[QGIS Commit] r11277 - trunk/qgis/python/core
svn_qgis at osgeo.org
Wed Aug 5 12:43:34 EDT 2009
Author: homann
Date: 2009-08-05 12:43:33 -0400 (Wed, 05 Aug 2009)
New Revision: 11277
trunk/qgis/python/core/qgscontinuouscolorrenderer.sip
trunk/qgis/python/core/qgsgraduatedsymbolrenderer.sip
trunk/qgis/python/core/qgsmarkercatalogue.sip
trunk/qgis/python/core/qgsrenderer.sip
trunk/qgis/python/core/qgssinglesymbolrenderer.sip
trunk/qgis/python/core/qgssymbol.sip
trunk/qgis/python/core/qgsuniquevaluerenderer.sip
Updated SIP-files after r11275 and r11276. Fix for #1220.
Modified: trunk/qgis/python/core/qgscontinuouscolorrenderer.sip
--- trunk/qgis/python/core/qgscontinuouscolorrenderer.sip 2009-08-05 16:12:24 UTC (rev 11276)
+++ trunk/qgis/python/core/qgscontinuouscolorrenderer.sip 2009-08-05 16:43:33 UTC (rev 11277)
@@ -12,7 +12,7 @@
virtual ~QgsContinuousColorRenderer();
/**Renders the feature using the minimum and maximum value of the classification field
* added in 1.2 */
- void renderFeature(QgsRenderContext &renderContext, QgsFeature& f, QImage* img, bool selected);
+ void renderFeature(QgsRenderContext &renderContext, QgsFeature& f, QImage* img, bool selected, double opacity = 1.0 );
/**Returns the number of the classification field*/
int classificationField() const;
/**Sets the id of the classification field*/
Modified: trunk/qgis/python/core/qgsgraduatedsymbolrenderer.sip
--- trunk/qgis/python/core/qgsgraduatedsymbolrenderer.sip 2009-08-05 16:12:24 UTC (rev 11276)
+++ trunk/qgis/python/core/qgsgraduatedsymbolrenderer.sip 2009-08-05 16:43:33 UTC (rev 11277)
@@ -52,7 +52,7 @@
\param p a painter (usually the one from the current map canvas)
\param f a pointer to a feature to render
\param t the transform object containing the information how to transform the map coordinates to screen coordinates*/
/**Sets the number of the classicifation field
\param field the number of the field to classify*/
Modified: trunk/qgis/python/core/qgsmarkercatalogue.sip
--- trunk/qgis/python/core/qgsmarkercatalogue.sip 2009-08-05 16:12:24 UTC (rev 11276)
+++ trunk/qgis/python/core/qgsmarkercatalogue.sip 2009-08-05 16:43:33 UTC (rev 11277)
@@ -19,12 +19,12 @@
/** Returns pixmap of the marker
* \param fullName full name, e.g. hard:circle, svg:/home/usr1/marker1.svg
- QImage imageMarker (QString fullName, int size, QPen pen, QBrush brush, bool qtBug = true );
+ QImage imageMarker (QString fullName, int size, QPen pen, QBrush brush, double opacity );
/** Returns qpicture of the marker
- QPicture pictureMarker (QString fullName, int size, QPen pen, QBrush brush, bool qtBug = true );
+ QPicture pictureMarker (QString fullName, int size, QPen pen, QBrush brush, double opacity );
/** Returns a pixmap given a file name of a svg marker
* NOTE: this method needs to be public static for QgsMarkerDialog::visualizeMarkers */
Modified: trunk/qgis/python/core/qgsrenderer.sip
--- trunk/qgis/python/core/qgsrenderer.sip 2009-08-05 16:12:24 UTC (rev 11276)
+++ trunk/qgis/python/core/qgsrenderer.sip 2009-08-05 16:43:33 UTC (rev 11277)
@@ -29,8 +29,10 @@
@param selected the feature is to be shown selected
added in 1.2 */
- virtual void renderFeature(QgsRenderContext &renderContext, QgsFeature& f,QImage* pic, bool selected)=0;
+ void renderFeature( QgsRenderContext &renderContext, QgsFeature& f, QImage* pic, bool selected );
+ virtual void renderFeature( QgsRenderContext &renderContext, QgsFeature& f, QImage* pic, bool selected, double opacity ) = 0;
/**Reads the renderer configuration from an XML file
@param rnode the Dom node to read
@param vl the vector layer which will be associated with the renderer*/
Modified: trunk/qgis/python/core/qgssinglesymbolrenderer.sip
--- trunk/qgis/python/core/qgssinglesymbolrenderer.sip 2009-08-05 16:12:24 UTC (rev 11276)
+++ trunk/qgis/python/core/qgssinglesymbolrenderer.sip 2009-08-05 16:43:33 UTC (rev 11277)
@@ -16,7 +16,7 @@
const QgsSymbol* symbol() const;
/**Renders a feature added in 1.2 */
Modified: trunk/qgis/python/core/qgssymbol.sip
--- trunk/qgis/python/core/qgssymbol.sip 2009-08-05 16:12:24 UTC (rev 11276)
+++ trunk/qgis/python/core/qgssymbol.sip 2009-08-05 16:43:33 UTC (rev 11277)
@@ -77,7 +77,8 @@
QColor selectionColor = Qt::yellow,
double scale = 1.0,
double rotation = 0.0,
- double rasterScaleFactor = 1.0 );
+ double rasterScaleFactor = 1.0
+ double opacity = 1.0 );
/**Writes the contents of the symbol to a configuration file
@ return true in case of success*/
Modified: trunk/qgis/python/core/qgsuniquevaluerenderer.sip
--- trunk/qgis/python/core/qgsuniquevaluerenderer.sip 2009-08-05 16:12:24 UTC (rev 11276)
+++ trunk/qgis/python/core/qgsuniquevaluerenderer.sip 2009-08-05 16:43:33 UTC (rev 11277)
@@ -14,7 +14,7 @@
/* render feature
* added in 1.2 */
+ void renderFeature(QgsRenderContext &renderContext, QgsFeature& f, QImage* img, bool selected, double opacity = 1.0);
