[QGIS Commit] r11310 - branches/symbology-ng-branch/src/core/pal
svn_qgis at osgeo.org
Sun Aug 9 07:49:35 EDT 2009
Author: wonder
Date: 2009-08-09 07:49:35 -0400 (Sun, 09 Aug 2009)
New Revision: 11310
branches/symbology-ng-branch/src/core/pal/feature.cpp
Additional cost factor for line labels: penalize label positions further from the line's center.
Might need some tuning, but seems to choose more appropriate label positions now.
Modified: branches/symbology-ng-branch/src/core/pal/feature.cpp
--- branches/symbology-ng-branch/src/core/pal/feature.cpp 2009-08-09 11:35:27 UTC (rev 11309)
+++ branches/symbology-ng-branch/src/core/pal/feature.cpp 2009-08-09 11:49:35 UTC (rev 11310)
@@ -571,8 +571,11 @@
if ( cost > 0.98 )
cost = 0.0001;
else
- cost = ( 1 - cost ) / 100;
+ cost = ( 1 - cost ) / 100; // < 0.0001, 0.01 > (but 0.005 is already pretty much)
+ // penalize positions which are further from the line's midpoint
+ double costCenter = vabs( ll/2 - (l+xrm/2) ) / ll; // <0, 0.5>
+ cost += costCenter / 1000; // < 0, 0.0005 >
if (( vabs( ey - by ) < EPSILON ) && ( vabs( ex - bx ) < EPSILON ) )
@@ -723,7 +726,7 @@
double end_x = 0;
double end_y = 0;
- std::cerr << "segment len " << segment_length << " distance " << distance << std::endl;
+ //std::cerr << "segment len " << segment_length << " distance " << distance << std::endl;
if (segment_length - distance >= ci.width)
// if the distance remaining in this segment is enough, we just go further along the segment
@@ -883,15 +886,22 @@
diff = fabs(tmp->getAlpha() - angle_last);
if (diff > 2*M_PI) diff -= 2*M_PI;
+ diff = min(diff, 2*M_PI - diff); // difference 350 deg is actually just 10 deg...
angle_diff += diff;
angle_last = tmp->getAlpha();
tmp = tmp->getNextPart();
- double cost = angle_diff/100.0;
+ double angle_diff_avg = angle_diff / (f->labelInfo->char_num-1); // <0, pi> but pi/8 is much already
+ double cost = angle_diff_avg / 100; // <0, 0.031 > but usually <0, 0.003 >
if (cost < 0.0001) cost = 0.0001;
- std::cerr << "cost " << angle_diff << std::endl;
+ double labelCenter = (i*delta) + f->label_x/2;
+ double costCenter = vabs( total_distance/2 - labelCenter ) / total_distance; // <0, 0.5>
+ //std::cerr << "cost " << angle_diff << " vs " << costCenter << std::endl;
slp->setCost(cost);
positions->push_back(slp);
