[QGIS Commit] r11343 - trunk/qgis/src/plugins/grass
svn_qgis at osgeo.org svn_qgis at osgeo.org
Tue Aug 11 09:29:52 EDT 2009
Author: rugginoso
Date: 2009-08-11 09:29:51 -0400 (Tue, 11 Aug 2009)
New Revision: 11343
   trunk/qgis/src/plugins/grass/qgsgrassmodule.cpp
Adapted the attribute table combobox to the "required" property of layer combobox.
Modified: trunk/qgis/src/plugins/grass/qgsgrassmodule.cpp
--- trunk/qgis/src/plugins/grass/qgsgrassmodule.cpp	2009-08-11 07:32:37 UTC (rev 11342)
+++ trunk/qgis/src/plugins/grass/qgsgrassmodule.cpp	2009-08-11 13:29:51 UTC (rev 11343)
@@ -2439,15 +2439,19 @@
   QgsDebugMsg( "called." );
+  int limit = 0;
+  if (!mRequired)
+    limit = 1;
   std::vector<QgsField> fields;
   int c = mLayerComboBox->currentIndex();
-  if ( c < 0 )
+  if ( c < limit )
     return fields;
   unsigned current = c;
-  if ( current >= 0 && current <  mVectorFields.size() )
+  if ( current >= limit && current <  mVectorFields.size() )
     fields = mVectorFields[current];
@@ -2459,13 +2463,17 @@
+  int limit = 0;
+  if (!mRequired)
+    limit = 1;
-  if ( c < 0 )
+  if ( c < limit )
     return 0;
   unsigned int current = c;
-  if ( current >= 0 && current <  mMapLayers.size() )
+  if ( current >= limit && current <  mMapLayers.size() )
     return mMapLayers[current];
@@ -2477,13 +2485,17 @@
+  int limit = 0;
+  if (!mRequired)
+    limit = 1;
-  if ( c < 0 )
+  if ( c < limit )
     return QString();
-  if ( current >= 0 && current <  mMaps.size() )
+  if ( current >= limit && current <  mMaps.size() )
     return mMaps[current];
More information about the QGIS-commit mailing list
