[QGIS Commit] r11270 - trunk/qgis/python/plugins/plugin_installer
svn_qgis at osgeo.org
Tue Aug 4 16:22:26 EDT 2009
Author: borysiasty
Date: 2009-08-04 16:22:25 -0400 (Tue, 04 Aug 2009)
New Revision: 11270
trunk/qgis/python/plugins/plugin_installer/__init__.py
trunk/qgis/python/plugins/plugin_installer/installer_data.py
trunk/qgis/python/plugins/plugin_installer/installer_plugin.py
Plugin Installer small fixes
Modified: trunk/qgis/python/plugins/plugin_installer/__init__.py
--- trunk/qgis/python/plugins/plugin_installer/__init__.py 2009-08-04 17:59:34 UTC (rev 11269)
+++ trunk/qgis/python/plugins/plugin_installer/__init__.py 2009-08-04 20:22:25 UTC (rev 11270)
@@ -14,7 +14,7 @@
return "Plugin Installer"
def version():
- return "Version 1.0.1"
+ return "Version 1.0.2"
def description():
return "Downloads and installs QGIS python plugins"
Modified: trunk/qgis/python/plugins/plugin_installer/installer_data.py
--- trunk/qgis/python/plugins/plugin_installer/installer_data.py 2009-08-04 17:59:34 UTC (rev 11269)
+++ trunk/qgis/python/plugins/plugin_installer/installer_data.py 2009-08-04 20:22:25 UTC (rev 11270)
@@ -84,6 +84,7 @@
("Martin Dobias' Sandbox", "http://mapserver.sk/~wonder/qgis/plugins-sandbox.xml", ""),
("Aaron Racicot's Repository", "http://qgisplugins.z-pulley.com", ""),
("Barry Rowlingson's Repository", "http://www.maths.lancs.ac.uk/~rowlings/Qgis/Plugins/plugins.xml", ""),
+ ("Volkan Kepoglu's Repository","http://ggit.metu.edu.tr/~volkan/plugins.xml", ""),
("GIS-Lab Repository", "http://gis-lab.info/programs/qgis/qgis-repo.xml", "")]
@@ -414,9 +415,11 @@
pluginNodes = reposXML.elementsByTagName("pyqgis_plugin")
if pluginNodes.size():
for i in range(pluginNodes.size()):
- fileName = QFileInfo(pluginNodes.item(i).firstChildElement("download_url").text().trimmed()).fileName()
+ fileName = pluginNodes.item(i).firstChildElement("file_name").text().simplified()
+ if not fileName:
+ fileName = QFileInfo(pluginNodes.item(i).firstChildElement("download_url").text().trimmed().split("?")[0]).fileName()
name = fileName.section(".", 0, 0)
- name = str(name)
+ name = unicode(name)
experimental = False
if pluginNodes.item(i).firstChildElement("experimental").text().simplified().toUpper() in ["TRUE","YES"]:
experimental = True
Modified: trunk/qgis/python/plugins/plugin_installer/installer_plugin.py
--- trunk/qgis/python/plugins/plugin_installer/installer_plugin.py 2009-08-04 17:59:34 UTC (rev 11269)
+++ trunk/qgis/python/plugins/plugin_installer/installer_plugin.py 2009-08-04 20:22:25 UTC (rev 11270)
@@ -159,7 +159,7 @@
# display an error message for every unavailable reposioty, except the case if all repositories are unavailable!
if repositories.allUnavailable() and repositories.allUnavailable() != repositories.allEnabled():
for key in repositories.allUnavailable():
- QMessageBox.warning(parent, QCoreApplication.translate("QgsPluginInstaller","QGIS Python Plugin Installer"), QCoreApplication.translate("QgsPluginInstaller","Error reading repository:") + u' %s\n%s' % (key,repositories.all()[key]["error"]))
+ QMessageBox.warning(parent, QCoreApplication.translate("QgsPluginInstaller","QGIS Python Plugin Installer"), QCoreApplication.translate("QgsPluginInstaller","Error reading repository:") + QString(' %s\n%s' % (key,repositories.all()[key]["error"])))
flags = Qt.WindowTitleHint | Qt.WindowSystemMenuHint | Qt.WindowMaximizeButtonHint
self.guiDlg = QgsPluginInstallerDialog(parent,flags)
