[QGIS Commit] r11282 - trunk/qgis/src/app
svn_qgis at osgeo.org
Thu Aug 6 06:43:29 EDT 2009
Author: wonder
Date: 2009-08-06 06:43:28 -0400 (Thu, 06 Aug 2009)
New Revision: 11282
trunk/qgis/src/app/qgsmaptoolnodetool.cpp
Fixed #1737. Contributed by Richard Kostecky.
Modified: trunk/qgis/src/app/qgsmaptoolnodetool.cpp
--- trunk/qgis/src/app/qgsmaptoolnodetool.cpp 2009-08-06 02:34:14 UTC (rev 11281)
+++ trunk/qgis/src/app/qgsmaptoolnodetool.cpp 2009-08-06 10:43:28 UTC (rev 11282)
@@ -783,6 +783,8 @@
QgsMapLayer* currentLayer = mCanvas->currentLayer();
QgsVectorLayer* vlayer = 0;
+ int topologicalEditing = QgsProject::instance()->readNumEntry( "Digitizing", "/TopologicalEditing", 0 );
+ QMultiMap<double, QgsSnappingResult> currentResultList;
if ( currentLayer )
vlayer = dynamic_cast<QgsVectorLayer*>( currentLayer );
@@ -805,11 +807,31 @@
QgsPoint coords = snapResults.first().snappedVertex;
QgsPoint layerCoords = toLayerCoordinates( vlayer, coords );
- //QgsPoint coords = mCanvas->getCoordinateTransform()->toMapPoint( e->pos().x(), e->pos().y() );
- //add vertex
+ if ( topologicalEditing )
+ //snapp from adding position to this vertex when topological editing is enabled
+ currentResultList.clear();
+ vlayer->snapWithContext( layerCoords, ZERO_TOLERANCE, currentResultList, QgsSnapper::SnapToSegment );
vlayer->beginEditCommand( tr( "Inserted vertex" ) );
mChangingGeometry = true;
+ //add vertex
vlayer->insertVertex( layerCoords.x(), layerCoords.y(), mSelectionFeature->featureId(), snapResults.first().afterVertexNr );
+ QMultiMap<double, QgsSnappingResult>::iterator resultIt = currentResultList.begin();
+ for ( ; resultIt != currentResultList.end(); ++resultIt )
+ //create vertexes on same position when topological editing is enabled
+ if ( mSelectionFeature->featureId() != resultIt.value().snappedAtGeometry )
+ vlayer->insertVertex( layerCoords.x(), layerCoords.y(), resultIt.value().snappedAtGeometry, resultIt.value().afterVertexNr );
vlayer->endEditCommand();
mSelectionFeature->updateFromFeature();
