[QGIS Commit] r11329 - trunk/qgis/src/plugins/grass
svn_qgis at osgeo.org
Mon Aug 10 11:41:33 EDT 2009
Author: rugginoso
Date: 2009-08-10 11:41:32 -0400 (Mon, 10 Aug 2009)
New Revision: 11329
trunk/qgis/src/plugins/grass/qgsgrassmodule.cpp
trunk/qgis/src/plugins/grass/qgsgrassmodule.h
Added the possibility to unselect an optional (required="no" into interface-description of the grass module) to fix #1134.
Modified: trunk/qgis/src/plugins/grass/qgsgrassmodule.cpp
--- trunk/qgis/src/plugins/grass/qgsgrassmodule.cpp 2009-08-10 14:55:27 UTC (rev 11328)
+++ trunk/qgis/src/plugins/grass/qgsgrassmodule.cpp 2009-08-10 15:41:32 UTC (rev 11329)
@@ -2633,6 +2633,13 @@
adjustTitle();
+ // Check if this parameter is required
+ if (gnode.toElement().attribute("required") == "yes") {
+ mRequired = true;
+ } else {
+ mRequired = false;
QDomNode promptNode = gnode.namedItem( "gisprompt" );
QDomElement promptElem = promptNode.toElement();
QString element = promptElem.attribute( "element" );
@@ -2700,6 +2707,14 @@
mUri.resize( 0 );
mOgrLayers.resize( 0 );
+ // If not required, add an empty item to combobox and a padding item into
+ // layer containers.
+ if (!mRequired){
+ mUri.push_back(QString());
+ mOgrLayers.push_back(QString());
+ mLayerComboBox->addItem(tr("Select a layer"), QVariant());
QgsMapCanvas *canvas = mModule->qgisIface()->mapCanvas();
int nlayers = canvas->layerCount();
Modified: trunk/qgis/src/plugins/grass/qgsgrassmodule.h
--- trunk/qgis/src/plugins/grass/qgsgrassmodule.h 2009-08-10 14:55:27 UTC (rev 11328)
+++ trunk/qgis/src/plugins/grass/qgsgrassmodule.h 2009-08-10 15:41:32 UTC (rev 11329)
@@ -695,6 +695,9 @@
//! Ogr where clauses
std::vector<QString> mOgrWheres;
+ //! Required field
+ bool mRequired;
/*********************** QgsGrassModuleField **********************/
