[QGIS Commit] r10680 - in docs/trunk/english_us/user_guide: .
plugins_oracle_raster
svn_qgis at osgeo.org
Tue Apr 28 20:33:49 EDT 2009
Author: cfarmer
Date: 2009-04-28 20:33:49 -0400 (Tue, 28 Apr 2009)
New Revision: 10680
Added:
docs/trunk/english_us/user_guide/plugins_oracle_raster/
docs/trunk/english_us/user_guide/plugins_oracle_raster/Makefile
docs/trunk/english_us/user_guide/plugins_oracle_raster/oracle_raster.eps
docs/trunk/english_us/user_guide/plugins_oracle_raster/oracle_raster.png
add oracle spatial georaster folder and icon
Added: docs/trunk/english_us/user_guide/plugins_oracle_raster/Makefile
--- docs/trunk/english_us/user_guide/plugins_oracle_raster/Makefile (rev 0)
+++ docs/trunk/english_us/user_guide/plugins_oracle_raster/Makefile 2009-04-29 00:33:49 UTC (rev 10680)
@@ -0,0 +1,40 @@
+# makefile to convert figures into eps format for the book
+# Comments from Michel Wurtz:
+# You will notice that the list given is the list of targets. "all" just
+# refer to this list. The most important rule is the next rule, that give
+# the generic rule for transforming a .fig into a .eps file. Note the use
+# of % (define the couple target:source) and the use of
+# $< (source postfix, here .fig) and $@ (target postfix, here .eps)
+# with .eps extension:
+# JPG=qgis_icon_new_verylarge.eps\
+# nextfile.eps
+PNG=oracle_raster.eps\
+##### TARGETS #####
+all: $(PNG) $(JPG)
+ if [ ! -d ../finalpix/ ]; then mkdir ../finalpix; fi
+ #do not use move (mv):
+ cp *.eps ../finalpix/
+#$(EPS): %.eps: %.fig
+# fig2dev -L eps $< > $@
+#$(FIGPNG): %.png: %.fig
+# fig2dev -L png -m 2 $< > $@
+$(PNG): %.eps: %.png
+ # Workaround for PDF
+ #convert -geometry 300x -depth 1 $< $@
+ convert $< $@
+$(JPG): %.eps: %.jpg
+ convert $< $@
+clean:
+ rm -f *.bak *~ *.pdf $(PNG) $(JPG)
Added: docs/trunk/english_us/user_guide/plugins_oracle_raster/oracle_raster.eps
--- docs/trunk/english_us/user_guide/plugins_oracle_raster/oracle_raster.eps (rev 0)
+++ docs/trunk/english_us/user_guide/plugins_oracle_raster/oracle_raster.eps 2009-04-29 00:33:49 UTC (rev 10680)
@@ -0,0 +1,319 @@
+%!PS-Adobe-3.0 EPSF-3.0
+%%Creator: (ImageMagick)
+%%Title: (oracle_raster.eps)
+%%CreationDate: (Tue Apr 28 23:50:03 2009)
+%%BoundingBox: 0 0 22 22
+%%HiResBoundingBox: 0 0 21.9973 22
+%%DocumentData: Clean7Bit
+%%LanguageLevel: 1
+%%Pages: 1
+%%EndComments
+%%BeginDefaults
+%%EndDefaults
+%%BeginProlog
+% Display a color image. The image is displayed in color on
+% Postscript viewers or printers that support color, otherwise
+% it is displayed as grayscale.
+/DirectClassPacket
+ % Get a DirectClass packet.
+ % Parameters:
+ % red.
+ % green.
+ % blue.
+ % length: number of pixels minus one of this color (optional).
+ currentfile color_packet readhexstring pop pop
+ compression 0 eq
+ /number_pixels 3 def
+ currentfile byte readhexstring pop 0 get
+ /number_pixels exch 1 add 3 mul def
+ } ifelse
+ 0 3 number_pixels 1 sub
+ pixels exch color_packet putinterval
+ } for
+ pixels 0 number_pixels getinterval
+} bind def
+/DirectClassImage
+ % Display a DirectClass image.
+ systemdict /colorimage known
+ columns rows 8
+ columns 0 0
+ rows neg 0 rows
+ { DirectClassPacket } false 3 colorimage
+ % No colorimage operator; convert to grayscale.
+ columns rows 8
+ columns 0 0
+ rows neg 0 rows
+ { GrayDirectClassPacket } image
+ } ifelse
+} bind def
+/GrayDirectClassPacket
+ % Get a DirectClass packet; convert to grayscale.
+ % Parameters:
+ % red
+ % green
+ % blue
+ color_packet 0 get 0.299 mul
+ color_packet 1 get 0.587 mul add
+ color_packet 2 get 0.114 mul add
+ cvi
+ /gray_packet exch def
+ compression 0 eq
+ /number_pixels 1 def
+ /number_pixels exch 1 add def
+ } ifelse
+ 0 1 number_pixels 1 sub
+ pixels exch gray_packet put
+ } for
+} bind def
+/GrayPseudoClassPacket
+ % Get a PseudoClass packet; convert to grayscale.
+ % Parameters:
+ % index: index into the colormap.
+ /offset exch 3 mul def
+ /color_packet colormap offset 3 getinterval def
+ cvi
+ compression 0 eq
+ } ifelse
+ } for
+} bind def
+/PseudoClassPacket
+ % Get a PseudoClass packet.
+ % Parameters:
+ compression 0 eq
+ } ifelse
+ } for
+} bind def
+/PseudoClassImage
+ % Display a PseudoClass image.
+ % Parameters:
+ % class: 0-PseudoClass or 1-Grayscale.
+ currentfile buffer readline pop
+ token pop /class exch def pop
+ class 0 gt
+ token pop /depth exch def pop
+ /grays columns 8 add depth sub depth mul 8 idiv string def
+ columns rows depth
+ columns 0 0
+ rows neg 0 rows
+ { currentfile grays readhexstring pop } image
+ % Parameters:
+ % colors: number of colors in the colormap.
+ % colormap: red, green, blue color packets.
+ token pop /colors exch def pop
+ /colors colors 3 mul def
+ /colormap colors string def
+ currentfile colormap readhexstring pop pop
+ columns rows 8
+ columns 0 0
+ rows neg 0 rows
+ { PseudoClassPacket } false 3 colorimage
+ columns rows 8
+ columns 0 0
+ rows neg 0 rows
+ { GrayPseudoClassPacket } image
+ } ifelse
+ } ifelse
+} bind def
+/DisplayImage
+ % Display a DirectClass or PseudoClass image.
+ % Parameters:
+ % x & y translation.
+ % x & y scale.
+ % label pointsize.
+ % image label.
+ % image columns & rows.
+ % class: 0-DirectClass or 1-PseudoClass.
+ % compression: 0-none or 1-RunlengthEncoded.
+ % hex color packets.
+ gsave
+ /buffer 512 string def
+ /byte 1 string def
+ /color_packet 3 string def
+ /pixels 768 string def
+ token pop /x exch def
+ token pop /y exch def pop
+ x y translate
+ token pop /pointsize exch def pop
+ /Times-Roman findfont pointsize scalefont setfont
+ x y scale
+ token pop /columns exch def
+ token pop /rows exch def pop
+ token pop /compression exch def pop
+ class 0 gt { PseudoClassImage } { DirectClassImage } ifelse
+ grestore
+} bind def
+%%EndProlog
+%%Page: 1 1
+%%PageBoundingBox: 0 0 22 22
+userdict begin
+DisplayImage
+0 0
+21.9973 21.9973
+12.000000
+22 22
+0
+0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+%%PageTrailer
+%%Trailer
+%%EOF
Added: docs/trunk/english_us/user_guide/plugins_oracle_raster/oracle_raster.png
(Binary files differ)
Property changes on: docs/trunk/english_us/user_guide/plugins_oracle_raster/oracle_raster.png
___________________________________________________________________
+ application/octet-stream
