[QGIS Commit] r10636 - in trunk/qgis: . i18n
svn_qgis at osgeo.org
Thu Apr 23 16:18:19 EDT 2009
Author: macho
Date: 2009-04-23 16:18:19 -0400 (Thu, 23 Apr 2009)
New Revision: 10636
trunk/qgis/TRANSLATORS
trunk/qgis/i18n/qgis_nl.ts
translation update: nl by Richard
Modified: trunk/qgis/TRANSLATORS
--- trunk/qgis/TRANSLATORS 2009-04-23 18:36:19 UTC (rev 10635)
+++ trunk/qgis/TRANSLATORS 2009-04-23 20:18:19 UTC (rev 10636)
@@ -13,9 +13,10 @@
Arabic|Assem Kamal
Czech|Martin Landa
Chinese|Zhang Jun
-Danish|Henriette Roued
+Danish|Henriette Roued
+Dutch|Richard Duivenvoorde, Raymond Nijssen
French|Eve Rousseau, Marc Monnerat, Lionel Roubeyrie
-German|Jürgen E. Fischer, Stephan Holl
+German|Jürgen E. Fischer, Stephan Holl, Otto Dassau, Werner Macho
Hungarian|Siki Zoltan
Indonesian|Januar V. Simarmata
Italian|Maurizio Napolitano
Modified: trunk/qgis/i18n/qgis_nl.ts
--- trunk/qgis/i18n/qgis_nl.ts 2009-04-23 18:36:19 UTC (rev 10635)
+++ trunk/qgis/i18n/qgis_nl.ts 2009-04-23 20:18:19 UTC (rev 10636)
@@ -478,415 +478,415 @@
</message>
<message>
<source>Intersect layer</source>
- <translation type="unfinished"></translation>
+ <translation>Intersectie van laag</translation>
</message>
<message>
<source>Buffer distance</source>
+ <translation>Bufferafstand</translation>
</message>
<message>
<source>Buffer distance field</source>
+ <translation>Veld voor bufferafstand</translation>
</message>
<message>
<source>Dissolve field</source>
+ <translation>Veld voor 'dissolve'-aktie</translation>
</message>
<message>
<source>Dissolve buffer results</source>
+ <translation>Dissolve buffer resultaten</translation>
</message>
<message>
<source>Output shapefile</source>
+ <translation>Uitvoerbestand (shape)</translation>
</message>
<message>
<source>Locate Line Intersections</source>
+ <translation>Localiseer lijndoorsnijdingen</translation>
</message>
<message>
<source>Input line layer</source>
+ <translation>Invoer lijnenlaag</translation>
</message>
<message>
<source>Input unique ID field</source>
+ <translation>Invoer unieke ID-veld</translation>
</message>
<message>
<source>Intersect line layer</source>
+ <translation>Intersectie lijnenlaag</translation>
</message>
<message>
<source>Intersect unique ID field</source>
+ <translation>Intersectie unieke ID-veld</translation>
</message>
<message>
<source>Output Shapefile</source>
</message>
<message>
<source>Join Attributes</source>
+ <translation>Join Attributen</translation>
</message>
<message>
<source>Target vector layer</source>
+ <translation>Doel-vectorlaag</translation>
</message>
<message>
<source>Target join field</source>
+ <translation>Doel-joinveld</translation>
</message>
<message>
<source>Join data</source>
+ <translation>Join data</translation>
</message>
<message>
<source>Join vector layer</source>
+ <translation>Join vectorlaag</translation>
</message>
<message>
<source>Join dbf table</source>
+ <translation>Join dbf tabel</translation>
</message>
<message>
<source>Join field</source>
+ <translation>Join veld</translation>
</message>
<message>
<source>Output table</source>
+ <translation>Uitvoer tabel</translation>
</message>
<message>
<source>Only keep matching records</source>
+ <translation>Alleen passende rijen behouden</translation>
</message>
<message>
<source>Keep all records (includeing non-matching target records)</source>
+ <translation>Alle rijen behouden (ook de niet passende doelrijen)</translation>
</message>
<message>
<source>Generate Centroids</source>
+ <translation>Genereer Centroiden</translation>
</message>
<message>
<source>Weight field</source>
+ <translation>Gewicht-veld</translation>
</message>
<message>
<source>Number of standard deviations</source>
+ <translation>Aantal standaardafwijkingen</translation>
</message>
<message>
<source>Std. Dev.</source>
+ <translation>Std.Afw.</translation>
</message>
<message>
<source>Create Distance Matrix</source>
+ <translation>Afstands Matrix Aanmaken</translation>
</message>
<message>
<source>Input point layer</source>
+ <translation>Invoer puntenlaag</translation>
</message>
<message>
<source>Target point layer</source>
+ <translation>Doel-puntenlaag</translation>
</message>
<message>
<source>Target unique ID field</source>
+ <translation>Doel unieke ID-veld</translation>
</message>
<message>
<source>Output matrix type</source>
+ <translation>Uitvoer matrixtype</translation>
</message>
<message>
<source>Linear (N*k x 3) distance matrix</source>
+ <translation>Lineaire (N*k x 3) afstandsmatrix</translation>
</message>
<message>
<source>Standard (N x T) distance matrix</source>
+ <translation>Standaard (N x T) afstands matrix</translation>
</message>
<message>
<source>Summary distance matrix (mean, std. dev., min, max)</source>
+ <translation>Samenvatting afstandsmatrix (gemiddeld, std.afw, min, max)</translation>
</message>
<message>
<source>Use only the nearest (k) target points:</source>
+ <translation>Alleen dichtstbijzijnde (k) doelpunten gebruiken:</translation>
</message>
<message>
<source>Output distance matrix</source>
+ <translation>Uitvoer afstandsmatrix</translation>
</message>
<message>
<source>Count Points In Polygons</source>
+ <translation>Punten in Polygonen Tellen</translation>
</message>
<message>
<source>Input polygon vector layer</source>
+ <translation>Invoer polygon-vectorlaag</translation>
</message>
<message>
<source>Input point vector layer</source>
+ <translation>Invoer punt-vectorlaag</translation>
</message>
<message>
<source>Output count field name</source>
+ <translation>Uitvoer tellen veldnaam</translation>
</message>
<message>
<source>PNTCNT</source>
+ <translation>PNTCNT</translation>
</message>
<message>
<source>Generate Random Points</source>
+ <translation>Random Punten Aanmaken</translation>
</message>
<message>
<source>Input Boundary Layer</source>
+ <translation>Invoer GrensLaag</translation>
</message>
<message>
<source>Minimum distance between points</source>
+ <translation>Minimale afstand tussen punten</translation>
</message>
<message>
<source>Sample Size</source>
+ <translation>Voorbeeld Grootte</translation>
</message>
<message>
<source>Unstratified Sampling Design (Entire layer)</source>
+ <translation>Unstratified Sampling Design (Gehele laag)</translation>
</message>
<message>
<source>Use this number of points</source>
+ <translation>Gebruik dit aantal punten</translation>
</message>
<message>
<source>Stratified Sampling Design (Individual polygons)</source>
+ <translation>Unstratified Sampling Design (Individuele polygonen)</translation>
</message>
<message>
<source>Use this density of points</source>
+ <translation>Gebruik deze dichtheid voor punten</translation>
</message>
<message>
<source>Use value from input field</source>
+ <translation>Gebruik de waarde van het invoerveld</translation>
</message>
<message>
<source>Random Selection Tool</source>
+ <translation>Willekeurige Selectie Gereedschap</translation>
</message>
<message>
<source>Input Vector Layer</source>
+ <translation>Invoer Vectorlaag</translation>
</message>
<message>
<source>Randomly Select</source>
+ <translation>Willekeurige Selectie</translation>
</message>
<message>
<source>Number of Features</source>
+ <translation>Aantal Objecten</translation>
</message>
<message>
<source>Percentage of Features</source>
+ <translation>Percentage Objecten</translation>
</message>
<message>
<source>%</source>
- <translation type="unfinished">%</translation>
+ <translation>%</translation>
</message>
<message>
<source>Projection Management Tool</source>
+ <translation>Gereedschap voor Projectiemanagement</translation>
</message>
<message>
<source>Input spatial reference system</source>
+ <translation>Ruimtelijk Referentie Systeem input</translation>
</message>
<message>
<source>Output spatial reference system</source>
+ <translation>Ruimtelijk Referentie Systeem uitvoer</translation>
</message>
<message>
<source>Use predefined spatial reference system</source>
+ <translation>Gebruik voorgedefineerd ruimtelijk referentie systeem</translation>
</message>
<message>
<source>Choose</source>
+ <translation>Kiezen</translation>
</message>
<message>
<source>Import spatial reference system from existing layer</source>
+ <translation>Gebruik ruimtelijk referentie systeem van bestaande laag</translation>
</message>
<message>
<source>Import spatial reference system:</source>
+ <translation>Gebruik ruimtelijk referentie systeem:</translation>
</message>
<message>
<source>Generate Regular Points</source>
+ <translation>Genereer Regelmatige Punten</translation>
</message>
<message>
<source>Input Coordinates</source>
+ <translation>Invoer Coördinaten</translation>
</message>
<message>
<source>X Min</source>
+ <translation>X Min</translation>
</message>
<message>
<source>Y Min</source>
+ <translation>Y Min</translation>
</message>
<message>
<source>X Max</source>
+ <translation>X Max</translation>
</message>
<message>
<source>Y Max</source>
+ <translation>Y Max</translation>
</message>
<message>
<source>Grid Spacing</source>
+ <translation>Grid Tussenruimte</translation>
</message>
<message>
<source>Use this point spacing</source>
+ <translation>Gebruik deze tussenruimte voor punten</translation>
</message>
<message>
<source>Apply random offset to point spacing</source>
+ <translation>Willekeurige verschuiving voor tussenruimte van punten</translation>
</message>
<message>
<source>Initial inset from corner (LH side)</source>
+ <translation>Beginwaarde voor hoek (LH kant)</translation>
</message>
<message>
<source>Spatial Join</source>
+ <translation>Ruimtelijke Join</translation>
</message>
<message>
<source>Attribute Summary</source>
+ <translation>Attribuut Samenvatting</translation>
</message>
<message>
<source>Take attributes of first located feature</source>
+ <translation>Attributen gebruiken van eerst gevonden object</translation>
</message>
<message>
<source>Take summary of intersecting features</source>
+ <translation>Samenvatting gebruiken van snijdende objecten</translation>
</message>
<message>
<source>Mean</source>
- <translation type="unfinished">Gemiddelde</translation>
+ <translation>Gemiddelde</translation>
</message>
<message>
<source>Min</source>
- <translation type="unfinished">Min</translation>
+ <translation>Min</translation>
</message>
<message>
<source>Max</source>
- <translation type="unfinished">Max</translation>
+ <translation>Max</translation>
</message>
<message>
<source>Sum</source>
+ <translation>Som</translation>
</message>
<message>
<source>Output Shapefile:</source>
+ <translation>Uitvoerbestand (shape):</translation>
</message>
<message>
<source>Random Selection From Within Subsets</source>
+ <translation>Willekeurige selectie binnen subsets</translation>
</message>
<message>
<source>Input subset field (unique ID field)</source>
+ <translation>Invoer subset veld (unieke ID veld)</translation>
</message>
<message>
<source>Sum Line Length In Polygons</source>
+ <translation>Som van lengte lijnen in Polygonen</translation>
</message>
<message>
<source>Output summed length field name</source>
+ <translation>Uitvoer sommatie van lengteveld naam</translation>
</message>
<message>
<source>LENGTH</source>
+ <translation>LENGTE</translation>
</message>
<message>
<source>Input line vector layer</source>
+ <translation>Invoer lijn-vectorlaag</translation>
</message>
<message>
<source>Grid extent</source>
+ <translation>Grid-extent</translation>
</message>
<message>
<source>Update extents from layer</source>
+ <translation>Extent opnieuw aanmaken o.b.v. laag</translation>
</message>
<message>
<source>Update extents from canvas</source>
+ <translation>Extent opnieuw aanmaken o.b.v. kaartvenster</translation>
</message>
<message>
<source>Parameters</source>
- <translation type="unfinished">Parameters</translation>
+ <translation>Parameters</translation>
</message>
<message>
<source>X</source>
- <translation type="unfinished">X</translation>
+ <translation>X</translation>
</message>
<message>
<source>Lock 1:1 ratio</source>
+ <translation>1:1 ratio vastzetten</translation>
</message>
<message>
<source>Y</source>
- <translation type="unfinished">Y</translation>
+ <translation>Y</translation>
</message>
<message>
<source>Output grid as polygons</source>
+ <translation>Grid als polygonen uitvoeren</translation>
</message>
<message>
<source>Output grid as lines</source>
+ <translation>Grid als lijnen uitvoeren</translation>
</message>
<message>
<source>Vector Split</source>
+ <translation>Vector Splitsen</translation>
</message>
<message>
<source>Output folder</source>
+ <translation>Map voor uitvoer</translation>
</message>
<message>
<source>List Unique Values</source>
+ <translation>Lijst unieke waarden</translation>
</message>
<message>
<source>Target field</source>
+ <translation>Doelveld</translation>
</message>
<message>
<source>Unique values list</source>
</message>
<message>
<source>Unique value count</source>
+ <translation>Aantal unieke waarden</translation>
</message>
</context>
<context>
@@ -1067,95 +1067,95 @@
<name>GeoprocessingDialog</name>
<message>
<source>Dissolve all</source>
+ <translation>'Dissolve' alles</translation>
</message>
<message>
<source>Please specify an input layer</source>
+ <translation>Selecteer een laag als input</translation>
</message>
<message>
<source>Please specify a difference/intersect/union layer</source>
+ <translation>Selecteer een laag als 'difference/intersectie/union'-laag</translation>
</message>
<message>
<source>Please specify valid buffer value</source>
+ <translation>Geef een geldige bufferwaarde</translation>
</message>
<message>
<source>Please specify dissolve field</source>
+ <translation>Selecteer het veld voor de 'dissolve'-aktie</translation>
</message>
<message>
<source>Please specify output shapefile</source>
+ <translation>Selecteer een vectorlaag voor uitvoer</translation>
</message>
<message>
<source>Unable to create geoprocessing result.</source>
+ <translation>Problemen bij het aanmaken van het resultaat.</translation>
</message>
<message>
<source>Created output shapefile</source>
</message>
<message>
<source>Would you like to add the new layer to the TOC?</source>
+ <translation>De nieuwe laag aan de TOC toevoegen?</translation>
</message>
<message>
<source>Buffer(s)</source>
+ <translation>Buffer(s)</translation>
</message>
<message>
<source>Create single minimum convex hull</source>
+ <translation>Aanmaken 'single minimum convex hull'</translation>
</message>
<message>
<source>Create convex hulls based on input field</source>
+ <translation>Aanmaken 'convex hull' op basis van een invoerveld</translation>
</message>
<message>
<source>Convex hull(s)</source>
+ <translation>'Convex hull(s)'</translation>
</message>
<message>
<source>Dissolve</source>
+ <translation>Dissolve</translation>
</message>
<message>
<source>Erase layer</source>
+ <translation>Laag verwijderen</translation>
</message>
<message>
<source>Difference</source>
+ <translation>Difference</translation>
</message>
<message>
</message>
<message>
<source>Intersect</source>
+ <translation>Intersectie</translation>
</message>
<message>
<source>Difference layer</source>
+ <translation>Difference laag</translation>
</message>
<message>
<source>Symetrical difference</source>
+ <translation>Symmetrische difference</translation>
</message>
<message>
<source>Clip layer</source>
+ <translation>'Clip' laag</translation>
</message>
<message>
<source>Clip</source>
+ <translation>Clip</translation>
</message>
<message>
<source>Union layer</source>
+ <translation>Union laag</translation>
</message>
<message>
<source>Union</source>
@@ -2505,87 +2505,88 @@
<source>No QGIS data provider plugins found in:
%1
</source>
+ <translation>Geen Dataprovider-plugins gevonden in:
+%1</translation>
</message>
<message>
<source>Referenced column wasn't found: %1</source>
+ <translation>Verwijzende kolom is niet gevonden: %1</translation>
</message>
<message>
<source>Location: %1</source>
+ <translation>Locatie: %1</translation>
</message>
<message>
<source>Location: %1<br>Mapset: %2</source>
+ <translation>Locatie: %1<br> Mapset: %2</translation>
</message>
<message>
<source>Couldn't open the data source: %1</source>
+ <translation>De volgende databron kan niet worden geopend: %1</translation>
</message>
<message>
<source>Parse error at line %1 : %2</source>
+ <translation>Parseerfout op positie %1 : %2</translation>
</message>
<message>
<source>%1 is not a GRASS mapset.</source>
+ <translation>%1 is geen GRASS-mapset.</translation>
</message>
<message>
<source>Cannot start %1/etc/lock</source>
+ <translation>Starten mislukt van %1 /etc/lock</translation>
</message>
<message>
<source>Temporary directory %1 exists but is not writable</source>
+ <translation>Tijdelijke map %1 bestaat, maar is niet schrijfbaar</translation>
</message>
<message>
<source>Cannot create temporary directory %1</source>
+ <translation>Kan tijdelijke map %1 niet aanmaken </translation>
</message>
<message>
<source>Cannot create %1</source>
+ <translation>Aanmaken %1 mislukt</translation>
</message>
<message>
<source>Cannot remove mapset lock: %1</source>
+ <translation>Kan de mapset niet vrijkrijgen ('locked'): %1</translation>
</message>
<message>
<source>Couldn't load plugin %1</source>
+ <translation>Kan plugin niet laden %1</translation>
</message>
<message>
<source>%1 due an error when calling its classFactory() method</source>
+ <translation>%1door een fout bij het aanroepen van de classFactory()-methode</translation>
</message>
<message>
<source>%1 due an error when calling its initGui() method</source>
+ <translation>%1 door een fout bij het aanroepen van de initGui()-methode</translation>
</message>
<message>
<source>Error while unloading plugin %1</source>
+ <translation>Fout bij het uitschakelen van plugin %1</translation>
</message>
<message>
<source>Georeferencer GDAL</source>
+ <translation>Georeferencer GDAL</translation>
</message>
<message>
<source>Adding projection info to rasters using GDAL</source>
+ <translation>Toevoegen projectie-informatie aan raster m.b.v GDAL</translation>
</message>
<message>
<source>SQLite DB (*.sqlite);;All files (*.*)</source>
+ <translation>SQLite DB (*.sqlite);;Alle bestanden (*.*)</translation>
</message>
<message>
<source>Oracle Spatial GeoRaster</source>
+ <translation>Oracle Spatial GeoRaster</translation>
</message>
<message>
<source>Access Oracle Spatial GeoRaster</source>
+ <translation>Toegang tot Oracle Spatial GeoRaster</translation>
</message>
</context>
<context>
@@ -7107,12 +7108,12 @@
<translation><html><head><meta name="qrichtext" content="1" /><style type="text/css">(new line)
p, li { white-space: pre-wrap; }(new line)
</style></head><body style=" font-family:'Verdana'; font-size:10pt; font-weight:400; font-style:normal;">(new line)
-<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px; font-family:'Sans Serif'; font-size:9pt;"><span style=" font-size:12pt;">Description</span></p>(new line)
+<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px; font-family:'Sans Serif'; font-size:9pt;"><span style=" font-size:12pt;">Omschrijving</span></p>(new line)
<p style="-qt-paragraph-type:empty; margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px; font-family:'Sans Serif'; font-size:9pt;"></p>(new line)
-<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px; font-family:'Sans Serif'; font-size:9pt;">Enter your copyright label below. This plugin supports basic html markup tags for formatting the label. For example:</p>(new line)
-<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px; font-family:'Sans Serif'; font-size:9pt;"><span style=" font-weight:600;">&lt;B&gt; Bold text &lt;/B&gt; </span></p>(new line)
-<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px; font-family:'Sans Serif'; font-size:9pt; font-weight:600;"><span style=" font-weight:400; font-style:italic;">&lt;I&gt; Italics &lt;/I&gt;</span></p>(new line)
-<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px; font-family:'Sans Serif'; font-size:9pt; font-style:italic;"><span style=" font-style:normal;">(note: &amp;copy; gives a copyright symbol)</span></p></body></html></translation>
+<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px; font-family:'Sans Serif'; font-size:9pt;">Voer uw copyright-melding beneden in. Deze plugin ondersteunt eenvoudige html om het label te tonen. Bijvoorbeeld:</p>(new line)
+<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px; font-family:'Sans Serif'; font-size:9pt;"><span style=" font-weight:600;">&lt;B&gt; Vette tekst &lt;/B&gt; </span></p>(new line)
+<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px; font-family:'Sans Serif'; font-size:9pt; font-weight:600;"><span style=" font-weight:400; font-style:italic;">&lt;I&gt; Schuin &lt;/I&gt;</span></p>(new line)
+<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px; font-family:'Sans Serif'; font-size:9pt; font-style:italic;"><span style=" font-style:normal;">(opmerking: &amp;copy; geeft het copyright symbool)</span></p></body></html></translation>
</message>
<message>
<source><html><head><meta name="qrichtext" content="1" /><style type="text/css">
@@ -14122,47 +14123,47 @@
</message>
<message>
<source>Enter attribute values</source>
+ <translation>Voer Attribuutwaarden in</translation>
</message>
<message>
<source>Suppress attributes pop-up windows after each created feature</source>
+ <translation>Geen attribuut-popups na het aanmaken van elk kaartobject tonen</translation>
</message>
<message>
<source>Proxy type</source>
+ <translation>Proxy type</translation>
</message>
<message>
<source>Exclude URLs:</source>
+ <translation>URLs uitsluiten:</translation>
</message>
<message>
<source>Add</source>
- <translation type="unfinished">Toevoegen</translation>
+ <translation>Toevoegen</translation>
</message>
<message>
<source>Remove</source>
- <translation type="unfinished">Verwijder</translation>
+ <translation>Verwijder</translation>
</message>
<message>
<source>Overlay</source>
+ <translation>Overlay</translation>
</message>
<message>
<source>Position</source>
- <translation type="unfinished">Positie</translation>
+ <translation>Positie</translation>
</message>
<message>
<source>Placement algorithm:</source>
+ <translation>Plaatsings-algoritme:</translation>
</message>
<message>
<source>map units</source>
+ <translation>kaart eenheden</translation>
</message>
<message>
<source>pixels</source>
+ <translation>pixels</translation>
</message>
</context>
<context>
@@ -15106,7 +15107,7 @@
</style></head><body style=" font-family:'DejaVu Sans'; font-size:9pt; font-weight:400; font-style:normal;">
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"><span style=" font-weight:600;">Note:</span> If this function is enabled, Quantum GIS will inform you whenever a new plugin or plugin update is available. Otherwise, fetching repositories will be performed during opening of the Plugin Installer window.</p></body></html></source>
- <translation><!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0//EN" "http://www.w3.org/TR/REC-html40/strict.dtd"><html><head><meta name="qrichtext" content="1" /><style type="text/css">p, li { white-space: pre-wrap; }</style></head><body style=" font-family:'DejaVu Sans'; font-size:9pt; font-weight:400; font-style:normal;"><p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"><span style=" font-weight:600;">Note:</span>Als ud dit instelt zal QGIS u op de hoogte stellen wanneer er een nieuwe plugin is of er een nieuwere versie van een plugin s. In het andere geval zal de informatie worden opgehaald tijdens het openen van de 'Plugin installer'-dialoog.</p></body></html></translation>
+ <translation><!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0//EN" "http://www.w3.org/TR/REC-html40/strict.dtd"><html><head><meta name="qrichtext" content="1" /><style type="text/css">p, li { white-space: pre-wrap; }</style></head><body style=" font-family:'DejaVu Sans'; font-size:9pt; font-weight:400; font-style:normal;"><p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"><span style=" font-weight:600;">Opmerking:</span>Als u dit instelt zal QGIS u op de hoogte stellen wanneer er een nieuwe plugin is of er een nieuwere versie van een plugin is. In het andere geval zal de informatie worden opgehaald tijdens het openen van de 'Plugin installer'-dialoog.</p></body></html></translation>
</message>
<message>
<source>Allowed plugins</source>
@@ -15130,7 +15131,7 @@
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"><span style=" font-weight:600;">Note:</span> Experimental plugins are generally unsuitable for production use. These plugins are in early stages of development, and should be considered 'incomplete' or 'proof of concept' tools. QGIS does not recommend installing these plugins unless you intend to use them for testing purposes.</p></body></html></source>
- <translation><!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0//EN" "http://www.w3.org/TR/REC-html40/strict.dtd"><html><head><meta name="qrichtext" content="1" /><style type="text/css">p, li { white-space: pre-wrap; }</style></head><body style=" font-family:'DejaVu Sans'; font-size:9pt; font-weight:400; font-style:normal;"><p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"><span style=" font-weight:600;">Note:</span> Experimentele plugins zijn niet bruikbaar in een produktieomgeving. Het zijn eerste versies, en moeten gezien worden als 'nog niet af' of 'probeersels'. QGIS raad deze plugins niet aan, behalve als u iets wilt uittesten.</p></body></html></translation>
+ <translation><!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0//EN" "http://www.w3.org/TR/REC-html40/strict.dtd"><html><head><meta name="qrichtext" content="1" /><style type="text/css">p, li { white-space: pre-wrap; }</style></head><body style=" font-family:'DejaVu Sans'; font-size:9pt; font-weight:400; font-style:normal;"><p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"><span style=" font-weight:600;">Opmerking:</span> Experimentele plugins zijn niet bruikbaar in een produktieomgeving. Het zijn eerste versies, en moeten gezien worden als 'nog niet af' of 'probeersels'. QGIS raadt deze plugins niet aan, behalve als u iets wilt uittesten.</p></body></html></translation>
</message>
</context>
<context>
@@ -16811,51 +16812,53 @@
<message>
<source><h3>Multiband Image Notes</h3><p>This is a multiband image. You can choose to render it as grayscale or color (RGB). For color images, you can associate bands to colors arbitarily. For example, if you have a seven band landsat image, you may choose to render it as:</p><ul><li>Visible Blue (0.45 to 0.52 microns) - not mapped</li><li>Visible Green (0.52 to 0.60 microns) - not mapped</li></li>Visible Red (0.63 to 0.69 microns) - mapped to red in image</li><li>Near Infrared (0.76 to 0.90 microns) - mapped to green in image</li><li>Mid Infrared (1.55 to 1.75 microns) - not mapped</li><li>Thermal Infrared (10.4 to 12.5 microns) - not mapped</li><li>Mid Infrared (2.08 to 2.35 microns) - mapped to blue in image</li></ul></source>
<comment>COMMENTED OUT</comment>
+ <translation><h3>Multiband Images Opmerking</h3><p>Dit is een multiband image. U kunt deze laten renderen als grijswaarden of kleur (RGB) afbeelding. Voor kleurafbeeldingen kunt u de zelf kleuren aan banden toewijzen. Bijvoorbeeld bij een zevenbands landsat image, zou u kunnen kiezen voor:</p><ul><li>Zichtbaar blauw (0.45 tot 0.52 microns) - niet zichtbaar</li><li>Zichtbaar groen (0.52 tot 0.60 microns) - niet zichtbaar</li></li>Zichtbaar rood (0.63 tot 0.69 microns) - zichtbaar als rood in afbeelding</li><li>Bijna infrarood (0.76 tot 0.90 microns) - zichtbaar als groen in afbeelding</li><li>Midden Infrarood (1.55 tot 1.75 microns) - niet zichtbaar</li><li>Thermisch infrarood (10.4 tot 12.5 microns) - niet zichtbaar</li><li>Midden Infrarood (2.08 tot 2.35 microns) - zichtbaar als blauw in afbeelding.</li></ul></translation>
</message>
<message>
<source><h3>Paletted Image Notes</h3> <p>This image uses a fixed color palette. You can remap these colors in different combinations e.g.</p><ul><li>Red - blue in image</li><li>Green - blue in image</li><li>Blue - green in image</li></ul></source>
+ <translation><h3>Opmerking over kleuring</h3> <p>Dit 'image' gebruikt een vast kleurenpalet. U kunt deze kleuren verwisselen naar verschillende andere combinaties bijvoorbeeld:</p><ul><li>Rood - blauw in afbeelding</li><li>Groen - rood in afbeelding</li><li>Blauw - groen in afbeelding</li></ul></translation>
</message>
<message>
<source><h3>Grayscale Image Notes</h3> <p>You can remap these grayscale colors to a pseudocolor image using an automatically generated color ramp.</p></source>
+ <translation><h3>Opmerking over grijswaardenkleuring</h3> <p>U kunt de grijswaarden verwisselen of instellen tot een pseudokleurenafbeelding met behulp van een automatisch gegenereerd kleurenpalet.</p></translation>
</message>
<message>
<source>Default R:%1 G:%2 B:%3</source>
+ <translation>Standaard R:%1 G:%2 B:%3</translation>
</message>
<message>
<source>Columns: %1</source>
+ <translation>Kolommen: %1</translation>
</message>
<message>
<source>Rows: %1</source>
+ <translation>Rijen: %1</translation>
</message>
<message>
<source>No-Data Value: %1</source>
+ <translation>Waarde voor 'geen data': %1</translation>
</message>
<message>
<source>Write access denied. Adjust the file permissions and try again.</source>
+ <translation>Schrijfrechten geweigerd. Pas de file-permissies aan en probeer opnieuw.</translation>
</message>
<message>
<source>The following lines contained errors
%1</source>
+ <translation>De volgende regels bevatten fouten
+%1</translation>
</message>
<message>
<source>The color map for band %1 failed to load</source>
+ <translation>De kleur voor ban %1 kon niet worden geladen </translation>
</message>
<message>
<source>Unknown style format: %1</source>
+ <translation>Onbekend stijlformaat: %1</translation>
</message>
</context>
<context>
@@ -21037,183 +21040,183 @@
<name>fTools</name>
<message>
<source>Quantum GIS version detected: </source>
+ <translation>QGIS versie gedetecteerd:</translation>
</message>
<message>
<source>This version of fTools requires at least QGIS version 1.0.0</source>
+ <translation>Deze versie van fTools vereist ten minste versie 1.0.0 van QGIS</translation>
</message>
<message>
<source>Plugin will not be enabled.</source>
+ <translation>Plugin zal niet worden ingeschakeld.</translation>
</message>
<message>
<source>&Tools</source>
+ <translation>&Gereedschappen</translation>
</message>
<message>
<source>&Analysis Tools</source>
+ <translation>&Analyse Gereedschappen</translation>
</message>
<message>
<source>Distance matrix</source>
+ <translation>Distance matrix</translation>
</message>
<message>
<source>Sum line lengths</source>
+ <translation>Lijnlengtes sommeren</translation>
</message>
<message>
<source>Points in polygon</source>
+ <translation>Punt in polygoon</translation>
</message>
<message>
<source>Basic statistics</source>
+ <translation>Basisstatistieken</translation>
</message>
<message>
<source>List unique values</source>
</message>
<message>
<source>Nearest neighbour analysis</source>
+ <translation>'Nearest neighbour'-analyse</translation>
</message>
<message>
<source>Mean coordinate(s)</source>
+ <translation>Gemiddelde coordinaten</translation>
</message>
<message>
<source>Line intersections</source>
+ <translation>Lijn-intersectie</translation>
</message>
<message>
<source>&Sampling Tools</source>
+ <translation>&Sample gereedschap</translation>
</message>
<message>
<source>Random selection</source>
+ <translation>Willekeurige selectie</translation>
</message>
<message>
<source>Random selection within subsets</source>
</message>
<message>
<source>Random points</source>
+ <translation>Willekeurige punten</translation>
</message>
<message>
<source>Regular points</source>
+ <translation>Regelmatige punten</translation>
</message>
<message>
<source>Vector grid</source>
+ <translation>Vectorgrid</translation>
</message>
<message>
<source>Select by location</source>
+ <translation>Selecteren op plaats</translation>
</message>
<message>
<source>&Geoprocessing Tools</source>
+ <translation>&Geoprocessing Gereedschap</translation>
</message>
<message>
</message>
<message>
</message>
<message>
</message>
<message>
- <translation type="unfinished">Union</translation>
+ <translation>Union</translation>
</message>
<message>
</message>
<message>
</message>
<message>
</message>
<message>
</message>
<message>
<source>G&eometry Tools</source>
+ <translation>G&eometrie gereedschappen</translation>
</message>
<message>
<source>Export/Add geometry columns</source>
+ <translation>Exporteer/Toevoegen geometrie-kolommen</translation>
</message>
<message>
<source>Check geometry validity</source>
+ <translation>Check geometrie op geldigheid</translation>
</message>
<message>
<source>Polygon centroids</source>
+ <translation>Polygoon-centroide</translation>
</message>
<message>
<source>Extract nodes</source>
+ <translation>Extraheer Knooppunten</translation>
</message>
<message>
<source>Simplify geometries</source>
+ <translation>Geometrien vereenvoudigen</translation>
</message>
<message>
<source>Multipart to singleparts</source>
+ <translation>Meervoudige objecten naar enkelvoudige</translation>
</message>
<message>
<source>Singleparts to multipart</source>
+ <translation>Enkelvoudige objecten naar meervoudige </translation>
</message>
<message>
<source>Polygons to lines</source>
+ <translation>Polygonen naar lijnen</translation>
</message>
<message>
<source>&Data Management Tools</source>
+ <translation>&Datamanagement Gereedschappen</translation>
</message>
<message>
<source>Export to new projection</source>
+ <translation>Naar nieuwe projectie exporteren</translation>
</message>
<message>
<source>Define current projection</source>
+ <translation>Definieer huidige projectie</translation>
</message>
<message>
<source>Join attributes</source>
+ <translation>Join attributen</translation>
</message>
<message>
<source>Join attributes by location</source>
+ <translation>Join attributen op basis van plaats</translation>
</message>
<message>
<source>Split vector layer</source>
+ <translation>Vector laag splitsen</translation>
</message>
<message>
<source>About fTools</source>
+ <translation>Info over fTools</translation>
</message>
</context>
<context>
