[QGIS Commit] r11507 - in docs/trunk/english_us/user_guide: .
features_at_a_glance_screenies getting_started_screenies
svn_qgis at osgeo.org
Wed Aug 26 06:34:22 EDT 2009
Author: aghisla
Date: 2009-08-26 06:34:21 -0400 (Wed, 26 Aug 2009)
New Revision: 11507
docs/trunk/english_us/user_guide/features_at_a_glance.tex
docs/trunk/english_us/user_guide/features_at_a_glance_screenies/startup.png
docs/trunk/english_us/user_guide/getting_started.tex
docs/trunk/english_us/user_guide/getting_started_screenies/simple_session.png
updated screenies, added GNOME/KDE lookup table for menu items
Modified: docs/trunk/english_us/user_guide/features_at_a_glance.tex
--- docs/trunk/english_us/user_guide/features_at_a_glance.tex 2009-08-26 09:04:08 UTC (rev 11506)
+++ docs/trunk/english_us/user_guide/features_at_a_glance.tex 2009-08-26 10:34:21 UTC (rev 11507)
@@ -107,14 +107,14 @@
\begin{figure}[ht]
\begin{center}
- \caption{QGIS GUI with Alaska sample data \nixcaption}
+ \caption{QGIS GUI with Alaska sample data \nixcaption (GNOME))}
\label{fig:startup}
\includegraphics[clip=true, width=17cm]{startup}
\end{center}
\end{figure}
\textbf{Note:} Your window decorations (title bar, etc.) may appear
-different depending on your operating system and window manager.
+different depending on your operating system and window manager.\\
The QGIS GUI is divided into six areas:
@@ -417,6 +417,24 @@
\end{itemize}
+\textbf{Note:} \nix The Menu Bar items listed above are the default ones in KDE window
+manager. In GNOME, Settings menu is missing and its items are to be found
+there:
+\begin{tabbing}
+\dropmenuopttwo{mActionProjectProperties}{Project Properties} \hspace{3cm}\=
+\dropmenucheck{File menu} \\
+\dropmenuopttwo{mActionOptions}{Options} \hspace{3cm}\>
+\dropmenucheck{Edit}\\
+\dropmenuopttwo{mActionCustomProjection}{Custom CRS}\hspace{3cm}\>
+\dropmenucheck{Edit} \\
+\dropmenuopt{Panels} \hspace{3cm}\>
+\dropmenucheck{View} \\
+\dropmenuopt{Toolbars} \hspace{3cm}\>
+\dropmenuopt{Toggle Fullscreen Mode} \hspace{3cm}\>
+\end{tabbing}
%See Appendix \ref{app_menu} for complete descriptions of the menu items.
\subsubsection{Toolbars}\label{label_toolbars}
Modified: docs/trunk/english_us/user_guide/features_at_a_glance_screenies/startup.png
(Binary files differ)
Modified: docs/trunk/english_us/user_guide/getting_started.tex
--- docs/trunk/english_us/user_guide/getting_started.tex 2009-08-26 09:04:08 UTC (rev 11506)
+++ docs/trunk/english_us/user_guide/getting_started.tex 2009-08-26 10:34:21 UTC (rev 11507)
@@ -118,7 +118,11 @@
\item Click on the \tab{Symbology} tab and select a blue as fill color.
\item Click on the \tab{Labels} tab and check the \checkbox{Display labels}
checkbox to enable labeling. Choose NAMES field as Field containing label.
-\item Click \button{Apply}.
+\item To improve readability of labels, you can add a white buffer around them,
+by clicking ``Buffer'' in the list on the left, checking \checkbox{Buffer
+around labels?} and choosing 3 as buffer dimension.
+\item Click \button{Apply}, check if the result looks good and finally
+click \button{OK}.
\end{enumerate}
\begin{figure}[ht]
Modified: docs/trunk/english_us/user_guide/getting_started_screenies/simple_session.png
