[QGIS Commit] r10673 - in trunk/qgis/src: app core
svn_qgis at osgeo.org
Tue Apr 28 17:32:20 EDT 2009
Author: jef
Date: 2009-04-28 17:32:19 -0400 (Tue, 28 Apr 2009)
New Revision: 10673
trunk/qgis/src/app/qgisapp.cpp
trunk/qgis/src/core/qgsproject.cpp
trunk/qgis/src/core/qgsproject.h
add progress indication when layers are loaded from projects
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp 2009-04-28 20:21:06 UTC (rev 10672)
+++ trunk/qgis/src/app/qgisapp.cpp 2009-04-28 21:32:19 UTC (rev 10673)
@@ -1555,6 +1555,8 @@
connect( QgsProject::instance(), SIGNAL( oldProjectVersionWarning( QString ) ),
this, SLOT( oldProjectVersionWarning( QString ) ) );
+ connect( QgsProject::instance(), SIGNAL( layerLoaded( int, int ) ), this, SLOT( showProgress( int, int ) ) );
void QgisApp::createCanvas()
@@ -3182,7 +3184,6 @@
} // QgisApp::fileOpen
adds a saved project to qgis, usually called on startup by specifying a
project file on the command line
@@ -3191,6 +3192,8 @@
mMapCanvas->freeze( true );
+ QApplication::setOverrideCursor( Qt::WaitCursor );
// clear the map canvas
removeAllLayers();
@@ -3254,6 +3257,8 @@
return false;
+ QApplication::restoreOverrideCursor();
mMapCanvas->freeze( false );
mMapCanvas->refresh();
return true;
Modified: trunk/qgis/src/core/qgsproject.cpp
--- trunk/qgis/src/core/qgsproject.cpp 2009-04-28 20:21:06 UTC (rev 10672)
+++ trunk/qgis/src/core/qgsproject.cpp 2009-04-28 21:32:19 UTC (rev 10673)
@@ -642,7 +642,7 @@
</maplayer>
-static std::pair< bool, std::list<QDomNode> > _getMapLayers( QDomDocument const &doc )
+std::pair< bool, std::list<QDomNode> > QgsProject::_getMapLayers( QDomDocument const &doc )
// Layer order is implicit in the order they are stored in the project file
@@ -671,6 +671,8 @@
bool returnStatus = true;
+ emit layerLoaded( 0, nl.count() );
for ( int i = 0; i < nl.count(); i++ )
QDomNode node = nl.item( i );
@@ -715,6 +717,8 @@
brokenNodes.push_back( node );
+ emit layerLoaded( i + 1, nl.count() );
return make_pair( returnStatus, brokenNodes );
Modified: trunk/qgis/src/core/qgsproject.h
--- trunk/qgis/src/core/qgsproject.h 2009-04-28 20:21:06 UTC (rev 10672)
+++ trunk/qgis/src/core/qgsproject.h 2009-04-28 21:32:19 UTC (rev 10673)
@@ -266,6 +266,11 @@
//! emitted when an old project file is read.
void oldProjectVersionWarning( QString );
+ //! emitted when a layer from a projects was read
+ // @param i current layer
+ // @param n number of layers
+ void layerLoaded( int i, int n );
private:
QgsProject(); // private 'cause it's a singleton
@@ -279,6 +284,8 @@
static QgsProject * theProject_;
+ std::pair< bool, std::list<QDomNode> > _getMapLayers( QDomDocument const &doc );
}; // QgsProject
#endif
