[QGIS Commit] r10657 - in trunk/qgis: python/core src/core
src/providers/postgres
svn_qgis at osgeo.org
Sun Apr 26 18:49:38 EDT 2009
Author: jef
Date: 2009-04-26 18:49:37 -0400 (Sun, 26 Apr 2009)
New Revision: 10657
trunk/qgis/python/core/qgsdatasourceuri.sip
trunk/qgis/src/core/qgsdatasourceuri.cpp
trunk/qgis/src/core/qgsdatasourceuri.h
trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp
speed up loading of projects with (complex) views:
save key column of postgresql layers to projects file and try it first on
reload.
Modified: trunk/qgis/python/core/qgsdatasourceuri.sip
--- trunk/qgis/python/core/qgsdatasourceuri.sip 2009-04-26 22:40:49 UTC (rev 10656)
+++ trunk/qgis/python/core/qgsdatasourceuri.sip 2009-04-26 22:49:37 UTC (rev 10657)
@@ -43,7 +43,8 @@
void setDataSource(const QString& aSchema,
const QString& aTable,
const QString& aGeometryColumn,
- const QString& aSql = QString());
+ const QString& aSql = QString(),
+ const QString& aKeyColumn = QString());
/** Removes password from uris
* @note this method was added in QGIS 1.1
@@ -64,4 +65,8 @@
SSLmode sslMode() const;
void setSql(QString sql);
+ // added in 1.2
+ QString keyColumn() const;
+ void setKeyColumn(QString column);
Modified: trunk/qgis/src/core/qgsdatasourceuri.cpp
--- trunk/qgis/src/core/qgsdatasourceuri.cpp 2009-04-26 22:40:49 UTC (rev 10656)
+++ trunk/qgis/src/core/qgsdatasourceuri.cpp 2009-04-26 22:49:37 UTC (rev 10657)
@@ -23,12 +23,12 @@
#include <QStringList>
#include <QRegExp>
-QgsDataSourceURI::QgsDataSourceURI() : mSSLmode( SSLprefer )
+QgsDataSourceURI::QgsDataSourceURI() : mSSLmode( SSLprefer ), mKeyColumn( "" )
// do nothing
-QgsDataSourceURI::QgsDataSourceURI( QString uri ) : mSSLmode( SSLprefer )
+QgsDataSourceURI::QgsDataSourceURI( QString uri ) : mSSLmode( SSLprefer ), mKeyColumn( "" )
int i = 0;
while ( i < uri.length() )
@@ -104,6 +104,10 @@
i++;
+ else if ( pname == "key" )
+ mKeyColumn = pval;
else if ( pname == "service" )
QgsDebugMsg( "service keyword ignored" );
@@ -257,6 +261,16 @@
return mGeometryColumn;
+QString QgsDataSourceURI::keyColumn() const
+ return mKeyColumn;
+void QgsDataSourceURI::setKeyColumn( QString column )
+ mKeyColumn = column;
void QgsDataSourceURI::setSql( QString sql )
mSql = sql;
@@ -376,7 +390,8 @@
QString QgsDataSourceURI::uri() const
return connectionInfo()
- + QString( " table=%1 (%2) sql=%3" )
+ + QString( " key='%1' table=%2 (%3) sql=%4" )
+ .arg( keyColumn() )
.arg( quotedTablename() )
.arg( mGeometryColumn )
.arg( mSql );
@@ -408,10 +423,12 @@
void QgsDataSourceURI::setDataSource( const QString &schema,
const QString &table,
const QString &geometryColumn,
+ const QString &keyColumn,
const QString &sql )
mSchema = schema;
mTable = table;
mGeometryColumn = geometryColumn;
+ mKeyColumn = keyColumn;
mSql = sql;
Modified: trunk/qgis/src/core/qgsdatasourceuri.h
--- trunk/qgis/src/core/qgsdatasourceuri.h 2009-04-26 22:40:49 UTC (rev 10656)
+++ trunk/qgis/src/core/qgsdatasourceuri.h 2009-04-26 22:49:37 UTC (rev 10657)
@@ -61,7 +61,8 @@
void setDataSource( const QString& aSchema,
- const QString& aSql = QString() );
+ const QString& aKeyColumn = QString() );
//! Removes password element from uris
static QString removePassword( const QString& aUri );
@@ -82,6 +83,10 @@
QString password() const;
enum SSLmode sslMode() const;
+ // added in version 1.2
+ void setKeyColumn( QString column );
private:
void skipBlanks( const QString &uri, int &i );
QString getValue( const QString &uri, int &i );
@@ -108,6 +113,8 @@
QString mPassword;
//! ssl mode
enum SSLmode mSSLmode;
+ //! key column
+ QString mKeyColumn;
#endif //QGSDATASOURCEURI_H
Modified: trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp
--- trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp 2009-04-26 22:40:49 UTC (rev 10656)
+++ trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp 2009-04-26 22:49:37 UTC (rev 10657)
@@ -74,6 +74,7 @@
mTableName = mUri.table();
geometryColumn = mUri.geometryColumn();
sqlWhereClause = mUri.sql();
+ primaryKey = mUri.keyColumn();
// Keep a schema qualified table name for convenience later on.
mSchemaTableName = mUri.quotedTablename();
@@ -483,7 +484,7 @@
if ( block > 0xffff )
- qWarning( "block number %x exceed 16 bit", block );
+ QgsDebugMsg( QString( "block number %1 exceeds 16 bit" ).arg( block ) );
return false;
@@ -491,7 +492,7 @@
else
- qWarning( "expecting 6 bytes for tid (found %d bytes)", PQgetlength( queryResult, row, 0 ) );
+ QgsDebugMsg( QString( "expecting 6 bytes for tid (found %1 bytes)" ).arg( PQgetlength( queryResult, row, 0 ) ) );
return false;
@@ -623,7 +624,7 @@
QString fetch = QString( "fetch forward %1 from %2" ).arg( mFeatureQueueSize ).arg( cursorName );
if ( connectionRO->PQsendQuery( fetch ) == 0 ) // fetch features asynchronously
- qWarning( "PQsendQuery failed (1)" );
+ QgsDebugMsg( "PQsendQuery failed (1)" );
Result queryResult;
@@ -948,12 +949,12 @@
Result tableType = connectionRO->PQexec( sql );
QString type = QString::fromUtf8( PQgetvalue( tableType, 0, 0 ) );
- primaryKey = "";
if ( type == "r" ) // the relation is a table
QgsDebugMsg( "Relation is a table. Checking to see if it has an oid column." );
+ primaryKey = "";
// If there is an oid on the table, use that instead,
// otherwise give up
sql = QString( "SELECT attname FROM pg_attribute WHERE attname='oid' AND attrelid=regclass(%1)" )
@@ -1008,15 +1009,40 @@
else if ( type == "v" ) // the relation is a view
- // Have a poke around the view to see if any of the columns
- // could be used as the primary key.
- tableCols cols;
- // Given a schema.view, populate the cols variable with the
- // schema.table.column's that underly the view columns.
- findColumns( cols );
- // From the view columns, choose one for which the underlying
- // column is suitable for use as a key into the view.
- primaryKey = chooseViewColumn( cols );
+ if ( !primaryKey.isEmpty() )
+ // check last used candidate
+ sql = QString( "select pg_type.typname from pg_attribute,pg_type where atttypid=pg_type.oid and attname=%1 and attrelid=regclass(%2)" )
+ .arg( quotedValue( primaryKey ) ).arg( quotedValue( mSchemaTableName ) );
+ QgsDebugMsg( "checking candidate: " + sql );
+ Result result = connectionRO->PQexec( sql );
+ if ( PQresultStatus( result ) != PGRES_TUPLES_OK ||
+ PQntuples( result ) != 1 ||
+ QString( PQgetvalue( result, 0, 0 ) ) != "int4" ||
+ !uniqueData( mSchemaName, mTableName, primaryKey ) )
+ primaryKey = "";
+ if ( primaryKey.isEmpty() )
+ // Have a poke around the view to see if any of the columns
+ // could be used as the primary key.
+ tableCols cols;
+ // Given a schema.view, populate the cols variable with the
+ // schema.table.column's that underly the view columns.
+ findColumns( cols );
+ // From the view columns, choose one for which the underlying
+ // column is suitable for use as a key into the view.
+ primaryKey = chooseViewColumn( cols );
+ mUri.setKeyColumn( primaryKey );
+ setDataSourceUri( mUri.uri() );
else
QgsDebugMsg( "Unexpected relation type of '" + type + "'." );
