[QGIS Commit] r10643 - in trunk/qgis/src: app python ui
svn_qgis at osgeo.org
Thu Apr 23 18:27:40 EDT 2009
Author: jef
Date: 2009-04-23 18:27:40 -0400 (Thu, 23 Apr 2009)
New Revision: 10643
trunk/qgis/src/app/qgspythondialog.cpp
trunk/qgis/src/app/qgspythondialog.h
trunk/qgis/src/python/qgspythonutils.h
trunk/qgis/src/python/qgspythonutilsimpl.cpp
trunk/qgis/src/python/qgspythonutilsimpl.h
trunk/qgis/src/ui/qgspythondialog.ui
apply #1646
Modified: trunk/qgis/src/app/qgspythondialog.cpp
--- trunk/qgis/src/app/qgspythondialog.cpp 2009-04-23 22:21:54 UTC (rev 10642)
+++ trunk/qgis/src/app/qgspythondialog.cpp 2009-04-23 22:27:40 UTC (rev 10643)
@@ -16,6 +16,7 @@
#include "qgspythondialog.h"
#include "qgspythonutils.h"
+#include "qgslogger.h"
#include <QShowEvent>
#include <QCloseEvent>
@@ -43,43 +44,35 @@
return text.replace( "<", "<" ).replace( ">", ">" );
-void QgsPythonDialog::keyPressEvent( QKeyEvent *ev )
+void QgsPythonDialog::on_pbnPrev_clicked()
- switch ( ev->key() )
+ if ( pos > 0 )
- case Qt::Key_Up:
- if ( pos > 0 )
- if ( pos == history.size() )
- history << edtCmdLine->text();
- else
- history[pos] = edtCmdLine->text();
- pos--;
- edtCmdLine->setText( history[pos] );
- break;
- case Qt::Key_Down:
- if ( pos < history.size() - 1 )
- pos++;
- break;
- default:
- QWidget::keyPressEvent( ev );
- break;
+ if ( pos == history.size() )
+ history << edtCmdLine->toPlainText();
+ else
+ history[pos] = edtCmdLine->toPlainText();
+ pos--;
+ edtCmdLine->setText( history[pos] );
-void QgsPythonDialog::on_edtCmdLine_returnPressed()
+void QgsPythonDialog::on_pbnNext_clicked()
- QString command = edtCmdLine->text();
+ if ( pos < history.size() - 1 )
+ pos++;
+void QgsPythonDialog::on_pbnExecute_clicked()
+ QString command = edtCmdLine->toPlainText();
+ QgsDebugMsg( QString("command: |%1|").arg( command ) );
if ( !command.isEmpty() )
history << command;
@@ -90,7 +83,7 @@
// when using Py_single_input the return value will be always null
// we're using custom hooks for output and exceptions to show output in console
- if ( mPythonUtils->runStringUnsafe( command ) )
+ if ( mPythonUtils->runStringUnsafe( command, false ) )
mPythonUtils->evalString( "sys.stdout.get_and_clean_data()", output );
QString result = mPythonUtils->getResult();
Modified: trunk/qgis/src/app/qgspythondialog.h
--- trunk/qgis/src/app/qgspythondialog.h 2009-04-23 22:21:54 UTC (rev 10642)
+++ trunk/qgis/src/app/qgspythondialog.h 2009-04-23 22:27:40 UTC (rev 10643)
@@ -37,11 +37,12 @@
public slots:
- void on_edtCmdLine_returnPressed();
+ void on_pbnPrev_clicked();
+ void on_pbnExecute_clicked();
+ void on_pbnNext_clicked();
protected:
- void keyPressEvent( QKeyEvent *event );
void closeEvent( QCloseEvent *event );
void showEvent( QShowEvent *event );
Modified: trunk/qgis/src/python/qgspythonutils.h
--- trunk/qgis/src/python/qgspythonutils.h 2009-04-23 22:21:54 UTC (rev 10642)
+++ trunk/qgis/src/python/qgspythonutils.h 2009-04-23 22:27:40 UTC (rev 10643)
@@ -52,7 +52,7 @@
//! run a statement, error reporting is not done
//! @return true if no error occured
- virtual bool runStringUnsafe( const QString& command ) = 0;
+ virtual bool runStringUnsafe( const QString& command, bool single = true ) = 0;
virtual bool evalString( const QString& command, QString& result ) = 0;
Modified: trunk/qgis/src/python/qgspythonutilsimpl.cpp
--- trunk/qgis/src/python/qgspythonutilsimpl.cpp 2009-04-23 22:21:54 UTC (rev 10642)
+++ trunk/qgis/src/python/qgspythonutilsimpl.cpp 2009-04-23 22:27:40 UTC (rev 10643)
@@ -167,12 +167,12 @@
-bool QgsPythonUtilsImpl::runStringUnsafe( const QString& command )
+bool QgsPythonUtilsImpl::runStringUnsafe( const QString& command, bool single )
// TODO: convert special characters from unicode strings u"..." to \uXXXX
// so that they're not mangled to utf-8
// (non-unicode strings can be mangled)
- PyRun_String( command.toUtf8().data(), Py_single_input, mMainDict, mMainDict );
+ PyRun_String( command.toUtf8().data(), single ? Py_single_input : Py_file_input, mMainDict, mMainDict );
return ( PyErr_Occurred() == 0 );
Modified: trunk/qgis/src/python/qgspythonutilsimpl.h
--- trunk/qgis/src/python/qgspythonutilsimpl.h 2009-04-23 22:21:54 UTC (rev 10642)
+++ trunk/qgis/src/python/qgspythonutilsimpl.h 2009-04-23 22:27:40 UTC (rev 10643)
@@ -57,7 +57,7 @@
- bool runStringUnsafe( const QString& command );
+ bool runStringUnsafe( const QString& command, bool single = true );
bool evalString( const QString& command, QString& result );
Modified: trunk/qgis/src/ui/qgspythondialog.ui
--- trunk/qgis/src/ui/qgspythondialog.ui 2009-04-23 22:21:54 UTC (rev 10642)
+++ trunk/qgis/src/ui/qgspythondialog.ui 2009-04-23 22:27:40 UTC (rev 10643)
@@ -5,26 +5,39 @@
<rect>
<x>0</x>
<y>0</y>
- <width>541</width>
- <height>338</height>
+ <width>709</width>
+ <height>265</height>
</rect>
</property>
<property name="windowTitle" >
<string>Python console</string>
</property>
- <layout class="QVBoxLayout" >
- <property name="margin" >
- <number>9</number>
- </property>
- <property name="spacing" >
- <number>6</number>
- </property>
- <item>
+ <layout class="QGridLayout" name="gridLayout" >
+ <item row="3" column="3" >
+ <widget class="QPushButton" name="pbnExecute" >
+ <property name="text" >
+ <string>&Execute</string>
+ </property>
+ </widget>
+ </item>
+ <item row="2" column="3" >
+ <widget class="QPushButton" name="pbnPrev" >
+ <string>&Previous</string>
+ </property>
+ </widget>
+ </item>
+ <item row="4" column="3" >
+ <widget class="QPushButton" name="pbnNext" >
+ <string>&Next</string>
+ </property>
+ </widget>
+ </item>
+ <item row="0" column="0" colspan="3" >
<widget class="QLabel" name="lblInfo" >
<property name="sizePolicy" >
- <sizepolicy>
- <hsizetype>7</hsizetype>
- <vsizetype>5</vsizetype>
+ <sizepolicy vsizetype="Preferred" hsizetype="Expanding" >
<horstretch>0</horstretch>
<verstretch>0</verstretch>
</sizepolicy>
@@ -37,37 +50,43 @@
</property>
</widget>
</item>
- <item>
+ <item row="1" column="0" colspan="4" >
<widget class="QTextBrowser" name="txtHistory" >
<property name="html" >
- <string></string>
+ <string><!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0//EN" "http://www.w3.org/TR/REC-html40/strict.dtd">
+<html><head><meta name="qrichtext" content="1" /><style type="text/css">
+p, li { white-space: pre-wrap; }
+</style></head><body style=" font-family:'Sans Serif'; font-size:9pt; font-weight:400; font-style:normal;">
+<p style="-qt-paragraph-type:empty; margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"></p></body></html></string>
</property>
</widget>
</item>
- <item>
- <layout class="QHBoxLayout" >
- <number>0</number>
+ <item row="3" column="1" >
+ <widget class="QLabel" name="lblPrompt" >
+ <property name="sizePolicy" >
+ <sizepolicy vsizetype="Expanding" hsizetype="Preferred" >
+ <horstretch>0</horstretch>
+ <verstretch>0</verstretch>
+ </sizepolicy>
</property>
+ <string>>>></string>
</property>
- <item>
- <widget class="QLabel" name="lblPrompt" >
- <property name="text" >
- <string>>>></string>
- </property>
- </widget>
- </item>
- <item>
- <widget class="QLineEdit" name="edtCmdLine" />
- </item>
- </layout>
+ </widget>
</item>
+ <item rowspan="3" row="2" column="2" >
+ <widget class="QTextEdit" name="edtCmdLine" />
+ </item>
</layout>
+ <zorder>pbnExecute</zorder>
+ <zorder>pbnPrev</zorder>
+ <zorder>pbnNext</zorder>
+ <zorder>lblInfo</zorder>
+ <zorder>txtHistory</zorder>
+ <zorder>lblPrompt</zorder>
+ <zorder>edtCmdLine</zorder>
</widget>
<tabstops>
- <tabstop>edtCmdLine</tabstop>
<tabstop>txtHistory</tabstop>
</tabstops>
<resources/>
