[QGIS Commit] r11290 - in trunk/qgis/src: app app/legend core
svn_qgis at osgeo.org
Fri Aug 7 07:58:50 EDT 2009
Author: mhugent
Date: 2009-08-07 07:58:50 -0400 (Fri, 07 Aug 2009)
New Revision: 11290
trunk/qgis/src/app/legend/qgslegend.cpp
trunk/qgis/src/app/legend/qgslegend.h
trunk/qgis/src/app/qgisapp.cpp
trunk/qgis/src/core/qgsvectorlayer.cpp
Ask for commit/rollback of pending edits on layer remove and when leaving QGIS (fix for bug #1443). Additionally fix for a memory leak and some formating changes of the commit script
Modified: trunk/qgis/src/app/legend/qgslegend.cpp
--- trunk/qgis/src/app/legend/qgslegend.cpp 2009-08-07 10:45:46 UTC (rev 11289)
+++ trunk/qgis/src/app/legend/qgslegend.cpp 2009-08-07 11:58:50 UTC (rev 11290)
@@ -76,12 +76,12 @@
this, SLOT( writeProject( QDomDocument & ) ) );
// Initialise the line indicator widget.
- mInsertionLine = new QWidget(viewport());
+ mInsertionLine = new QWidget( viewport() );
hideLine();
- mInsertionLine->setAutoFillBackground(true);
+ mInsertionLine->setAutoFillBackground( true );
QPalette pal = mInsertionLine->palette();
- pal.setColor(mInsertionLine->backgroundRole(), Qt::blue);
- mInsertionLine->setPalette(pal);
+ pal.setColor( mInsertionLine->backgroundRole(), Qt::blue );
+ mInsertionLine->setPalette( pal );
setSortingEnabled( false );
setDragEnabled( false );
@@ -129,6 +129,7 @@
mPixmapHeightValues.clear();
updateMapCanvasLayerSet();
setIconSize( mMinimumIconSize );
+ mItemBeingMoved = 0;
void QgsLegend::selectAll( bool select )
@@ -256,7 +257,7 @@
hideLine();
updateLineWidget();
- scrollToItem (item );
+ scrollToItem( item );
QgsLegendItem* origin = dynamic_cast<QgsLegendItem*>( mItemBeingMoved );
QgsLegendItem* dest = dynamic_cast<QgsLegendItem*>( item );
@@ -269,14 +270,14 @@
if ( yCoordAboveCenter( dest, e->y() ) ) //over center of item
- int line_y = visualItemRect(item).top() + 1;
- int line_left = visualItemRect(item).left();
+ int line_y = visualItemRect( item ).top() + 1;
+ int line_left = visualItemRect( item ).left();
if ( action == QgsLegendItem::REORDER || action == QgsLegendItem::INSERT )
QgsDebugMsg( "mouseMoveEvent::INSERT or REORDER" );
mDropAction = BEFORE;
- showLine( line_y, line_left);
+ showLine( line_y, line_left );
setCursor( QCursor( Qt::SizeVerCursor ) );
else //no action
@@ -288,21 +289,21 @@
else // below center of item
- int line_y = visualItemRect(item).bottom() - 2;
+ int line_y = visualItemRect( item ).bottom() - 2;
if ( action == QgsLegendItem::REORDER )
QgsDebugMsg( "mouseMoveEvent::REORDER bottom half" );
mDropAction = AFTER;
else if ( action == QgsLegendItem::INSERT )
QgsDebugMsg( "mouseMoveEvent::INSERT" );
mDropAction = INTO_GROUP;
else//no action
@@ -318,7 +319,7 @@
setCursor( QCursor( Qt::ForbiddenCursor ) );
- else if (!item && e->pos().y() >= 0 && e->pos().y() < viewport()->height() && e->pos().x() >= 0 && e->pos().x() < viewport()->width() )
+ else if ( !item && e->pos().y() >= 0 && e->pos().y() < viewport()->height() && e->pos().x() >= 0 && e->pos().x() < viewport()->width() )
// Outside the listed items, but check if we are in the empty area
// of the viewport, so we can drop after the last top level item.
@@ -330,7 +331,7 @@
- showLine(visualItemRect( lastVisibleItem() ).bottom() + 1, 0);
+ showLine( visualItemRect( lastVisibleItem() ).bottom() + 1, 0 );
else //no action
@@ -338,7 +339,7 @@
QgsDebugMsg( "mouseMoveEvent::NO_ACTION" );
mDropAction = NO_ACTION;
else
@@ -370,7 +371,7 @@
QgsLegendItem* dest = dynamic_cast<QgsLegendItem*>( destItem );
// no change?
- if ( !dest || !origin || (dest == origin) )
+ if ( !dest || !origin || ( dest == origin ) )
checkLayerOrderUpdate();
return;
@@ -438,7 +439,7 @@
// Do the actual move here.
QgsDebugMsg( "Other type of drag'n'drop happened!" );
- if ( mDropAction == AFTER) //over center of item
+ if ( mDropAction == AFTER ) //over center of item
QgsDebugMsg( "Drop AFTER" );
if ( dest->nextSibling() != origin )
@@ -702,9 +703,7 @@
//remove the layer
if ( *it )
- //the map layer registry emits a signal and this will remove the legend layer file
- //from the legend and from memory by calling QgsLegend::removeLayer(QString layer key)
- QgsMapLayerRegistry::instance()->removeMapLayer(( *it )->getLayerID() );
+ removeLayer( *it, true );
@@ -735,8 +734,61 @@
return;
+bool QgsLegend::removeLayer( QgsMapLayer* ml, bool askCancelOnEditable )
+ if ( !ml )
+ return false;
+ QgsVectorLayer* vl = dynamic_cast<QgsVectorLayer*>( ml );
+ if ( vl )
+ //is layer editable and changed?
+ if ( vl->isEditable() && vl->isModified() )
+ QMessageBox::StandardButton commit;
+ if ( askCancelOnEditable )
+ commit = QMessageBox::information( this,
+ tr( "Stop editing" ),
+ tr( "Do you want to save the changes to layer %1?" ).arg( vl->name() ),
+ QMessageBox::Save | QMessageBox::Discard | QMessageBox::Cancel );
+ if ( commit == QMessageBox::Cancel )
+ return false;
+ else
+ QMessageBox::Save | QMessageBox::Discard );
+ if ( commit == QMessageBox::Save )
+ if ( !vl->commitChanges() )
+ return false;
+ else if ( commit == QMessageBox::Discard )
+ if ( !vl->rollBack() )
+ return false;
+ QgsMapLayerRegistry::instance()->removeMapLayer( ml->getLayerID() );
+ return true;
void QgsLegend::legendLayerShowProperties()
if ( !mMapCanvas || mMapCanvas->isDrawing() )
@@ -1992,12 +2044,12 @@
void QgsLegend::hideLine()
- mInsertionLine->setGeometry(0, -100, 1, 1);
+ mInsertionLine->setGeometry( 0, -100, 1, 1 );
-void QgsLegend::showLine(int y, int left)
+void QgsLegend::showLine( int y, int left )
- mInsertionLine->setGeometry(left, y, viewport()->width(), 2);
+ mInsertionLine->setGeometry( left, y, viewport()->width(), 2 );
void QgsLegend::updateLineWidget()
@@ -2010,9 +2062,9 @@
QTreeWidgetItem *current;
QTreeWidgetItem *next;
current = topLevelItem( topLevelItemCount() - 1 );
- while ( ( next = itemBelow( current ) ) )
+ while (( next = itemBelow( current ) ) )
current = next;
Modified: trunk/qgis/src/app/legend/qgslegend.h
--- trunk/qgis/src/app/legend/qgslegend.h 2009-08-07 10:45:46 UTC (rev 11289)
+++ trunk/qgis/src/app/legend/qgslegend.h 2009-08-07 11:58:50 UTC (rev 11290)
@@ -222,6 +222,13 @@
/**Removes the current LegendLayer and all its LegendLayerFiles*/
void legendLayerRemove();
+ /**Removes a layer. If the layer is editable, a dialog is shown where user can select 'save', 'discard' and optionally 'cancel'. Cancel
+ is useful if a single layer is removed whereas on closing of the whole project or application, the cancel option may not be possible
+ @param ml the maplayer to remove
+ @param askCancelOnEditable gibe cancel option in the dialog for editable (and changed) layers
+ @param return false if canceled or in case of error, true else*/
+ bool removeLayer( QgsMapLayer* ml, bool askCancelOnEditable );
/**Toggle show in overview for current layer*/
void legendLayerShowInOverview();
@@ -317,7 +324,7 @@
void hideLine();
/** Show the line that indicates insertion position */
- void showLine(int y, int left);
+ void showLine( int y, int left );
/** Update the widget with latest changes immediately */
void updateLineWidget();
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp 2009-08-07 10:45:46 UTC (rev 11289)
+++ trunk/qgis/src/app/qgisapp.cpp 2009-08-07 11:58:50 UTC (rev 11290)
@@ -3026,6 +3026,7 @@
if ( saveDirty() )
+ mMapCanvas->freeze( true );
removeAllLayers();
qApp->exit( 0 );
@@ -3051,6 +3052,9 @@
if ( !saveDirty() )
+ removeAllLayers();
+ mMapCanvas->freeze( false );
return;
@@ -3058,7 +3062,7 @@
//QgsDebugMsg("erasing project");
- QgsMapLayerRegistry::instance()->removeAllMapLayers();
mMapCanvas->clear();
delete mComposer;
@@ -4240,6 +4244,7 @@
QgsMergeAttributesDialog d( featureList, vl, mapCanvas() );
if ( d.exec() == QDialog::Rejected )
+ delete unionGeom;
return;
@@ -4287,7 +4292,7 @@
vl->addFeature( newFeature, false );
- vl->endEditCommand();;
+ vl->endEditCommand();
if ( mapCanvas() )
@@ -4652,10 +4657,6 @@
void QgisApp::removeLayer()
QgsLegendLayerFile* currentLayerFile = mMapLegend->currentLayerFile();
- if ( currentLayerFile && currentLayerFile->isEditing() )
- toggleEditing( dynamic_cast<QgsVectorLayer *>( currentLayerFile->layer() ) );
mMapLegend->legendLayerRemove();
// notify the project we've made a change
QgsProject::instance()->dirty( true );
@@ -4664,7 +4665,22 @@
void QgisApp::removeAllLayers()
+ //iterate through all the layers in order to ask if uncommited changes should be saved
+ if ( mMapLegend )
+ QMap<QString, QgsMapLayer*> layers = QgsMapLayerRegistry::instance()->mapLayers();
+ QMap<QString, QgsMapLayer*>::iterator layer_it = layers.begin();
+ for ( ; layer_it != layers.end(); ++layer_it )
+ mMapLegend->removeLayer( layer_it.value(), false );
+ mMapLegend->removeAll();
+ else //no legend? Remove all the layers from the registry directly in this case
+ QgsMapLayerRegistry::instance()->removeAllMapLayers();
mMapCanvas->refresh();
Modified: trunk/qgis/src/core/qgsvectorlayer.cpp
--- trunk/qgis/src/core/qgsvectorlayer.cpp 2009-08-07 10:45:46 UTC (rev 11289)
+++ trunk/qgis/src/core/qgsvectorlayer.cpp 2009-08-07 11:58:50 UTC (rev 11290)
@@ -743,7 +743,7 @@
double opacity = 1.0;
if ( !mRenderer->usesTransparency() )
- opacity = ( mTransparencyLevel * 1.0) / 255.0;
+ opacity = ( mTransparencyLevel * 1.0 ) / 255.0;
mRenderer->renderFeature( rendererContext, fet, &marker, sel, opacity );
@@ -3094,9 +3094,9 @@
emit editingStopped();
setModified( FALSE );
triggerRepaint();
return true;
