[QGIS Commit] r11447 - in trunk/qgis: resources scripts src/app src/core
svn_qgis at osgeo.org svn_qgis at osgeo.org
Wed Aug 19 17:22:32 EDT 2009
Author: homann
Date: 2009-08-19 17:22:31 -0400 (Wed, 19 Aug 2009)
New Revision: 11447
Added:
   trunk/qgis/resources/README
   trunk/qgis/scripts/qgis_srs.sh
   trunk/qgis/resources/srs.db
   trunk/qgis/scripts/postprocess_srs.sql
   trunk/qgis/src/app/qgscustomprojectiondialog.cpp
   trunk/qgis/src/app/qgsoptions.cpp
   trunk/qgis/src/core/qgscoordinatereferencesystem.cpp
   trunk/qgis/src/core/qgsdistancearea.cpp
* Added script for updating the srs.db from the GDAL installation (thanks msieczka !)
* Added a small README on the process on how to do the above
* Change the CRS recognition when reading from projects, so it tries to match the proj4 string if valid. This is a must when the srs.db now is updated
* Changed to read ellipsoid an projection acronyms from srs.db nistead of qgis.db (mostly)
* Misc. clean up of comments and deletion of stale code.
* Fixes #1534.
Added: trunk/qgis/resources/README
--- trunk/qgis/resources/README	                        (rev 0)
+++ trunk/qgis/resources/README	2009-08-19 21:22:31 UTC (rev 11447)
@@ -0,0 +1,16 @@
+Updating the srs.db
+The srs.db can be updated from the EPSG codes in the
+GDAL installation:
+1) Install latest GDAL, be sure to configure with --with-python.
+2) Set PATH and PYTHONDIR if installed GDAL in non-standard location.
+3) Run 'scripts/qgis_srs.sh > new_srs.sql'. It may take a minute or two.
+4) Run 'sqlite3 new_srs.db < new_srs.sql'.'
+4) Run 'sqlite3 new_srs.db <postprocess_srs.sql'
+You can use sqlite3 to dump the contents from both srs.db and new_srs.db
+before you decide to commit.
+Magnus Homann 2009-08-19
\ No newline at end of file
Modified: trunk/qgis/resources/srs.db
(Binary files differ)
Modified: trunk/qgis/scripts/postprocess_srs.sql
--- trunk/qgis/scripts/postprocess_srs.sql	2009-08-19 21:04:03 UTC (rev 11446)
+++ trunk/qgis/scripts/postprocess_srs.sql	2009-08-19 21:22:31 UTC (rev 11447)
@@ -3,18 +3,18 @@
 -- sqlite3 srs.db <postprocess_srs.sql
 -- Swedish RT-90 projections with increased accuracy
-REPLACE INTO tbl_srs VALUES(984,'RT90 7.5 gon V','tmerc','GRS80',
-'+proj=tmerc +lat_0=0 +lon_0=11.306250000000 +k=1.000006000000 +x_0=1500025.141 +y_0=-667.282 +ellps=GRS80 +units=m +no_defs',3019,3019,0);
-REPLACE INTO tbl_srs VALUES(985,'RT90 5 gon V','tmerc','GRS80',
-'+proj=tmerc +lat_0=0  +lon_0=13.55626666666 +k=1.000005800000 +x_0=1500044.695 +y_0=-667.130 +ellps=GRS80 +units=m +no_defs',3020,3020,0);
-REPLACE INTO tbl_srs VALUES(986,'RT90 2.5 gon V','tmerc','GRS80',
-'+proj=tmerc +lat_0=0 +lon_0=15.806284529444 +k=1.000005610240 +x_0=1500064.274 +y_0=-667.711 +ellps=GRS80 +units=m +no_defs',3021,3021,0);
-REPLACE INTO tbl_srs VALUES(987,'RT90 0 gon','tmerc','GRS80',
-'+proj=tmerc +lat_0=0 +lon_0=18.056300000000 +k=1.000005400000 +x_0=1500083.521 +y_0=-668.844 +ellps=GRS80 +units=m +no_defs',3022,3022,0);
-REPLACE INTO tbl_srs VALUES(988,'RT90 2.5 gon O','tmerc','GRS80',
-'+proj=tmerc +lat_0=0 +lon_0=20.306316666666 +k=1.000005200000 +x_0=1500102.765 +y_0=-670.706 +ellps=GRS80 +units=m +no_defs',3023,3023,0);
-REPLACE INTO tbl_srs VALUES(989,'RT90 5 gon O','tmerc','GRS80',
-'+proj=tmerc +lat_0=0 +lon_0=22.556333333333 +k=1.000004900000 +x_0=1500121.846 +y_0=-672.557 +ellps=GRS80 +units=m +no_defs',3024,3024,0);
+INSERT INTO tbl_srs VALUES(NULL,'RT90 7.5 gon V from WGS84','tmerc','GRS80',
+'+proj=tmerc +lat_0=0 +lon_0=11.306250000000 +k=1.000006000000 +x_0=1500025.141 +y_0=-667.282 +ellps=GRS80 +units=m +no_defs',93019,93019,0);
+INSERT INTO tbl_srs VALUES(NULL,'RT90 5 gon V from WGS84','tmerc','GRS80',
+'+proj=tmerc +lat_0=0  +lon_0=13.55626666666 +k=1.000005800000 +x_0=1500044.695 +y_0=-667.130 +ellps=GRS80 +units=m +no_defs',93020,93020,0);
+INSERT INTO tbl_srs VALUES(NULL,'RT90 2.5 gon V from WGS84','tmerc','GRS80',
+'+proj=tmerc +lat_0=0 +lon_0=15.806284529444 +k=1.000005610240 +x_0=1500064.274 +y_0=-667.711 +ellps=GRS80 +units=m +no_defs',93021,93021,0);
+INSERT INTO tbl_srs VALUES(NULL,'RT90 0 gon from WGS84','tmerc','GRS80',
+'+proj=tmerc +lat_0=0 +lon_0=18.056300000000 +k=1.000005400000 +x_0=1500083.521 +y_0=-668.844 +ellps=GRS80 +units=m +no_defs',93022,93022,0);
+INSERT INTO tbl_srs VALUES(NULL,'RT90 2.5 gon O from WGS84','tmerc','GRS80',
+'+proj=tmerc +lat_0=0 +lon_0=20.306316666666 +k=1.000005200000 +x_0=1500102.765 +y_0=-670.706 +ellps=GRS80 +units=m +no_defs',93023,93023,0);
+INSERT INTO tbl_srs VALUES(NULL,'RT90 5 gon O from WGS84','tmerc','GRS80',
+'+proj=tmerc +lat_0=0 +lon_0=22.556333333333 +k=1.000004900000 +x_0=1500121.846 +y_0=-672.557 +ellps=GRS80 +units=m +no_defs',93024,93024,0);
 -- S-JTSK/Krovak (Greenwich) (ticket #728)
-insert into tbl_srs values (3520,'S-JTSK (Greenwich) / Krovak','krovak','bessel','+proj=krovak +lat_0=49.5 +lon_0=24.83333333333333 +alpha=30.28813972222222 +k=0.9999 +x_0=0 +y_0=0 +ellps=bessel +pm=greenwich +units=m +no_defs','102067','102067','0');
+INSERT INTO tbl_srs VALUES (NULL,'S-JTSK (Greenwich) / Krovak','krovak','bessel','+proj=krovak +lat_0=49.5 +lon_0=24.83333333333333 +alpha=30.28813972222222 +k=0.9999 +x_0=0 +y_0=0 +ellps=bessel +pm=greenwich +units=m +no_defs','102067','102067','0');
Added: trunk/qgis/scripts/qgis_srs.sh
--- trunk/qgis/scripts/qgis_srs.sh	                        (rev 0)
+++ trunk/qgis/scripts/qgis_srs.sh	2009-08-19 21:22:31 UTC (rev 11447)
@@ -0,0 +1,278 @@
+#!/bin/sh
+# AUTHOR:       Maciej Sieczka, msieczka at sieczka.org, http://www.sieczka.org
+# PURPOSE:      Create a QGIS srs.db-compliant SQL script with SRS, ellipsoid
+#               and projections defs based on the output of installed PROJ.4 and
+#               GDAL.
+# VERSION:      1.1.0, 2009.03.19
+# COPYRIGHT:    (c) 2008,2009 Maciej Sieczka
+# LICENSE:      This program is free software under the GNU General Public
+#               License (>=v2).
+# CHANGELOG:
+# 1.1.0:
+# - Reorganize the code into functions.
+# - Support qgis.db convenient update too.
+# - Workaround the issue http://trac.osgeo.org/gdal/ticket/2900.
+# 1.0.3: Minor cosmetics in comments.
+# 1.0.2: Replace 'latlon' and 'lonlat' in the `proj -le` output, so that QGIS
+#        can parse the 'tbl_projection' table to provide the GCSs list in the
+#        'Projection' dialog (BTW, the dialog should be called 'Coordinate
+#        system' actually, as a projection is only a component of a cs).
+#        More comments.
+# 1.0.1: Typos in comments fixed.
+# 1.0:   First public release.
+# USAGE:  1. qgis_srs.sh --full/--tmpl > output.sql
+#         2. import output.sql into SQLite Database Browser
+#         3. save as a new dbase, name it srs.db (--full) or qgis.db (--tmpl),
+#            use with QGIS
+# DETAILS:
+# The script creates an SQL plain text dump that can be imported into
+# SQlite db eg. using SQLite Database Browser's "Import > Database from
+# SQL file" tool.
+# The ellipsoids (tbl_ellipsoid) and projections (tbl_projection) tables
+# are created parsing the proj command output. I chose this approach,
+# because looking at the original tables content it seems the original
+# tables were created the same way.
+# The tbl_srs table is created parsing the epsg_tr.py output. EPSG codes
+# to process are taken from the installed GDAL's pcs.csv and gcs.csv files.
+# Tables structure and final SQL statements creating the view and indices
+# were copied from the original srs.db shipped with QGIS trunk r8544,
+# after dumping it to a plain text format with SQLite Database Browser.
+### FUNCTIONS ###
+mk_tbl_bookmarks ()
+# Create bookmarks table:
+echo "CREATE TABLE tbl_bookmarks (
+  bookmark_id integer PRIMARY KEY,
+  name varchar(255) NOT NULL,
+  project_name varchar(32),
+  xmin double,
+  ymin double,
+  xmax double,
+  ymax double,
+  projection_srid integer
+mk_tbl_ellps ()
+# Create ellipsoids table:
+echo "CREATE TABLE tbl_ellipsoid (
+  acronym char(20) NOT NULL default '',
+  name char(255) NOT NULL default '',
+  radius char(255) NOT NULL default '',
+  parameter2 char(255) NOT NULL default '',
+  PRIMARY KEY (acronym)
+pop_tbl_ellps ()
+# Populate ellipsoids table. Care about (possible) apostrophes in strings, which
+# would brake the SQL syntax, as the "'" is also a string separator:
+proj -le | sed 's/^ *//g' | tr -d "\t" | sed "s/  */ /g" | sed "s/'/''/g" | awk 'BEGIN {sep="'\'','\''"} NF>4 {printf $1 sep $4; for (i=5;i<NF+1;i++) {printf " "$i} print sep $2 sep $3} NF<5 {print $1 sep $4 sep $2 sep $3}' | while read i; do
+ echo "INSERT INTO tbl_ellipsoid VALUES('"${i}"');"
+done
+mk_tbl_projs ()
+# Create projections table:
+echo "CREATE TABLE tbl_projection (
+  acronym varchar(20) NOT NULL PRIMARY KEY,
+  name varchar(255) NOT NULL default '',
+  notes varchar(255) NOT NULL default '',
+  parameters varchar(255) NOT NULL default ''
+pop_tbl_projs ()
+# Populate projections table:
+# Process each proj4 projection acronym...
+for i in `proj -l | cut -d" " -f1 | sed -e 's/lonlat/longlat/' -e 's/latlon/latlong/'` ; do
+ #...to extract it's parameters, making sure not more than 4 fields are created...
+ proj=`proj -l=$i | tr -d "\t" | sed 's/^ *//g' | sed 's/ : /\n/' | sed "s/'/''/g" | awk '{print "'\''"$0"'\''"}' | tr "\n" "," | sed 's/,$/\n/' | sed "s/','/ /4g"`
+ #...count the number of parameters...
+ proj_nf=`echo $proj | awk -F"','" '{print NF}'`
+ #...if only 3 (3 or 4 are possible) add an empty 4th one.
+ if [ $proj_nf -eq 3 ] ; then
+   proj=${proj}",''"
+ fi
+ # Create an SQL command for each proj:
+ echo "INSERT INTO tbl_projection VALUES("${proj}");"
+done
+mk_tbl_srss_srs ()
+# Create SRSs table for srs.db:
+echo "CREATE TABLE tbl_srs (
+  srs_id INTEGER PRIMARY KEY,
+  description text NOT NULL,
+  projection_acronym text NOT NULL,
+  ellipsoid_acronym NOT NULL,
+  parameters text NOT NULL,
+  srid integer NOT NULL,
+  epsg integer NOT NULL,
+  is_geo integer NOT NULL
+mk_tbl_srss_qgis ()
+# Create SRSs table for qgis.db:
+  srid integer NULL,
+  epsg integer NULL,
+pop_tbl_srss ()
+# Populate SRSs table:
+gdal_share=`gdal-config --datadir`
+no=0
+# Extract projected SRSs from the installed GDAL pcs.csv file:
+#Find valid EPSG numbers parsing GDAL's pcs.csv:
+for i in `awk 'NR>1' ${gdal_share}/pcs.csv | cut -d, -f1`; do
+  raw=`epsg_tr.py -proj4 $i 2>&1 | tr "\n" " " | sed 's/  <> $//' | grep -v "^ERROR 6: "`
+  if [ -n "$raw" ]; then
+   no=`expr $no + 1`
+   name=`echo $raw | sed 's/^# //' | grep -o "^.\{1,\} <[[:digit:]]\{1,\}>" | sed 's/ <[[:digit:]]\{1,\}>//' | sed "s/'/''/g"`
+   proj=`echo $raw | grep -o "+proj=[^[:space:]]\{1,\}" | cut -d"=" -f2`
+   ellps=`echo $raw | grep -o "+ellps=[^[:space:]]\{1,\}" | cut -d"=" -f2`
+   srs=`echo $raw | grep -o "+proj.\{1,\} +no_defs"`
+   epsg=`echo $raw | grep -o ' <[[:digit:]]\{1,\}> ' | sed 's/[^[:digit:]]//g'`
+   isgeo=0
+   echo "INSERT INTO tbl_srs VALUES(${no},'${name}','${proj}','${ellps}','${srs}',${epsg},${epsg},${isgeo});"
+  fi
+done
+# Extract un-projected SRSs from the installed GDAL gcs.csv file:
+#Find valid EPSG numbers parsing GDAL's gcs.csv:
+for i in `awk 'NR>1' ${gdal_share}/gcs.csv | cut -d, -f1`; do
+   no=`expr $no + 1`
+   isgeo=1
+  fi
+done
+mk_view ()
+# Final SQL statements:
+echo "CREATE VIEW vw_srs as
+   select a.description as description,
+          a.srs_id as srs_id,
+          a.is_geo as is_geo,
+          b.name as name,
+          a.parameters as parameters,
+          a.epsg as epsg
+   from tbl_srs a
+     inner join tbl_projection b
+     on a.projection_acronym=b.acronym
+   order by
+     b.name, a.description;"
+usage ()
+echo "
+Usage:
+--qgis Create a database to be used as the 'qgis.db' upgraded replacement.
+--srs  Create a database to be used as the 'srs.db' upgraded replacement.
+### DO IT ###
+if [ "$1" = "--qgis" ]; then
+  echo "BEGIN TRANSACTION;"
+  mk_tbl_bookmarks
+  mk_tbl_ellps; pop_tbl_ellps
+  mk_tbl_projs; pop_tbl_projs
+  mk_tbl_srss_qgis
+  mk_view
+  echo "COMMIT;"
+elif [ "$1" = "--srs" ]; then
+  mk_tbl_srss_srs; pop_tbl_srss
+  mk_view
+  echo "CREATE UNIQUE INDEX idx_srsepsg on tbl_srs(epsg);
+CREATE UNIQUE INDEX idx_srssrid on tbl_srs(srid);
+COMMIT;"
+else
+  usage
+fi
Property changes on: trunk/qgis/scripts/qgis_srs.sh
___________________________________________________________________
Added: svn:executable
Modified: trunk/qgis/src/app/qgscustomprojectiondialog.cpp
--- trunk/qgis/src/app/qgscustomprojectiondialog.cpp	2009-08-19 21:04:03 UTC (rev 11446)
+++ trunk/qgis/src/app/qgscustomprojectiondialog.cpp	2009-08-19 21:22:31 UTC (rev 11447)
@@ -91,78 +91,7 @@
- * These two methods will be deprecated
-void QgsCustomProjectionDialog::getProjList ()
-  // Populate the projection combo
-  sqlite3      *myDatabase;
-  const char   *myTail;
-  sqlite3_stmt *myPreparedStatement;
-  int           myResult;
-  //check the db is available
-  myResult = sqlite3_open(QgsApplication::qgisUserDbFilePath().toUtf8().data(), &myDatabase);
-  if(myResult!=SQLITE_OK)
-    QgsDebugMsg(QString("Can't open database: %1").arg(sqlite3_errmsg(myDatabase)));
-    // XXX This will likely never happen since on open, sqlite creates the
-    //     database if it does not exist.
-    assert(myResult == SQLITE_OK);
-  // Set up the query to retrieve the projection information needed to populate the CRS list
-  QString mySql = "select * from tbl_projection order by name";
-  myResult = sqlite3_prepare(myDatabase, mySql.toUtf8(), mySql.length(), &myPreparedStatement, &myTail);
-  // XXX Need to free memory from the error msg if one is set
-  if(myResult == SQLITE_OK)
-    while(sqlite3_step(myPreparedStatement) == SQLITE_ROW)
-      cboProjectionFamily->insertItem(QString::fromUtf8((char *)sqlite3_column_text(myPreparedStatement,1)));
-  sqlite3_finalize(myPreparedStatement);
-  sqlite3_close(myDatabase);
-void QgsCustomProjectionDialog::getEllipsoidList()
-  // Populate the ellipsoid combo
-  int           myResult;
-  // Set up the query to retrieve the projection information needed to populate the ELLIPSOID list
-  QString mySql = "select * from tbl_ellipsoid order by name";
-      cboEllipsoid->insertItem(QString::fromUtf8((char *)sqlite3_column_text(myPreparedStatement,1)));
-  // close the sqlite3 statement
 void QgsCustomProjectionDialog::on_pbnDelete_clicked()
@@ -274,7 +203,7 @@
   int           myResult;
   QString       myName;
-  myResult = sqlite3_open( QgsApplication::qgisUserDbFilePath().toUtf8().data(), &myDatabase );
+  myResult = sqlite3_open( QgsApplication::srsDbFilePath().toUtf8().data(), &myDatabase );
   if ( myResult != SQLITE_OK )
     QgsDebugMsg( QString( "Can't open database: %1" ).arg( sqlite3_errmsg( myDatabase ) ) );
@@ -282,7 +211,7 @@
     assert( myResult == SQLITE_OK );
+  // Set up the query to retrieve the projection information needed to populate the PROJECTION list
   QString mySql = "select name from tbl_projection where acronym='" + theProjectionFamilyAcronym + "'";
   myResult = sqlite3_prepare( myDatabase, mySql.toUtf8(), mySql.toUtf8().length(), &myPreparedStatement, &myTail );
@@ -305,7 +234,7 @@
   int           myResult;
   QString       myName;
@@ -336,7 +265,7 @@
   int           myResult;
   QString       myName;
@@ -344,7 +273,7 @@
   QString mySql = "select acronym from tbl_projection where name='" + theProjectionFamilyName + "'";
@@ -367,7 +296,7 @@
   int           myResult;
   QString       myName;
@@ -860,7 +789,55 @@
   sqlite3_finalize( myPreparedStatement );
+  // If we have a projection acronym not in the user db previously, add it.
+  // This is a must, or else we can't select it from the vw_srs table.
+  // Actually, add it always and let the SQL PRIMARY KEY remove duplicates.
+  sqlite3      *srsDatabase;
+  const char   *srsTail;
+  sqlite3_stmt *srsPreparedStatement;
+  int           srsResult;
+  //check the db is available
+  srsResult = sqlite3_open( QgsApplication::srsDbFilePath().toUtf8().data(), &srsDatabase );
+  if ( myResult != SQLITE_OK )
+    QgsDebugMsg( QString( "Can't open database: %1" ).arg( sqlite3_errmsg( srsDatabase ) ) );
+    // XXX This will likely never happen since on open, sqlite creates the
+    //     database if it does not exist.
+    assert( myResult == SQLITE_OK );
+  QString srsSql = "select * from tbl_projection where acronym='" + myProjectionAcronym + "'";
+  srsResult = sqlite3_prepare( srsDatabase, srsSql.toUtf8(), srsSql.length(), &srsPreparedStatement, &srsTail );
+  // XXX Need to free memory from the error msg if one is set
+  if ( srsResult == SQLITE_OK )
+    if ( sqlite3_step( srsPreparedStatement ) == SQLITE_ROW )
+      QgsDebugMsg( "Trying to insert projection" );
+      // We have the result from system srs.db. Now insert into user db.
+      mySql = QString( "INSERT INTO tbl_projection VALUES('%1','%2','%3','%4')" )
+              .arg( QString::fromUtf8(( char * )sqlite3_column_text( srsPreparedStatement, 0 ) ) )
+              .arg( QString::fromUtf8(( char * )sqlite3_column_text( srsPreparedStatement, 1 ) ) )
+              .arg( QString::fromUtf8(( char * )sqlite3_column_text( srsPreparedStatement, 2 ) ) )
+              .arg( QString::fromUtf8(( char * )sqlite3_column_text( srsPreparedStatement, 3 ) ) );
+      myResult = sqlite3_prepare( myDatabase, mySql.toUtf8(), mySql.length(), &myPreparedStatement, &myTail );
+      sqlite3_step( myPreparedStatement );
+        QgsDebugMsg( "Update or insert failed in custom projection dialog: " + mySql );
+      sqlite3_finalize( myPreparedStatement );
+  // close the user and srs sqlite3 db
   sqlite3_close( myDatabase );
+  sqlite3_finalize( srsPreparedStatement );
+  sqlite3_close( srsDatabase );
   pbnDelete->setEnabled( true );
@@ -940,48 +917,9 @@
-/* This is deprecated - to be deleted
-void QgsCustomProjectionDialog::cboProjectionFamily_highlighted( const QString & theText)
-    QgsDebugMsg("Projection selected from combo");
-  //search the sqlite user projections db for the projection entry
-  //and display its parameters
-  int           myResult;
-  QString mySql = "select parameters from tbl_projection name where name='"+theText+"'";
-    QgsDebugMsg(QString("Query to get proj params:%1").arg(mySql));
-    sqlite3_step(myPreparedStatement) == SQLITE_ROW;
-    QString myParametersString = QString::fromUtf8((char *)sqlite3_column_text(myPreparedStatement,0));
-    QgsDebugMsg(QString("Setting parameters text box to: %1").arg(myParametersString));
-    txtExpectedParameters->setReadOnly(false);
-    txtExpectedParameters->setText(myParametersString);
-    txtExpectedParameters->setReadOnly(true);
 QString QgsCustomProjectionDialog::getProjFromParameters()
-  QgsLogger::debug( "QgsCustomProjectionDialog::getProjFromParameters()" );
+  QgsDebugMsg( "entered." );
   QString myProj4String = leParameters->text();
   QRegExp myProjRegExp( "\\+proj=[a-zA-Z]*" );
   int myStart = 0;
Modified: trunk/qgis/src/app/qgsoptions.cpp
--- trunk/qgis/src/app/qgsoptions.cpp	2009-08-19 21:04:03 UTC (rev 11446)
+++ trunk/qgis/src/app/qgsoptions.cpp	2009-08-19 21:22:31 UTC (rev 11447)
@@ -556,7 +556,7 @@
   cmbEllipsoid->addItem( ELLIPS_FLAT_DESC );
   if ( myResult )
@@ -589,7 +589,7 @@
   int           myResult;
   QString       myName( ELLIPS_FLAT );
   if ( myResult )
@@ -621,7 +621,7 @@
   int           myResult;
   QString       myName( ELLIPS_FLAT_DESC );
   if ( myResult )
Modified: trunk/qgis/src/core/qgscoordinatereferencesystem.cpp
--- trunk/qgis/src/core/qgscoordinatereferencesystem.cpp	2009-08-19 21:04:03 UTC (rev 11446)
+++ trunk/qgis/src/core/qgscoordinatereferencesystem.cpp	2009-08-19 21:22:31 UTC (rev 11447)
@@ -935,48 +935,59 @@
     QDomNode myNode = srsNode.namedItem( "proj4" );
     QDomElement myElement = myNode.toElement();
-    setProj4String( myElement.text() );
-    myNode = srsNode.namedItem( "srsid" );
-    myElement = myNode.toElement();
-    setInternalId( myElement.text().toLong() );
+    if ( createFromProj4( myElement.text() ) )
+      // createFromProj4() sets everything, inlcuding map units
+      QgsDebugMsg( "Setting from proj4 string" );
+    else
+      QgsDebugMsg( "Setting from elements one by one" );
-    myNode = srsNode.namedItem( "srid" );
-    setSrid( myElement.text().toLong() );
+      setProj4String( myElement.text() );
-    myNode = srsNode.namedItem( "epsg" );
-    setEpsg( myElement.text().toLong() );
+      myNode = srsNode.namedItem( "srsid" );
+      myElement = myNode.toElement();
+      setInternalId( myElement.text().toLong() );
-    myNode = srsNode.namedItem( "description" );
-    setDescription( myElement.text() );
+      myNode = srsNode.namedItem( "srid" );
+      setSrid( myElement.text().toLong() );
-    myNode = srsNode.namedItem( "projectionacronym" );
-    setProjectionAcronym( myElement.text() );
+      myNode = srsNode.namedItem( "epsg" );
+      setEpsg( myElement.text().toLong() );
-    myNode = srsNode.namedItem( "ellipsoidacronym" );
-    setEllipsoidAcronym( myElement.text() );
+      myNode = srsNode.namedItem( "description" );
+      setDescription( myElement.text() );
-    myNode = srsNode.namedItem( "geographicflag" );
-    if ( myElement.text().compare( "true" ) )
-      setGeographicFlag( true );
-    else
-      setGeographicFlag( false );
+      myNode = srsNode.namedItem( "projectionacronym" );
+      setProjectionAcronym( myElement.text() );
-    //make sure the map units have been set
-    setMapUnits();
+      myNode = srsNode.namedItem( "ellipsoidacronym" );
+      setEllipsoidAcronym( myElement.text() );
-    //@TODO this srs needs to be validated!!!
-    mIsValidFlag = true;//shamelessly hard coded for now
+      myNode = srsNode.namedItem( "geographicflag" );
+      if ( myElement.text().compare( "true" ) )
+        setGeographicFlag( true );
+      else
+        setGeographicFlag( false );
+      //make sure the map units have been set
+      setMapUnits();
+      //@TODO this srs needs to be validated!!!
+      mIsValidFlag = true;//shamelessly hard coded for now
   else
Modified: trunk/qgis/src/core/qgsdistancearea.cpp
--- trunk/qgis/src/core/qgsdistancearea.cpp	2009-08-19 21:04:03 UTC (rev 11446)
+++ trunk/qgis/src/core/qgsdistancearea.cpp	2009-08-19 21:22:31 UTC (rev 11447)
@@ -94,7 +94,7 @@
   if ( myResult )
More information about the QGIS-commit mailing list
