[QGIS Commit] r11348 - trunk/qgis/python/plugins/fTools/tools
svn_qgis at osgeo.org
Tue Aug 11 20:49:54 EDT 2009
Author: cfarmer
Date: 2009-08-11 20:49:53 -0400 (Tue, 11 Aug 2009)
New Revision: 11348
trunk/qgis/python/plugins/fTools/tools/doGeoprocessing.py
Additional updates to 'Clip' Geoprocessing tool: Properly fixes #1758.
Modified: trunk/qgis/python/plugins/fTools/tools/doGeoprocessing.py
--- trunk/qgis/python/plugins/fTools/tools/doGeoprocessing.py 2009-08-11 22:23:53 UTC (rev 11347)
+++ trunk/qgis/python/plugins/fTools/tools/doGeoprocessing.py 2009-08-12 00:49:53 UTC (rev 11348)
@@ -1213,55 +1213,90 @@
nElement += 1
self.emit( SIGNAL( "runStatus(PyQt_PyObject)" ), nElement )
geom = QgsGeometry( inFeatA.geometry() )
- diff_geom = QgsGeometry( geom )
+ int_geom = QgsGeometry( geom )
atMap = inFeatA.attributeMap()
intersects = index.intersects( geom.boundingBox() )
+ found = False
+ first = True
for id in intersects:
if id in selectionB:
vproviderB.featureAtId( int( id ), inFeatB , True, allAttrsB )
tmpGeom = QgsGeometry( inFeatB.geometry() )
+ if tmpGeom.intersects( geom ):
+ found = True
+ if first:
+ outFeat.setGeometry( QgsGeometry( tmpGeom ) )
+ first = False
+ else:
+ try:
+ cur_geom = QgsGeometry( outFeat.geometry() )
+ new_geom = QgsGeometry( cur_geom.combine( tmpGeom ) )
+ outFeat.setGeometry( QgsGeometry( new_geom ) )
+ except:
+ GEOS_EXCEPT = False
+ break
+ if found:
+ try:
+ new_geom = QgsGeometry( geom.intersection( cur_geom ) )
+ if new_geom.wkbType() == 7:
+ int_com = QgsGeometry( geom.combine( cur_geom ) )
+ int_sym = QgsGeometry( geom.symDifference( cur_geom ) )
+ new_geom = QgsGeometry( int_com.difference( int_sym ) )
try:
- if geom.intersects( tmpGeom ):
- diff_geom = QgsGeometry( diff_geom.difference( tmpGeom ) )
+ outFeat.setGeometry( new_geom )
+ outFeat.setAttributeMap( atMap )
+ writer.addFeature( outFeat )
except:
- add = False
- GEOS_EXCEPT = False
- break
- try:
- outGeom = QgsGeometry( geom.difference( diff_geom ) )
- outFeat.setGeometry( outGeom )
- outFeat.setAttributeMap( atMap )
- writer.addFeature( outFeat )
- except:
- break
+ FEAT_EXCEPT = False
+ continue
+ except:
+ continue
# we have no selection in overlay layer
else:
for inFeatA in selectionA:
nElement += 1
+ found = False
+ first = True
+ found = True
+ if first:
+ first = False
+ else:
+ try:
+ except:
+ break
+ if found:
try:
+ try:
+ except:
+ continue
except:
- add = False
GEOS_EXCEPT = False
- break
- try:
- except:
- break
+ continue
# there is no selection in input layer
else:
nFeat = vproviderA.featureCount()
@@ -1274,55 +1309,90 @@
nElement += 1
+ found = False
+ first = True
+ found = True
+ if first:
+ first = False
+ else:
+ try:
+ except:
+ break
+ if found:
+ try:
try:
except:
- add = False
- break
- try:
- except:
- break
+ continue
+ except:
+ continue
else:
while vproviderA.nextFeature( inFeatA ):
nElement += 1
- for id in intersects:
- vproviderB.featureAtId( int( id ), inFeatB , True, allAttrsB )
- tmpGeom = QgsGeometry( inFeatB.geometry() )
- try:
- except:
- add = False
- break
- try:
- except:
- break
+ first = True
+ found = False
+ if len( intersects ) > 0:
+ for id in intersects:
+ vproviderB.featureAtId( int( id ), inFeatB , True, allAttrsB )
+ tmpGeom = QgsGeometry( inFeatB.geometry() )
+ found = True
+ if first:
+ first = False
+ else:
+ try:
+ except:
+ break
+ if found:
+ try:
+ try:
+ except:
+ continue
+ except:
+ continue
del writer
return GEOS_EXCEPT, FEATURE_EXCEPT, crs_match
