[QGIS Commit] r11479 - trunk/qgis/src/app
svn_qgis at osgeo.org
Sat Aug 22 06:20:19 EDT 2009
Author: jef
Date: 2009-08-22 06:20:18 -0400 (Sat, 22 Aug 2009)
New Revision: 11479
trunk/qgis/src/app/qgsdbsourceselect.cpp
trunk/qgis/src/app/qgsdbsourceselect.h
trunk/qgis/src/app/qgsdbtablemodel.cpp
trunk/qgis/src/app/qgsdbtablemodel.h
[FEATURE] add selection of postgres primary key column (for views; apply #1855)
Modified: trunk/qgis/src/app/qgsdbsourceselect.cpp
--- trunk/qgis/src/app/qgsdbsourceselect.cpp 2009-08-22 10:19:52 UTC (rev 11478)
+++ trunk/qgis/src/app/qgsdbsourceselect.cpp 2009-08-22 10:20:18 UTC (rev 11479)
@@ -31,13 +31,9 @@
#include <QMessageBox>
#include <QSettings>
#include <QTextStream>
-#include <QTableWidgetItem>
#include <QHeaderView>
#include <QStringList>
-#include <cassert>
-#include <iostream>
#ifdef HAVE_PGCONFIG
#include <pg_config.h>
#endif
@@ -57,6 +53,7 @@
mSearchColumnComboBox->addItem( tr( "Table" ) );
mSearchColumnComboBox->addItem( tr( "Type" ) );
mSearchColumnComboBox->addItem( tr( "Geometry column" ) );
+ mSearchColumnComboBox->addItem( tr( "Primary key column" ) );
mSearchColumnComboBox->addItem( tr( "Sql" ) );
mProxyModel.setParent( this );
@@ -67,6 +64,10 @@
mTablesTreeView->setModel( &mProxyModel );
mTablesTreeView->setSortingEnabled( true );
+ mTablesTreeView->setEditTriggers( QAbstractItemView::CurrentChanged );
+ mTablesTreeView->setItemDelegateForColumn( QgsDbTableModel::dbtmPkCol, new QgsDbSourceSelectDelegate( this ) );
QSettings settings;
mTablesTreeView->setSelectionMode( settings.value( "/qgis/addPostgisDC", false ).toBool() ?
QAbstractItemView::ExtendedSelection :
@@ -169,23 +170,27 @@
else if ( text == tr( "Schema" ) )
- mProxyModel.setFilterKeyColumn( 0 );
+ mProxyModel.setFilterKeyColumn( QgsDbTableModel::dbtmSchema );
else if ( text == tr( "Table" ) )
- mProxyModel.setFilterKeyColumn( 1 );
+ mProxyModel.setFilterKeyColumn( QgsDbTableModel::dbtmTable );
else if ( text == tr( "Type" ) )
- mProxyModel.setFilterKeyColumn( 2 );
+ mProxyModel.setFilterKeyColumn( QgsDbTableModel::dbtmType );
else if ( text == tr( "Geometry column" ) )
- mProxyModel.setFilterKeyColumn( 3 );
+ mProxyModel.setFilterKeyColumn( QgsDbTableModel::dbtmGeomCol );
+ else if ( text == tr( "Primay key column" ) )
+ mProxyModel.setFilterKeyColumn( QgsDbTableModel::dbtmPkCol );
else if ( text == tr( "Sql" ) )
- mProxyModel.setFilterKeyColumn( 4 );
+ mProxyModel.setFilterKeyColumn( QgsDbTableModel::dbtmSql );
@@ -199,26 +204,15 @@
QString type )
mTableModel.setGeometryTypesForTable( schema, table, column, type );
- mTablesTreeView->sortByColumn( 1, Qt::AscendingOrder );
- mTablesTreeView->sortByColumn( 0, Qt::AscendingOrder );
+ mTablesTreeView->sortByColumn( QgsDbTableModel::dbtmTable, Qt::AscendingOrder );
+ mTablesTreeView->sortByColumn( QgsDbTableModel::dbtmSchema, Qt::AscendingOrder );
-QString QgsDbSourceSelect::makeGeomQuery( QString schema,
- QString table, QString column )
- return QString( "select distinct "
- "case"
- " when geometrytype(%1) IN ('POINT','MULTIPOINT') THEN 'POINT'"
- " when geometrytype(%1) IN ('LINESTRING','MULTILINESTRING') THEN 'LINESTRING'"
- " when geometrytype(%1) IN ('POLYGON','MULTIPOLYGON') THEN 'POLYGON'"
- " end "
- "from \"%2\".\"%3\"" ).arg( "\"" + column + "\"" ).arg( schema ).arg( table );
QgsDbSourceSelect::~QgsDbSourceSelect()
PQfinish( pd );
void QgsDbSourceSelect::populateConnectionList()
QSettings settings;
@@ -234,6 +228,7 @@
settings.endGroup();
setConnectionListPosition();
void QgsDbSourceSelect::addNewConnection()
QgsNewConnection *nc = new QgsNewConnection( this );
@@ -243,6 +238,7 @@
populateConnectionList();
void QgsDbSourceSelect::editConnection()
QgsNewConnection *nc = new QgsNewConnection( this, cmbConnections->currentText() );
@@ -278,6 +274,7 @@
void QgsDbSourceSelect::addTables()
m_selectedTables.clear();
@@ -310,16 +307,13 @@
if ( dbInfo[currentSchemaName][currentRow].size() == 0 )
- dbInfo[currentSchemaName][currentRow].resize( 5 );
+ dbInfo[currentSchemaName][currentRow].resize( QgsDbTableModel::dbtmColumns );
dbInfo[currentSchemaName][currentRow][currentColumn] = currentItem->text();
//now traverse all the schemas and table infos
- QString schemaName, tableName, geomColumnName, sql;
- QString query;
QMap<QString, schemaInfo>::const_iterator schema_it = dbInfo.constBegin();
for ( ; schema_it != dbInfo.constEnd(); ++schema_it )
@@ -327,16 +321,17 @@
schemaInfo::const_iterator entry_it = scheme.constBegin();
for ( ; entry_it != scheme.constEnd(); ++entry_it )
- schemaName = entry_it->at( 0 );
- tableName = entry_it->at( 1 );
- geomColumnName = entry_it->at( 3 );
- sql = entry_it->at( 4 );
+ QString schemaName = entry_it->at( QgsDbTableModel::dbtmSchema );
+ QString tableName = entry_it->at( QgsDbTableModel::dbtmTable );
+ QString geomColumnName = entry_it->at( QgsDbTableModel::dbtmGeomCol );
+ QString pkColumnName = entry_it->at( QgsDbTableModel::dbtmPkCol );
+ QString sql = entry_it->at( QgsDbTableModel::dbtmSql );
if ( geomColumnName.contains( " AS " ) )
int a = geomColumnName.indexOf( " AS " );
QString typeName = geomColumnName.mid( a + 4 ); //only the type name
- geomColumnName = geomColumnName.mid( 0, a ); //only the geom column name
+ geomColumnName = geomColumnName.left( a ); //only the geom column name
if ( !sql.isEmpty() )
@@ -360,8 +355,17 @@
- query = "\"" + schemaName + "\".\"" + tableName + "\" " + "(" + geomColumnName + ") sql=" + sql;
+ QString query;
+ if ( !pkColumnName.isEmpty() )
+ query += QString( "key=\"%1\" " ).arg( pkColumnName );
+ query += QString( "table=\"%1\".\"%2\" (%3) sql=%4" )
+ .arg( schemaName ).arg( tableName )
+ .arg( geomColumnName )
+ .arg( sql );
m_selectedTables.push_back( query );
@@ -493,8 +497,8 @@
.arg( QString::fromUtf8( PQerrorMessage( pd ) ) ) );
//if we have only one schema item, expand it by default
int numTopLevelItems = mTableModel.invisibleRootItem()->rowCount();
@@ -532,8 +536,8 @@
//create "Schema"."Table" and find out existing sql string
- QModelIndex schemaSibling = index.sibling( index.row(), 0 );
- QModelIndex tableSibling = index.sibling( index.row(), 1 );
+ QModelIndex schemaSibling = index.sibling( index.row(), QgsDbTableModel::dbtmSchema );
+ QModelIndex tableSibling = index.sibling( index.row(), QgsDbTableModel::dbtmTable );
if ( !schemaSibling.isValid() || !tableSibling.isValid() )
return;
@@ -545,7 +549,7 @@
QgsDebugMsg( tableString );
QString currentSql;
- QModelIndex sqlSibling = index.sibling( index.row(), 4 );
+ QModelIndex sqlSibling = index.sibling( index.row(), QgsDbTableModel::dbtmSql );
if ( sqlSibling.isValid() )
currentSql = mTableModel.itemFromIndex( mProxyModel.mapToSource( sqlSibling ) )->text();
@@ -576,6 +580,33 @@
mColumnTypeThread->addGeometryColumn( schema, table, column );
+QStringList QgsDbSourceSelect::pkCandidates( PGconn *pg, QString schemaName, QString tableName )
+ QStringList cols;
+ cols << QString::null;
+ QString sql = QString( "select attname from pg_attribute join pg_type on atttypid=pg_type.oid WHERE pg_type.typname='int4' AND attrelid=regclass('\"%1\".\"%2\"')" ).arg( schemaName ).arg( tableName );
+ QgsDebugMsg( sql );
+ PGresult *colRes = PQexec( pg, sql.toUtf8() );
+ if ( PQresultStatus( colRes ) == PGRES_TUPLES_OK )
+ for ( int i = 0; i < PQntuples( colRes ); i++ )
+ QgsDebugMsg( PQgetvalue( colRes, i, 0 ) );
+ cols << QString::fromUtf8( PQgetvalue( colRes, i, 0 ) );
+ else
+ QgsDebugMsg( QString( "SQL:%1\nresult:%2\nerror:%3\n" ).arg( sql ).arg( PQresultStatus( colRes ) ).arg( PQerrorMessage( pg ) ) );
+ PQclear( colRes );
+ return cols;
bool QgsDbSourceSelect::getTableInfo( PGconn *pg, bool searchGeometryColumnsOnly, bool searchPublicOnly )
int n = 0;
@@ -583,12 +614,23 @@
// The following query returns only tables that exist and the user has SELECT privilege on.
// Can't use regclass here because table must exist, else error occurs.
- QString sql = "select * from geometry_columns,pg_class,pg_namespace "
- "where relname=f_table_name and f_table_schema=nspname "
- "and pg_namespace.oid = pg_class.relnamespace "
- "and has_schema_privilege(pg_namespace.nspname,'usage') "
- "and has_table_privilege('\"'||pg_namespace.nspname||'\".\"'||pg_class.relname||'\"','select') " // user has select privilege
- "order by f_table_schema,f_table_name,f_geometry_column";
+ QString sql = "select "
+ "f_table_name,"
+ "f_table_schema,"
+ "f_geometry_column,"
+ "type"
+ " from "
+ "geometry_columns,"
+ "pg_class,"
+ "pg_namespace"
+ " where "
+ "relname=f_table_name"
+ " and f_table_schema=nspname"
+ " and pg_namespace.oid=pg_class.relnamespace"
+ " and has_schema_privilege(pg_namespace.nspname,'usage')"
+ " and has_table_privilege('\"'||pg_namespace.nspname||'\".\"'||pg_class.relname||'\"','select')" // user has select privilege
+ " order by "
+ "f_table_schema,f_table_name,f_geometry_column";
PGresult *result = PQexec( pg, sql.toUtf8() );
if ( result )
@@ -606,12 +648,11 @@
for ( int idx = 0; idx < PQntuples( result ); idx++ )
- QString tableName = QString::fromUtf8( PQgetvalue( result, idx, PQfnumber( result, QString( "f_table_name" ).toUtf8() ) ) );
- QString schemaName = QString::fromUtf8( PQgetvalue( result, idx, PQfnumber( result, QString( "f_table_schema" ).toUtf8() ) ) );
+ QString tableName = QString::fromUtf8( PQgetvalue( result, idx, 0 ) );
+ QString schemaName = QString::fromUtf8( PQgetvalue( result, idx, 1 ) );
+ QString column = QString::fromUtf8( PQgetvalue( result, idx, 2 ) );
+ QString type = QString::fromUtf8( PQgetvalue( result, idx, 3 ) );
- QString column = QString::fromUtf8( PQgetvalue( result, idx, PQfnumber( result, QString( "f_geometry_column" ).toUtf8() ) ) );
- QString type = QString::fromUtf8( PQgetvalue( result, idx, PQfnumber( result, QString( "type" ).toUtf8() ) ) );
QString as = "";
if ( type == "GEOMETRY" && !searchGeometryColumnsOnly )
@@ -619,7 +660,7 @@
as = type = "WAITING";
- mTableModel.addTableEntry( type, schemaName, tableName, column, "" );
+ mTableModel.addTableEntry( type, schemaName, tableName, column, pkCandidates( pg, schemaName, tableName ), "" );
n++;
@@ -636,31 +677,38 @@
// geometry_columns table. This code is specific to postgresql,
// but an equivalent query should be possible in other
// databases.
- sql = "select pg_class.relname,pg_namespace.nspname,pg_attribute.attname,pg_class.relkind "
- "from pg_attribute, pg_class, pg_namespace "
- "where pg_namespace.oid = pg_class.relnamespace "
- "and pg_attribute.attrelid = pg_class.oid "
- "and ("
+ sql = "select "
+ "pg_class.relname,"
+ "pg_namespace.nspname,"
+ "pg_attribute.attname,"
+ "pg_class.relkind"
+ " from "
+ "pg_attribute,"
+ "pg_class,"
+ "pg_namespace"
+ " where "
+ "pg_namespace.oid = pg_class.relnamespace"
+ " and pg_attribute.attrelid = pg_class.oid "
+ " and ("
"pg_attribute.atttypid = regtype('geometry')"
- " or "
- "pg_attribute.atttypid IN (select oid FROM pg_type WHERE typbasetype=regtype('geometry'))"
- "and has_table_privilege('\"'||pg_namespace.nspname||'\".\"'||pg_class.relname||'\"','select') ";
+ " or pg_attribute.atttypid IN (select oid FROM pg_type WHERE typbasetype=regtype('geometry'))"
+ " and has_table_privilege('\"'||pg_namespace.nspname||'\".\"'||pg_class.relname||'\"','select')";
if ( searchPublicOnly )
- sql += "and pg_namespace.nspname = 'public' ";
+ sql += " and pg_namespace.nspname = 'public'";
if ( n > 0 )
- sql += "and not exists (select * from geometry_columns WHERE pg_namespace.nspname=f_table_schema AND pg_class.relname=f_table_name) ";
+ sql += " and not exists (select * from geometry_columns WHERE pg_namespace.nspname=f_table_schema AND pg_class.relname=f_table_name)";
else
n = 0;
- sql += "and pg_class.relkind in ('v', 'r')"; // only from views and relations (tables)
+ sql += " and pg_class.relkind in ('v', 'r')"; // only from views and relations (tables)
@@ -692,7 +740,7 @@
addSearchGeometryColumn( schema, table, column );
//details.push_back(geomPair(fullDescription(schema, table, column, "WAITING"), "WAITING"));
- mTableModel.addTableEntry( "Waiting", schema, table, column, "" );
+ mTableModel.addTableEntry( "Waiting", schema, table, column, pkCandidates( pg, schema, table ), "" );
n++;
@@ -798,9 +846,14 @@
for ( uint i = 0; i < schemas.size(); i++ )
- QString query = QgsDbSourceSelect::makeGeomQuery( schemas[i],
- tables[i],
- columns[i] );
+ QString query = QString( "select distinct "
+ "case"
+ " when geometrytype(%1) IN ('POINT','MULTIPOINT') THEN 'POINT'"
+ " when geometrytype(%1) IN ('LINESTRING','MULTILINESTRING') THEN 'LINESTRING'"
+ " when geometrytype(%1) IN ('POLYGON','MULTIPOLYGON') THEN 'POLYGON'"
+ " end "
+ "from "
+ "\"%2\".\"%3\"" ).arg( "\"" + columns[i] + "\"" ).arg( schemas[i] ).arg( tables[i] );
PGresult* gresult = PQexec( pd, query.toUtf8() );
QString type;
if ( PQresultStatus( gresult ) == PGRES_TUPLES_OK )
Modified: trunk/qgis/src/app/qgsdbsourceselect.h
--- trunk/qgis/src/app/qgsdbsourceselect.h 2009-08-22 10:19:52 UTC (rev 11478)
+++ trunk/qgis/src/app/qgsdbsourceselect.h 2009-08-22 10:20:18 UTC (rev 11479)
@@ -36,11 +36,43 @@
#include <QMap>
#include <QPair>
#include <QIcon>
+#include <QItemDelegate>
class QStringList;
-class QTableWidgetItem;
class QgsGeomColumnTypeThread;
class QgisApp;
+class QgsDbSourceSelectDelegate : public QItemDelegate
+ Q_OBJECT;
+ public:
+ QgsDbSourceSelectDelegate( QObject *parent = NULL ) : QItemDelegate( parent )
+ /** Used to create an editor for when the user tries to
+ * change the contents of a cell */
+ QWidget *createEditor(
+ QWidget *parent,
+ const QStyleOptionViewItem &option,
+ const QModelIndex &index ) const
+ QComboBox *cb = new QComboBox( parent );
+ cb->addItems( index.data( Qt::UserRole + 1 ).toStringList() );
+ return cb;
+ void setModelData( QWidget *editor, QAbstractItemModel *model, const QModelIndex &index ) const
+ QComboBox *cb = dynamic_cast<QComboBox *>( editor );
+ if ( !cb )
+ return;
+ model->setData( index, cb->currentText() );
/*! \class QgsDbSourceSelect
* \brief Dialog to create connections and add tables from PostgresQL.
@@ -73,9 +105,6 @@
QString connectionInfo();
// Store the selected database
void dbChanged();
- // Utility function to construct the query for finding out the
- // geometry type of a column
- static QString makeGeomQuery( QString schema, QString table, QString column );
public slots:
/*! Connects to the database using the stored connection parameters.
@@ -102,14 +131,6 @@
void setSearchExpression( const QString& regexp );
private:
- enum columns
- dbssType = 0,
- dbssDetail,
- dbssSql,
- dbssColumns
typedef std::pair<QString, QString> geomPair;
typedef std::list<geomPair > geomCol;
@@ -121,6 +142,9 @@
/**Inserts information about the spatial tables into mTableModel*/
bool getTableInfo( PGconn *pg, bool searchGeometryColumnsOnly, bool searchPublicOnly );
+ /** get primary key candidates (all int4 columns) */
+ QStringList pkCandidates( PGconn *pg, QString schemaName, QString tableName );
// queue another query for the thread
void addSearchGeometryColumn( const QString &schema, const QString &table, const QString &column );
Modified: trunk/qgis/src/app/qgsdbtablemodel.cpp
--- trunk/qgis/src/app/qgsdbtablemodel.cpp 2009-08-22 10:19:52 UTC (rev 11478)
+++ trunk/qgis/src/app/qgsdbtablemodel.cpp 2009-08-22 10:20:18 UTC (rev 11479)
@@ -26,6 +26,7 @@
headerLabels << tr( "Table" );
headerLabels << tr( "Type" );
headerLabels << tr( "Geometry column" );
+ headerLabels << tr( "Primary key column" );
headerLabels << tr( "Sql" );
setHorizontalHeaderLabels( headerLabels );
@@ -35,7 +36,7 @@
-void QgsDbTableModel::addTableEntry( QString type, QString schemaName, QString tableName, QString geometryColName, QString sql )
+void QgsDbTableModel::addTableEntry( QString type, QString schemaName, QString tableName, QString geometryColName, const QStringList &pkCols, QString sql )
//is there already a root item with the given scheme Name?
QStandardItem* schemaItem;
@@ -68,6 +69,9 @@
tableItem->setFlags( Qt::ItemIsEnabled | Qt::ItemIsSelectable );
QStandardItem* geomItem = new QStandardItem( geometryColName );
geomItem->setFlags( Qt::ItemIsEnabled | Qt::ItemIsSelectable );
+ QStandardItem* pkItem = new QStandardItem( "" );
+ pkItem->setData( pkCols );
+ pkItem->setFlags( Qt::ItemIsEnabled | Qt::ItemIsSelectable | Qt::ItemIsEditable );
QStandardItem* sqlItem = new QStandardItem( sql );
sqlItem->setFlags( Qt::ItemIsEnabled | Qt::ItemIsSelectable );
@@ -76,13 +80,14 @@
childItemList.push_back( tableItem );
childItemList.push_back( typeItem );
childItemList.push_back( geomItem );
+ childItemList.push_back( pkItem );
childItemList.push_back( sqlItem );
schemaItem->appendRow( childItemList );
++mTableCount;
-void QgsDbTableModel::setSql( const QModelIndex& index, const QString& sql )
+void QgsDbTableModel::setSql( const QModelIndex& index, const QString &sql )
if ( !index.isValid() || !index.parent().isValid() )
@@ -138,7 +143,7 @@
if ( itemFromIndex( currentTableIndex )->text() == tableName &&
itemFromIndex( currentGeomIndex )->text() == geomName )
- QModelIndex sqlIndex = currentChildIndex.sibling( i, 4 );
+ QModelIndex sqlIndex = currentChildIndex.sibling( i, dbtmSql );
if ( sqlIndex.isValid() )
itemFromIndex( sqlIndex )->setText( sql );
@@ -168,6 +173,7 @@
QModelIndex currentTableIndex;
QModelIndex currentTypeIndex;
QModelIndex currentGeomColumnIndex;
+ QModelIndex currentPkColumnIndex;
for ( int i = 0; i < numChildren; ++i )
@@ -176,10 +182,12 @@
continue;
- currentTableIndex = currentChildIndex.sibling( i, 1 );
- currentTypeIndex = currentChildIndex.sibling( i, 2 );
- currentGeomColumnIndex = currentChildIndex.sibling( i, 3 );
+ currentTableIndex = currentChildIndex.sibling( i, dbtmTable );
+ currentTypeIndex = currentChildIndex.sibling( i, dbtmType );
+ currentGeomColumnIndex = currentChildIndex.sibling( i, dbtmGeomCol );
+ currentPkColumnIndex = currentChildIndex.sibling( i, dbtmPkCol );
QString geomColText = itemFromIndex( currentGeomColumnIndex )->text();
+ QStringList pkCols = itemFromIndex( currentPkColumnIndex )->data().toStringList();
if ( !currentTypeIndex.isValid() || !currentTableIndex.isValid() || !currentGeomColumnIndex.isValid() )
@@ -207,7 +215,7 @@
for ( int j = 1; j < typeList.size(); ++j )
//todo: add correct type
- addTableEntry( typeList.at( j ), schema, table, geomColText + " AS " + typeList.at( j ), "" );
+ addTableEntry( typeList.at( j ), schema, table, geomColText + " AS " + typeList.at( j ), pkCols, "" );
Modified: trunk/qgis/src/app/qgsdbtablemodel.h
--- trunk/qgis/src/app/qgsdbtablemodel.h 2009-08-22 10:19:52 UTC (rev 11478)
+++ trunk/qgis/src/app/qgsdbtablemodel.h 2009-08-22 10:20:18 UTC (rev 11479)
@@ -29,7 +29,7 @@
QgsDbTableModel();
~QgsDbTableModel();
/**Adds entry for one database table to the model*/
- void addTableEntry( QString type, QString schemaName, QString tableName, QString geometryColName, QString Sql );
+ void addTableEntry( QString type, QString schemaName, QString tableName, QString geometryColName, const QStringList &pkCols, QString Sql );
/**Sets an sql statement that belongs to a cell specified by a model index*/
void setSql( const QModelIndex& index, const QString& sql );
/**Sets one or more geometry types to a row. In case of several types, additional rows are inserted.
@@ -38,6 +38,17 @@
/**Returns the number of tables in the model*/
int tableCount() const {return mTableCount;}
+ enum columns
+ dbtmSchema = 0,
+ dbtmTable,
+ dbtmType,
+ dbtmGeomCol,
+ dbtmPkCol,
+ dbtmSql,
+ dbtmColumns
private:
/**Number of tables in the model*/
int mTableCount;
