+          </property>
+         </widget>
+        </item>
+        <item>
+         <widget class="QLabel" name="TextLabel3" >
+           <string>Username</string>
+          </property>
+           <cstring>txtUsername</cstring>
+          </property>
+         </widget>
+        </item>
+        <item>
+         <widget class="QLabel" name="TextLabel3_2" >
+           <string>Password</string>
+          </property>
+           <cstring>txtPassword</cstring>
+          </property>
+         </widget>
+        </item>
+       </layout>
+      </item>
+      <item>
+       <layout class="QVBoxLayout" name="boxFieldEntries" >
+        </property>
+        </property>
+        <item>
+         <widget class="QLineEdit" name="txtName" >
+          <property name="toolTip" >
+           <string>Name of the new connection</string>
+          </property>
+         </widget>
+        </item>
+        <item>
+         <widget class="QLineEdit" name="txtDatabase" />
+        </item>
+        <item>
+         <widget class="QLineEdit" name="txtUsername" />
+        </item>
+        <item>
+         <widget class="QLineEdit" name="txtPassword" >
+          <property name="echoMode" >
+           <enum>QLineEdit::Password</enum>
+          </property>
+         </widget>
+        </item>
+       </layout>
+      </item>
+     </layout>
+    </item>
+    <item>
+     <layout class="QHBoxLayout" name="boxCheckbox" >
+      </property>
+      </property>
+      <item>
+       <widget class="QCheckBox" name="chkStorePassword" >
+         <string>Save Password</string>
+        </property>
+       </widget>
+      </item>
+     </layout>
+    </item>
+   </layout>
+  </widget>
+ </widget>
+ <layoutdefault spacing="6" margin="11" />
+ <resources/>
+ <connections>
+  <connection>
+   <sender>btnOk</sender>
+   <signal>clicked()</signal>
+   <receiver>OracleConnectGuiBase</receiver>
+   <slot>accept()</slot>
+   <hints>
+    <hint type="sourcelabel" >
+     <x>383</x>
+     <y>24</y>
+    </hint>
+    <hint type="destinationlabel" >
+     <x>217</x>
+     <y>103</y>
+    </hint>
+   </hints>
+  </connection>
+  <connection>
+   <sender>btnCancel</sender>
+   <slot>reject()</slot>
+   <hints>
+     <x>383</x>
+     <y>56</y>
+    </hint>
+     <x>217</x>
+     <y>103</y>
+    </hint>
+   </hints>
+  </connection>
+ </connections>
+</ui>
Added: trunk/qgis/src/plugins/oracle_raster/qgsselectgeoraster_ui.cpp
--- trunk/qgis/src/plugins/oracle_raster/qgsselectgeoraster_ui.cpp	                        (rev 0)
+++ trunk/qgis/src/plugins/oracle_raster/qgsselectgeoraster_ui.cpp	2009-04-15 14:18:30 UTC (rev 10566)
@@ -0,0 +1,321 @@
+  oracleselectgui.cpp
+/* $Id$ */
+//GDAL includes
+#include "gdal.h"
+#include "ogr_api.h"
+#include "ogrsf_frmts.h"
+#include "qgsvectorlayer.h"
+QgsOracleSelectGeoraster::QgsOracleSelectGeoraster(QWidget* parent,
+        QgisInterface* iface,
+        Qt::WFlags fl) : QDialog(parent, fl), mIface(iface)
+    setupUi(this);
+     *  Load the list of connection from the registry
+    populateConnectionList();
+     *  Repeat last selected connection
+    QString selected = settings.value( "/Oracle/connections/selected" ).toString();
+    if ( selected == cmbConnections->currentText() )
+        this->connectToServer();
+QgsOracleSelectGeoraster::~QgsOracleSelectGeoraster()
+void QgsOracleSelectGeoraster::populateConnectionList()
+    settings.beginGroup( "/Oracle/connections" );
+    QStringList keys = settings.childGroups();
+    QStringList::Iterator it = keys.begin();
+     *  Fillup the combobox with connection names
+    cmbConnections->clear();
+    while ( it != keys.end() )
+        cmbConnections->addItem( *it );
+        ++it;
+    settings.endGroup();
+    setConnectionListPosition();
+     *  Update the status of several buttons
+    if ( keys.begin() == keys.end() )
+        btnConnect->setEnabled( false );
+        btnEdit->setEnabled( false );
+        btnDelete->setEnabled( false );
+    else
+        btnConnect->setEnabled( true );
+        btnEdit->setEnabled( true );
+        btnDelete->setEnabled( true );
+void QgsOracleSelectGeoraster::addNewConnection()
+    QgsOracleConnect *oc = new QgsOracleConnect( this, "New Connection" );
+    if ( oc->exec() )
+void QgsOracleSelectGeoraster::editConnection()
+    QgsOracleConnect *oc = new QgsOracleConnect( this, cmbConnections->currentText() );
+    if ( oc->exec() )
+void QgsOracleSelectGeoraster::deleteConnection()
+    QString key = "/Oracle/connections/" + cmbConnections->currentText();
+    QString msg =
+            tr( "Are you sure you want to remove the " ) +
+            cmbConnections->currentText() +
+            tr( " connection and all associated settings?" );
+    QMessageBox::StandardButton result = QMessageBox::information( this,
+            tr( "Confirm Delete" ),
+            msg,
+            QMessageBox::Ok | QMessageBox::Cancel );
+    if ( result == QMessageBox::Ok )
+        settings.remove( key + "/database" );
+        settings.remove( key + "/username" );
+        settings.remove( key + "/password" );
+        settings.remove( key + "/savepass" );
+        settings.remove( key + "/subdtset" );
+        settings.remove( key );
+        cmbConnections->removeItem( cmbConnections->currentIndex() );
+        lineEdit->setText( "" );
+        listWidget->clear();
+void QgsOracleSelectGeoraster::connectToServer()
+    QString username = settings.value( key + "/username" ).toString();
+    QString password = settings.value( key + "/password" ).toString();
+    QString savepass = settings.value( key + "/savepass" ).toString();
+    QString database = settings.value( key + "/database" ).toString();
+    QString subdtset = settings.value( key + "/subdtset" ).toString();
+    bool makeConnection = true;
+    if ( savepass == "false" )
+        makeConnection = false;
+        QString password = QInputDialog::getText( this,
+                tr( "Password for " ) + username + "/<password>@" + database,
+                tr( "Please enter your password:" ),
+                QLineEdit::Password,
+                QString::null,
+                &makeConnection);
+    if (makeConnection)
+        settings.setValue( "/Oracle/connections/selected",
+                    cmbConnections->currentText() );
+        showSelection( subdtset );
+        lineEdit->setText( subdtset );
+void QgsOracleSelectGeoraster::showSelection( const QString & line )
+    QString identification = line;
+    GDALDatasetH hDS = NULL;
+    GDALAccess eAccess = GA_ReadOnly;
+     *  Set access mode
+    if( checkBox->checkState() == Qt::Checked )
+        eAccess = GA_Update;
+     *  Try to open georaster dataset
+    hDS = GDALOpenShared( identification.toAscii(), eAccess );
+    btnAdd->setEnabled( false );
+    if ( hDS == NULL )
+        QMessageBox::information( this,
+                tr( "Open failed" ),
+                tr( "The connection to " + identification.toAscii() +
+                " failed. Please verify your connection parameters."
+                " Make sure you have the GDAL GeoRaster plugin installed." ) );
+        return;
+    btnAdd->setEnabled( true );
+     *  Get subdataset list
+    char **papszMetadata = NULL;
+    papszMetadata = GDALGetMetadata( hDS, "SUBDATASETS" );
+    int nSubDatasets = CSLCount( papszMetadata );
+     *  Add GeoRaster Layer
+    if ( ! nSubDatasets )
+        mIface->addRasterLayer( identification );
+        GDALClose(hDS);
+        return;
+     *  Save subdataset
+    settings.setValue( "/Oracle/connections/" +
+        cmbConnections->currentText() + "/subdtset", identification );
+     *  List subdatasets
+    QStringList fields = identification.split(',');
+    QString count = QString::number( nSubDatasets / 2 );
+    QString plural = "s";
+    if ( count == "1" )
+        plural = "";
+    if ( fields.size() < 4 )
+        labelStatus->setText( QString( "%1 GeoRaster table%2" )
+          .arg( count ).arg( plural ) );
+        checkBox->setEnabled( false );
+    else if ( fields.size() == 4 )
+        labelStatus->setText( QString( "%1 GeoRaster column%2 on table %3" )
+          .arg( count ).arg( plural ).arg( fields[3] ) );
+    else if ( fields.size() == 5 )
+        labelStatus->setText( QString( "%1 GeoRaster object%2 on table %3 column %4" )
+          .arg( count ).arg( plural ).arg( fields[3] ).arg( fields[4] ) );
+        checkBox->setEnabled( true );
+    else
+        labelStatus->setText( QString( "%1 GeoRaster object%2 on table %3 column %4 where %5" )
+          .arg( count ).arg( plural ).arg( fields[3] ).arg( fields[4] ).arg( fields[5] ) );
+     *  Populate selection list based on subdataset names
+    QListWidgetItem *textItem;
+    for ( int i = 0; i < nSubDatasets; i += 2 )
+        QString metadata = papszMetadata[i];
+        QStringList subdataset = metadata.split( '=' );
+        textItem = new QListWidgetItem( subdataset[1] );
+        listWidget->addItem( textItem );
+    GDALClose(hDS);
+void QgsOracleSelectGeoraster::showHelp()
+    // implement me
+void QgsOracleSelectGeoraster::setConnectionListPosition()
+    // If possible, set the item currently displayed database
+    QString toSelect = settings.value( "/Oracle/connections/selected" ).toString();
+    // Does toSelect exist in cmbConnections?
+    bool set = false;
+    for ( int i = 0; i < cmbConnections->count(); ++ i)
+        if ( cmbConnections->itemText(i) == toSelect )
+            cmbConnections->setCurrentIndex( i );
+            set = true;
+            break;
+    // If we couldn't find the stored item, but there are some,
+    // default to the last item (this makes some sense when deleting
+    // items as it allows the user to repeatidly click on delete to
+    // remove a whole lot of items).
+    if ( ! set && cmbConnections->count() > 0 )
+        // If toSelect is null, then the selected connection wasn't found
+        // by QSettings, which probably means that this is the first time
+        // the user has used qgis with database connections, so default to
+        // the first in the list of connetions. Otherwise default to the last.
+        if ( toSelect.isNull() )
+            cmbConnections->setCurrentIndex( 0 );
+        else
+            cmbConnections->setCurrentIndex( cmbConnections->count() - 1 );
Added: trunk/qgis/src/plugins/oracle_raster/qgsselectgeoraster_ui.h
--- trunk/qgis/src/plugins/oracle_raster/qgsselectgeoraster_ui.h	                        (rev 0)
+++ trunk/qgis/src/plugins/oracle_raster/qgsselectgeoraster_ui.h	2009-04-15 14:18:30 UTC (rev 10566)
@@ -0,0 +1,95 @@
+    oracleselectgui.h
+/* $Id$ */
+#ifndef OraclePluginGUI_H
+#define OraclePluginGUI_H
+#include "ui_qgsselectgeorasterbase.h"
+//Qt includes
+#include <QInputDialog>
+// QGIS Includes
+#include <qgsmapcanvas.h>
+class QgsOracleSelectGeoraster : public QDialog, private Ui::SelectGeoRasterBase
+    Q_OBJECT
+public:
+    QgsOracleSelectGeoraster(QWidget* parent, QgisInterface* iface, Qt::WFlags fl = 0);
+    ~QgsOracleSelectGeoraster();
+private:
+    QgisInterface* mIface;
+    QString mUri;
+private:
+    void addNewConnection();
+    void editConnection();
+    void deleteConnection();
+    void populateConnectionList();
+    void connectToServer();
+    void showHelp();
+    void setConnectionListPosition();
+    void showSelection( const QString & line );
+public slots:
+    void on_btnNew_clicked()
+        addNewConnection();
+    void on_btnEdit_clicked()
+        editConnection();
+    void on_btnDelete_clicked()
+        deleteConnection();
+    void on_btnConnect_clicked()
+        connectToServer();
+    void on_listWidget_clicked( QModelIndex Index )
+        if( lineEdit->text() == listWidget->currentItem()->text() )
+            showSelection( lineEdit->text() );
+        else
+            lineEdit->setText( listWidget->currentItem()->text() );
+    void on_btnAdd_clicked()
+#endif
Added: trunk/qgis/src/plugins/oracle_raster/qgsselectgeorasterbase.ui
--- trunk/qgis/src/plugins/oracle_raster/qgsselectgeorasterbase.ui	                        (rev 0)
+++ trunk/qgis/src/plugins/oracle_raster/qgsselectgeorasterbase.ui	2009-04-15 14:18:30 UTC (rev 10566)
@@ -0,0 +1,284 @@
+ <class>SelectGeoRasterBase</class>
+ <widget class="QDialog" name="SelectGeoRasterBase" >
+   <rect>
+    <x>0</x>
+    <y>0</y>
+    <width>461</width>
+    <height>454</height>
+   </rect>
+  </property>
+   <string>Select Oracle Spatial GeoRaster</string>
+  </property>
+   <iconset>
+    <normaloff>../../ui</normaloff>../../ui</iconset>
+  </property>
+  <property name="sizeGripEnabled" >
+   <bool>true</bool>
+  </property>
+  <property name="modal" >
+   <bool>true</bool>
+  </property>
+  <layout class="QGridLayout" >
+    <number>9</number>
+   </property>
+   </property>
+   <item row="0" column="0" colspan="4" >
+      <string>Server Connections</string>
+     </property>
+      </property>
+      </property>
+      <item row="1" column="4" >
+       <spacer>
+         <enum>Qt::Horizontal</enum>
+        </property>
+        </property>
+         <size>
+          <width>131</width>
+          <height>30</height>
+         </size>
+        </property>
+       </spacer>
+      </item>
+      <item row="0" column="0" colspan="5" >
+       <widget class="QComboBox" name="cmbConnections" />
+      </item>
+      <item row="1" column="0" >
+       <widget class="QPushButton" name="btnConnect" >
+        <property name="enabled" >
+         <bool>false</bool>
+        </property>
+         <string>C&amp;onnect</string>
+        </property>
+       </widget>
+      </item>
+      <item row="1" column="2" >
+       <widget class="QPushButton" name="btnEdit" >
+        </property>
+         <string>Edit</string>
+        </property>
+       </widget>
+      </item>
+      <item row="1" column="3" >
+       <widget class="QPushButton" name="btnDelete" >
+        </property>
+         <string>Delete</string>
+        </property>
+       </widget>
+      </item>
+      <item row="1" column="1" >
+       <widget class="QPushButton" name="btnNew" >
+         <string>&amp;New</string>
+        </property>
+       </widget>
+      </item>
+     </layout>
+    </widget>
+   </item>
+   <item row="2" column="0" colspan="4" >
+    <widget class="QGroupBox" name="gbCRS" >
+      <string>Selection</string>
+     </property>
+     <layout class="QHBoxLayout" >
+      </property>
+      </property>
+      <item>
+       <widget class="QLabel" name="labelCoordRefSys" >
+         <string/>
+        </property>
+       </widget>
+      </item>
+      <item>
+       <widget class="QLineEdit" name="lineEdit" />
+      </item>
+      <item>
+       <widget class="QCheckBox" name="checkBox" >
+        </property>
+         <string>Update</string>
+        </property>
+       </widget>
+      </item>
+     </layout>
+    </widget>
+   </item>
+   <item row="4" column="0" colspan="4" >
+    <widget class="QLabel" name="labelStatus" >
+     <property name="sizePolicy" >
+      <sizepolicy vsizetype="Preferred" hsizetype="Ignored" >
+       <horstretch>0</horstretch>
+       <verstretch>0</verstretch>
+      </sizepolicy>
+     </property>
+      <string>Ready</string>
+     </property>
+     <property name="wordWrap" >
+     </property>
+    </widget>
+   </item>
+   <item row="3" column="2" >
+    <widget class="QPushButton" name="btnAdd" >
+     </property>
+      <string>&amp;Select</string>
+     </property>
+      <string>Alt+A</string>
+     </property>
+      <bool>true</bool>
+     </property>
+      <bool>true</bool>
+     </property>
+    </widget>
+   </item>
+   <item row="1" column="0" colspan="4" >
+    <widget class="QGroupBox" name="btnGrpImageEncoding" >
+      <sizepolicy vsizetype="Preferred" hsizetype="Preferred" >
+      </sizepolicy>
+     </property>
+     <property name="minimumSize" >
+      <size>
+       <width>16</width>
+       <height>64</height>
+      </size>
+     </property>
+      <string>Subdatasets</string>
+     </property>
+     <layout class="QVBoxLayout" name="verticalLayout" >
+      <item>
+       <widget class="QListWidget" name="listWidget" >
+         <sizepolicy vsizetype="Expanding" hsizetype="Expanding" >
+         </sizepolicy>
+        </property>
+        <property name="autoFillBackground" >
+        </property>
+       </widget>
+      </item>
+     </layout>
+    </widget>
+   </item>
+   <item row="3" column="1" >
+    <spacer>
+     </property>
+     </property>
+      <size>
+       <width>284</width>
+       <height>31</height>
+      </size>
+     </property>
+    </spacer>
+   </item>
+   <item row="3" column="0" >
+    <widget class="QPushButton" name="btnHelp" >
+      <bool>true</bool>
+     </property>
+      <string>Help</string>
+     </property>
+      <string>F1</string>
+     </property>
+      <bool>true</bool>
+     </property>
+    </widget>
+   </item>
+   <item row="3" column="3" >
+      <string>C&amp;lose</string>
+     </property>
+      <string>Alt+L</string>
+     </property>
+      <bool>true</bool>
+     </property>
+    </widget>
+   </item>
+  </layout>
+ </widget>
+ <tabstops>
+  <tabstop>cmbConnections</tabstop>
+  <tabstop>btnConnect</tabstop>
+  <tabstop>btnNew</tabstop>
+  <tabstop>btnEdit</tabstop>
+  <tabstop>btnDelete</tabstop>
+  <tabstop>btnHelp</tabstop>
+  <tabstop>btnAdd</tabstop>
+  <tabstop>btnCancel</tabstop>
+ </tabstops>
+ <resources/>
+ <connections>
+  <connection>
+   <receiver>SelectGeoRasterBase</receiver>
+   <hints>
+     <x>410</x>
+     <y>457</y>
+    </hint>
+     <x>229</x>
+     <y>252</y>
+    </hint>
+   </hints>
+  </connection>
+ </connections>
+</ui>
More information about the QGIS-commit mailing list
