[QGIS Commit] r11284 - in trunk/qgis: python/plugins/osm
src/providers/osm
svn_qgis at osgeo.org
Thu Aug 6 10:12:49 EDT 2009
Author: wonder
Date: 2009-08-06 10:12:49 -0400 (Thu, 06 Aug 2009)
New Revision: 11284
trunk/qgis/python/plugins/osm/DlgLoadOSM.py
trunk/qgis/src/providers/osm/osmprovider.cpp
trunk/qgis/src/providers/osm/osmprovider.h
Update to OSM provider+plugin from Lukas Berka:
-osm provider code documentation; refactoring
Modified: trunk/qgis/python/plugins/osm/DlgLoadOSM.py
--- trunk/qgis/python/plugins/osm/DlgLoadOSM.py 2009-08-06 14:09:40 UTC (rev 11283)
+++ trunk/qgis/python/plugins/osm/DlgLoadOSM.py 2009-08-06 14:12:49 UTC (rev 11284)
@@ -135,8 +135,6 @@
# remove layers of current data first
QgsMapLayerRegistry.instance().removeMapLayer(self.canvas.currentLayer().getLayerID(),True)
- tags = "&tags=yes"
if self.chkCustomRenderer.isChecked():
styleFile=self.styleFiles[self.styleCombo.currentIndex()]
style="&style="+styleFile
@@ -160,7 +158,7 @@
self.setProperty("osm_stop_parsing",QVariant(0))
# add polygon layer
- polygonLayer = QgsVectorLayer(self.fname+"?type=polygon"+observer + tags + tag + style, basename+" polygons", "osm")
+ polygonLayer = QgsVectorLayer(self.fname+"?type=polygon"+observer + tag + style, basename+" polygons", "osm")
if self.loadingCanceled:
polygonLayer=None
@@ -174,7 +172,7 @@
QgsMapLayerRegistry.instance().addMapLayer(polygonLayer)
# add line layer
- lineLayer = QgsVectorLayer(self.fname+"?type=line"+observer + tags + tag + style, basename+" lines", "osm")
+ lineLayer = QgsVectorLayer(self.fname+"?type=line"+observer + tag + style, basename+" lines", "osm")
lineLayer=None
@@ -188,7 +186,7 @@
QgsMapLayerRegistry.instance().addMapLayer(lineLayer)
# add point layer
- pointLayer = QgsVectorLayer(self.fname+"?type=point"+observer + tags + tag + style, basename+" points", "osm")
+ pointLayer = QgsVectorLayer(self.fname+"?type=point"+observer + tag + style, basename+" points", "osm")
pointLayer=None
Modified: trunk/qgis/src/providers/osm/osmprovider.cpp
--- trunk/qgis/src/providers/osm/osmprovider.cpp 2009-08-06 14:09:40 UTC (rev 11283)
+++ trunk/qgis/src/providers/osm/osmprovider.cpp 2009-08-06 14:12:49 UTC (rev 11284)
@@ -56,7 +56,7 @@
mDatabase = NULL;
mInitObserver = NULL;
mFeatureType = PointType; // default
- mTagsRetrieval = false;
// set default boundaries
xMin = -DEFAULT_EXTENT;
xMax = DEFAULT_EXTENT;
@@ -102,10 +102,6 @@
mInitObserver = ( QObject* ) observerAddr;
mInitObserver->setProperty( "osm_state", QVariant( 1 ) );
- if ( propName == "tags" )
- mTagsRetrieval = ( propValue == "yes" );
if ( propName == "tag" )
mCustomTagsList = propValue.split( "+" );
@@ -265,7 +261,7 @@
QFile osmFile( mFileName );
QFileInfo osmFileInfo( osmFile );
- mOsmFileLastModif = osmFileInfo.lastModified();
+ QDateTime mOsmFileLastModif = osmFileInfo.lastModified();
QString cmd = QString( "SELECT val FROM meta WHERE key='osm-file-last-modified';" );
QByteArray cmd_bytes = cmd.toAscii();
@@ -522,7 +518,7 @@
geo[geo[0] == QgsApplication::NDR ? 1 : 4] = QGis::WKBPoint;
std::memcpy( geo + 5, &selLon, sizeof( double ) );
std::memcpy( geo + 13, &selLat, sizeof( double ) );
- feature.setGeometryAndOwnership(( unsigned char * )geo, sizeof( wkbPoint ) );
+ feature.setGeometryAndOwnership(( unsigned char * )geo, 24 ); // 24 is size of wkb point structure!
// fetch attributes
@@ -536,10 +532,7 @@
case UserAttr:
feature.addAttribute( UserAttr, QString::fromUtf8( selUser ) ); break;
case TagAttr:
- if ( mTagsRetrieval )
- feature.addAttribute( TagAttr, tagsForObject( "node", selId ) );
- else
- feature.addAttribute( TagAttr, QString() );
+ feature.addAttribute(TagAttr, tagsForObject("node",selId));
break;
default: // suppose it's a custom tag
@@ -652,10 +645,7 @@
break;
case TagAttr:
- feature.addAttribute( TagAttr, tagsForObject( "way", selId ) );
- else
+ feature.addAttribute(TagAttr, tagsForObject("way",selId));
break;
if ( *iter >= CustomTagAttr && *iter < CustomTagAttr + mCustomTagsList.count() )
@@ -670,33 +660,7 @@
-int QgsOSMDataProvider::relationMemberCount( int relId )
- const char *zSql = "select count(*) from relation_member rm, way_member wm, node n where rm.relation_id=? and rm.member_type='way' and rm.member_id=wm.way_id and wm.node_id=n.id and wm.u=1 and n.u=1 and rm.u=1;";
- sqlite3_stmt *pStmt;
- int rc = sqlite3_prepare_v2( mDatabase, zSql, -1, &pStmt, 0 );
- if ( rc != SQLITE_OK )
- QgsDebugMsg( QString( "Failed (1)." ) );
- return 0;
- sqlite3_bind_int( pStmt, 1, relId );
- rc = sqlite3_step( pStmt );
- if ( rc != SQLITE_ROW )
- QgsDebugMsg( QString( "Failed (2)." ) );
- return 0;
- int memberCnt = sqlite3_column_int( pStmt, 0 );
- sqlite3_finalize( pStmt );
- return memberCnt;
QString QgsOSMDataProvider::tagForObject( const char* type, int id, QString tagKey )
sqlite3_bind_int( mCustomTagsStmt, 1, id );
@@ -945,54 +909,6 @@
-bool QgsOSMDataProvider::changeGeometryValue( const int & featid, QgsGeometry & geom )
- if ( mFeatureType == PointType )
- QgsDebugMsg( QString( "Changing geometry of point with id=%1." ).arg( featid ) );
- QgsPoint point = geom.asPoint();
- const char *zSql = "UPDATE node SET lat=?, lon=?, status='U' WHERE id=? AND u=1";
- int rc;
- rc = sqlite3_prepare_v2( mDatabase, zSql, -1, &pStmt, 0 );
- return rc;
- sqlite3_bind_double( pStmt, 1, point.y() );
- sqlite3_bind_double( pStmt, 2, point.x() );
- sqlite3_bind_int( pStmt, 3, featid );
- rc = sqlite3_finalize( pStmt );
- else if ( mFeatureType == LineType )
- QgsDebugMsg( QString( "Changing geometry of way with id=%1." ).arg( featid ) );
- QgsPolyline way = geom.asPolyline();
- unsigned char *wkb = geom.asWkb();
- const char *zSql = "UPDATE way SET wkb=?, membercnt=?, status='U' WHERE id=? AND u=1";
- int rc;
- return rc;
- sqlite3_bind_blob( pStmt, 1, wkb, 9 + 16 * way.size(), SQLITE_STATIC );
- sqlite3_bind_int( pStmt, 2, way.size() );
- return true;
int QgsOSMDataProvider::capabilities() const
return QgsVectorDataProvider::SelectAtId | QgsVectorDataProvider::SelectGeometryAtId;
Modified: trunk/qgis/src/providers/osm/osmprovider.h
--- trunk/qgis/src/providers/osm/osmprovider.h 2009-08-06 14:09:40 UTC (rev 11283)
+++ trunk/qgis/src/providers/osm/osmprovider.h 2009-08-06 14:12:49 UTC (rev 11284)
@@ -16,24 +16,97 @@
#include <sqlite3.h>
#include <QFile>
-#include <QDateTime>
+class QgsOSMDataProvider: public QgsVectorDataProvider
-typedef QMap<int, QgsFeature> QgsFeatureMap;
+ private:
+ //! provider can manage features with one of three geometry types; variable determines feature type of this provider
+ enum { PointType, LineType, PolygonType } mFeatureType;
+ //! supported feature attributes
+ enum Attribute { TimestampAttr=0, UserAttr=1, TagAttr, CustomTagAttr };
-class QgsOSMDataProvider: public QgsVectorDataProvider
- Q_OBJECT
+ static const char* attr[];
+ //! constant that helps to set default map extent
+ const static int DEFAULT_EXTENT=100;
+ //! absolute name of input OSM file
+ QString mFileName;
+ //! determines if this provider is in valid state (initialized correctly, etc.)
+ bool mValid;
+ //! holds information on error that occured in provider execution
+ char *mError;
+ //! object that receives notifications from init
+ QObject* mInitObserver;
+ //! boundary of all OSM data that provider manages
+ double xMin, xMax, yMin, yMax;
+ //! list of feature tags for which feature attributes are created
+ QStringList mCustomTagsList;
+ //! name of file with renderer style information
+ QString mStyleFileName;
+ //! determines style for rendering: one of "medium", "big", "small"
+ QString mStyle;
+ // sqlite3 database stuff:
+ //! absolute name of local database file with OSM data
+ QString mDatabaseFileName;
+ //! pointer to sqlite3 database that keeps OSM data
+ sqlite3 *mDatabase;
+ //! pointer to main sqlite3 database statement object; this statement serves to select OSM data
+ sqlite3_stmt *mDatabaseStmt;
+ //! sqlite3 database statement ready to select all feature tags
+ sqlite3_stmt *mTagsStmt;
+ //! sqlite3 database statement ready to select concrete feature tag
+ sqlite3_stmt *mCustomTagsStmt;
+ //! sqlite3 database statement for exact way selection
+ sqlite3_stmt *mWayStmt;
+ //! sqlite3 database statement for exact node selection
+ sqlite3_stmt *mNodeStmt;
+ // variables used to select OSM data; used mainly in select(), nextFeature() functions:
+ //! list of supported attribute fields
+ QgsFieldMap mAttributeFields;
+ //! which attributes should be fetched after calling of select() function
+ QgsAttributeList mAttributesToFetch;
+ //! features from which area should be fetched after calling of select() function?
+ QgsRectangle mSelectionRectangle;
+ //! geometry object of area from which features should be fetched after calling of select() function
+ QgsGeometry* mSelectionRectangleGeom;
+ //! determines if intersect should be used while selecting OSM data
+ bool mSelectUseIntersect;
public:
- * Constructor of the vector provider.
- * @param uri uniform resource locator (URI) for a dataset
+ * Constructor of vector provider.
+ * @param uri uniform resource locator (URI) for a dataset
QgsOSMDataProvider( QString uri );
@@ -43,7 +116,7 @@
virtual ~QgsOSMDataProvider();
- // Implementation of functions from QgsVectorDataProvider
+ // Implementation of QgsVectorDataProvider functions
* Returns the permanent storage type for this layer as a friendly name.
@@ -126,7 +199,7 @@
virtual int capabilities() const;
- // Implementation of functions from QgsDataProvider
+ // Implementation of QgsDataProvider functions
* Returns a provider name.
@@ -155,88 +228,56 @@
private:
- enum { PointType, LineType, PolygonType } mFeatureType;
- enum Attribute { TimestampAttr = 0, UserAttr = 1, TagAttr, CustomTagAttr };
- const static int DEFAULT_EXTENT = 100;
+ * Finds out if database (provider is connected to) belongs to (was created from) specified input file.
+ * @param mFileName name of input OSM file
+ * @return answer to that question
+ bool isDatabaseCompatibleWithInput(QString mFileName);
- static const char* attr[];
- QString mFileName;
- QString mDatabaseFileName;
- QDateTime mOsmFileLastModif;
- bool mValid;
- sqlite3 *mDatabase;
- sqlite3_stmt *mDatabaseStmt;
- char *mError;
- //! object that receives notifications from init
- QObject* mInitObserver;
- double xMin, xMax, yMin, yMax; // boundary
- // selection
- QgsAttributeList mAttributesToFetch;
- QgsFieldMap mAttributeFields;
- QgsRectangle mSelectionRectangle;
- QgsGeometry* mSelectionRectangleGeom;
- // flags
- bool mSelectUseIntersect;
- // private methods
- sqlite3_stmt *mTagsStmt;
- bool mTagsRetrieval;
- QString tagsForObject( const char* type, int id );
- sqlite3_stmt *mCustomTagsStmt;
- QStringList mCustomTagsList;
- QString tagForObject( const char* type, int id, QString tagKey );
- sqlite3_stmt *mWayStmt;
- sqlite3_stmt *mNodeStmt;
- QString mStyleFileName;
- QString mStyle;
- // manipulation with sqlite database
- bool isDatabaseCompatibleWithInput( QString mFileName );
+ * Finds out if database and provider versions are compatible.
bool isDatabaseCompatibleWithPlugin();
- * Create Open Street Map database schema, using c++ library for attempt to sqlite database.
+ * Creates Open Street Map database schema, using c++ library for attempt to sqlite database.
* @return true in case of success and false in case of failure
bool createDatabaseSchema();
- * Create indexes for OSM database schema, using c++ library for attempt to sqlite database.
+ * Creates indexes for OSM database schema, using c++ library for attempt to sqlite database.
bool createIndexes();
+ * Creates triggers for OSM database schema, using c++ library for attempt to sqlite database.
+ * @return true in case of success and false in case of failure
bool createTriggers();
- * Drop the whole OSM database schema, using c++ library for attempt to sqlite database.
+ * Drops the whole OSM database schema, using c++ library for attempt to sqlite database.
bool dropDatabaseSchema();
- * Open sqlite3 database.
+ * Opens sqlite3 database.
bool openDatabase();
- * Close opened sqlite3 database.
+ * Closes opened sqlite3 database.
bool closeDatabase();
- * Process Open Street Map file, parse it and store data in sqlite database.
+ * Processes Open Street Map file, parse it and store data in sqlite database.
* Function doesn't require much memory: uses simple SAX XML parser
* and stores data directly to database while processing OSM file.
* @param osm_filename name of file with OSM data to parse into sqlite3 database
@@ -244,8 +285,25 @@
bool loadOsmFile( QString osm_filename );
+ * Function computes WKB (well-known-binary) information on geometry of specified way
+ * and store it into database. Later this enables faster displaying of features.
+ * @param wayId way identifier
+ * @param isClosed is this way closed? closed=polygon X notClosed=line
+ * @param geo output; way geometry in wkb format
+ * @param geolen output; len of wkb geometry
bool updateWayWKB( int wayId, int isClosed, char **geo, int *geolen );
+ * Function performs all necessary postparsing manipulations with node records.
bool updateNodes();
+ * Function removes all ways that are not correct. This is called after parsing input file is completed.
+ * The main purpose is removing ways that contain nodes that are not included in loaded data.
bool removeIncorrectWays();
@@ -261,9 +319,12 @@
bool splitNodes();
- * This function is postprocess after osm file parsing. Parsing stored all information into database, but
- * such database schema is not optimal e.g. for way selection, that is called very often. It should be better
- * to have way members (with their coordinates) store directly in way table - in WKB (well known binary) format
+ * This function performs postprocessing after OSM file parsing.
+ * Parsing has stored all information into database, but such database schema is not optimal e.g. for way selection,
+ * that must be done very often. It should be better to have way members (with their coordinates) stored directly
+ * in way table - in WKB (well known binary) format. Also some other redundant/cached information can be useful.
bool postparsing();
@@ -276,30 +337,47 @@
int freeFeatureId();
- * Get number of members of specified way.
+ * Gets number of members of specified way.
* @return number of way members
int wayMemberCount( int wayId );
- int relationMemberCount( int relId );
- // fetch node from current statement
+ * Function fetches one node from current sqlite3 statement.
+ * @param feature output; feature representing fetched node
+ * @param stmt database statement to fetch node from
+ * @param fetchGeometry determines if node geometry should be fetched also
+ * @param fetchAttrs list of attributes to be fetched with node
+ * @return success of failure flag (true/false)
bool fetchNode( QgsFeature& feature, sqlite3_stmt* stmt, bool fetchGeometry, QgsAttributeList& fetchAttrs );
- // fetch way from current statement
+ * Function fetches one way from current sqlite3 statement.
+ * @param feature output; feature representing fetched way
+ * @param stmt database statement to fetch way from
+ * @param fetchGeometry determines if way geometry should be fetched also
+ * @param fetchAttrs list of attributes to be fetched with way
bool fetchWay( QgsFeature& feature, sqlite3_stmt* stmt, bool fetchGeometry, QgsAttributeList& fetchAttrs );
- // Change geometry of one feature (used by changeGeometryValues())
- bool changeGeometryValue( const int & featid, QgsGeometry & geom );
+ * Function returns string of concatenated tags of specified feature.
+ * @param type type of feature (one of "node","way","relation")
+ * @param id feature identifier
+ * @return string of tags concatenation
+ QString tagsForObject(const char* type, int id);
- struct wkbPoint
- char byteOrder;
- unsigned wkbType;
- double x;
- double y;
- wkbPoint mWKBpt;
+ * Function returns one tag value of specified feature and specified key.
+ * @param tagKey tag key
+ * @return tag value
+ QString tagForObject(const char* type, int id, QString tagKey);
