[QGIS Commit] r11472 - in trunk/qgis: images/themes/default
src/app/composer src/ui
svn_qgis at osgeo.org
Fri Aug 21 17:41:34 EDT 2009
Author: borysiasty
Date: 2009-08-21 17:41:33 -0400 (Fri, 21 Aug 2009)
New Revision: 11472
Added:
trunk/qgis/images/themes/default/mActionAddImage.png
trunk/qgis/images/themes/default/mActionAddMap.png
trunk/qgis/images/themes/default/mActionSaveMapAsImage.png
trunk/qgis/src/app/composer/qgscomposer.cpp
trunk/qgis/src/ui/qgscomposerbase.ui
Fix wrong icons in the Map Composer
Added: trunk/qgis/images/themes/default/mActionAddImage.png
(Binary files differ)
Property changes on: trunk/qgis/images/themes/default/mActionAddImage.png
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Added: trunk/qgis/images/themes/default/mActionAddMap.png
Property changes on: trunk/qgis/images/themes/default/mActionAddMap.png
Modified: trunk/qgis/images/themes/default/mActionSaveMapAsImage.png
Modified: trunk/qgis/src/app/composer/qgscomposer.cpp
--- trunk/qgis/src/app/composer/qgscomposer.cpp 2009-08-21 20:58:26 UTC (rev 11471)
+++ trunk/qgis/src/app/composer/qgscomposer.cpp 2009-08-21 21:41:33 UTC (rev 11472)
@@ -241,7 +241,7 @@
//missing from active theme
mActionLoadFromTemplate->setIcon( QgisApp::getThemeIcon( "/mActionFileOpen.png" ) );
mActionSaveAsTemplate->setIcon( QgisApp::getThemeIcon( "/mActionFileSaveAs.png" ) );
- mActionExportAsImage->setIcon( QgisApp::getThemeIcon( "/mActionExportMapServer.png" ) );
+ mActionExportAsImage->setIcon( QgisApp::getThemeIcon( "/mActionSaveMapAsImage.png" ) );
mActionExportAsSVG->setIcon( QgisApp::getThemeIcon( "/mActionSaveAsSVG.png" ) );
mActionExportAsPDF->setIcon( QgisApp::getThemeIcon( "/mActionSaveAsPDF.png" ) );
mActionPrint->setIcon( QgisApp::getThemeIcon( "/mActionFilePrint.png" ) );
@@ -249,8 +249,8 @@
mActionZoomIn->setIcon( QgisApp::getThemeIcon( "/mActionZoomIn.png" ) );
mActionZoomOut->setIcon( QgisApp::getThemeIcon( "/mActionZoomOut.png" ) );
mActionRefreshView->setIcon( QgisApp::getThemeIcon( "/mActionDraw.png" ) );
- mActionAddImage->setIcon( QgisApp::getThemeIcon( "/mActionSaveMapAsImage.png" ) );
- mActionAddNewMap->setIcon( QgisApp::getThemeIcon( "/mActionAddRasterLayer.png" ) );
+ mActionAddImage->setIcon( QgisApp::getThemeIcon( "/mActionAddImage.png" ) );
+ mActionAddNewMap->setIcon( QgisApp::getThemeIcon( "/mActionAddMap.png" ) );
mActionAddNewLabel->setIcon( QgisApp::getThemeIcon( "/mActionLabel.png" ) );
mActionAddNewLegend->setIcon( QgisApp::getThemeIcon( "/mActionAddLegend.png" ) );
mActionAddNewScalebar->setIcon( QgisApp::getThemeIcon( "/mActionScaleBar.png" ) );
Modified: trunk/qgis/src/ui/qgscomposerbase.ui
--- trunk/qgis/src/ui/qgscomposerbase.ui 2009-08-21 20:58:26 UTC (rev 11471)
+++ trunk/qgis/src/ui/qgscomposerbase.ui 2009-08-21 21:41:33 UTC (rev 11472)
@@ -285,7 +285,7 @@
</action>
<action name="mActionAddNewMap" >
<property name="icon" >
- <iconset>../themes/default/mActionAddRasterLayer.png</iconset>
+ <iconset>../themes/default/mActionAddMap.png</iconset>
</property>
<property name="text" >
<string>Add Map</string>
@@ -329,7 +329,7 @@
</action>
<action name="mActionExportAsImage" >
- <iconset>../themes/default/mActionExportMapServer.png</iconset>
+ <iconset>../themes/default/mActionSaveMapAsImage.png</iconset>
</property>
<string>Export as Image...</string>
@@ -375,7 +375,7 @@
</action>
<action name="mActionAddImage" >
- <iconset>../themes/default/mActionSaveMapAsImage.png</iconset>
+ <iconset>../themes/default/mActionAddImage.png</iconset>
</property>
<string>Add Image</string>
