[QGIS Commit] r11373 - trunk/qgis/src/core
svn_qgis at osgeo.org
Fri Aug 14 06:54:01 EDT 2009
Author: homann
Date: 2009-08-14 06:54:01 -0400 (Fri, 14 Aug 2009)
New Revision: 11373
trunk/qgis/src/core/qgscoordinatereferencesystem.cpp
Fixing globbing search after breaking it in r11366
Modified: trunk/qgis/src/core/qgscoordinatereferencesystem.cpp
--- trunk/qgis/src/core/qgscoordinatereferencesystem.cpp 2009-08-14 09:22:25 UTC (rev 11372)
+++ trunk/qgis/src/core/qgscoordinatereferencesystem.cpp 2009-08-14 10:54:01 UTC (rev 11373)
@@ -425,12 +425,17 @@
// Last ditch attempt to piece together what we know of the projection to find a match...
QgsDebugMsg( "globbing search for srsid from this proj string" );
+ setProj4String( theProj4String );
mySrsId = findMatchingProj();
QgsDebugMsg( "globbing search for srsid returned srsid: " + QString::number( mySrsId ) );
if ( mySrsId > 0 )
createFromSrsId( mySrsId );
+ else
+ mIsValidFlag = false;
@@ -771,7 +776,8 @@
QgsDebugMsg( "entered." );
if ( mEllipsoidAcronym.isNull() || mProjectionAcronym.isNull() || !mIsValidFlag )
- QgsDebugMsg( "QgsCoordinateReferenceSystem::findMatchingProj will only work if prj acr ellipsoid acr and proj4string are set!..." );
+ QgsDebugMsg( "QgsCoordinateReferenceSystem::findMatchingProj will only work if prj acr ellipsoid acr and proj4string are set"
+ " and the current projection is valid!" );
return 0;
