[QGIS Commit] r11460 - trunk/qgis/src/gui
svn_qgis at osgeo.org
Thu Aug 20 23:42:25 EDT 2009
Author: gcontreras
Date: 2009-08-20 23:42:24 -0400 (Thu, 20 Aug 2009)
New Revision: 11460
trunk/qgis/src/gui/qgsprojectionselector.cpp
Fix for Ticket #1881. This allows to change the srs for wms based in geoserver.
Modified: trunk/qgis/src/gui/qgsprojectionselector.cpp
--- trunk/qgis/src/gui/qgsprojectionselector.cpp 2009-08-20 22:17:14 UTC (rev 11459)
+++ trunk/qgis/src/gui/qgsprojectionselector.cpp 2009-08-21 03:42:24 UTC (rev 11460)
@@ -195,13 +195,19 @@
// iterate through all incoming CRSs
QSet<QString>::const_iterator i = crsFilter->begin();
+ QRegExp rx( "[^0-9]" );
while ( i != crsFilter->end() )
QStringList parts = i->split( ":" );
if ( parts.at( 0 ) == "EPSG" && parts.size() >= 2 )
- epsgParts.push_back( parts.at( 1 ) );
+ //this line is neccesary to make change projection work
+ //with geoserver because for some reason geoserver returns
+ //EPSG:WGS84(DD) as the first srs and is invalid because the
+ //epsg database expect an integer string
+ if(rx.indexIn(parts.at( 1 )) == -1)
+ epsgParts.push_back( parts.at( 1 ) );
++i;
